1 #ifndef RTEMS_COMPAT_DEFS_H     2 #define RTEMS_COMPAT_DEFS_H     8 #define NETDRIVER_SLOTS 1    11 #define NETDRIVER       "em"    13 #define NETDRIVER_PREFIX em    15 #define adapter         em_softc    16 #define interface_data  arpcom    30 #define NET_CHIP_MEM_IO    31 #undef  NET_CHIP_PORT_IO    36 #define NET_SOFTC_BHANDLE_FIELD osdep.mem_bus_space_handle    43 #define  IF_REG_HEADER "../if_em/if_em.h"    47 #define NETDRIVER_PCI <bsp/pci.h>    64 #define NET_ENABLE_IRQS(sc) do { \    65         E1000_WRITE_REG(&sc->hw, IMS, (IMS_ENABLE_MASK)); \    68 #define NET_DISABLE_IRQS(sc)    do { \    69         E1000_WRITE_REG(&sc->hw, IMC, 0xffffffff);  \    72 #define KASSERT(a...) do {} while (0)    88 typedef unsigned bus_size_t;
    89 typedef unsigned bus_addr_t;
    96 #define bus_dma_tag_destroy(args...) do {} while(0)    98 #define bus_dmamap_destroy(args...) do {} while(0)   100 #define bus_dmamap_unload(args...) do {} while (0)   103 #define bus_dmamap_sync(args...) do { __asm__ volatile("sync":::"memory"); } while (0)   105 #define bus_dmamap_sync(args...) do {} while (0)   108 #define BUS_DMA_NOWAIT      0xdeadbeef     110 #define em_adapter_list _bsd_em_adapter_list   111 #define em_arc_subsystem_valid _bsd_em_arc_subsystem_valid   112 #define em_check_downshift _bsd_em_check_downshift   113 #define em_check_for_link _bsd_em_check_for_link   114 #define em_check_mng_mode _bsd_em_check_mng_mode   115 #define em_check_phy_reset_block _bsd_em_check_phy_reset_block   116 #define em_check_polarity _bsd_em_check_polarity   117 #define em_cleanup_led _bsd_em_cleanup_led   118 #define em_clear_hw_cntrs _bsd_em_clear_hw_cntrs   119 #define em_clear_vfta _bsd_em_clear_vfta   120 #define em_commit_shadow_ram _bsd_em_commit_shadow_ram   121 #define em_config_collision_dist _bsd_em_config_collision_dist   122 #define em_config_dsp_after_link_change _bsd_em_config_dsp_after_link_change   123 #define em_config_fc_after_link_up _bsd_em_config_fc_after_link_up   124 #define em_dbg_config _bsd_em_dbg_config   125 #define em_detect_gig_phy _bsd_em_detect_gig_phy   126 #define em_disable_pciex_master _bsd_em_disable_pciex_master   127 #define em_display_debug_stats _bsd_em_display_debug_stats   128 #define em_driver_version _bsd_em_driver_version   129 #define em_enable_mng_pass_thru _bsd_em_enable_mng_pass_thru   130 #define em_enable_pciex_master _bsd_em_enable_pciex_master   131 #define em_enable_tx_pkt_filtering _bsd_em_enable_tx_pkt_filtering   132 #define em_force_mac_fc _bsd_em_force_mac_fc   133 #define em_get_auto_rd_done _bsd_em_get_auto_rd_done   134 #define em_get_bus_info _bsd_em_get_bus_info   135 #define em_get_cable_length _bsd_em_get_cable_length   136 #define em_get_hw_eeprom_semaphore _bsd_em_get_hw_eeprom_semaphore   137 #define em_get_phy_cfg_done _bsd_em_get_phy_cfg_done   138 #define em_get_speed_and_duplex _bsd_em_get_speed_and_duplex   139 #define em_hash_mc_addr _bsd_em_hash_mc_addr   140 #define em_hw_early_init _bsd_em_hw_early_init   141 #define em_id_led_init _bsd_em_id_led_init   142 #define em_init_eeprom_params _bsd_em_init_eeprom_params   143 #define em_init_hw _bsd_em_init_hw   144 #define em_init_rx_addrs _bsd_em_init_rx_addrs   145 #define em_io_read _bsd_em_io_read   146 #define em_io_write _bsd_em_io_write   147 #define em_is_onboard_nvm_eeprom _bsd_em_is_onboard_nvm_eeprom   148 #define em_led_off _bsd_em_led_off   149 #define em_led_on _bsd_em_led_on   150 #define em_mc_addr_list_update _bsd_em_mc_addr_list_update   151 #define em_mng_enable_host_if _bsd_em_mng_enable_host_if   152 #define em_mng_host_if_write _bsd_em_mng_host_if_write   153 #define em_mng_write_cmd_header _bsd_em_mng_write_cmd_header   154 #define em_mng_write_commit _bsd_em_mng_write_commit   155 #define em_mng_write_dhcp_info _bsd_em_mng_write_dhcp_info   156 #define em_mta_set _bsd_em_mta_set   157 #define em_pci_clear_mwi _bsd_em_pci_clear_mwi   158 #define em_pci_set_mwi _bsd_em_pci_set_mwi   159 #define em_phy_get_info _bsd_em_phy_get_info   160 #define em_phy_hw_reset _bsd_em_phy_hw_reset   161 #define em_phy_igp_get_info _bsd_em_phy_igp_get_info   162 #define em_phy_m88_get_info _bsd_em_phy_m88_get_info   163 #define em_phy_reset _bsd_em_phy_reset   164 #define em_phy_setup_autoneg _bsd_em_phy_setup_autoneg   165 #define em_poll_eerd_eewr_done _bsd_em_poll_eerd_eewr_done   166 #define em_put_hw_eeprom_semaphore _bsd_em_put_hw_eeprom_semaphore   167 #define em_rar_set _bsd_em_rar_set   168 #define em_read_eeprom _bsd_em_read_eeprom   169 #define em_read_eeprom_eerd _bsd_em_read_eeprom_eerd   170 #define em_read_mac_addr _bsd_em_read_mac_addr   171 #define em_read_part_num _bsd_em_read_part_num   172 #define em_read_pci_cfg _bsd_em_read_pci_cfg   173 #define em_read_phy_reg _bsd_em_read_phy_reg   174 #define em_read_reg_io _bsd_em_read_reg_io   175 #define em_reset_adaptive _bsd_em_reset_adaptive   176 #define em_reset_hw _bsd_em_reset_hw   177 #define em_set_d0_lplu_state _bsd_em_set_d0_lplu_state   178 #define em_set_d3_lplu_state _bsd_em_set_d3_lplu_state   179 #define em_set_mac_type _bsd_em_set_mac_type   180 #define em_set_media_type _bsd_em_set_media_type   181 #define em_set_pci_express_master_disable _bsd_em_set_pci_express_master_disable   182 #define em_setup_led _bsd_em_setup_led   183 #define em_setup_link _bsd_em_setup_link   184 #define em_tbi_adjust_stats _bsd_em_tbi_adjust_stats   185 #define em_update_adaptive _bsd_em_update_adaptive   186 #define em_update_eeprom_checksum _bsd_em_update_eeprom_checksum   187 #define em_validate_eeprom_checksum _bsd_em_validate_eeprom_checksum   188 #define em_validate_mdi_setting _bsd_em_validate_mdi_setting   189 #define em_wait_autoneg _bsd_em_wait_autoneg   190 #define em_write_eeprom _bsd_em_write_eeprom   191 #define em_write_eeprom_eewr _bsd_em_write_eeprom_eewr   192 #define em_write_pci_cfg _bsd_em_write_pci_cfg   193 #define em_write_phy_reg _bsd_em_write_phy_reg   194 #define em_write_reg_io _bsd_em_write_reg_io   195 #define em_write_vfta _bsd_em_write_vfta   196 #define the_em_devs _bsd_the_em_devs Definition: rtemscompat_defs.h:91
