    RTEMS
    5.1
Go to the documentation of this file.   19 #ifndef _I386_KEYBOARD_H    20 #define _I386_KEYBOARD_H    24 #define KEYBOARD_IRQ            1    25 #define DISABLE_KBD_DURING_INTERRUPTS   0    27 extern int pckbd_setkeycode(
unsigned int scancode,
unsigned int keycode);
    28 extern int pckbd_getkeycode(
unsigned int scancode);
    29 extern int pckbd_translate(
unsigned char scancode,
unsigned char *keycode,
    31 extern char pckbd_unexpected_up(
unsigned char keycode);
    32 extern void pckbd_leds(
unsigned char leds);
    33 extern void pckbd_init_hw(
void);
    34 extern unsigned char pckbd_sysrq_xlate[128];
    36 #define kbd_setkeycode      pckbd_setkeycode    37 #define kbd_getkeycode      pckbd_getkeycode    38 #define kbd_translate       pckbd_translate    39 #define kbd_unexpected_up   pckbd_unexpected_up    40 #define kbd_leds              pckbd_leds    41 #define kbd_init_hw        pckbd_init_hw    42 #define kbd_sysrq_xlate     pckbd_sysrq_xlate    44 #define SYSRQ_KEY 0x54    47 #define kbd_request_region()         48 #define kbd_request_irq(handler)     51 #define kbd_read_input() inb(KBD_DATA_REG)    52 #define kbd_read_status() inb(KBD_STATUS_REG)    53 #define kbd_write_output(val) outb(val, KBD_DATA_REG)    54 #define kbd_write_command(val) outb(val, KBD_CNTL_REG)    57 #define kbd_pause() do { } while(0)    65 #define aux_request_irq(hand, dev_id)      67 #define aux_free_irq(dev_id)       82 #define KBD_REPORT_UNKN             83 #define KBD_REPORT_TIMEOUTS         84 #undef KBD_IS_FOCUS_9000            85 #undef INITIALIZE_MOUSE             87 #define KBD_INIT_TIMEOUT 1000           88 #define KBC_TIMEOUT 250             89 #define KBD_TIMEOUT 1000            95 extern unsigned char pckbd_read_mask;
    96 extern unsigned char aux_device_present;
   102 #define KBD_STATUS_REG      0x64       103 #define KBD_CNTL_REG        0x64       104 #define KBD_DATA_REG        0x60       110 #define KBD_CCMD_READ_MODE  0x20       111 #define KBD_CCMD_WRITE_MODE 0x60       112 #define KBD_CCMD_GET_VERSION    0xA1       113 #define KBD_CCMD_MOUSE_DISABLE  0xA7       114 #define KBD_CCMD_MOUSE_ENABLE   0xA8       115 #define KBD_CCMD_TEST_MOUSE 0xA9       116 #define KBD_CCMD_SELF_TEST  0xAA       117 #define KBD_CCMD_KBD_TEST   0xAB       118 #define KBD_CCMD_KBD_DISABLE    0xAD       119 #define KBD_CCMD_KBD_ENABLE 0xAE       120 #define KBD_CCMD_WRITE_AUX_OBUF 0xD3       122 #define KBD_CCMD_WRITE_MOUSE    0xD4       128 #define KBD_CMD_SET_LEDS    0xED       129 #define KBD_CMD_SET_RATE    0xF3       130 #define KBD_CMD_ENABLE      0xF4       131 #define KBD_CMD_DISABLE     0xF5       132 #define KBD_CMD_RESET       0xFF       138 #define KBD_REPLY_POR       0xAA       139 #define KBD_REPLY_ACK       0xFA       140 #define KBD_REPLY_RESEND    0xFE       146 #define KBD_STAT_OBF        0x01       147 #define KBD_STAT_IBF        0x02       148 #define KBD_STAT_SELFTEST   0x04       149 #define KBD_STAT_CMD        0x08       150 #define KBD_STAT_UNLOCKED   0x10       151 #define KBD_STAT_MOUSE_OBF  0x20       152 #define KBD_STAT_GTO        0x40       153 #define KBD_STAT_PERR       0x80       155 #define AUX_STAT_OBF (KBD_STAT_OBF | KBD_STAT_MOUSE_OBF)   161 #define KBD_MODE_KBD_INT    0x01       162 #define KBD_MODE_MOUSE_INT  0x02       163 #define KBD_MODE_SYS        0x04       164 #define KBD_MODE_NO_KEYLOCK 0x08       165 #define KBD_MODE_DISABLE_KBD    0x10       166 #define KBD_MODE_DISABLE_MOUSE  0x20       167 #define KBD_MODE_KCC        0x40       168 #define KBD_MODE_RFU        0x80   174 #define AUX_SET_RES     0xE8       175 #define AUX_SET_SCALE11     0xE6       176 #define AUX_SET_SCALE21     0xE7       177 #define AUX_GET_SCALE       0xE9       178 #define AUX_SET_STREAM      0xEA       179 #define AUX_SET_SAMPLE      0xF3       180 #define AUX_ENABLE_DEV      0xF4       181 #define AUX_DISABLE_DEV     0xF5       182 #define AUX_RESET       0xFF       185 #define AUX_BUF_SIZE        2048
