    RTEMS
    5.1
Go to the documentation of this file.   29 #define rtems_inb(port)                         \    31         register int _inb_result;                   \    33         __asm__ volatile ("xorl %%eax,%%eax; inb %%dx,%%al" :       \    34             "=a" (_inb_result) : "d" (port));               \    38 #define rtems_inw(port)                         \    40         register int _inbw_result;                  \    42         __asm__ volatile ("xorl %%eax,%%eax; inw %%dx,%%ax" :       \    43             "=a" (_inbw_result) : "d" (port));              \    47 #define rtems_outb(port, data)                      \    48         __asm__ volatile ("outb %%al,%%dx" : : "a" (data), "d" (port))    50 #define rtems_outw(port, data)                      \    51         __asm__ volatile ("outw %%ax,%%dx" : : "a" (data), "d" (port))    53 #define outp(port, val) rtems_outb(port,val)    54 #define inp(port)         rtems_inb(port)    56 #define outb(val, port) rtems_outb(port,val)    57 #define inb(port)         rtems_inb(port)    59 #define outb_p(val, port)   rtems_outb(port,val)    60 #define inb_p(port)       rtems_inb(port)    62 #define outportb(port,val)  rtems_outb(port,val)    63 #define inportb(port)   rtems_inb(port)    65 #define outw(val, port) rtems_outw(port,val)    66 #define inw(port)         rtems_inw(port)    68 #define cli()   __asm__ __volatile__("cli")    69 #define sti()   __asm__ __volatile__("sti");
