45 #define GE_RXDESC_MEMSIZE       (1 * PAGE_SIZE)    46 #define GE_RXDESC_MAX           64    47 #define GE_RXBUF_SIZE           2048    48 #define GE_RXBUF_MEMSIZE        (GE_RXDESC_MAX*GE_RXBUF_SIZE)    50 #define GE_RXDESC_MEMSIZE       (GE_RXDESC_MAX * sizeof(struct gt_eth_desc))    51 #define GE_RXDESC_MAX           (sc->num_rxdesc)    52 #define GE_RXBUF_MEMSIZE        0    55 #define GE_RXBUF_NSEGS          ((GE_RXBUF_MEMSIZE/PAGE_SIZE)+1)    56 #define GE_DMSEG_MAX            (GE_RXBUF_NSEGS)    61     void        *gdm_unaligned_buf;
    73 #define GE_TXDESC_MEMSIZE       (1 * PAGE_SIZE)    74 #define GE_TXDESC_MAX           (GE_TXDESC_MEMSIZE / 16)    75 #define GE_TXBUF_SIZE           (4 * PAGE_SIZE)    77 #define GE_TXDESC_MEMSIZE       (sc->num_txdesc * sizeof(struct gt_eth_desc))    78 #define GE_TXDESC_MAX           (sc->num_txdesc)    82     struct ifqueue txq_pendq;
    83     struct ifqueue txq_sentq;
    91     unsigned int txq_ei_gapcount;
    93     unsigned int txq_nactive;
    95     unsigned int txq_outptr;
    96     unsigned int txq_inptr;
    98     uint32_t txq_intrbits;
    99     uint32_t txq_esdcmrbits;
   100     uint32_t txq_epsrbits;
   102     bus_addr_t txq_ectdp;
   103     bus_addr_t txq_desc_busaddr;
   105     bus_addr_t txq_buf_busaddr;
   116     uint8_t rb_data[GE_RXBUF_SIZE];
   124     struct mbuf *rxq_curpkt;
   130     struct mbuf **rxq_bufs;
   133     unsigned int rxq_active;
   134     uint32_t rxq_intrbits;
   135     bus_addr_t rxq_desc_busaddr;
   137     bus_size_t rxq_efrdp;
   138     bus_size_t rxq_ecrdp;
   156 #define sc_dev      arpcom   157 #define dv_xname    ac_if.if_name   163     struct ethercom sc_ec;
   170     bus_space_tag_t sc_gt_memt;
   171     bus_space_handle_t sc_gt_memh;
   172     bus_space_handle_t sc_memh;
   173     bus_dma_tag_t sc_dmat;
   178     unsigned char   irq_no;
   181     int             num_rxdesc, num_txdesc;
   185     unsigned int sc_tickflags;
   186 #define GE_TICK_TX_IFSTART  0x0001   187 #define GE_TICK_RX_RESTART  0x0002   188     unsigned int sc_flags;
   189 #define GE_ALLMULTI 0x0001   190 #define GE_PHYSTSCHG    0x0002   191 #define GE_RXACTIVE 0x0004   192 #define GE_NOFREE   0x0008         195     uint32_t sc_intrmask;
   196     uint32_t sc_idlemask;
   197     size_t sc_max_frame_length;
   203     uint64_t *sc_hashtable;
   204     unsigned int sc_hashmask;
   219 gfe_mii_read(
int phy,
void *arg,
unsigned reg, uint32_t *pval);
   222 gfe_mii_write(
int phy,
void *arg,
unsigned reg, uint32_t value);
 Definition: gtethreg.h:61
Definition: if_gfevar.h:81
Definition: rtemscompat1.h:15
Definition: if_gfevar.h:58
Definition: if_gfevar.h:160
Definition: if_gfevar.h:115
Definition: rtemscompat_defs.h:91
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Definition: rtemsmain.c:734
Definition: if_gfevar.h:120
