43 #include <dev/em/if_em_osdep.h>    45 #include "if_em_osdep.h"    75     em_eeprom_uninitialized = 0,
    84     em_media_type_copper = 0,
    85     em_media_type_fiber = 1,
    86     em_media_type_internal_serdes = 2,
    95 } em_speed_duplex_type;
   108     em_bus_type_unknown = 0,
   111     em_bus_type_pci_express,
   117     em_bus_speed_unknown = 0,
   124     em_bus_speed_reserved
   129     em_bus_width_unknown = 0,
   132     em_bus_width_pciex_1,
   133     em_bus_width_pciex_4,
   134     em_bus_width_reserved
   139     em_cable_length_50 = 0,
   140     em_cable_length_50_80,
   141     em_cable_length_80_110,
   142     em_cable_length_110_140,
   144     em_cable_length_undefined = 0xFF
   148     em_igp_cable_length_10  = 10,
   149     em_igp_cable_length_20  = 20,
   150     em_igp_cable_length_30  = 30,
   151     em_igp_cable_length_40  = 40,
   152     em_igp_cable_length_50  = 50,
   153     em_igp_cable_length_60  = 60,
   154     em_igp_cable_length_70  = 70,
   155     em_igp_cable_length_80  = 80,
   156     em_igp_cable_length_90  = 90,
   157     em_igp_cable_length_100 = 100,
   158     em_igp_cable_length_110 = 110,
   159     em_igp_cable_length_120 = 120,
   160     em_igp_cable_length_130 = 130,
   161     em_igp_cable_length_140 = 140,
   162     em_igp_cable_length_150 = 150,
   163     em_igp_cable_length_160 = 160,
   164     em_igp_cable_length_170 = 170,
   165     em_igp_cable_length_180 = 180
   166 } em_igp_cable_length;
   169     em_10bt_ext_dist_enable_normal = 0,
   170     em_10bt_ext_dist_enable_lower,
   171     em_10bt_ext_dist_enable_undefined = 0xFF
   172 } em_10bt_ext_dist_enable;
   175     em_rev_polarity_normal = 0,
   176     em_rev_polarity_reversed,
   177     em_rev_polarity_undefined = 0xFF
   181     em_downshift_normal = 0,
   182     em_downshift_activated,
   183     em_downshift_undefined = 0xFF
   187     em_smart_speed_default = 0,
   193     em_polarity_reversal_enabled = 0,
   194     em_polarity_reversal_disabled,
   195     em_polarity_reversal_undefined = 0xFF
   196 } em_polarity_reversal;
   199     em_auto_x_mode_manual_mdi = 0,
   200     em_auto_x_mode_manual_mdix,
   201     em_auto_x_mode_auto1,
   202     em_auto_x_mode_auto2,
   203     em_auto_x_mode_undefined = 0xFF
   207     em_1000t_rx_status_not_ok = 0,
   208     em_1000t_rx_status_ok,
   209     em_1000t_rx_status_undefined = 0xFF
   210 } em_1000t_rx_status;
   216     em_phy_undefined = 0xFF
   220     em_ms_hw_default = 0,
   227     em_ffe_config_enabled = 0,
   228     em_ffe_config_active,
   229     em_ffe_config_blocked
   233     em_dsp_config_disabled = 0,
   234     em_dsp_config_enabled,
   235     em_dsp_config_activated,
   236     em_dsp_config_undefined = 0xFF
   240     em_cable_length cable_length;
   241     em_10bt_ext_dist_enable extended_10bt_distance;
   242     em_rev_polarity cable_polarity;
   243     em_downshift downshift;
   244     em_polarity_reversal polarity_correction;
   245     em_auto_x_mode mdix_mode;
   246     em_1000t_rx_status local_rx;
   247     em_1000t_rx_status remote_rx;
   251     uint32_t idle_errors;
   252     uint32_t receive_errors;
   258     uint16_t opcode_bits;
   259     uint16_t address_bits;
   267 #define E1000_HOST_IF_MAX_SIZE  2048   278 #define E1000_SUCCESS      0   279 #define E1000_ERR_EEPROM   1   280 #define E1000_ERR_PHY      2   281 #define E1000_ERR_CONFIG   3   282 #define E1000_ERR_PARAM    4   283 #define E1000_ERR_MAC_TYPE 5   284 #define E1000_ERR_PHY_TYPE 6   285 #define E1000_ERR_RESET   9   286 #define E1000_ERR_MASTER_REQUESTS_PENDING 10   287 #define E1000_ERR_HOST_INTERFACE_COMMAND 11   288 #define E1000_BLK_PHY_RESET   12   292 int32_t em_reset_hw(
struct em_hw *hw);
   293 int32_t em_init_hw(
struct em_hw *hw);
   294 int32_t em_id_led_init(
struct em_hw * hw);
   295 int32_t em_set_mac_type(
struct em_hw *hw);
   296 void em_set_media_type(
struct em_hw *hw);
   299 int32_t em_setup_link(
struct em_hw *hw);
   300 int32_t em_phy_setup_autoneg(
struct em_hw *hw);
   301 void em_config_collision_dist(
struct em_hw *hw);
   302 int32_t em_config_fc_after_link_up(
struct em_hw *hw);
   303 int32_t em_check_for_link(
struct em_hw *hw);
   304 int32_t em_get_speed_and_duplex(
struct em_hw *hw, uint16_t * speed, uint16_t * duplex);
   305 int32_t em_wait_autoneg(
struct em_hw *hw);
   306 int32_t em_force_mac_fc(
struct em_hw *hw);
   309 int32_t em_read_phy_reg(
struct em_hw *hw, uint32_t reg_addr, uint16_t *phy_data);
   310 int32_t em_write_phy_reg(
struct em_hw *hw, uint32_t reg_addr, uint16_t data);
   311 int32_t em_phy_hw_reset(
struct em_hw *hw);
   312 int32_t em_phy_reset(
struct em_hw *hw);
   313 int32_t em_detect_gig_phy(
struct em_hw *hw);
   315 int32_t em_phy_m88_get_info(
struct em_hw *hw,
struct em_phy_info *phy_info);
   316 int32_t em_phy_igp_get_info(
struct em_hw *hw,
   317 int32_t em_get_cable_length(
struct em_hw *hw, uint16_t *min_length, uint16_t *max_length);
   318 int32_t em_check_polarity(
struct em_hw *hw, uint16_t *polarity);
   319 int32_t em_check_downshift(
struct em_hw *hw);
   320 int32_t em_validate_mdi_setting(
struct em_hw *hw);
   323 int32_t em_init_eeprom_params(
struct em_hw *hw);
   324 boolean_t em_is_onboard_nvm_eeprom(
struct em_hw *hw);
   325 int32_t em_read_eeprom_eerd(
struct em_hw *hw, uint16_t offset, uint16_t words, uint16_t *data);
   326 int32_t em_write_eeprom_eewr(
   327 int32_t em_poll_eerd_eewr_done(
struct em_hw *hw,
int eerd);
   330 uint32_t em_enable_mng_pass_thru(
struct em_hw *hw);
   332 #define E1000_MNG_DHCP_TX_PAYLOAD_CMD   64   333 #define E1000_HI_MAX_MNG_DATA_LENGTH    0x6F8      335 #define E1000_MNG_DHCP_COMMAND_TIMEOUT  10         336 #define E1000_MNG_DHCP_COOKIE_OFFSET    0x6F0      337 #define E1000_MNG_DHCP_COOKIE_LENGTH    0x10       338 #define E1000_MNG_IAMT_MODE     0x3   339 #define E1000_IAMT_SIGNATURE            0x544D4149    341 #define E1000_MNG_DHCP_COOKIE_STATUS_PARSING_SUPPORT 0x1    342 #define E1000_MNG_DHCP_COOKIE_STATUS_VLAN_SUPPORT    0x2    343 #define E1000_VFTA_ENTRY_SHIFT                       0x5   344 #define E1000_VFTA_ENTRY_MASK                        0x7F   345 #define E1000_VFTA_ENTRY_BIT_SHIFT_MASK              0x1F   352     uint16_t command_length;
   357     uint8_t command_data[E1000_HI_MAX_MNG_DATA_LENGTH];
   383 int32_t em_mng_write_dhcp_info(
struct em_hw *hw, uint8_t *buffer,
   385 boolean_t em_check_mng_mode(
struct em_hw *hw);
   386 boolean_t em_enable_tx_pkt_filtering(
struct em_hw *hw);
   387 int32_t em_mng_enable_host_if(
struct em_hw *hw);
   388 int32_t em_mng_host_if_write(
   389                             uint16_t length, uint16_t offset, uint8_t *sum);
   390 int32_t em_mng_write_cmd_header(
struct em_hw* hw,
   393 int32_t em_mng_write_commit(
struct em_hw *hw);
   395 int32_t em_read_eeprom(
struct em_hw *hw, uint16_t reg, uint16_t words, uint16_t *data);
   396 int32_t em_validate_eeprom_checksum(
struct em_hw *hw);
   397 int32_t em_update_eeprom_checksum(
struct em_hw *hw);
   398 int32_t em_write_eeprom(
   399 int32_t em_read_part_num(
struct em_hw *hw, uint32_t * part_num);
   400 int32_t em_read_mac_addr(
struct em_hw * hw);
   401 int32_t em_swfw_sync_acquire(
struct em_hw *hw, uint16_t mask);
   402 void em_swfw_sync_release(
   405 void em_init_rx_addrs(
struct em_hw *hw);
   406 void em_mc_addr_list_update(
struct em_hw *hw, uint8_t * mc_addr_list, uint32_t mc_addr_count, uint32_t pad, uint32_t rar_used_count);
   407 uint32_t em_hash_mc_addr(
struct em_hw *hw, uint8_t * mc_addr);
   408 void em_mta_set(
struct em_hw *hw, uint32_t hash_value);
   409 void em_rar_set(
struct em_hw *hw, uint8_t * mc_addr, uint32_t rar_index);
   410 void em_write_vfta(
struct em_hw *hw, uint32_t offset, uint32_t value);
   411 void em_clear_vfta(
struct em_hw *hw);
   414 int32_t em_setup_led(
struct em_hw *hw);
   415 int32_t em_cleanup_led(
struct em_hw *hw);
   416 int32_t em_led_on(
struct em_hw *hw);
   417 int32_t em_led_off(
struct em_hw *hw);
   422 void em_clear_hw_cntrs(
struct em_hw *hw);
   423 void em_reset_adaptive(
struct em_hw *hw);
   424 void em_update_adaptive(
struct em_hw *hw);
   425 void em_tbi_adjust_stats(
struct em_hw *hw,
struct em_hw_stats *stats, uint32_t frame_len, uint8_t * mac_addr);
   426 void em_get_bus_info(
struct em_hw *hw);
   427 void em_pci_set_mwi(
struct em_hw *hw);
   428 void em_pci_clear_mwi(
struct em_hw *hw);
   429 void em_read_pci_cfg(
struct em_hw *hw, uint32_t reg, uint16_t * value);
   430 void em_write_pci_cfg(
   432 uint32_t em_io_read(
struct em_hw *hw,
unsigned long port);
   433 uint32_t em_read_reg_io(
struct em_hw *hw, uint32_t offset);
   434 void em_io_write(
struct em_hw *hw,
unsigned long port, uint32_t value);
   435 void em_write_reg_io(
   436 int32_t em_config_dsp_after_link_change(
struct em_hw *hw, boolean_t link_up);
   437 int32_t em_set_d3_lplu_state(
struct em_hw *hw, boolean_t active);
   438 int32_t em_set_d0_lplu_state(
   439 void em_set_pci_express_master_disable(
struct em_hw *hw);
   440 void em_enable_pciex_master(
struct em_hw *hw);
   441 int32_t em_disable_pciex_master(
struct em_hw *hw);
   442 int32_t em_get_auto_rd_done(
struct em_hw *hw);
   443 int32_t em_get_phy_cfg_done(
struct em_hw *hw);
   444 int32_t em_get_software_semaphore(
struct em_hw *hw);
   445 void em_release_software_semaphore(
struct em_hw *hw);
   446 int32_t em_check_phy_reset_block(
struct em_hw *hw);
   447 int32_t em_get_hw_eeprom_semaphore(
struct em_hw *hw);
   448 void em_put_hw_eeprom_semaphore(
struct em_hw *hw);
   449 int32_t em_commit_shadow_ram(
struct em_hw *hw);
   450 uint8_t em_arc_subsystem_valid(
struct em_hw *hw);
   452 #define E1000_READ_REG_IO(a, reg) \   453     em_read_reg_io((a), E1000_##reg)   454 #define E1000_WRITE_REG_IO(a, reg, val) \   455     em_write_reg_io((a), E1000_##reg, val)   458 #define E1000_DEV_ID_82542               0x1000   459 #define E1000_DEV_ID_82543GC_FIBER       0x1001   460 #define E1000_DEV_ID_82543GC_COPPER      0x1004   461 #define E1000_DEV_ID_82544EI_COPPER      0x1008   462 #define E1000_DEV_ID_82544EI_FIBER       0x1009   463 #define E1000_DEV_ID_82544GC_COPPER      0x100C   464 #define E1000_DEV_ID_82544GC_LOM         0x100D   465 #define E1000_DEV_ID_82540EM             0x100E   466 #define E1000_DEV_ID_82541ER_LOM         0x1014   467 #define E1000_DEV_ID_82540EM_LOM         0x1015   468 #define E1000_DEV_ID_82540EP_LOM         0x1016   469 #define E1000_DEV_ID_82540EP             0x1017   470 #define E1000_DEV_ID_82540EP_LP          0x101E   471 #define E1000_DEV_ID_82545EM_COPPER      0x100F   472 #define E1000_DEV_ID_82545EM_FIBER       0x1011   473 #define E1000_DEV_ID_82545GM_COPPER      0x1026   474 #define E1000_DEV_ID_82545GM_FIBER       0x1027   475 #define E1000_DEV_ID_82545GM_SERDES      0x1028   476 #define E1000_DEV_ID_82546EB_COPPER      0x1010   477 #define E1000_DEV_ID_82546EB_FIBER       0x1012   478 #define E1000_DEV_ID_82546EB_QUAD_COPPER 0x101D   479 #define E1000_DEV_ID_82541EI             0x1013   480 #define E1000_DEV_ID_82541EI_MOBILE      0x1018   481 #define E1000_DEV_ID_82541ER             0x1078   482 #define E1000_DEV_ID_82547GI             0x1075   483 #define E1000_DEV_ID_82541GI             0x1076   484 #define E1000_DEV_ID_82541GI_MOBILE      0x1077   485 #define E1000_DEV_ID_82541GI_LF          0x107C   486 #define E1000_DEV_ID_82546GB_COPPER      0x1079   487 #define E1000_DEV_ID_82546GB_FIBER       0x107A   488 #define E1000_DEV_ID_82546GB_SERDES      0x107B   489 #define E1000_DEV_ID_82546GB_PCIE        0x108A   490 #define E1000_DEV_ID_82547EI             0x1019   491 #define E1000_DEV_ID_82547EI_MOBILE      0x101A   492 #define E1000_DEV_ID_82573E              0x108B   493 #define E1000_DEV_ID_82573E_IAMT         0x108C   495 #define E1000_DEV_ID_82546GB_QUAD_COPPER 0x1099   497 #define NODE_ADDRESS_SIZE 6   498 #define ETH_LENGTH_OF_ADDRESS 6   501 #define MAC_DECODE_SIZE (128 * 1024)   503 #define E1000_82542_2_0_REV_ID 2   504 #define E1000_82542_2_1_REV_ID 3   505 #define E1000_REVISION_0       0   506 #define E1000_REVISION_1       1   507 #define E1000_REVISION_2       2   508 #define E1000_REVISION_3       3   511 #define SPEED_100   100   512 #define SPEED_1000  1000   513 #define HALF_DUPLEX 1   514 #define FULL_DUPLEX 2   517 #define ENET_HEADER_SIZE             14   518 #define MAXIMUM_ETHERNET_FRAME_SIZE  1518    519 #define MINIMUM_ETHERNET_FRAME_SIZE  64      520 #define ETHERNET_FCS_SIZE            4   521 #define MAXIMUM_ETHERNET_PACKET_SIZE \   522     (MAXIMUM_ETHERNET_FRAME_SIZE - ETHERNET_FCS_SIZE)   523 #define MINIMUM_ETHERNET_PACKET_SIZE \   524     (MINIMUM_ETHERNET_FRAME_SIZE - ETHERNET_FCS_SIZE)   525 #define CRC_LENGTH                   ETHERNET_FCS_SIZE   526 #define MAX_JUMBO_FRAME_SIZE         0x3F00   530 #define VLAN_TAG_SIZE                     4        533 #define ETHERNET_IEEE_VLAN_TYPE 0x8100     534 #define ETHERNET_IP_TYPE        0x0800     535 #define ETHERNET_ARP_TYPE       0x0806     538 #define IP_PROTOCOL_TCP    6   539 #define IP_PROTOCOL_UDP    0x11   546 #define POLL_IMS_ENABLE_MASK ( \   558 #define IMS_ENABLE_MASK ( \   571 #define E1000_RAR_ENTRIES 15   573 #define MIN_NUMBER_OF_DESCRIPTORS 8   574 #define MAX_NUMBER_OF_DESCRIPTORS 0xFFF8   578     uint64_t buffer_addr;
   589         uint64_t buffer_addr;
   604             uint32_t status_error;
   611 #define MAX_PS_BUFFERS 4   616         uint64_t buffer_addr[MAX_PS_BUFFERS];
   630             uint32_t status_error;
   635             uint16_t header_status;
   643 #define E1000_RXD_STAT_DD       0x01       644 #define E1000_RXD_STAT_EOP      0x02       645 #define E1000_RXD_STAT_IXSM     0x04       646 #define E1000_RXD_STAT_VP       0x08       647 #define E1000_RXD_STAT_UDPCS    0x10       648 #define E1000_RXD_STAT_TCPCS    0x20       649 #define E1000_RXD_STAT_IPCS     0x40       650 #define E1000_RXD_STAT_PIF      0x80       651 #define E1000_RXD_STAT_IPIDV    0x200      652 #define E1000_RXD_STAT_UDPV     0x400      653 #define E1000_RXD_STAT_ACK      0x8000     654 #define E1000_RXD_ERR_CE        0x01       655 #define E1000_RXD_ERR_SE        0x02       656 #define E1000_RXD_ERR_SEQ       0x04       657 #define E1000_RXD_ERR_CXE       0x10       658 #define E1000_RXD_ERR_TCPE      0x20       659 #define E1000_RXD_ERR_IPE       0x40       660 #define E1000_RXD_ERR_RXE       0x80       661 #define E1000_RXD_SPC_VLAN_MASK 0x0FFF     662 #define E1000_RXD_SPC_PRI_MASK  0xE000     663 #define E1000_RXD_SPC_PRI_SHIFT 13   664 #define E1000_RXD_SPC_CFI_MASK  0x1000     665 #define E1000_RXD_SPC_CFI_SHIFT 12   667 #define E1000_RXDEXT_STATERR_CE    0x01000000   668 #define E1000_RXDEXT_STATERR_SE    0x02000000   669 #define E1000_RXDEXT_STATERR_SEQ   0x04000000   670 #define E1000_RXDEXT_STATERR_CXE   0x10000000   671 #define E1000_RXDEXT_STATERR_TCPE  0x20000000   672 #define E1000_RXDEXT_STATERR_IPE   0x40000000   673 #define E1000_RXDEXT_STATERR_RXE   0x80000000   675 #define E1000_RXDPS_HDRSTAT_HDRSP        0x00008000   676 #define E1000_RXDPS_HDRSTAT_HDRLEN_MASK  0x000003FF   679 #define E1000_RXD_ERR_FRAME_ERR_MASK ( \   682     E1000_RXD_ERR_SEQ |                \   683     E1000_RXD_ERR_CXE |                \   688 #define E1000_RXDEXT_ERR_FRAME_ERR_MASK ( \   689     E1000_RXDEXT_STATERR_CE  |            \   690     E1000_RXDEXT_STATERR_SE  |            \   691     E1000_RXDEXT_STATERR_SEQ |            \   692     E1000_RXDEXT_STATERR_CXE |            \   693     E1000_RXDEXT_STATERR_RXE)   697     uint64_t buffer_addr;
   717 #define E1000_TXD_DTYP_D     0x00100000    718 #define E1000_TXD_DTYP_C     0x00000000    719 #define E1000_TXD_POPTS_IXSM 0x01          720 #define E1000_TXD_POPTS_TXSM 0x02          721 #define E1000_TXD_CMD_EOP    0x01000000    722 #define E1000_TXD_CMD_IFCS   0x02000000    723 #define E1000_TXD_CMD_IC     0x04000000    724 #define E1000_TXD_CMD_RS     0x08000000    725 #define E1000_TXD_CMD_RPS    0x10000000    726 #define E1000_TXD_CMD_DEXT   0x20000000    727 #define E1000_TXD_CMD_VLE    0x40000000    728 #define E1000_TXD_CMD_IDE    0x80000000    729 #define E1000_TXD_STAT_DD    0x00000001    730 #define E1000_TXD_STAT_EC    0x00000002    731 #define E1000_TXD_STAT_LC    0x00000004    732 #define E1000_TXD_STAT_TU    0x00000008    733 #define E1000_TXD_CMD_TCP    0x01000000    734 #define E1000_TXD_CMD_IP     0x02000000    735 #define E1000_TXD_CMD_TSE    0x04000000    736 #define E1000_TXD_STAT_TC    0x00000004    756     uint32_t cmd_and_length;
   769     uint64_t buffer_addr;
   789 #define E1000_NUM_UNICAST          16      790 #define E1000_MC_TBL_SIZE          128     791 #define E1000_VLAN_FILTER_TBL_SIZE 128     796     volatile uint32_t low;
   797     volatile uint32_t high;
   801 #define E1000_NUM_MTA_REGISTERS 128   805     volatile uint32_t ipv4_addr;
   806     volatile uint32_t reserved;
   810 #define E1000_WAKEUP_IP_ADDRESS_COUNT_MAX 4   811 #define E1000_IP4AT_SIZE                  E1000_WAKEUP_IP_ADDRESS_COUNT_MAX   812 #define E1000_IP6AT_SIZE                  1   816     volatile uint8_t ipv6_addr[16];
   821     volatile uint32_t length;
   822     volatile uint32_t reserved;
   827     volatile uint32_t mask;
   828     volatile uint32_t reserved;
   833     volatile uint32_t value;
   834     volatile uint32_t reserved;
   838 #define E1000_FLEXIBLE_FILTER_COUNT_MAX 4   841 #define E1000_FLEXIBLE_FILTER_SIZE_MAX  128   843 #define E1000_FFLT_SIZE E1000_FLEXIBLE_FILTER_COUNT_MAX   844 #define E1000_FFMT_SIZE E1000_FLEXIBLE_FILTER_SIZE_MAX   845 #define E1000_FFVT_SIZE E1000_FLEXIBLE_FILTER_SIZE_MAX   859 #define E1000_CTRL     0x00000     860 #define E1000_CTRL_DUP 0x00004     861 #define E1000_STATUS   0x00008     862 #define E1000_EECD     0x00010     863 #define E1000_EERD     0x00014     864 #define E1000_CTRL_EXT 0x00018     865 #define E1000_FLA      0x0001C     866 #define E1000_MDIC     0x00020     867 #define E1000_FCAL     0x00028     868 #define E1000_FCAH     0x0002C     869 #define E1000_FCT      0x00030     870 #define E1000_VET      0x00038     871 #define E1000_ICR      0x000C0     872 #define E1000_ITR      0x000C4     873 #define E1000_ICS      0x000C8     874 #define E1000_IMS      0x000D0     875 #define E1000_IMC      0x000D8     876 #define E1000_IAM      0x000E0     877 #define E1000_RCTL     0x00100     878 #define E1000_FCTTV    0x00170     879 #define E1000_TXCW     0x00178     880 #define E1000_RXCW     0x00180     881 #define E1000_TCTL     0x00400     882 #define E1000_TIPG     0x00410     883 #define E1000_TBT      0x00448     884 #define E1000_AIT      0x00458     885 #define E1000_LEDCTL   0x00E00     886 #define E1000_EXTCNF_CTRL  0x00F00     887 #define E1000_EXTCNF_SIZE  0x00F08     888 #define E1000_PBA      0x01000     889 #define E1000_PBS      0x01008     890 #define E1000_EEMNGCTL 0x01010     891 #define E1000_FLASH_UPDATES 1000   892 #define E1000_EEARBC   0x01024     893 #define E1000_FLASHT   0x01028     894 #define E1000_EEWR     0x0102C     895 #define E1000_FLSWCTL  0x01030     896 #define E1000_FLSWDATA 0x01034     897 #define E1000_FLSWCNT  0x01038     898 #define E1000_FLOP     0x0103C     899 #define E1000_ERT      0x02008     900 #define E1000_FCRTL    0x02160     901 #define E1000_FCRTH    0x02168     902 #define E1000_PSRCTL   0x02170     903 #define E1000_RDBAL    0x02800     904 #define E1000_RDBAH    0x02804     905 #define E1000_RDLEN    0x02808     906 #define E1000_RDH      0x02810     907 #define E1000_RDT      0x02818     908 #define E1000_RDTR     0x02820     909 #define E1000_RXDCTL   0x02828     910 #define E1000_RADV     0x0282C     911 #define E1000_RSRPD    0x02C00     912 #define E1000_RAID     0x02C08     913 #define E1000_TXDMAC   0x03000     914 #define E1000_TDFH     0x03410     915 #define E1000_TDFT     0x03418     916 #define E1000_TDFHS    0x03420     917 #define E1000_TDFTS    0x03428     918 #define E1000_TDFPC    0x03430     919 #define E1000_TDBAL    0x03800     920 #define E1000_TDBAH    0x03804     921 #define E1000_TDLEN    0x03808     922 #define E1000_TDH      0x03810     923 #define E1000_TDT      0x03818     924 #define E1000_TIDV     0x03820     925 #define E1000_TXDCTL   0x03828     926 #define E1000_TADV     0x0382C     927 #define E1000_TSPMT    0x03830     928 #define E1000_TARC0    0x03840    929 #define E1000_TDBAL1   0x03900    930 #define E1000_TDBAH1   0x03904    931 #define E1000_TDLEN1   0x03908    932 #define E1000_TDH1     0x03910    933 #define E1000_TDT1     0x03918    934 #define E1000_TXDCTL1  0x03928    935 #define E1000_TARC1    0x03940    936 #define E1000_CRCERRS  0x04000     937 #define E1000_ALGNERRC 0x04004     938 #define E1000_SYMERRS  0x04008     939 #define E1000_RXERRC   0x0400C     940 #define E1000_MPC      0x04010     941 #define E1000_SCC      0x04014     942 #define E1000_ECOL     0x04018     943 #define E1000_MCC      0x0401C     944 #define E1000_LATECOL  0x04020     945 #define E1000_COLC     0x04028     946 #define E1000_DC       0x04030     947 #define E1000_TNCRS    0x04034     948 #define E1000_SEC      0x04038     949 #define E1000_CEXTERR  0x0403C     950 #define E1000_RLEC     0x04040     951 #define E1000_XONRXC   0x04048     952 #define E1000_XONTXC   0x0404C     953 #define E1000_XOFFRXC  0x04050     954 #define E1000_XOFFTXC  0x04054     955 #define E1000_FCRUC    0x04058     956 #define E1000_PRC64    0x0405C     957 #define E1000_PRC127   0x04060     958 #define E1000_PRC255   0x04064     959 #define E1000_PRC511   0x04068     960 #define E1000_PRC1023  0x0406C     961 #define E1000_PRC1522  0x04070     962 #define E1000_GPRC     0x04074     963 #define E1000_BPRC     0x04078     964 #define E1000_MPRC     0x0407C     965 #define E1000_GPTC     0x04080     966 #define E1000_GORCL    0x04088     967 #define E1000_GORCH    0x0408C     968 #define E1000_GOTCL    0x04090     969 #define E1000_GOTCH    0x04094     970 #define E1000_RNBC     0x040A0     971 #define E1000_RUC      0x040A4     972 #define E1000_RFC      0x040A8     973 #define E1000_ROC      0x040AC     974 #define E1000_RJC      0x040B0     975 #define E1000_MGTPRC   0x040B4     976 #define E1000_MGTPDC   0x040B8     977 #define E1000_MGTPTC   0x040BC     978 #define E1000_TORL     0x040C0     979 #define E1000_TORH     0x040C4     980 #define E1000_TOTL     0x040C8     981 #define E1000_TOTH     0x040CC     982 #define E1000_TPR      0x040D0     983 #define E1000_TPT      0x040D4     984 #define E1000_PTC64    0x040D8     985 #define E1000_PTC127   0x040DC     986 #define E1000_PTC255   0x040E0     987 #define E1000_PTC511   0x040E4     988 #define E1000_PTC1023  0x040E8     989 #define E1000_PTC1522  0x040EC     990 #define E1000_MPTC     0x040F0     991 #define E1000_BPTC     0x040F4     992 #define E1000_TSCTC    0x040F8     993 #define E1000_TSCTFC   0x040FC     994 #define E1000_IAC       0x4100     995 #define E1000_ICRXPTC   0x4104     996 #define E1000_ICRXATC   0x4108     997 #define E1000_ICTXPTC   0x410C     998 #define E1000_ICTXATC   0x4110     999 #define E1000_ICTXQEC   0x4118    1000 #define E1000_ICTXQMTC  0x411C    1001 #define E1000_ICRXDMTC  0x4120    1002 #define E1000_ICRXOC    0x4124    1003 #define E1000_RXCSUM   0x05000    1004 #define E1000_RFCTL    0x05008    1005 #define E1000_MTA      0x05200    1006 #define E1000_RA       0x05400    1007 #define E1000_VFTA     0x05600    1008 #define E1000_WUC      0x05800    1009 #define E1000_WUFC     0x05808    1010 #define E1000_WUS      0x05810    1011 #define E1000_MANC     0x05820    1012 #define E1000_IPAV     0x05838    1013 #define E1000_IP4AT    0x05840    1014 #define E1000_IP6AT    0x05880    1015 #define E1000_WUPL     0x05900    1016 #define E1000_WUPM     0x05A00    1017 #define E1000_FFLT     0x05F00    1018 #define E1000_HOST_IF  0x08800    1019 #define E1000_FFMT     0x09000    1020 #define E1000_FFVT     0x09800    1022 #define E1000_GCR       0x05B00   1023 #define E1000_GSCL_1    0x05B10   1024 #define E1000_GSCL_2    0x05B14   1025 #define E1000_GSCL_3    0x05B18   1026 #define E1000_GSCL_4    0x05B1C   1027 #define E1000_FACTPS    0x05B30   1028 #define E1000_SWSM      0x05B50   1029 #define E1000_FWSM      0x05B54   1030 #define E1000_FFLT_DBG  0x05F04   1031 #define E1000_HICR      0x08F00   1038 #define E1000_82542_CTRL     E1000_CTRL  1039 #define E1000_82542_CTRL_DUP E1000_CTRL_DUP  1040 #define E1000_82542_STATUS   E1000_STATUS  1041 #define E1000_82542_EECD     E1000_EECD  1042 #define E1000_82542_EERD     E1000_EERD  1043 #define E1000_82542_CTRL_EXT E1000_CTRL_EXT  1044 #define E1000_82542_FLA      E1000_FLA  1045 #define E1000_82542_MDIC     E1000_MDIC  1046 #define E1000_82542_FCAL     E1000_FCAL  1047 #define E1000_82542_FCAH     E1000_FCAH  1048 #define E1000_82542_FCT      E1000_FCT  1049 #define E1000_82542_VET      E1000_VET  1050 #define E1000_82542_RA       0x00040  1051 #define E1000_82542_ICR      E1000_ICR  1052 #define E1000_82542_ITR      E1000_ITR  1053 #define E1000_82542_ICS      E1000_ICS  1054 #define E1000_82542_IMS      E1000_IMS  1055 #define E1000_82542_IMC      E1000_IMC  1056 #define E1000_82542_RCTL     E1000_RCTL  1057 #define E1000_82542_RDTR     0x00108  1058 #define E1000_82542_RDBAL    0x00110  1059 #define E1000_82542_RDBAH    0x00114  1060 #define E1000_82542_RDLEN    0x00118  1061 #define E1000_82542_RDH      0x00120  1062 #define E1000_82542_RDT      0x00128  1063 #define E1000_82542_FCRTH    0x00160  1064 #define E1000_82542_FCRTL    0x00168  1065 #define E1000_82542_FCTTV    E1000_FCTTV  1066 #define E1000_82542_TXCW     E1000_TXCW  1067 #define E1000_82542_RXCW     E1000_RXCW  1068 #define E1000_82542_MTA      0x00200  1069 #define E1000_82542_TCTL     E1000_TCTL  1070 #define E1000_82542_TIPG     E1000_TIPG  1071 #define E1000_82542_TDBAL    0x00420  1072 #define E1000_82542_TDBAH    0x00424  1073 #define E1000_82542_TDLEN    0x00428  1074 #define E1000_82542_TDH      0x00430  1075 #define E1000_82542_TDT      0x00438  1076 #define E1000_82542_TIDV     0x00440  1077 #define E1000_82542_TBT      E1000_TBT  1078 #define E1000_82542_AIT      E1000_AIT  1079 #define E1000_82542_VFTA     0x00600  1080 #define E1000_82542_LEDCTL   E1000_LEDCTL  1081 #define E1000_82542_PBA      E1000_PBA  1082 #define E1000_82542_PBS      E1000_PBS  1083 #define E1000_82542_EEMNGCTL E1000_EEMNGCTL  1084 #define E1000_82542_EEARBC   E1000_EEARBC  1085 #define E1000_82542_FLASHT   E1000_FLASHT  1086 #define E1000_82542_EEWR     E1000_EEWR  1087 #define E1000_82542_FLSWCTL  E1000_FLSWCTL  1088 #define E1000_82542_FLSWDATA E1000_FLSWDATA  1089 #define E1000_82542_FLSWCNT  E1000_FLSWCNT  1090 #define E1000_82542_FLOP     E1000_FLOP  1091 #define E1000_82542_EXTCNF_CTRL  E1000_EXTCNF_CTRL  1092 #define E1000_82542_EXTCNF_SIZE  E1000_EXTCNF_SIZE  1093 #define E1000_82542_ERT      E1000_ERT  1094 #define E1000_82542_RXDCTL   E1000_RXDCTL  1095 #define E1000_82542_RADV     E1000_RADV  1096 #define E1000_82542_RSRPD    E1000_RSRPD  1097 #define E1000_82542_TXDMAC   E1000_TXDMAC  1098 #define E1000_82542_TDFHS    E1000_TDFHS  1099 #define E1000_82542_TDFTS    E1000_TDFTS  1100 #define E1000_82542_TDFPC    E1000_TDFPC  1101 #define E1000_82542_TXDCTL   E1000_TXDCTL  1102 #define E1000_82542_TADV     E1000_TADV  1103 #define E1000_82542_TSPMT    E1000_TSPMT  1104 #define E1000_82542_CRCERRS  E1000_CRCERRS  1105 #define E1000_82542_ALGNERRC E1000_ALGNERRC  1106 #define E1000_82542_SYMERRS  E1000_SYMERRS  1107 #define E1000_82542_RXERRC   E1000_RXERRC  1108 #define E1000_82542_MPC      E1000_MPC  1109 #define E1000_82542_SCC      E1000_SCC  1110 #define E1000_82542_ECOL     E1000_ECOL  1111 #define E1000_82542_MCC      E1000_MCC  1112 #define E1000_82542_LATECOL  E1000_LATECOL  1113 #define E1000_82542_COLC     E1000_COLC  1114 #define E1000_82542_DC       E1000_DC  1115 #define E1000_82542_TNCRS    E1000_TNCRS  1116 #define E1000_82542_SEC      E1000_SEC  1117 #define E1000_82542_CEXTERR  E1000_CEXTERR  1118 #define E1000_82542_RLEC     E1000_RLEC  1119 #define E1000_82542_XONRXC   E1000_XONRXC  1120 #define E1000_82542_XONTXC   E1000_XONTXC  1121 #define E1000_82542_XOFFRXC  E1000_XOFFRXC  1122 #define E1000_82542_XOFFTXC  E1000_XOFFTXC  1123 #define E1000_82542_FCRUC    E1000_FCRUC  1124 #define E1000_82542_PRC64    E1000_PRC64  1125 #define E1000_82542_PRC127   E1000_PRC127  1126 #define E1000_82542_PRC255   E1000_PRC255  1127 #define E1000_82542_PRC511   E1000_PRC511  1128 #define E1000_82542_PRC1023  E1000_PRC1023  1129 #define E1000_82542_PRC1522  E1000_PRC1522  1130 #define E1000_82542_GPRC     E1000_GPRC  1131 #define E1000_82542_BPRC     E1000_BPRC  1132 #define E1000_82542_MPRC     E1000_MPRC  1133 #define E1000_82542_GPTC     E1000_GPTC  1134 #define E1000_82542_GORCL    E1000_GORCL  1135 #define E1000_82542_GORCH    E1000_GORCH  1136 #define E1000_82542_GOTCL    E1000_GOTCL  1137 #define E1000_82542_GOTCH    E1000_GOTCH  1138 #define E1000_82542_RNBC     E1000_RNBC  1139 #define E1000_82542_RUC      E1000_RUC  1140 #define E1000_82542_RFC      E1000_RFC  1141 #define E1000_82542_ROC      E1000_ROC  1142 #define E1000_82542_RJC      E1000_RJC  1143 #define E1000_82542_MGTPRC   E1000_MGTPRC  1144 #define E1000_82542_MGTPDC   E1000_MGTPDC  1145 #define E1000_82542_MGTPTC   E1000_MGTPTC  1146 #define E1000_82542_TORL     E1000_TORL  1147 #define E1000_82542_TORH     E1000_TORH  1148 #define E1000_82542_TOTL     E1000_TOTL  1149 #define E1000_82542_TOTH     E1000_TOTH  1150 #define E1000_82542_TPR      E1000_TPR  1151 #define E1000_82542_TPT      E1000_TPT  1152 #define E1000_82542_PTC64    E1000_PTC64  1153 #define E1000_82542_PTC127   E1000_PTC127  1154 #define E1000_82542_PTC255   E1000_PTC255  1155 #define E1000_82542_PTC511   E1000_PTC511  1156 #define E1000_82542_PTC1023  E1000_PTC1023  1157 #define E1000_82542_PTC1522  E1000_PTC1522  1158 #define E1000_82542_MPTC     E1000_MPTC  1159 #define E1000_82542_BPTC     E1000_BPTC  1160 #define E1000_82542_TSCTC    E1000_TSCTC  1161 #define E1000_82542_TSCTFC   E1000_TSCTFC  1162 #define E1000_82542_RXCSUM   E1000_RXCSUM  1163 #define E1000_82542_WUC      E1000_WUC  1164 #define E1000_82542_WUFC     E1000_WUFC  1165 #define E1000_82542_WUS      E1000_WUS  1166 #define E1000_82542_MANC     E1000_MANC  1167 #define E1000_82542_IPAV     E1000_IPAV  1168 #define E1000_82542_IP4AT    E1000_IP4AT  1169 #define E1000_82542_IP6AT    E1000_IP6AT  1170 #define E1000_82542_WUPL     E1000_WUPL  1171 #define E1000_82542_WUPM     E1000_WUPM  1172 #define E1000_82542_FFLT     E1000_FFLT  1173 #define E1000_82542_TDFH     0x08010  1174 #define E1000_82542_TDFT     0x08018  1175 #define E1000_82542_FFMT     E1000_FFMT  1176 #define E1000_82542_FFVT     E1000_FFVT  1177 #define E1000_82542_HOST_IF  E1000_HOST_IF  1178 #define E1000_82542_IAM         E1000_IAM  1179 #define E1000_82542_EEMNGCTL    E1000_EEMNGCTL  1180 #define E1000_82542_PSRCTL      E1000_PSRCTL  1181 #define E1000_82542_RAID        E1000_RAID  1182 #define E1000_82542_TARC0       E1000_TARC0  1183 #define E1000_82542_TDBAL1      E1000_TDBAL1  1184 #define E1000_82542_TDBAH1      E1000_TDBAH1  1185 #define E1000_82542_TDLEN1      E1000_TDLEN1  1186 #define E1000_82542_TDH1        E1000_TDH1  1187 #define E1000_82542_TDT1        E1000_TDT1  1188 #define E1000_82542_TXDCTL1     E1000_TXDCTL1  1189 #define E1000_82542_TARC1       E1000_TARC1  1190 #define E1000_82542_RFCTL       E1000_RFCTL  1191 #define E1000_82542_GCR         E1000_GCR  1192 #define E1000_82542_GSCL_1      E1000_GSCL_1  1193 #define E1000_82542_GSCL_2      E1000_GSCL_2  1194 #define E1000_82542_GSCL_3      E1000_GSCL_3  1195 #define E1000_82542_GSCL_4      E1000_GSCL_4  1196 #define E1000_82542_FACTPS      E1000_FACTPS  1197 #define E1000_82542_SWSM        E1000_SWSM  1198 #define E1000_82542_FWSM        E1000_FWSM  1199 #define E1000_82542_FFLT_DBG    E1000_FFLT_DBG  1200 #define E1000_82542_IAC         E1000_IAC  1201 #define E1000_82542_ICRXPTC     E1000_ICRXPTC  1202 #define E1000_82542_ICRXATC     E1000_ICRXATC  1203 #define E1000_82542_ICTXPTC     E1000_ICTXPTC  1204 #define E1000_82542_ICTXATC     E1000_ICTXATC  1205 #define E1000_82542_ICTXQEC     E1000_ICTXQEC  1206 #define E1000_82542_ICTXQMTC    E1000_ICTXQMTC  1207 #define E1000_82542_ICRXDMTC    E1000_ICRXDMTC  1208 #define E1000_82542_ICRXOC      E1000_ICRXOC  1209 #define E1000_82542_HICR        E1000_HICR  1285     uint8_t *flash_address;
  1286     em_mac_type mac_type;
  1287     em_phy_type phy_type;
  1288     uint32_t phy_init_script;
  1289     em_media_type media_type;
  1292     em_bus_speed bus_speed;
  1293     em_bus_width bus_width;
  1294     em_bus_type bus_type;
  1296     em_ms_type master_slave;
  1297     em_ms_type original_master_slave;
  1298     em_ffe_config ffe_config_state;
  1299     uint32_t asf_firmware_present;
  1300     uint32_t eeprom_semaphore_present;
  1301     unsigned long io_base;
  1303     uint32_t phy_revision;
  1305     uint32_t original_fc;
  1307     uint32_t autoneg_failed;
  1308     uint32_t max_frame_size;
  1309     uint32_t min_frame_size;
  1310     uint32_t mc_filter_type;
  1311     uint32_t num_mc_addrs;
  1312     uint32_t collision_delta;
  1313     uint32_t tx_packet_delta;
  1314     uint32_t ledctl_default;
  1315     uint32_t ledctl_mode1;
  1316     uint32_t ledctl_mode2;
  1317     boolean_t tx_pkt_filtering;
  1319     uint16_t phy_spd_default;
  1320     uint16_t autoneg_advertised;
  1321     uint16_t pci_cmd_word;
  1322     uint16_t fc_high_water;
  1323     uint16_t fc_low_water;
  1324     uint16_t fc_pause_time;
  1325     uint16_t current_ifs_val;
  1326     uint16_t ifs_min_val;
  1327     uint16_t ifs_max_val;
  1328     uint16_t ifs_step_size;
  1332     uint16_t subsystem_id;
  1333     uint16_t subsystem_vendor_id;
  1334     uint8_t revision_id;
  1337     uint8_t forced_speed_duplex;
  1338     uint8_t wait_autoneg_complete;
  1339     uint8_t dma_fairness;
  1340     uint8_t mac_addr[NODE_ADDRESS_SIZE];
  1341     uint8_t perm_mac_addr[NODE_ADDRESS_SIZE];
  1342     boolean_t disable_polarity_correction;
  1343     boolean_t speed_downgraded;
  1344     em_smart_speed smart_speed;
  1345     em_dsp_config dsp_config_state;
  1346     boolean_t get_link_status;
  1347     boolean_t serdes_link_down;
  1348     boolean_t tbi_compatibility_en;
  1349     boolean_t tbi_compatibility_on;
  1350     boolean_t phy_reset_disable;
  1351     boolean_t fc_send_xon;
  1352     boolean_t fc_strict_ieee;
  1353     boolean_t report_tx_early;
  1354     boolean_t adaptive_ifs;
  1355     boolean_t ifs_params_forced;
  1356     boolean_t in_ifs_mode;
  1357     boolean_t mng_reg_access_disabled;
  1361 #define E1000_EEPROM_SWDPIN0   0x0001     1362 #define E1000_EEPROM_LED_LOGIC 0x0020     1363 #define E1000_EEPROM_RW_REG_DATA   16     1364 #define E1000_EEPROM_RW_REG_DONE   2      1365 #define E1000_EEPROM_RW_REG_START  1      1366 #define E1000_EEPROM_RW_ADDR_SHIFT 2      1367 #define E1000_EEPROM_POLL_WRITE    1      1368 #define E1000_EEPROM_POLL_READ     0      1371 #define E1000_CTRL_FD       0x00000001    1372 #define E1000_CTRL_BEM      0x00000002    1373 #define E1000_CTRL_PRIOR    0x00000004    1374 #define E1000_CTRL_GIO_MASTER_DISABLE 0x00000004   1375 #define E1000_CTRL_LRST     0x00000008    1376 #define E1000_CTRL_TME      0x00000010    1377 #define E1000_CTRL_SLE      0x00000020    1378 #define E1000_CTRL_ASDE     0x00000020    1379 #define E1000_CTRL_SLU      0x00000040    1380 #define E1000_CTRL_ILOS     0x00000080    1381 #define E1000_CTRL_SPD_SEL  0x00000300    1382 #define E1000_CTRL_SPD_10   0x00000000    1383 #define E1000_CTRL_SPD_100  0x00000100    1384 #define E1000_CTRL_SPD_1000 0x00000200    1385 #define E1000_CTRL_BEM32    0x00000400    1386 #define E1000_CTRL_FRCSPD   0x00000800    1387 #define E1000_CTRL_FRCDPX   0x00001000    1388 #define E1000_CTRL_D_UD_POLARITY 0x00004000   1389 #define E1000_CTRL_SWDPIN0  0x00040000    1390 #define E1000_CTRL_SWDPIN1  0x00080000    1391 #define E1000_CTRL_SWDPIN2  0x00100000    1392 #define E1000_CTRL_SWDPIN3  0x00200000    1393 #define E1000_CTRL_SWDPIO0  0x00400000    1394 #define E1000_CTRL_SWDPIO1  0x00800000    1395 #define E1000_CTRL_SWDPIO2  0x01000000    1396 #define E1000_CTRL_SWDPIO3  0x02000000    1397 #define E1000_CTRL_RST      0x04000000    1398 #define E1000_CTRL_RFCE     0x08000000    1399 #define E1000_CTRL_TFCE     0x10000000    1400 #define E1000_CTRL_RTE      0x20000000    1401 #define E1000_CTRL_VME      0x40000000    1402 #define E1000_CTRL_PHY_RST  0x80000000    1405 #define E1000_STATUS_FD         0x00000001        1406 #define E1000_STATUS_LU         0x00000002        1407 #define E1000_STATUS_FUNC_MASK  0x0000000C        1408 #define E1000_STATUS_FUNC_SHIFT 2  1409 #define E1000_STATUS_FUNC_0     0x00000000        1410 #define E1000_STATUS_FUNC_1     0x00000004        1411 #define E1000_STATUS_TXOFF      0x00000010        1412 #define E1000_STATUS_TBIMODE    0x00000020        1413 #define E1000_STATUS_SPEED_MASK 0x000000C0  1414 #define E1000_STATUS_SPEED_10   0x00000000        1415 #define E1000_STATUS_SPEED_100  0x00000040        1416 #define E1000_STATUS_SPEED_1000 0x00000080        1417 #define E1000_STATUS_ASDV       0x00000300        1418 #define E1000_STATUS_DOCK_CI    0x00000800        1419 #define E1000_STATUS_GIO_MASTER_ENABLE 0x00080000   1420 #define E1000_STATUS_MTXCKOK    0x00000400        1421 #define E1000_STATUS_PCI66      0x00000800        1422 #define E1000_STATUS_BUS64      0x00001000        1423 #define E1000_STATUS_PCIX_MODE  0x00002000        1424 #define E1000_STATUS_PCIX_SPEED 0x0000C000        1427 #define E1000_STATUS_PCIX_SPEED_66  0x00000000   1428 #define E1000_STATUS_PCIX_SPEED_100 0x00004000   1429 #define E1000_STATUS_PCIX_SPEED_133 0x00008000   1432 #define E1000_EECD_SK        0x00000001   1433 #define E1000_EECD_CS        0x00000002   1434 #define E1000_EECD_DI        0x00000004   1435 #define E1000_EECD_DO        0x00000008   1436 #define E1000_EECD_FWE_MASK  0x00000030  1437 #define E1000_EECD_FWE_DIS   0x00000010   1438 #define E1000_EECD_FWE_EN    0x00000020   1439 #define E1000_EECD_FWE_SHIFT 4  1440 #define E1000_EECD_REQ       0x00000040   1441 #define E1000_EECD_GNT       0x00000080   1442 #define E1000_EECD_PRES      0x00000100   1443 #define E1000_EECD_SIZE      0x00000200   1444 #define E1000_EECD_ADDR_BITS 0x00000400   1446 #define E1000_EECD_TYPE      0x00002000   1447 #ifndef E1000_EEPROM_GRANT_ATTEMPTS  1448 #define E1000_EEPROM_GRANT_ATTEMPTS 1000   1450 #define E1000_EECD_AUTO_RD          0x00000200    1451 #define E1000_EECD_SIZE_EX_MASK     0x00007800    1452 #define E1000_EECD_SIZE_EX_SHIFT    11  1453 #define E1000_EECD_NVADDS    0x00018000   1454 #define E1000_EECD_SELSHAD   0x00020000   1455 #define E1000_EECD_INITSRAM  0x00040000   1456 #define E1000_EECD_FLUPD     0x00080000   1457 #define E1000_EECD_AUPDEN    0x00100000   1458 #define E1000_EECD_SHADV     0x00200000   1459 #define E1000_EECD_SEC1VAL   0x00400000   1460 #define E1000_STM_OPCODE     0xDB00  1461 #define E1000_HICR_FW_RESET  0xC0  1464 #define E1000_EERD_START      0x00000001   1465 #define E1000_EERD_DONE       0x00000010   1466 #define E1000_EERD_ADDR_SHIFT 8  1467 #define E1000_EERD_ADDR_MASK  0x0000FF00   1468 #define E1000_EERD_DATA_SHIFT 16  1469 #define E1000_EERD_DATA_MASK  0xFFFF0000   1472 #define EEPROM_STATUS_RDY_SPI  0x01  1473 #define EEPROM_STATUS_WEN_SPI  0x02  1474 #define EEPROM_STATUS_BP0_SPI  0x04  1475 #define EEPROM_STATUS_BP1_SPI  0x08  1476 #define EEPROM_STATUS_WPEN_SPI 0x80  1479 #define E1000_CTRL_EXT_GPI0_EN   0x00000001   1480 #define E1000_CTRL_EXT_GPI1_EN   0x00000002   1481 #define E1000_CTRL_EXT_PHYINT_EN E1000_CTRL_EXT_GPI1_EN  1482 #define E1000_CTRL_EXT_GPI2_EN   0x00000004   1483 #define E1000_CTRL_EXT_GPI3_EN   0x00000008   1484 #define E1000_CTRL_EXT_SDP4_DATA 0x00000010   1485 #define E1000_CTRL_EXT_SDP5_DATA 0x00000020   1486 #define E1000_CTRL_EXT_PHY_INT   E1000_CTRL_EXT_SDP5_DATA  1487 #define E1000_CTRL_EXT_SDP6_DATA 0x00000040   1488 #define E1000_CTRL_EXT_SDP7_DATA 0x00000080   1489 #define E1000_CTRL_EXT_SDP4_DIR  0x00000100   1490 #define E1000_CTRL_EXT_SDP5_DIR  0x00000200   1491 #define E1000_CTRL_EXT_SDP6_DIR  0x00000400   1492 #define E1000_CTRL_EXT_SDP7_DIR  0x00000800   1493 #define E1000_CTRL_EXT_ASDCHK    0x00001000   1494 #define E1000_CTRL_EXT_EE_RST    0x00002000   1495 #define E1000_CTRL_EXT_IPS       0x00004000   1496 #define E1000_CTRL_EXT_SPD_BYPS  0x00008000   1497 #define E1000_CTRL_EXT_LINK_MODE_MASK 0x00C00000  1498 #define E1000_CTRL_EXT_LINK_MODE_GMII 0x00000000  1499 #define E1000_CTRL_EXT_LINK_MODE_TBI  0x00C00000  1500 #define E1000_CTRL_EXT_WR_WMARK_MASK  0x03000000  1501 #define E1000_CTRL_EXT_WR_WMARK_256   0x00000000  1502 #define E1000_CTRL_EXT_WR_WMARK_320   0x01000000  1503 #define E1000_CTRL_EXT_WR_WMARK_384   0x02000000  1504 #define E1000_CTRL_EXT_WR_WMARK_448   0x03000000  1505 #define E1000_CTRL_EXT_IAME           0x08000000    1506 #define E1000_CTRL_EXT_INT_TIMER_CLR  0x20000000    1509 #define E1000_MDIC_DATA_MASK 0x0000FFFF  1510 #define E1000_MDIC_REG_MASK  0x001F0000  1511 #define E1000_MDIC_REG_SHIFT 16  1512 #define E1000_MDIC_PHY_MASK  0x03E00000  1513 #define E1000_MDIC_PHY_SHIFT 21  1514 #define E1000_MDIC_OP_WRITE  0x04000000  1515 #define E1000_MDIC_OP_READ   0x08000000  1516 #define E1000_MDIC_READY     0x10000000  1517 #define E1000_MDIC_INT_EN    0x20000000  1518 #define E1000_MDIC_ERROR     0x40000000  1521 #define E1000_LEDCTL_LED0_MODE_MASK       0x0000000F  1522 #define E1000_LEDCTL_LED0_MODE_SHIFT      0  1523 #define E1000_LEDCTL_LED0_BLINK_RATE      0x0000020  1524 #define E1000_LEDCTL_LED0_IVRT            0x00000040  1525 #define E1000_LEDCTL_LED0_BLINK           0x00000080  1526 #define E1000_LEDCTL_LED1_MODE_MASK       0x00000F00  1527 #define E1000_LEDCTL_LED1_MODE_SHIFT      8  1528 #define E1000_LEDCTL_LED1_BLINK_RATE      0x0002000  1529 #define E1000_LEDCTL_LED1_IVRT            0x00004000  1530 #define E1000_LEDCTL_LED1_BLINK           0x00008000  1531 #define E1000_LEDCTL_LED2_MODE_MASK       0x000F0000  1532 #define E1000_LEDCTL_LED2_MODE_SHIFT      16  1533 #define E1000_LEDCTL_LED2_BLINK_RATE      0x00200000  1534 #define E1000_LEDCTL_LED2_IVRT            0x00400000  1535 #define E1000_LEDCTL_LED2_BLINK           0x00800000  1536 #define E1000_LEDCTL_LED3_MODE_MASK       0x0F000000  1537 #define E1000_LEDCTL_LED3_MODE_SHIFT      24  1538 #define E1000_LEDCTL_LED3_IVRT            0x40000000  1539 #define E1000_LEDCTL_LED3_BLINK           0x80000000  1541 #define E1000_LEDCTL_MODE_LINK_10_1000  0x0  1542 #define E1000_LEDCTL_MODE_LINK_100_1000 0x1  1543 #define E1000_LEDCTL_MODE_LINK_UP       0x2  1544 #define E1000_LEDCTL_MODE_ACTIVITY      0x3  1545 #define E1000_LEDCTL_MODE_LINK_ACTIVITY 0x4  1546 #define E1000_LEDCTL_MODE_LINK_10       0x5  1547 #define E1000_LEDCTL_MODE_LINK_100      0x6  1548 #define E1000_LEDCTL_MODE_LINK_1000     0x7  1549 #define E1000_LEDCTL_MODE_PCIX_MODE     0x8  1550 #define E1000_LEDCTL_MODE_FULL_DUPLEX   0x9  1551 #define E1000_LEDCTL_MODE_COLLISION     0xA  1552 #define E1000_LEDCTL_MODE_BUS_SPEED     0xB  1553 #define E1000_LEDCTL_MODE_BUS_SIZE      0xC  1554 #define E1000_LEDCTL_MODE_PAUSED        0xD  1555 #define E1000_LEDCTL_MODE_LED_ON        0xE  1556 #define E1000_LEDCTL_MODE_LED_OFF       0xF  1559 #define E1000_RAH_AV  0x80000000          1562 #define E1000_ICR_TXDW          0x00000001   1563 #define E1000_ICR_TXQE          0x00000002   1564 #define E1000_ICR_LSC           0x00000004   1565 #define E1000_ICR_RXSEQ         0x00000008   1566 #define E1000_ICR_RXDMT0        0x00000010   1567 #define E1000_ICR_RXO           0x00000040   1568 #define E1000_ICR_RXT0          0x00000080   1569 #define E1000_ICR_MDAC          0x00000200   1570 #define E1000_ICR_RXCFG         0x00000400   1571 #define E1000_ICR_GPI_EN0       0x00000800   1572 #define E1000_ICR_GPI_EN1       0x00001000   1573 #define E1000_ICR_GPI_EN2       0x00002000   1574 #define E1000_ICR_GPI_EN3       0x00004000   1575 #define E1000_ICR_TXD_LOW       0x00008000  1576 #define E1000_ICR_SRPD          0x00010000  1577 #define E1000_ICR_ACK           0x00020000   1578 #define E1000_ICR_MNG           0x00040000   1579 #define E1000_ICR_DOCK          0x00080000   1580 #define E1000_ICR_INT_ASSERTED  0x80000000   1583 #define E1000_ICS_TXDW      E1000_ICR_TXDW        1584 #define E1000_ICS_TXQE      E1000_ICR_TXQE        1585 #define E1000_ICS_LSC       E1000_ICR_LSC         1586 #define E1000_ICS_RXSEQ     E1000_ICR_RXSEQ       1587 #define E1000_ICS_RXDMT0    E1000_ICR_RXDMT0      1588 #define E1000_ICS_RXO       E1000_ICR_RXO         1589 #define E1000_ICS_RXT0      E1000_ICR_RXT0        1590 #define E1000_ICS_MDAC      E1000_ICR_MDAC        1591 #define E1000_ICS_RXCFG     E1000_ICR_RXCFG       1592 #define E1000_ICS_GPI_EN0   E1000_ICR_GPI_EN0     1593 #define E1000_ICS_GPI_EN1   E1000_ICR_GPI_EN1     1594 #define E1000_ICS_GPI_EN2   E1000_ICR_GPI_EN2     1595 #define E1000_ICS_GPI_EN3   E1000_ICR_GPI_EN3     1596 #define E1000_ICS_TXD_LOW   E1000_ICR_TXD_LOW  1597 #define E1000_ICS_SRPD      E1000_ICR_SRPD  1598 #define E1000_ICS_ACK       E1000_ICR_ACK         1599 #define E1000_ICS_MNG       E1000_ICR_MNG         1600 #define E1000_ICS_DOCK      E1000_ICR_DOCK        1603 #define E1000_IMS_TXDW      E1000_ICR_TXDW        1604 #define E1000_IMS_TXQE      E1000_ICR_TXQE        1605 #define E1000_IMS_LSC       E1000_ICR_LSC         1606 #define E1000_IMS_RXSEQ     E1000_ICR_RXSEQ       1607 #define E1000_IMS_RXDMT0    E1000_ICR_RXDMT0      1608 #define E1000_IMS_RXO       E1000_ICR_RXO         1609 #define E1000_IMS_RXT0      E1000_ICR_RXT0        1610 #define E1000_IMS_MDAC      E1000_ICR_MDAC        1611 #define E1000_IMS_RXCFG     E1000_ICR_RXCFG       1612 #define E1000_IMS_GPI_EN0   E1000_ICR_GPI_EN0     1613 #define E1000_IMS_GPI_EN1   E1000_ICR_GPI_EN1     1614 #define E1000_IMS_GPI_EN2   E1000_ICR_GPI_EN2     1615 #define E1000_IMS_GPI_EN3   E1000_ICR_GPI_EN3     1616 #define E1000_IMS_TXD_LOW   E1000_ICR_TXD_LOW  1617 #define E1000_IMS_SRPD      E1000_ICR_SRPD  1618 #define E1000_IMS_ACK       E1000_ICR_ACK         1619 #define E1000_IMS_MNG       E1000_ICR_MNG         1620 #define E1000_IMS_DOCK      E1000_ICR_DOCK        1623 #define E1000_IMC_TXDW      E1000_ICR_TXDW        1624 #define E1000_IMC_TXQE      E1000_ICR_TXQE        1625 #define E1000_IMC_LSC       E1000_ICR_LSC         1626 #define E1000_IMC_RXSEQ     E1000_ICR_RXSEQ       1627 #define E1000_IMC_RXDMT0    E1000_ICR_RXDMT0      1628 #define E1000_IMC_RXO       E1000_ICR_RXO         1629 #define E1000_IMC_RXT0      E1000_ICR_RXT0        1630 #define E1000_IMC_MDAC      E1000_ICR_MDAC        1631 #define E1000_IMC_RXCFG     E1000_ICR_RXCFG       1632 #define E1000_IMC_GPI_EN0   E1000_ICR_GPI_EN0     1633 #define E1000_IMC_GPI_EN1   E1000_ICR_GPI_EN1     1634 #define E1000_IMC_GPI_EN2   E1000_ICR_GPI_EN2     1635 #define E1000_IMC_GPI_EN3   E1000_ICR_GPI_EN3     1636 #define E1000_IMC_TXD_LOW   E1000_ICR_TXD_LOW  1637 #define E1000_IMC_SRPD      E1000_ICR_SRPD  1638 #define E1000_IMC_ACK       E1000_ICR_ACK         1639 #define E1000_IMC_MNG       E1000_ICR_MNG         1640 #define E1000_IMC_DOCK      E1000_ICR_DOCK        1643 #define E1000_RCTL_RST            0x00000001      1644 #define E1000_RCTL_EN             0x00000002      1645 #define E1000_RCTL_SBP            0x00000004      1646 #define E1000_RCTL_UPE            0x00000008      1647 #define E1000_RCTL_MPE            0x00000010      1648 #define E1000_RCTL_LPE            0x00000020      1649 #define E1000_RCTL_LBM_NO         0x00000000      1650 #define E1000_RCTL_LBM_MAC        0x00000040      1651 #define E1000_RCTL_LBM_SLP        0x00000080      1652 #define E1000_RCTL_LBM_TCVR       0x000000C0      1653 #define E1000_RCTL_DTYP_MASK      0x00000C00      1654 #define E1000_RCTL_DTYP_PS        0x00000400      1655 #define E1000_RCTL_RDMTS_HALF     0x00000000      1656 #define E1000_RCTL_RDMTS_QUAT     0x00000100      1657 #define E1000_RCTL_RDMTS_EIGTH    0x00000200      1658 #define E1000_RCTL_MO_SHIFT       12              1659 #define E1000_RCTL_MO_0           0x00000000      1660 #define E1000_RCTL_MO_1           0x00001000      1661 #define E1000_RCTL_MO_2           0x00002000      1662 #define E1000_RCTL_MO_3           0x00003000      1663 #define E1000_RCTL_MDR            0x00004000      1664 #define E1000_RCTL_BAM            0x00008000      1666 #define E1000_RCTL_SZ_2048        0x00000000      1667 #define E1000_RCTL_SZ_1024        0x00010000      1668 #define E1000_RCTL_SZ_512         0x00020000      1669 #define E1000_RCTL_SZ_256         0x00030000      1671 #define E1000_RCTL_SZ_16384       0x00010000      1672 #define E1000_RCTL_SZ_8192        0x00020000      1673 #define E1000_RCTL_SZ_4096        0x00030000      1674 #define E1000_RCTL_VFE            0x00040000      1675 #define E1000_RCTL_CFIEN          0x00080000      1676 #define E1000_RCTL_CFI            0x00100000      1677 #define E1000_RCTL_DPF            0x00400000      1678 #define E1000_RCTL_PMCF           0x00800000      1679 #define E1000_RCTL_BSEX           0x02000000      1680 #define E1000_RCTL_SECRC          0x04000000      1681 #define E1000_RCTL_FLXBUF_MASK    0x78000000      1682 #define E1000_RCTL_FLXBUF_SHIFT   27              1700 #define E1000_PSRCTL_BSIZE0_MASK   0x0000007F  1701 #define E1000_PSRCTL_BSIZE1_MASK   0x00003F00  1702 #define E1000_PSRCTL_BSIZE2_MASK   0x003F0000  1703 #define E1000_PSRCTL_BSIZE3_MASK   0x3F000000  1705 #define E1000_PSRCTL_BSIZE0_SHIFT  7              1706 #define E1000_PSRCTL_BSIZE1_SHIFT  2              1707 #define E1000_PSRCTL_BSIZE2_SHIFT  6              1708 #define E1000_PSRCTL_BSIZE3_SHIFT 14              1711 #define E1000_RDT_DELAY 0x0000ffff        1712 #define E1000_RDT_FPDB  0x80000000        1713 #define E1000_RDLEN_LEN 0x0007ff80        1714 #define E1000_RDH_RDH   0x0000ffff        1715 #define E1000_RDT_RDT   0x0000ffff        1718 #define E1000_FCRTH_RTH  0x0000FFF8       1719 #define E1000_FCRTH_XFCE 0x80000000       1720 #define E1000_FCRTL_RTL  0x0000FFF8       1721 #define E1000_FCRTL_XONE 0x80000000       1724 #define E1000_RFCTL_ISCSI_DIS           0x00000001  1725 #define E1000_RFCTL_ISCSI_DWC_MASK      0x0000003E  1726 #define E1000_RFCTL_ISCSI_DWC_SHIFT     1  1727 #define E1000_RFCTL_NFSW_DIS            0x00000040  1728 #define E1000_RFCTL_NFSR_DIS            0x00000080  1729 #define E1000_RFCTL_NFS_VER_MASK        0x00000300  1730 #define E1000_RFCTL_NFS_VER_SHIFT       8  1731 #define E1000_RFCTL_IPV6_DIS            0x00000400  1732 #define E1000_RFCTL_IPV6_XSUM_DIS       0x00000800  1733 #define E1000_RFCTL_ACK_DIS             0x00001000  1734 #define E1000_RFCTL_ACKD_DIS            0x00002000  1735 #define E1000_RFCTL_IPFRSP_DIS          0x00004000  1736 #define E1000_RFCTL_EXTEN               0x00008000  1737 #define E1000_RFCTL_IPV6_EX_DIS         0x00010000  1738 #define E1000_RFCTL_NEW_IPV6_EXT_DIS    0x00020000  1741 #define E1000_RXDCTL_PTHRESH 0x0000003F   1742 #define E1000_RXDCTL_HTHRESH 0x00003F00   1743 #define E1000_RXDCTL_WTHRESH 0x003F0000   1744 #define E1000_RXDCTL_GRAN    0x01000000   1747 #define E1000_TXDCTL_PTHRESH 0x000000FF   1748 #define E1000_TXDCTL_HTHRESH 0x0000FF00   1749 #define E1000_TXDCTL_WTHRESH 0x00FF0000   1750 #define E1000_TXDCTL_GRAN    0x01000000   1751 #define E1000_TXDCTL_LWTHRESH 0xFE000000   1752 #define E1000_TXDCTL_FULL_TX_DESC_WB 0x01010000   1753 #define E1000_TXDCTL_COUNT_DESC 0x00400000   1757 #define E1000_TXCW_FD         0x00000020          1758 #define E1000_TXCW_HD         0x00000040          1759 #define E1000_TXCW_PAUSE      0x00000080          1760 #define E1000_TXCW_ASM_DIR    0x00000100          1761 #define E1000_TXCW_PAUSE_MASK 0x00000180          1762 #define E1000_TXCW_RF         0x00003000          1763 #define E1000_TXCW_NP         0x00008000          1764 #define E1000_TXCW_CW         0x0000ffff          1765 #define E1000_TXCW_TXC        0x40000000          1766 #define E1000_TXCW_ANE        0x80000000          1769 #define E1000_RXCW_CW    0x0000ffff       1770 #define E1000_RXCW_NC    0x04000000       1771 #define E1000_RXCW_IV    0x08000000       1772 #define E1000_RXCW_CC    0x10000000       1773 #define E1000_RXCW_C     0x20000000       1774 #define E1000_RXCW_SYNCH 0x40000000       1775 #define E1000_RXCW_ANC   0x80000000       1778 #define E1000_TCTL_RST    0x00000001      1779 #define E1000_TCTL_EN     0x00000002      1780 #define E1000_TCTL_BCE    0x00000004      1781 #define E1000_TCTL_PSP    0x00000008      1782 #define E1000_TCTL_CT     0x00000ff0      1783 #define E1000_TCTL_COLD   0x003ff000      1784 #define E1000_TCTL_SWXOFF 0x00400000      1785 #define E1000_TCTL_PBE    0x00800000      1786 #define E1000_TCTL_RTLC   0x01000000      1787 #define E1000_TCTL_NRTU   0x02000000      1788 #define E1000_TCTL_MULR   0x10000000      1791 #define E1000_RXCSUM_PCSS_MASK 0x000000FF     1792 #define E1000_RXCSUM_IPOFL     0x00000100     1793 #define E1000_RXCSUM_TUOFL     0x00000200     1794 #define E1000_RXCSUM_IPV6OFL   0x00000400     1795 #define E1000_RXCSUM_IPPCSE    0x00001000     1796 #define E1000_RXCSUM_PCSD      0x00002000     1801 #define E1000_WUC_APME       0x00000001   1802 #define E1000_WUC_PME_EN     0x00000002   1803 #define E1000_WUC_PME_STATUS 0x00000004   1804 #define E1000_WUC_APMPME     0x00000008   1805 #define E1000_WUC_SPM        0x80000000   1808 #define E1000_WUFC_LNKC 0x00000001   1809 #define E1000_WUFC_MAG  0x00000002   1810 #define E1000_WUFC_EX   0x00000004   1811 #define E1000_WUFC_MC   0x00000008   1812 #define E1000_WUFC_BC   0x00000010   1813 #define E1000_WUFC_ARP  0x00000020   1814 #define E1000_WUFC_IPV4 0x00000040   1815 #define E1000_WUFC_IPV6 0x00000080   1816 #define E1000_WUFC_IGNORE_TCO      0x00008000   1817 #define E1000_WUFC_FLX0 0x00010000   1818 #define E1000_WUFC_FLX1 0x00020000   1819 #define E1000_WUFC_FLX2 0x00040000   1820 #define E1000_WUFC_FLX3 0x00080000   1821 #define E1000_WUFC_ALL_FILTERS 0x000F00FF   1822 #define E1000_WUFC_FLX_OFFSET 16         1823 #define E1000_WUFC_FLX_FILTERS 0x000F0000   1826 #define E1000_WUS_LNKC 0x00000001   1827 #define E1000_WUS_MAG  0x00000002   1828 #define E1000_WUS_EX   0x00000004   1829 #define E1000_WUS_MC   0x00000008   1830 #define E1000_WUS_BC   0x00000010   1831 #define E1000_WUS_ARP  0x00000020   1832 #define E1000_WUS_IPV4 0x00000040   1833 #define E1000_WUS_IPV6 0x00000080   1834 #define E1000_WUS_FLX0 0x00010000   1835 #define E1000_WUS_FLX1 0x00020000   1836 #define E1000_WUS_FLX2 0x00040000   1837 #define E1000_WUS_FLX3 0x00080000   1838 #define E1000_WUS_FLX_FILTERS 0x000F0000   1841 #define E1000_MANC_SMBUS_EN      0x00000001   1842 #define E1000_MANC_ASF_EN        0x00000002   1843 #define E1000_MANC_R_ON_FORCE    0x00000004   1844 #define E1000_MANC_RMCP_EN       0x00000100   1845 #define E1000_MANC_0298_EN       0x00000200   1846 #define E1000_MANC_IPV4_EN       0x00000400   1847 #define E1000_MANC_IPV6_EN       0x00000800   1848 #define E1000_MANC_SNAP_EN       0x00001000   1849 #define E1000_MANC_ARP_EN        0x00002000   1850 #define E1000_MANC_NEIGHBOR_EN   0x00004000   1852 #define E1000_MANC_ARP_RES_EN    0x00008000   1853 #define E1000_MANC_TCO_RESET     0x00010000   1854 #define E1000_MANC_RCV_TCO_EN    0x00020000   1855 #define E1000_MANC_REPORT_STATUS 0x00040000   1856 #define E1000_MANC_BLK_PHY_RST_ON_IDE   0x00040000   1857 #define E1000_MANC_EN_MAC_ADDR_FILTER   0x00100000   1859 #define E1000_MANC_EN_MNG2HOST   0x00200000   1861 #define E1000_MANC_EN_IP_ADDR_FILTER    0x00400000   1863 #define E1000_MANC_EN_XSUM_FILTER   0x00800000   1864 #define E1000_MANC_BR_EN            0x01000000   1865 #define E1000_MANC_SMB_REQ       0x01000000   1866 #define E1000_MANC_SMB_GNT       0x02000000   1867 #define E1000_MANC_SMB_CLK_IN    0x04000000   1868 #define E1000_MANC_SMB_DATA_IN   0x08000000   1869 #define E1000_MANC_SMB_DATA_OUT  0x10000000   1870 #define E1000_MANC_SMB_CLK_OUT   0x20000000   1872 #define E1000_MANC_SMB_DATA_OUT_SHIFT  28   1873 #define E1000_MANC_SMB_CLK_OUT_SHIFT   29   1876 #define E1000_SWSM_SMBI         0x00000001   1877 #define E1000_SWSM_SWESMBI      0x00000002   1878 #define E1000_SWSM_WMNG         0x00000004   1879 #define E1000_SWSM_DRV_LOAD     0x00000008   1882 #define E1000_FWSM_MODE_MASK    0x0000000E   1883 #define E1000_FWSM_MODE_SHIFT            1  1884 #define E1000_FWSM_FW_VALID     0x00008000   1887 #define E1000_FFLT_DBG_INVC     0x00100000   1890     em_mng_mode_none     = 0,
  1894     em_mng_mode_host_interface_only
  1898 #define E1000_HICR_EN           0x00000001    1899 #define E1000_HICR_C            0x00000002    1901 #define E1000_HICR_SV           0x00000004    1902 #define E1000_HICR_FWR          0x00000080    1905 #define E1000_HI_MAX_DATA_LENGTH         252   1906 #define E1000_HI_MAX_BLOCK_BYTE_LENGTH  1792   1907 #define E1000_HI_MAX_BLOCK_DWORD_LENGTH  448   1908 #define E1000_HI_COMMAND_TIMEOUT         500   1912     uint8_t command_length;
  1913     uint8_t command_options;
  1918     uint8_t command_data[E1000_HI_MAX_DATA_LENGTH];
  1922 #define E1000_HSMC0R_CLKIN      0x00000001    1923 #define E1000_HSMC0R_DATAIN     0x00000002    1924 #define E1000_HSMC0R_DATAOUT    0x00000004    1925 #define E1000_HSMC0R_CLKOUT     0x00000008    1928 #define E1000_HSMC1R_CLKIN      E1000_HSMC0R_CLKIN  1929 #define E1000_HSMC1R_DATAIN     E1000_HSMC0R_DATAIN  1930 #define E1000_HSMC1R_DATAOUT    E1000_HSMC0R_DATAOUT  1931 #define E1000_HSMC1R_CLKOUT     E1000_HSMC0R_CLKOUT  1934 #define E1000_FWSTS_FWS_MASK    0x000000FF    1937 #define E1000_WUPL_LENGTH_MASK 0x0FFF     1939 #define E1000_MDALIGN          4096  1941 #define E1000_GCR_BEM32                 0x00400000  1943 #define E1000_FACTPS_FUNC0_POWER_STATE_MASK         0x00000003  1944 #define E1000_FACTPS_LAN0_VALID                     0x00000004  1945 #define E1000_FACTPS_FUNC0_AUX_EN                   0x00000008  1946 #define E1000_FACTPS_FUNC1_POWER_STATE_MASK         0x000000C0  1947 #define E1000_FACTPS_FUNC1_POWER_STATE_SHIFT        6  1948 #define E1000_FACTPS_LAN1_VALID                     0x00000100  1949 #define E1000_FACTPS_FUNC1_AUX_EN                   0x00000200  1950 #define E1000_FACTPS_FUNC2_POWER_STATE_MASK         0x00003000  1951 #define E1000_FACTPS_FUNC2_POWER_STATE_SHIFT        12  1952 #define E1000_FACTPS_IDE_ENABLE                     0x00004000  1953 #define E1000_FACTPS_FUNC2_AUX_EN                   0x00008000  1954 #define E1000_FACTPS_FUNC3_POWER_STATE_MASK         0x000C0000  1955 #define E1000_FACTPS_FUNC3_POWER_STATE_SHIFT        18  1956 #define E1000_FACTPS_SP_ENABLE                      0x00100000  1957 #define E1000_FACTPS_FUNC3_AUX_EN                   0x00200000  1958 #define E1000_FACTPS_FUNC4_POWER_STATE_MASK         0x03000000  1959 #define E1000_FACTPS_FUNC4_POWER_STATE_SHIFT        24  1960 #define E1000_FACTPS_IPMI_ENABLE                    0x04000000  1961 #define E1000_FACTPS_FUNC4_AUX_EN                   0x08000000  1962 #define E1000_FACTPS_MNGCG                          0x20000000  1963 #define E1000_FACTPS_LAN_FUNC_SEL                   0x40000000  1964 #define E1000_FACTPS_PM_STATE_CHANGED               0x80000000  1967 #define EEPROM_READ_OPCODE_MICROWIRE  0x6    1968 #define EEPROM_WRITE_OPCODE_MICROWIRE 0x5    1969 #define EEPROM_ERASE_OPCODE_MICROWIRE 0x7    1970 #define EEPROM_EWEN_OPCODE_MICROWIRE  0x13   1971 #define EEPROM_EWDS_OPCODE_MICROWIRE  0x10   1974 #define EEPROM_MAX_RETRY_SPI    5000   1975 #define EEPROM_READ_OPCODE_SPI      0x03    1976 #define EEPROM_WRITE_OPCODE_SPI     0x02    1977 #define EEPROM_A8_OPCODE_SPI        0x08    1978 #define EEPROM_WREN_OPCODE_SPI      0x06    1979 #define EEPROM_WRDI_OPCODE_SPI      0x04    1980 #define EEPROM_RDSR_OPCODE_SPI      0x05    1981 #define EEPROM_WRSR_OPCODE_SPI      0x01    1982 #define EEPROM_ERASE4K_OPCODE_SPI   0x20    1983 #define EEPROM_ERASE64K_OPCODE_SPI  0xD8    1984 #define EEPROM_ERASE256_OPCODE_SPI  0xDB    1987 #define EEPROM_WORD_SIZE_SHIFT  6  1988 #define EEPROM_SIZE_SHIFT       10  1989 #define EEPROM_SIZE_MASK        0x1C00  1992 #define EEPROM_COMPAT                 0x0003  1993 #define EEPROM_ID_LED_SETTINGS        0x0004  1994 #define EEPROM_SERDES_AMPLITUDE       0x0006   1995 #define EEPROM_PHY_CLASS_WORD         0x0007  1996 #define EEPROM_INIT_CONTROL1_REG      0x000A  1997 #define EEPROM_INIT_CONTROL2_REG      0x000F  1998 #define EEPROM_INIT_CONTROL3_PORT_B   0x0014  1999 #define EEPROM_INIT_CONTROL3_PORT_A   0x0024  2000 #define EEPROM_CFG                    0x0012  2001 #define EEPROM_FLASH_VERSION          0x0032  2002 #define EEPROM_CHECKSUM_REG           0x003F  2005 #define ID_LED_RESERVED_0000 0x0000  2006 #define ID_LED_RESERVED_FFFF 0xFFFF  2007 #define ID_LED_DEFAULT       ((ID_LED_OFF1_ON2 << 12) | \  2008                               (ID_LED_OFF1_OFF2 << 8) | \  2009                               (ID_LED_DEF1_DEF2 << 4) | \  2011 #define ID_LED_DEF1_DEF2     0x1  2012 #define ID_LED_DEF1_ON2      0x2  2013 #define ID_LED_DEF1_OFF2     0x3  2014 #define ID_LED_ON1_DEF2      0x4  2015 #define ID_LED_ON1_ON2       0x5  2016 #define ID_LED_ON1_OFF2      0x6  2017 #define ID_LED_OFF1_DEF2     0x7  2018 #define ID_LED_OFF1_ON2      0x8  2019 #define ID_LED_OFF1_OFF2     0x9  2021 #define IGP_ACTIVITY_LED_MASK   0xFFFFF0FF  2022 #define IGP_ACTIVITY_LED_ENABLE 0x0300  2023 #define IGP_LED3_MODE           0x07000000  2027 #define EEPROM_SERDES_AMPLITUDE_MASK  0x000F  2030 #define EEPROM_PHY_CLASS_A   0x8000  2033 #define EEPROM_WORD0A_ILOS   0x0010  2034 #define EEPROM_WORD0A_SWDPIO 0x01E0  2035 #define EEPROM_WORD0A_LRST   0x0200  2036 #define EEPROM_WORD0A_FD     0x0400  2037 #define EEPROM_WORD0A_66MHZ  0x0800  2040 #define EEPROM_WORD0F_PAUSE_MASK 0x3000  2041 #define EEPROM_WORD0F_PAUSE      0x1000  2042 #define EEPROM_WORD0F_ASM_DIR    0x2000  2043 #define EEPROM_WORD0F_ANE        0x0800  2044 #define EEPROM_WORD0F_SWPDIO_EXT 0x00F0  2047 #define EEPROM_SUM 0xBABA  2050 #define EEPROM_NODE_ADDRESS_BYTE_0 0  2051 #define EEPROM_PBA_BYTE_1          8  2053 #define EEPROM_RESERVED_WORD          0xFFFF  2059 #define E1000_COLLISION_THRESHOLD       15  2060 #define E1000_CT_SHIFT                  4  2061 #define E1000_COLLISION_DISTANCE        64  2062 #define E1000_FDX_COLLISION_DISTANCE    E1000_COLLISION_DISTANCE  2063 #define E1000_HDX_COLLISION_DISTANCE    E1000_COLLISION_DISTANCE  2064 #define E1000_COLD_SHIFT                12  2067 #define REQ_TX_DESCRIPTOR_MULTIPLE  8  2068 #define REQ_RX_DESCRIPTOR_MULTIPLE  8  2071 #define DEFAULT_82542_TIPG_IPGT        10  2072 #define DEFAULT_82543_TIPG_IPGT_FIBER  9  2073 #define DEFAULT_82543_TIPG_IPGT_COPPER 8  2075 #define E1000_TIPG_IPGT_MASK  0x000003FF  2076 #define E1000_TIPG_IPGR1_MASK 0x000FFC00  2077 #define E1000_TIPG_IPGR2_MASK 0x3FF00000  2079 #define DEFAULT_82542_TIPG_IPGR1 2  2080 #define DEFAULT_82543_TIPG_IPGR1 8  2081 #define E1000_TIPG_IPGR1_SHIFT  10  2083 #define DEFAULT_82542_TIPG_IPGR2 10  2084 #define DEFAULT_82543_TIPG_IPGR2 6  2085 #define E1000_TIPG_IPGR2_SHIFT  20  2087 #define E1000_TXDMAC_DPP 0x00000001  2090 #define TX_THRESHOLD_START     8  2091 #define TX_THRESHOLD_INCREMENT 10  2092 #define TX_THRESHOLD_DECREMENT 1  2093 #define TX_THRESHOLD_STOP      190  2094 #define TX_THRESHOLD_DISABLE   0  2095 #define TX_THRESHOLD_TIMER_MS  10000  2096 #define MIN_NUM_XMITS          1000  2103 #define E1000_EXTCNF_CTRL_PCIE_WRITE_ENABLE 0x00000001  2104 #define E1000_EXTCNF_CTRL_PHY_WRITE_ENABLE  0x00000002  2105 #define E1000_EXTCNF_CTRL_D_UD_ENABLE       0x00000004  2106 #define E1000_EXTCNF_CTRL_D_UD_LATENCY      0x00000008  2107 #define E1000_EXTCNF_CTRL_D_UD_OWNER        0x00000010  2108 #define E1000_EXTCNF_CTRL_MDIO_SW_OWNERSHIP 0x00000020  2109 #define E1000_EXTCNF_CTRL_MDIO_HW_OWNERSHIP 0x00000040  2110 #define E1000_EXTCNF_CTRL_EXT_CNF_POINTER   0x1FFF0000  2112 #define E1000_EXTCNF_SIZE_EXT_PHY_LENGTH    0x000000FF  2113 #define E1000_EXTCNF_SIZE_EXT_DOCK_LENGTH   0x0000FF00  2114 #define E1000_EXTCNF_SIZE_EXT_PCIE_LENGTH   0x00FF0000  2117 #define E1000_PBA_12K 0x000C      2118 #define E1000_PBA_16K 0x0010      2119 #define E1000_PBA_22K 0x0016  2120 #define E1000_PBA_24K 0x0018  2121 #define E1000_PBA_30K 0x001E  2122 #define E1000_PBA_40K 0x0028  2123 #define E1000_PBA_48K 0x0030      2126 #define FLOW_CONTROL_ADDRESS_LOW  0x00C28001  2127 #define FLOW_CONTROL_ADDRESS_HIGH 0x00000100  2128 #define FLOW_CONTROL_TYPE         0x8808  2131 #define FC_DEFAULT_HI_THRESH        (0x8000)      2132 #define FC_DEFAULT_LO_THRESH        (0x4000)      2133 #define FC_DEFAULT_TX_TIMER         (0x100)       2136 #define PCIX_COMMAND_REGISTER    0xE6  2137 #define PCIX_STATUS_REGISTER_LO  0xE8  2138 #define PCIX_STATUS_REGISTER_HI  0xEA  2140 #define PCIX_COMMAND_MMRBC_MASK      0x000C  2141 #define PCIX_COMMAND_MMRBC_SHIFT     0x2  2142 #define PCIX_STATUS_HI_MMRBC_MASK    0x0060  2143 #define PCIX_STATUS_HI_MMRBC_SHIFT   0x5  2144 #define PCIX_STATUS_HI_MMRBC_4K      0x3  2145 #define PCIX_STATUS_HI_MMRBC_2K      0x2  2151 #define PAUSE_SHIFT 5  2156 #define SWDPIO_SHIFT 17  2161 #define SWDPIO__EXT_SHIFT 4  2166 #define ILOS_SHIFT  3  2169 #define RECEIVE_BUFFER_ALIGN_SIZE  (256)  2172 #define LINK_UP_TIMEOUT             500  2175 #define MASTER_DISABLE_TIMEOUT      800  2177 #define AUTO_READ_DONE_TIMEOUT      10  2179 #define PHY_CFG_TIMEOUT             40  2181 #define E1000_TX_BUFFER_SIZE ((uint32_t)1514)  2184 #define CARRIER_EXTENSION   0x0F  2213 #define TBI_ACCEPT(adapter, status, errors, length, last_byte) \  2214     ((adapter)->tbi_compatibility_on && \  2215      (((errors) & E1000_RXD_ERR_FRAME_ERR_MASK) == E1000_RXD_ERR_CE) && \  2216      ((last_byte) == CARRIER_EXTENSION) && \  2217      (((status) & E1000_RXD_STAT_VP) ? \  2218           (((length) > ((adapter)->min_frame_size - VLAN_TAG_SIZE)) && \  2219            ((length) <= ((adapter)->max_frame_size + 1))) : \  2220           (((length) > (adapter)->min_frame_size) && \  2221            ((length) <= ((adapter)->max_frame_size + VLAN_TAG_SIZE + 1)))))  2229 #define E1000_CTRL_PHY_RESET_DIR  E1000_CTRL_SWDPIO0  2230 #define E1000_CTRL_PHY_RESET      E1000_CTRL_SWDPIN0  2231 #define E1000_CTRL_MDIO_DIR       E1000_CTRL_SWDPIO2  2232 #define E1000_CTRL_MDIO           E1000_CTRL_SWDPIN2  2233 #define E1000_CTRL_MDC_DIR        E1000_CTRL_SWDPIO3  2234 #define E1000_CTRL_MDC            E1000_CTRL_SWDPIN3  2235 #define E1000_CTRL_PHY_RESET_DIR4 E1000_CTRL_EXT_SDP4_DIR  2236 #define E1000_CTRL_PHY_RESET4     E1000_CTRL_EXT_SDP4_DATA  2240 #define PHY_CTRL         0x00   2241 #define PHY_STATUS       0x01   2242 #define PHY_ID1          0x02   2243 #define PHY_ID2          0x03   2244 #define PHY_AUTONEG_ADV  0x04   2245 #define PHY_LP_ABILITY   0x05   2246 #define PHY_AUTONEG_EXP  0x06   2247 #define PHY_NEXT_PAGE_TX 0x07   2248 #define PHY_LP_NEXT_PAGE 0x08   2249 #define PHY_1000T_CTRL   0x09   2250 #define PHY_1000T_STATUS 0x0A   2251 #define PHY_EXT_STATUS   0x0F   2254 #define M88E1000_PHY_SPEC_CTRL     0x10    2255 #define M88E1000_PHY_SPEC_STATUS   0x11    2256 #define M88E1000_INT_ENABLE        0x12    2257 #define M88E1000_INT_STATUS        0x13    2258 #define M88E1000_EXT_PHY_SPEC_CTRL 0x14    2259 #define M88E1000_RX_ERR_CNTR       0x15    2261 #define M88E1000_PHY_EXT_CTRL      0x1A    2262 #define M88E1000_PHY_PAGE_SELECT   0x1D    2263 #define M88E1000_PHY_GEN_CONTROL   0x1E    2264 #define M88E1000_PHY_VCO_REG_BIT8  0x100   2265 #define M88E1000_PHY_VCO_REG_BIT11 0x800      2267 #define IGP01E1000_IEEE_REGS_PAGE  0x0000  2268 #define IGP01E1000_IEEE_RESTART_AUTONEG 0x3300  2269 #define IGP01E1000_IEEE_FORCE_GIGA      0x0140  2272 #define IGP01E1000_PHY_PORT_CONFIG 0x10   2273 #define IGP01E1000_PHY_PORT_STATUS 0x11   2274 #define IGP01E1000_PHY_PORT_CTRL   0x12   2275 #define IGP01E1000_PHY_LINK_HEALTH 0x13   2276 #define IGP01E1000_GMII_FIFO       0x14   2277 #define IGP01E1000_PHY_CHANNEL_QUALITY 0x15   2278 #define IGP02E1000_PHY_POWER_MGMT      0x19  2279 #define IGP01E1000_PHY_PAGE_SELECT     0x1F   2282 #define IGP01E1000_PHY_AGC_A        0x1172  2283 #define IGP01E1000_PHY_AGC_B        0x1272  2284 #define IGP01E1000_PHY_AGC_C        0x1472  2285 #define IGP01E1000_PHY_AGC_D        0x1872  2288 #define IGP02E1000_PHY_AGC_A        0x11B1  2289 #define IGP02E1000_PHY_AGC_B        0x12B1  2290 #define IGP02E1000_PHY_AGC_C        0x14B1  2291 #define IGP02E1000_PHY_AGC_D        0x18B1  2294 #define IGP01E1000_PHY_DSP_RESET   0x1F33  2295 #define IGP01E1000_PHY_DSP_SET     0x1F71  2296 #define IGP01E1000_PHY_DSP_FFE     0x1F35  2298 #define IGP01E1000_PHY_CHANNEL_NUM    4  2299 #define IGP02E1000_PHY_CHANNEL_NUM    4  2301 #define IGP01E1000_PHY_AGC_PARAM_A    0x1171  2302 #define IGP01E1000_PHY_AGC_PARAM_B    0x1271  2303 #define IGP01E1000_PHY_AGC_PARAM_C    0x1471  2304 #define IGP01E1000_PHY_AGC_PARAM_D    0x1871  2306 #define IGP01E1000_PHY_EDAC_MU_INDEX        0xC000  2307 #define IGP01E1000_PHY_EDAC_SIGN_EXT_9_BITS 0x8000  2309 #define IGP01E1000_PHY_ANALOG_TX_STATE      0x2890  2310 #define IGP01E1000_PHY_ANALOG_CLASS_A       0x2000  2311 #define IGP01E1000_PHY_FORCE_ANALOG_ENABLE  0x0004  2312 #define IGP01E1000_PHY_DSP_FFE_CM_CP        0x0069  2314 #define IGP01E1000_PHY_DSP_FFE_DEFAULT      0x002A  2317 #define IGP01E1000_PHY_PCS_INIT_REG  0x00B4  2318 #define IGP01E1000_PHY_PCS_CTRL_REG  0x00B5  2320 #define IGP01E1000_ANALOG_REGS_PAGE  0x20C0  2322 #define MAX_PHY_REG_ADDRESS 0x1F          2323 #define MAX_PHY_MULTI_PAGE_REG  0xF       2325 #define MII_CR_SPEED_SELECT_MSB 0x0040    2326 #define MII_CR_COLL_TEST_ENABLE 0x0080    2327 #define MII_CR_FULL_DUPLEX      0x0100    2328 #define MII_CR_RESTART_AUTO_NEG 0x0200    2329 #define MII_CR_ISOLATE          0x0400    2330 #define MII_CR_POWER_DOWN       0x0800    2331 #define MII_CR_AUTO_NEG_EN      0x1000    2332 #define MII_CR_SPEED_SELECT_LSB 0x2000    2333 #define MII_CR_LOOPBACK         0x4000    2334 #define MII_CR_RESET            0x8000    2337 #define MII_SR_EXTENDED_CAPS     0x0001   2338 #define MII_SR_JABBER_DETECT     0x0002   2339 #define MII_SR_LINK_STATUS       0x0004   2340 #define MII_SR_AUTONEG_CAPS      0x0008   2341 #define MII_SR_REMOTE_FAULT      0x0010   2342 #define MII_SR_AUTONEG_COMPLETE  0x0020   2343 #define MII_SR_PREAMBLE_SUPPRESS 0x0040   2344 #define MII_SR_EXTENDED_STATUS   0x0100   2345 #define MII_SR_100T2_HD_CAPS     0x0200   2346 #define MII_SR_100T2_FD_CAPS     0x0400   2347 #define MII_SR_10T_HD_CAPS       0x0800   2348 #define MII_SR_10T_FD_CAPS       0x1000   2349 #define MII_SR_100X_HD_CAPS      0x2000   2350 #define MII_SR_100X_FD_CAPS      0x4000   2351 #define MII_SR_100T4_CAPS        0x8000   2354 #define NWAY_AR_SELECTOR_FIELD 0x0001     2355 #define NWAY_AR_10T_HD_CAPS    0x0020     2356 #define NWAY_AR_10T_FD_CAPS    0x0040     2357 #define NWAY_AR_100TX_HD_CAPS  0x0080     2358 #define NWAY_AR_100TX_FD_CAPS  0x0100     2359 #define NWAY_AR_100T4_CAPS     0x0200     2360 #define NWAY_AR_PAUSE          0x0400     2361 #define NWAY_AR_ASM_DIR        0x0800     2362 #define NWAY_AR_REMOTE_FAULT   0x2000     2363 #define NWAY_AR_NEXT_PAGE      0x8000     2366 #define NWAY_LPAR_SELECTOR_FIELD 0x0000   2367 #define NWAY_LPAR_10T_HD_CAPS    0x0020   2368 #define NWAY_LPAR_10T_FD_CAPS    0x0040   2369 #define NWAY_LPAR_100TX_HD_CAPS  0x0080   2370 #define NWAY_LPAR_100TX_FD_CAPS  0x0100   2371 #define NWAY_LPAR_100T4_CAPS     0x0200   2372 #define NWAY_LPAR_PAUSE          0x0400   2373 #define NWAY_LPAR_ASM_DIR        0x0800   2374 #define NWAY_LPAR_REMOTE_FAULT   0x2000   2375 #define NWAY_LPAR_ACKNOWLEDGE    0x4000   2376 #define NWAY_LPAR_NEXT_PAGE      0x8000   2379 #define NWAY_ER_LP_NWAY_CAPS      0x0001   2380 #define NWAY_ER_PAGE_RXD          0x0002   2381 #define NWAY_ER_NEXT_PAGE_CAPS    0x0004   2382 #define NWAY_ER_LP_NEXT_PAGE_CAPS 0x0008   2383 #define NWAY_ER_PAR_DETECT_FAULT  0x0010   2386 #define NPTX_MSG_CODE_FIELD 0x0001   2387 #define NPTX_TOGGLE         0x0800   2390 #define NPTX_ACKNOWLDGE2    0x1000   2393 #define NPTX_MSG_PAGE       0x2000   2394 #define NPTX_NEXT_PAGE      0x8000   2399 #define LP_RNPR_MSG_CODE_FIELD 0x0001   2400 #define LP_RNPR_TOGGLE         0x0800   2403 #define LP_RNPR_ACKNOWLDGE2    0x1000   2406 #define LP_RNPR_MSG_PAGE       0x2000    2407 #define LP_RNPR_ACKNOWLDGE     0x4000    2408 #define LP_RNPR_NEXT_PAGE      0x8000    2413 #define CR_1000T_ASYM_PAUSE      0x0080   2414 #define CR_1000T_HD_CAPS         0x0100   2415 #define CR_1000T_FD_CAPS         0x0200   2416 #define CR_1000T_REPEATER_DTE    0x0400   2418 #define CR_1000T_MS_VALUE        0x0800   2420 #define CR_1000T_MS_ENABLE       0x1000   2422 #define CR_1000T_TEST_MODE_NORMAL 0x0000   2423 #define CR_1000T_TEST_MODE_1     0x2000   2424 #define CR_1000T_TEST_MODE_2     0x4000   2425 #define CR_1000T_TEST_MODE_3     0x6000   2426 #define CR_1000T_TEST_MODE_4     0x8000   2429 #define SR_1000T_IDLE_ERROR_CNT   0x00FF   2430 #define SR_1000T_ASYM_PAUSE_DIR   0x0100   2431 #define SR_1000T_LP_HD_CAPS       0x0400   2432 #define SR_1000T_LP_FD_CAPS       0x0800   2433 #define SR_1000T_REMOTE_RX_STATUS 0x1000   2434 #define SR_1000T_LOCAL_RX_STATUS  0x2000   2435 #define SR_1000T_MS_CONFIG_RES    0x4000   2436 #define SR_1000T_MS_CONFIG_FAULT  0x8000   2437 #define SR_1000T_REMOTE_RX_STATUS_SHIFT          12  2438 #define SR_1000T_LOCAL_RX_STATUS_SHIFT           13  2439 #define SR_1000T_PHY_EXCESSIVE_IDLE_ERR_COUNT    5  2440 #define FFE_IDLE_ERR_COUNT_TIMEOUT_20            20  2441 #define FFE_IDLE_ERR_COUNT_TIMEOUT_100           100  2444 #define IEEE_ESR_1000T_HD_CAPS 0x1000   2445 #define IEEE_ESR_1000T_FD_CAPS 0x2000   2446 #define IEEE_ESR_1000X_HD_CAPS 0x4000   2447 #define IEEE_ESR_1000X_FD_CAPS 0x8000   2449 #define PHY_TX_POLARITY_MASK   0x0100   2450 #define PHY_TX_NORMAL_POLARITY 0        2452 #define AUTO_POLARITY_DISABLE  0x0010   2456 #define M88E1000_PSCR_JABBER_DISABLE    0x0001   2457 #define M88E1000_PSCR_POLARITY_REVERSAL 0x0002   2458 #define M88E1000_PSCR_SQE_TEST          0x0004   2459 #define M88E1000_PSCR_CLK125_DISABLE    0x0010   2462 #define M88E1000_PSCR_MDI_MANUAL_MODE  0x0000    2464 #define M88E1000_PSCR_MDIX_MANUAL_MODE 0x0020    2465 #define M88E1000_PSCR_AUTO_X_1000T     0x0040    2469 #define M88E1000_PSCR_AUTO_X_MODE      0x0060    2472 #define M88E1000_PSCR_10BT_EXT_DIST_ENABLE 0x0080  2476 #define M88E1000_PSCR_MII_5BIT_ENABLE      0x0100  2479 #define M88E1000_PSCR_SCRAMBLER_DISABLE    0x0200   2480 #define M88E1000_PSCR_FORCE_LINK_GOOD      0x0400   2481 #define M88E1000_PSCR_ASSERT_CRS_ON_TX     0x0800   2483 #define M88E1000_PSCR_POLARITY_REVERSAL_SHIFT    1  2484 #define M88E1000_PSCR_AUTO_X_MODE_SHIFT          5  2485 #define M88E1000_PSCR_10BT_EXT_DIST_ENABLE_SHIFT 7  2488 #define M88E1000_PSSR_JABBER             0x0001   2489 #define M88E1000_PSSR_REV_POLARITY       0x0002   2490 #define M88E1000_PSSR_DOWNSHIFT          0x0020   2491 #define M88E1000_PSSR_MDIX               0x0040   2492 #define M88E1000_PSSR_CABLE_LENGTH       0x0380   2494 #define M88E1000_PSSR_LINK               0x0400   2495 #define M88E1000_PSSR_SPD_DPLX_RESOLVED  0x0800   2496 #define M88E1000_PSSR_PAGE_RCVD          0x1000   2497 #define M88E1000_PSSR_DPLX               0x2000   2498 #define M88E1000_PSSR_SPEED              0xC000   2499 #define M88E1000_PSSR_10MBS              0x0000   2500 #define M88E1000_PSSR_100MBS             0x4000   2501 #define M88E1000_PSSR_1000MBS            0x8000   2503 #define M88E1000_PSSR_REV_POLARITY_SHIFT 1  2504 #define M88E1000_PSSR_DOWNSHIFT_SHIFT    5  2505 #define M88E1000_PSSR_MDIX_SHIFT         6  2506 #define M88E1000_PSSR_CABLE_LENGTH_SHIFT 7  2509 #define M88E1000_EPSCR_FIBER_LOOPBACK 0x4000   2510 #define M88E1000_EPSCR_DOWN_NO_IDLE   0x8000   2517 #define M88E1000_EPSCR_MASTER_DOWNSHIFT_MASK 0x0C00  2518 #define M88E1000_EPSCR_MASTER_DOWNSHIFT_1X   0x0000  2519 #define M88E1000_EPSCR_MASTER_DOWNSHIFT_2X   0x0400  2520 #define M88E1000_EPSCR_MASTER_DOWNSHIFT_3X   0x0800  2521 #define M88E1000_EPSCR_MASTER_DOWNSHIFT_4X   0x0C00  2524 #define M88E1000_EPSCR_SLAVE_DOWNSHIFT_MASK  0x0300  2525 #define M88E1000_EPSCR_SLAVE_DOWNSHIFT_DIS   0x0000  2526 #define M88E1000_EPSCR_SLAVE_DOWNSHIFT_1X    0x0100  2527 #define M88E1000_EPSCR_SLAVE_DOWNSHIFT_2X    0x0200  2528 #define M88E1000_EPSCR_SLAVE_DOWNSHIFT_3X    0x0300  2529 #define M88E1000_EPSCR_TX_CLK_2_5     0x0060   2530 #define M88E1000_EPSCR_TX_CLK_25      0x0070   2531 #define M88E1000_EPSCR_TX_CLK_0       0x0000   2534 #define IGP01E1000_PSCFR_AUTO_MDIX_PAR_DETECT  0x0010  2535 #define IGP01E1000_PSCFR_PRE_EN                0x0020  2536 #define IGP01E1000_PSCFR_SMART_SPEED           0x0080  2537 #define IGP01E1000_PSCFR_DISABLE_TPLOOPBACK    0x0100  2538 #define IGP01E1000_PSCFR_DISABLE_JABBER        0x0400  2539 #define IGP01E1000_PSCFR_DISABLE_TRANSMIT      0x2000  2542 #define IGP01E1000_PSSR_AUTONEG_FAILED         0x0001   2543 #define IGP01E1000_PSSR_POLARITY_REVERSED      0x0002  2544 #define IGP01E1000_PSSR_CABLE_LENGTH           0x007C  2545 #define IGP01E1000_PSSR_FULL_DUPLEX            0x0200  2546 #define IGP01E1000_PSSR_LINK_UP                0x0400  2547 #define IGP01E1000_PSSR_MDIX                   0x0800  2548 #define IGP01E1000_PSSR_SPEED_MASK             0xC000   2549 #define IGP01E1000_PSSR_SPEED_10MBPS           0x4000  2550 #define IGP01E1000_PSSR_SPEED_100MBPS          0x8000  2551 #define IGP01E1000_PSSR_SPEED_1000MBPS         0xC000  2552 #define IGP01E1000_PSSR_CABLE_LENGTH_SHIFT     0x0002   2553 #define IGP01E1000_PSSR_MDIX_SHIFT             0x000B   2556 #define IGP01E1000_PSCR_TP_LOOPBACK            0x0010  2557 #define IGP01E1000_PSCR_CORRECT_NC_SCMBLR      0x0200  2558 #define IGP01E1000_PSCR_TEN_CRS_SELECT         0x0400  2559 #define IGP01E1000_PSCR_FLIP_CHIP              0x0800  2560 #define IGP01E1000_PSCR_AUTO_MDIX              0x1000  2561 #define IGP01E1000_PSCR_FORCE_MDI_MDIX         0x2000   2564 #define IGP01E1000_PLHR_SS_DOWNGRADE           0x8000  2565 #define IGP01E1000_PLHR_GIG_SCRAMBLER_ERROR    0x4000  2566 #define IGP01E1000_PLHR_MASTER_FAULT           0x2000  2567 #define IGP01E1000_PLHR_MASTER_RESOLUTION      0x1000  2568 #define IGP01E1000_PLHR_GIG_REM_RCVR_NOK       0x0800   2569 #define IGP01E1000_PLHR_IDLE_ERROR_CNT_OFLOW   0x0400   2570 #define IGP01E1000_PLHR_DATA_ERR_1             0x0200   2571 #define IGP01E1000_PLHR_DATA_ERR_0             0x0100  2572 #define IGP01E1000_PLHR_AUTONEG_FAULT          0x0040  2573 #define IGP01E1000_PLHR_AUTONEG_ACTIVE         0x0010  2574 #define IGP01E1000_PLHR_VALID_CHANNEL_D        0x0008  2575 #define IGP01E1000_PLHR_VALID_CHANNEL_C        0x0004  2576 #define IGP01E1000_PLHR_VALID_CHANNEL_B        0x0002  2577 #define IGP01E1000_PLHR_VALID_CHANNEL_A        0x0001  2580 #define IGP01E1000_MSE_CHANNEL_D        0x000F  2581 #define IGP01E1000_MSE_CHANNEL_C        0x00F0  2582 #define IGP01E1000_MSE_CHANNEL_B        0x0F00  2583 #define IGP01E1000_MSE_CHANNEL_A        0xF000  2585 #define IGP02E1000_PM_SPD                         0x0001    2586 #define IGP02E1000_PM_D3_LPLU                     0x0004    2587 #define IGP02E1000_PM_D0_LPLU                     0x0002    2590 #define DSP_RESET_ENABLE     0x0  2591 #define DSP_RESET_DISABLE    0x2  2592 #define E1000_MAX_DSP_RESETS 10  2596 #define IGP01E1000_AGC_LENGTH_SHIFT 7           2597 #define IGP02E1000_AGC_LENGTH_SHIFT 9           2600 #define IGP02E1000_AGC_LENGTH_MASK  0x7F  2603 #define IGP01E1000_AGC_LENGTH_TABLE_SIZE 128  2604 #define IGP02E1000_AGC_LENGTH_TABLE_SIZE 128  2607 #define IGP01E1000_AGC_RANGE    10  2608 #define IGP02E1000_AGC_RANGE    10  2612 #define IGP01E1000_PHY_POLARITY_MASK    0x0078  2615 #define IGP01E1000_GMII_FLEX_SPD               0x10   2617 #define IGP01E1000_GMII_SPD                    0x20   2620 #define IGP01E1000_ANALOG_SPARE_FUSE_STATUS       0x20D1  2621 #define IGP01E1000_ANALOG_FUSE_STATUS             0x20D0  2622 #define IGP01E1000_ANALOG_FUSE_CONTROL            0x20DC  2623 #define IGP01E1000_ANALOG_FUSE_BYPASS             0x20DE  2625 #define IGP01E1000_ANALOG_FUSE_POLY_MASK            0xF000  2626 #define IGP01E1000_ANALOG_FUSE_FINE_MASK            0x0F80  2627 #define IGP01E1000_ANALOG_FUSE_COARSE_MASK          0x0070  2628 #define IGP01E1000_ANALOG_SPARE_FUSE_ENABLED        0x0100  2629 #define IGP01E1000_ANALOG_FUSE_ENABLE_SW_CONTROL    0x0002  2631 #define IGP01E1000_ANALOG_FUSE_COARSE_THRESH        0x0040  2632 #define IGP01E1000_ANALOG_FUSE_COARSE_10            0x0010  2633 #define IGP01E1000_ANALOG_FUSE_FINE_1               0x0080  2634 #define IGP01E1000_ANALOG_FUSE_FINE_10              0x0500  2641 #define M88E1000_E_PHY_ID  0x01410C50  2642 #define M88E1000_I_PHY_ID  0x01410C30  2643 #define M88E1011_I_PHY_ID  0x01410C20  2644 #define IGP01E1000_I_PHY_ID  0x02A80380  2645 #define M88E1000_12_PHY_ID M88E1000_E_PHY_ID  2646 #define M88E1000_14_PHY_ID M88E1000_E_PHY_ID  2647 #define M88E1011_I_REV_4   0x04  2648 #define M88E1111_I_PHY_ID  0x01410CC0  2649 #define L1LXT971A_PHY_ID   0x001378E0  2652 #define PHY_PREAMBLE        0xFFFFFFFF  2653 #define PHY_SOF             0x01  2654 #define PHY_OP_READ         0x02  2655 #define PHY_OP_WRITE        0x01  2656 #define PHY_TURNAROUND      0x02  2657 #define PHY_PREAMBLE_SIZE   32  2658 #define MII_CR_SPEED_1000   0x0040  2659 #define MII_CR_SPEED_100    0x2000  2660 #define MII_CR_SPEED_10     0x0000  2661 #define E1000_PHY_ADDRESS   0x01  2662 #define PHY_AUTO_NEG_TIME   45    2663 #define PHY_FORCE_TIME      20    2664 #define PHY_REVISION_MASK   0xFFFFFFF0  2665 #define DEVICE_SPEED_MASK   0x00000300    2666 #define REG4_SPEED_MASK     0x01E0  2667 #define REG9_SPEED_MASK     0x0300  2668 #define ADVERTISE_10_HALF   0x0001  2669 #define ADVERTISE_10_FULL   0x0002  2670 #define ADVERTISE_100_HALF  0x0004  2671 #define ADVERTISE_100_FULL  0x0008  2672 #define ADVERTISE_1000_HALF 0x0010  2673 #define ADVERTISE_1000_FULL 0x0020  2674 #define AUTONEG_ADVERTISE_SPEED_DEFAULT 0x002F    2675 #define AUTONEG_ADVERTISE_10_100_ALL    0x000F   2676 #define AUTONEG_ADVERTISE_10_ALL        0x0003  Definition: if_em_hw.h:1910
Definition: if_em_hw.h:613
Definition: if_em_hw.h:1916
Definition: if_em_hw.h:739
Definition: if_em_hw.h:795
Definition: if_em_hw.h:371
Definition: if_em_hw.h:820
Definition: if_em_hw.h:347
Definition: if_em_hw.h:826
Definition: if_em_hw.h:250
Definition: if_em_hw.h:1212
Definition: if_em_hw.h:355
Definition: if_em_hw.h:815
Definition: if_em_hw.h:832
Definition: if_em_hw.h:1283
Definition: if_em_hw.h:804
Definition: if_em_hw.h:239
Definition: 8xx_immap.h:312
Definition: if_em_hw.h:255
Definition: if_em_hw.h:768
Definition: if_em_hw.h:696
Definition: if_em_hw.h:577
Definition: if_em_hw.h:587
