    RTEMS
    5.1
Go to the documentation of this file.   33 #ifndef _RTEMS_MIPS_IDTCPU_H    34 #define _RTEMS_MIPS_IDTCPU_H    53 #define K0BASE  0x80000000    54 #define K0SIZE  0x20000000    55 #define K1BASE  0xa0000000    56 #define K1SIZE  0x20000000    57 #define K2BASE  0xc0000000    58 #define K2SIZE  0x20000000    60 #define KSBASE  0xe0000000    61 #define KSSIZE  0x20000000    65 #define KUSIZE  0x80000000    72 #define DB_VEC  (K0BASE+0x40)               73 #define E_VEC   (K0BASE+0x80)           75 #define T_VEC   (K0BASE+0x000)          76 #define X_VEC   (K0BASE+0x080)          77 #define C_VEC   (K0BASE+0x100)          78 #define E_VEC   (K0BASE+0x180)          80 #define T_VEC   (K0BASE+0x000)          81 #define X_VEC   (K0BASE+0x080)          82 #define C_VEC   (K0BASE+0x100)          83 #define E_VEC   (K0BASE+0x180)          85 #error "EXCEPTION VECTORS: unknown ISA level"    87 #define R_VEC   (K1BASE+0x1fc00000)     97 #define K0_TO_K1(x) (CAST(unsigned)(x)|0xA0000000)      98 #define K1_TO_K0(x) (CAST(unsigned)(x)&0x9FFFFFFF)      99 #define K0_TO_PHYS(x)   (CAST(unsigned)(x)&0x1FFFFFFF)     100 #define K1_TO_PHYS(x)   (CAST(unsigned)(x)&0x1FFFFFFF)     101 #define PHYS_TO_K0(x)   (CAST(unsigned)(x)|0x80000000)     102 #define PHYS_TO_K1(x)   (CAST(unsigned)(x)|0xA0000000)     107 #define MINCACHE    0x200          108 #define MAXCACHE    0x40000        112 #define CFG_CM      0x80000000     113 #define CFG_ECMASK  0x70000000     114 #define CFG_ECBY2   0x00000000     115 #define CFG_ECBY3   0x10000000     116 #define CFG_ECBY4   0x20000000     117 #define CFG_EPMASK  0x0f000000     118 #define CFG_EPD     0x00000000     119 #define CFG_EPDDX   0x01000000     120 #define CFG_EPDDXX  0x02000000     121 #define CFG_EPDXDX  0x03000000     122 #define CFG_EPDDXXX 0x04000000     123 #define CFG_EPDDXXXX    0x05000000     124 #define CFG_EPDXXDXX    0x06000000     125 #define CFG_EPDDXXXXX   0x07000000     126 #define CFG_EPDXXXDXXX  0x08000000     127 #define CFG_SBMASK  0x00c00000     128 #define CFG_SBSHIFT 22   129 #define CFG_SB4     0x00000000     130 #define CFG_SB8     0x00400000     131 #define CFG_SB16    0x00800000     132 #define CFG_SB32    0x00c00000     133 #define CFG_SS      0x00200000     134 #define CFG_SW      0x00100000     135 #define CFG_EWMASK  0x000c0000     136 #define CFG_EWSHIFT 18   137 #define CFG_EW64    0x00000000     138 #define CFG_EW32    0x00010000     139 #define CFG_SC      0x00020000     140 #define CFG_SM      0x00010000     141 #define CFG_BE      0x00008000     142 #define CFG_EM      0x00004000     143 #define CFG_EB      0x00002000     144 #define CFG_ICMASK  0x00000e00     145 #define CFG_ICSHIFT 9   146 #define CFG_DCMASK  0x000001c0     147 #define CFG_DCSHIFT 6   148 #define CFG_IB      0x00000020     149 #define CFG_DB      0x00000010     150 #define CFG_CU      0x00000008     151 #define CFG_K0MASK  0x00000007     156 #define CFG_C_UNCACHED      2   157 #define CFG_C_NONCOHERENT   3   158 #define CFG_C_COHERENTXCL   4   159 #define CFG_C_COHERENTXCLW  5   160 #define CFG_C_COHERENTUPD   6   165 #define Index_Invalidate_I               0x0            166 #define Index_Writeback_Inv_D            0x1            167 #define Index_Invalidate_SI              0x2            168 #define Index_Writeback_Inv_SD           0x3            169 #define Index_Load_Tag_I                 0x4            170 #define Index_Load_Tag_D                 0x5            171 #define Index_Load_Tag_SI                0x6            172 #define Index_Load_Tag_SD                0x7            173 #define Index_Store_Tag_I                0x8            174 #define Index_Store_Tag_D                0x9            175 #define Index_Store_Tag_SI               0xA            176 #define Index_Store_Tag_SD               0xB            177 #define Create_Dirty_Exc_D               0xD            178 #define Create_Dirty_Exc_SD              0xF            179 #define Hit_Invalidate_I                 0x10           180 #define Hit_Invalidate_D                 0x11           181 #define Hit_Invalidate_SI                0x12           182 #define Hit_Invalidate_SD                0x13           183 #define Hit_Writeback_Inv_D              0x15           184 #define Hit_Writeback_Inv_SD             0x17           186 #define Hit_Writeback_D                  0x19           187 #define Hit_Writeback_SD                 0x1B           188 #define Hit_Writeback_I                  0x18           189 #define Hit_Set_Virtual_SI               0x1E           190 #define Hit_Set_Virtual_SD               0x1F           207 #define CFG_CM      0x80000000     208 #define CFG_ECMASK  0x70000000     209 #define CFG_ECBY2   0x00000000     210 #define CFG_ECBY3   0x10000000     211 #define CFG_ECBY4   0x20000000     212 #define CFG_EPMASK  0x0f000000     213 #define CFG_EPD     0x00000000     214 #define CFG_EPDDX   0x01000000     215 #define CFG_EPDDXX  0x02000000     216 #define CFG_EPDXDX  0x03000000     217 #define CFG_EPDDXXX 0x04000000     218 #define CFG_EPDDXXXX    0x05000000     219 #define CFG_EPDXXDXX    0x06000000     220 #define CFG_EPDDXXXXX   0x07000000     221 #define CFG_EPDXXXDXXX  0x08000000     222 #define CFG_SBMASK  0x00c00000     223 #define CFG_SBSHIFT 22   224 #define CFG_SB4     0x00000000     225 #define CFG_SB8     0x00400000     226 #define CFG_SB16    0x00800000     227 #define CFG_SB32    0x00c00000     228 #define CFG_SS      0x00200000     229 #define CFG_SW      0x00100000     230 #define CFG_EWMASK  0x000c0000     231 #define CFG_EWSHIFT 18   232 #define CFG_EW64    0x00000000     233 #define CFG_EW32    0x00010000     234 #define CFG_SC      0x00020000     235 #define CFG_SM      0x00010000     236 #define CFG_BE      0x00008000     237 #define CFG_EM      0x00004000     238 #define CFG_EB      0x00002000     239 #define CFG_ICMASK  0x00000e00     240 #define CFG_ICSHIFT 9   241 #define CFG_DCMASK  0x000001c0     242 #define CFG_DCSHIFT 6   243 #define CFG_IB      0x00000020     244 #define CFG_DB      0x00000010     245 #define CFG_CU      0x00000008     246 #define CFG_K0MASK  0x00000007     251 #define CFG_C_UNCACHED      2   252 #define CFG_C_NONCOHERENT   3   253 #define CFG_C_COHERENTXCL   4   254 #define CFG_C_COHERENTXCLW  5   255 #define CFG_C_COHERENTUPD   6   260 #define Index_Invalidate_I               0x0            261 #define Index_Writeback_Inv_D            0x1            262 #define Index_Invalidate_SI              0x2            263 #define Index_Writeback_Inv_SD           0x3            264 #define Index_Load_Tag_I                 0x4            265 #define Index_Load_Tag_D                 0x5            266 #define Index_Load_Tag_SI                0x6            267 #define Index_Load_Tag_SD                0x7            268 #define Index_Store_Tag_I                0x8            269 #define Index_Store_Tag_D                0x9            270 #define Index_Store_Tag_SI               0xA            271 #define Index_Store_Tag_SD               0xB            272 #define Create_Dirty_Exc_D               0xD            273 #define Create_Dirty_Exc_SD              0xF            274 #define Hit_Invalidate_I                 0x10           275 #define Hit_Invalidate_D                 0x11           276 #define Hit_Invalidate_SI                0x12           277 #define Hit_Invalidate_SD                0x13           278 #define Hit_Writeback_Inv_D              0x15           279 #define Hit_Writeback_Inv_SD             0x17           281 #define Hit_Writeback_D                  0x19           282 #define Hit_Writeback_SD                 0x1B           283 #define Hit_Writeback_I                  0x18           284 #define Hit_Set_Virtual_SI               0x1E           285 #define Hit_Set_Virtual_SD               0x1F           304 #define N_TLB_ENTRIES   64   305 #define TLB_PGSIZE  0x1000   307 #define TLBLO_PFNMASK   0xfffff000   308 #define TLBLO_PFNSHIFT  12   309 #define TLBLO_N     0x800      310 #define TLBLO_D     0x400      311 #define TLBLO_V     0x200      312 #define TLBLO_G     0x100      314 #define TLBHI_VPNMASK   0xfffff000   315 #define TLBHI_VPNSHIFT  12   316 #define TLBHI_PIDMASK   0xfc0   317 #define TLBHI_PIDSHIFT  6   318 #define TLBHI_NPID  64   320 #define TLBINX_PROBE    0x80000000   321 #define TLBINX_INXMASK  0x00003f00   322 #define TLBINX_INXSHIFT 8   324 #define TLBRAND_RANDMASK    0x00003f00   325 #define TLBRAND_RANDSHIFT   8   327 #define TLBCTXT_BASEMASK    0xffe00000   328 #define TLBCTXT_BASESHIFT   21   330 #define TLBCTXT_VPNMASK     0x001ffffc   331 #define TLBCTXT_VPNSHIFT    2   334 #define N_TLB_ENTRIES   48   336 #define TLBHI_VPN2MASK  0xffffe000   337 #define TLBHI_PIDMASK   0x000000ff   338 #define TLBHI_NPID  256   340 #define TLBLO_PFNMASK   0x3fffffc0   341 #define TLBLO_PFNSHIFT  6   342 #define TLBLO_D     0x00000004     343 #define TLBLO_V     0x00000002     344 #define TLBLO_G     0x00000001     345 #define TLBLO_CMASK 0x00000038     346 #define TLBLO_CSHIFT    3   348 #define TLBLO_UNCACHED      (CFG_C_UNCACHED<<TLBLO_CSHIFT)   349 #define TLBLO_NONCOHERENT   (CFG_C_NONCOHERENT<<TLBLO_CSHIFT)   350 #define TLBLO_COHERENTXCL   (CFG_C_COHERENTXCL<<TLBLO_CSHIFT)   351 #define TLBLO_COHERENTXCLW  (CFG_C_COHERENTXCLW<<TLBLO_CSHIFT)   352 #define TLBLO_COHERENTUPD   (CFG_C_COHERENTUPD<<TLBLO_CSHIFT)   354 #define TLBINX_PROBE    0x80000000   355 #define TLBINX_INXMASK  0x0000003f   357 #define TLBRAND_RANDMASK    0x0000003f   359 #define TLBCTXT_BASEMASK    0xff800000   360 #define TLBCTXT_BASESHIFT   23   362 #define TLBCTXT_VPN2MASK    0x007ffff0   363 #define TLBCTXT_VPN2SHIFT   4   365 #define TLBPGMASK_MASK      0x01ffe000   369 #define N_TLB_ENTRIES   16   371 #define TLBHI_VPN2MASK  0xffffe000   372 #define TLBHI_PIDMASK   0x000000ff   373 #define TLBHI_NPID  256   375 #define TLBLO_PFNMASK   0x3fffffc0   376 #define TLBLO_PFNSHIFT  6   377 #define TLBLO_D     0x00000004     378 #define TLBLO_V     0x00000002     379 #define TLBLO_G     0x00000001     380 #define TLBLO_CMASK 0x00000038     381 #define TLBLO_CSHIFT    3   383 #define TLBLO_UNCACHED      (CFG_C_UNCACHED<<TLBLO_CSHIFT)   384 #define TLBLO_NONCOHERENT   (CFG_C_NONCOHERENT<<TLBLO_CSHIFT)   385 #define TLBLO_COHERENTXCL   (CFG_C_COHERENTXCL<<TLBLO_CSHIFT)   386 #define TLBLO_COHERENTXCLW  (CFG_C_COHERENTXCLW<<TLBLO_CSHIFT)   387 #define TLBLO_COHERENTUPD   (CFG_C_COHERENTUPD<<TLBLO_CSHIFT)   389 #define TLBINX_PROBE    0x80000000   390 #define TLBINX_INXMASK  0x0000003f   392 #define TLBRAND_RANDMASK    0x0000003f   394 #define TLBCTXT_BASEMASK    0xff800000   395 #define TLBCTXT_BASESHIFT   23   397 #define TLBCTXT_VPN2MASK    0x007ffff0   398 #define TLBCTXT_VPN2SHIFT   4   400 #define TLBPGMASK_MASK      0x01ffe000   407 #define DCIC_TR     0x80000000     408 #define DCIC_UD     0x40000000     409 #define DCIC_KD     0x20000000     410 #define DCIC_TE     0x10000000     411 #define DCIC_DW     0x08000000     412 #define DCIC_DR     0x04000000     413 #define DCIC_DAE    0x02000000     414 #define DCIC_PCE    0x01000000     415 #define DCIC_DE     0x00800000     416 #define DCIC_DL     0x00008000     417 #define DCIC_IL     0x00004000     418 #define DCIC_D      0x00002000     419 #define DCIC_I      0x00001000     420 #define DCIC_T      0x00000020     421 #define DCIC_W      0x00000010     422 #define DCIC_R      0x00000008     423 #define DCIC_DA     0x00000004     424 #define DCIC_PC     0x00000002     425 #define DCIC_DB     0x00000001     430 #define SR_CUMASK   0xf0000000     431 #define SR_CU3      0x80000000     432 #define SR_CU2      0x40000000     433 #define SR_CU1      0x20000000     434 #define SR_CU0      0x10000000     436 #define SR_BEV      0x00400000     439 #define SR_TS       0x00200000     440 #define SR_PE       0x00100000     441 #define SR_CM       0x00080000     442 #define SR_PZ       0x00040000     443 #define SR_SWC      0x00020000     444 #define SR_ISC      0x00010000     450 #define SR_IMASK    0x0000ff00     451 #define SR_IMASK8   0x00000000     452 #define SR_IMASK7   0x00008000     453 #define SR_IMASK6   0x0000c000     454 #define SR_IMASK5   0x0000e000     455 #define SR_IMASK4   0x0000f000     456 #define SR_IMASK3   0x0000f800     457 #define SR_IMASK2   0x0000fc00     458 #define SR_IMASK1   0x0000fe00     459 #define SR_IMASK0   0x0000ff00     461 #define SR_IMASKSHIFT   8   463 #define SR_IBIT8    0x00008000     464 #define SR_IBIT7    0x00004000     465 #define SR_IBIT6    0x00002000     466 #define SR_IBIT5    0x00001000     467 #define SR_IBIT4    0x00000800     468 #define SR_IBIT3    0x00000400     469 #define SR_IBIT2    0x00000200     470 #define SR_IBIT1    0x00000100     472 #define SR_KUO      0x00000020     473 #define SR_IEO      0x00000010     474 #define SR_KUP      0x00000008     475 #define SR_IEP      0x00000004     476 #define SR_KUC      0x00000002     477 #define SR_IEC      0x00000001     481 #define SR_CUMASK   0xf0000000     482 #define SR_CU3      0x80000000     483 #define SR_CU2      0x40000000     484 #define SR_CU1      0x20000000     485 #define SR_CU0      0x10000000     487 #define SR_RP       0x08000000         488 #define SR_FR       0x04000000     489 #define SR_RE       0x02000000     491 #define SR_BEV      0x00400000     492 #define SR_TS       0x00200000     493 #define SR_SR       0x00100000     494 #define SR_CH       0x00040000     495 #define SR_CE       0x00020000     496 #define SR_DE       0x00010000     502 #define SR_IMASK    0x0000ff00     503 #define SR_IMASK8   0x00000000     504 #define SR_IMASK7   0x00008000     505 #define SR_IMASK6   0x0000c000     506 #define SR_IMASK5   0x0000e000     507 #define SR_IMASK4   0x0000f000     508 #define SR_IMASK3   0x0000f800     509 #define SR_IMASK2   0x0000fc00     510 #define SR_IMASK1   0x0000fe00     511 #define SR_IMASK0   0x0000ff00     513 #define SR_IMASKSHIFT   8   515 #define SR_IBIT8    0x00008000     516 #define SR_IBIT7    0x00004000     517 #define SR_IBIT6    0x00002000     518 #define SR_IBIT5    0x00001000     519 #define SR_IBIT4    0x00000800     520 #define SR_IBIT3    0x00000400     521 #define SR_IBIT2    0x00000200     522 #define SR_IBIT1    0x00000100     524 #define SR_KSMASK   0x00000018     525 #define SR_KSUSER   0x00000010     526 #define SR_KSSUPER  0x00000008     527 #define SR_KSKERNEL 0x00000000     528 #define SR_ERL      0x00000004     529 #define SR_EXL      0x00000002     530 #define SR_IE       0x00000001     534 #define SR_CUMASK   0xf0000000     535 #define SR_CU3      0x80000000     536 #define SR_CU2      0x40000000     537 #define SR_CU1      0x20000000     538 #define SR_CU0      0x10000000     540 #define SR_RP       0x08000000         541 #define SR_FR       0x04000000     542 #define SR_RE       0x02000000     544 #define SR_BEV      0x00400000     545 #define SR_TS       0x00200000     546 #define SR_SR       0x00100000     547 #define SR_CH       0x00040000     548 #define SR_CE       0x00020000     549 #define SR_DE       0x00010000     555 #define SR_IMASK    0x0000ff00     556 #define SR_IMASK8   0x00000000     557 #define SR_IMASK7   0x00008000     558 #define SR_IMASK6   0x0000c000     559 #define SR_IMASK5   0x0000e000     560 #define SR_IMASK4   0x0000f000     561 #define SR_IMASK3   0x0000f800     562 #define SR_IMASK2   0x0000fc00     563 #define SR_IMASK1   0x0000fe00     564 #define SR_IMASK0   0x0000ff00     566 #define SR_IMASKSHIFT   8   568 #define SR_IBIT8    0x00008000     569 #define SR_IBIT7    0x00004000     570 #define SR_IBIT6    0x00002000     571 #define SR_IBIT5    0x00001000     572 #define SR_IBIT4    0x00000800     573 #define SR_IBIT3    0x00000400     574 #define SR_IBIT2    0x00000200     575 #define SR_IBIT1    0x00000100     577 #define SR_KSMASK   0x00000018     578 #define SR_KSUSER   0x00000010     579 #define SR_KSSUPER  0x00000008     580 #define SR_KSKERNEL 0x00000000     581 #define SR_ERL      0x00000004     582 #define SR_EXL      0x00000002     583 #define SR_IE       0x00000001     589 #define CAUSE_BD    0x80000000     590 #define CAUSE_BT    0x40000000     591 #define CAUSE_CEMASK    0x30000000     592 #define CAUSE_CESHIFT   28   595 #define CAUSE_IPMASK    0x0000FF00     596 #define CAUSE_IPSHIFT   8   598 #define CAUSE_EXCMASK   0x0000003C     599 #define CAUSE_EXCSHIFT  2   624 #define C0_PAGEMASK $5         629 #define C0_PAGEMASK $5         637 #define C0_BADVADDR $8         649 #define C0_COMPARE  $11        653 #define C0_COMPARE  $11        666 #define C0_CONFIG   $16        667 #define C0_LLADDR   $17        668 #define C0_WATCHLO  $18        669 #define C0_WATCHHI  $19        672 #define C0_CACHEERR $27        679 #define C0_CONFIG   $16        680 #define C0_LLADDR   $17        681 #define C0_WATCHLO  $18        682 #define C0_WATCHHI  $19        685 #define C0_CACHEERR $27        692 #define C1_REVISION     $0   693 #define C1_STATUS       $31
