#define  | KG_SHIFT   0 |
#define  | KG_CTRL   2 |
#define  | KG_ALT   3 |
#define  | KG_ALTGR   1 |
#define  | KG_SHIFTL   4 |
#define  | KG_SHIFTR   5 |
#define  | KG_CTRLL   6 |
#define  | KG_CTRLR   7 |
#define  | KG_CAPSSHIFT   8 |
#define  | NR_SHIFT   9 |
#define  | NR_KEYS   128 |
#define  | MAX_NR_KEYMAPS   256 |
#define  | MAX_NR_OF_USER_KEYMAPS   256 	/* should be at least 7 */ |
#define  | MAX_NR_FUNC   256	/* max nr of strings assigned to keys */ |
#define  | MAX_NR_CONSOLES   1 |
#define  | KT_LATIN   0	/* we depend on this being zero */ |
#define  | KT_LETTER   11	/* symbol that can be acted upon by CapsLock */ |
#define  | KT_FN   1 |
#define  | KT_SPEC   2 |
#define  | KT_PAD   3 |
#define  | KT_DEAD   4 |
#define  | KT_CONS   5 |
#define  | KT_CUR   6 |
#define  | KT_SHIFT   7 |
#define  | KT_META   8 |
#define  | KT_ASCII   9 |
#define  | KT_LOCK   10 |
#define  | KT_SLOCK   12 |
#define  | K(t,  v)   (((t)<<8)|(v)) |
#define  | KTYP(x)   ((x) >> 8) |
#define  | KVAL(x)   ((x) & 0xff) |
#define  | K_F1   K(KT_FN,0) |
#define  | K_F2   K(KT_FN,1) |
#define  | K_F3   K(KT_FN,2) |
#define  | K_F4   K(KT_FN,3) |
#define  | K_F5   K(KT_FN,4) |
#define  | K_F6   K(KT_FN,5) |
#define  | K_F7   K(KT_FN,6) |
#define  | K_F8   K(KT_FN,7) |
#define  | K_F9   K(KT_FN,8) |
#define  | K_F10   K(KT_FN,9) |
#define  | K_F11   K(KT_FN,10) |
#define  | K_F12   K(KT_FN,11) |
#define  | K_F13   K(KT_FN,12) |
#define  | K_F14   K(KT_FN,13) |
#define  | K_F15   K(KT_FN,14) |
#define  | K_F16   K(KT_FN,15) |
#define  | K_F17   K(KT_FN,16) |
#define  | K_F18   K(KT_FN,17) |
#define  | K_F19   K(KT_FN,18) |
#define  | K_F20   K(KT_FN,19) |
#define  | K_FIND   K(KT_FN,20) |
#define  | K_INSERT   K(KT_FN,21) |
#define  | K_REMOVE   K(KT_FN,22) |
#define  | K_SELECT   K(KT_FN,23) |
#define  | K_PGUP   K(KT_FN,24) /* PGUP is a synonym for PRIOR */ |
#define  | K_PGDN   K(KT_FN,25) /* PGDN is a synonym for NEXT */ |
#define  | K_MACRO   K(KT_FN,26) |
#define  | K_HELP   K(KT_FN,27) |
#define  | K_DO   K(KT_FN,28) |
#define  | K_PAUSE   K(KT_FN,29) |
#define  | K_F21   K(KT_FN,30) |
#define  | K_F22   K(KT_FN,31) |
#define  | K_F23   K(KT_FN,32) |
#define  | K_F24   K(KT_FN,33) |
#define  | K_F25   K(KT_FN,34) |
#define  | K_F26   K(KT_FN,35) |
#define  | K_F27   K(KT_FN,36) |
#define  | K_F28   K(KT_FN,37) |
#define  | K_F29   K(KT_FN,38) |
#define  | K_F30   K(KT_FN,39) |
#define  | K_F31   K(KT_FN,40) |
#define  | K_F32   K(KT_FN,41) |
#define  | K_F33   K(KT_FN,42) |
#define  | K_F34   K(KT_FN,43) |
#define  | K_F35   K(KT_FN,44) |
#define  | K_F36   K(KT_FN,45) |
#define  | K_F37   K(KT_FN,46) |
#define  | K_F38   K(KT_FN,47) |
#define  | K_F39   K(KT_FN,48) |
#define  | K_F40   K(KT_FN,49) |
#define  | K_F41   K(KT_FN,50) |
#define  | K_F42   K(KT_FN,51) |
#define  | K_F43   K(KT_FN,52) |
#define  | K_F44   K(KT_FN,53) |
#define  | K_F45   K(KT_FN,54) |
#define  | K_F46   K(KT_FN,55) |
#define  | K_F47   K(KT_FN,56) |
#define  | K_F48   K(KT_FN,57) |
#define  | K_F49   K(KT_FN,58) |
#define  | K_F50   K(KT_FN,59) |
#define  | K_F51   K(KT_FN,60) |
#define  | K_F52   K(KT_FN,61) |
#define  | K_F53   K(KT_FN,62) |
#define  | K_F54   K(KT_FN,63) |
#define  | K_F55   K(KT_FN,64) |
#define  | K_F56   K(KT_FN,65) |
#define  | K_F57   K(KT_FN,66) |
#define  | K_F58   K(KT_FN,67) |
#define  | K_F59   K(KT_FN,68) |
#define  | K_F60   K(KT_FN,69) |
#define  | K_F61   K(KT_FN,70) |
#define  | K_F62   K(KT_FN,71) |
#define  | K_F63   K(KT_FN,72) |
#define  | K_F64   K(KT_FN,73) |
#define  | K_F65   K(KT_FN,74) |
#define  | K_F66   K(KT_FN,75) |
#define  | K_F67   K(KT_FN,76) |
#define  | K_F68   K(KT_FN,77) |
#define  | K_F69   K(KT_FN,78) |
#define  | K_F70   K(KT_FN,79) |
#define  | K_F71   K(KT_FN,80) |
#define  | K_F72   K(KT_FN,81) |
#define  | K_F73   K(KT_FN,82) |
#define  | K_F74   K(KT_FN,83) |
#define  | K_F75   K(KT_FN,84) |
#define  | K_F76   K(KT_FN,85) |
#define  | K_F77   K(KT_FN,86) |
#define  | K_F78   K(KT_FN,87) |
#define  | K_F79   K(KT_FN,88) |
#define  | K_F80   K(KT_FN,89) |
#define  | K_F81   K(KT_FN,90) |
#define  | K_F82   K(KT_FN,91) |
#define  | K_F83   K(KT_FN,92) |
#define  | K_F84   K(KT_FN,93) |
#define  | K_F85   K(KT_FN,94) |
#define  | K_F86   K(KT_FN,95) |
#define  | K_F87   K(KT_FN,96) |
#define  | K_F88   K(KT_FN,97) |
#define  | K_F89   K(KT_FN,98) |
#define  | K_F90   K(KT_FN,99) |
#define  | K_F91   K(KT_FN,100) |
#define  | K_F92   K(KT_FN,101) |
#define  | K_F93   K(KT_FN,102) |
#define  | K_F94   K(KT_FN,103) |
#define  | K_F95   K(KT_FN,104) |
#define  | K_F96   K(KT_FN,105) |
#define  | K_F97   K(KT_FN,106) |
#define  | K_F98   K(KT_FN,107) |
#define  | K_F99   K(KT_FN,108) |
#define  | K_F100   K(KT_FN,109) |
#define  | K_F101   K(KT_FN,110) |
#define  | K_F102   K(KT_FN,111) |
#define  | K_F103   K(KT_FN,112) |
#define  | K_F104   K(KT_FN,113) |
#define  | K_F105   K(KT_FN,114) |
#define  | K_F106   K(KT_FN,115) |
#define  | K_F107   K(KT_FN,116) |
#define  | K_F108   K(KT_FN,117) |
#define  | K_F109   K(KT_FN,118) |
#define  | K_F110   K(KT_FN,119) |
#define  | K_F111   K(KT_FN,120) |
#define  | K_F112   K(KT_FN,121) |
#define  | K_F113   K(KT_FN,122) |
#define  | K_F114   K(KT_FN,123) |
#define  | K_F115   K(KT_FN,124) |
#define  | K_F116   K(KT_FN,125) |
#define  | K_F117   K(KT_FN,126) |
#define  | K_F118   K(KT_FN,127) |
#define  | K_F119   K(KT_FN,128) |
#define  | K_F120   K(KT_FN,129) |
#define  | K_F121   K(KT_FN,130) |
#define  | K_F122   K(KT_FN,131) |
#define  | K_F123   K(KT_FN,132) |
#define  | K_F124   K(KT_FN,133) |
#define  | K_F125   K(KT_FN,134) |
#define  | K_F126   K(KT_FN,135) |
#define  | K_F127   K(KT_FN,136) |
#define  | K_F128   K(KT_FN,137) |
#define  | K_F129   K(KT_FN,138) |
#define  | K_F130   K(KT_FN,139) |
#define  | K_F131   K(KT_FN,140) |
#define  | K_F132   K(KT_FN,141) |
#define  | K_F133   K(KT_FN,142) |
#define  | K_F134   K(KT_FN,143) |
#define  | K_F135   K(KT_FN,144) |
#define  | K_F136   K(KT_FN,145) |
#define  | K_F137   K(KT_FN,146) |
#define  | K_F138   K(KT_FN,147) |
#define  | K_F139   K(KT_FN,148) |
#define  | K_F140   K(KT_FN,149) |
#define  | K_F141   K(KT_FN,150) |
#define  | K_F142   K(KT_FN,151) |
#define  | K_F143   K(KT_FN,152) |
#define  | K_F144   K(KT_FN,153) |
#define  | K_F145   K(KT_FN,154) |
#define  | K_F146   K(KT_FN,155) |
#define  | K_F147   K(KT_FN,156) |
#define  | K_F148   K(KT_FN,157) |
#define  | K_F149   K(KT_FN,158) |
#define  | K_F150   K(KT_FN,159) |
#define  | K_F151   K(KT_FN,160) |
#define  | K_F152   K(KT_FN,161) |
#define  | K_F153   K(KT_FN,162) |
#define  | K_F154   K(KT_FN,163) |
#define  | K_F155   K(KT_FN,164) |
#define  | K_F156   K(KT_FN,165) |
#define  | K_F157   K(KT_FN,166) |
#define  | K_F158   K(KT_FN,167) |
#define  | K_F159   K(KT_FN,168) |
#define  | K_F160   K(KT_FN,169) |
#define  | K_F161   K(KT_FN,170) |
#define  | K_F162   K(KT_FN,171) |
#define  | K_F163   K(KT_FN,172) |
#define  | K_F164   K(KT_FN,173) |
#define  | K_F165   K(KT_FN,174) |
#define  | K_F166   K(KT_FN,175) |
#define  | K_F167   K(KT_FN,176) |
#define  | K_F168   K(KT_FN,177) |
#define  | K_F169   K(KT_FN,178) |
#define  | K_F170   K(KT_FN,179) |
#define  | K_F171   K(KT_FN,180) |
#define  | K_F172   K(KT_FN,181) |
#define  | K_F173   K(KT_FN,182) |
#define  | K_F174   K(KT_FN,183) |
#define  | K_F175   K(KT_FN,184) |
#define  | K_F176   K(KT_FN,185) |
#define  | K_F177   K(KT_FN,186) |
#define  | K_F178   K(KT_FN,187) |
#define  | K_F179   K(KT_FN,188) |
#define  | K_F180   K(KT_FN,189) |
#define  | K_F181   K(KT_FN,190) |
#define  | K_F182   K(KT_FN,191) |
#define  | K_F183   K(KT_FN,192) |
#define  | K_F184   K(KT_FN,193) |
#define  | K_F185   K(KT_FN,194) |
#define  | K_F186   K(KT_FN,195) |
#define  | K_F187   K(KT_FN,196) |
#define  | K_F188   K(KT_FN,197) |
#define  | K_F189   K(KT_FN,198) |
#define  | K_F190   K(KT_FN,199) |
#define  | K_F191   K(KT_FN,200) |
#define  | K_F192   K(KT_FN,201) |
#define  | K_F193   K(KT_FN,202) |
#define  | K_F194   K(KT_FN,203) |
#define  | K_F195   K(KT_FN,204) |
#define  | K_F196   K(KT_FN,205) |
#define  | K_F197   K(KT_FN,206) |
#define  | K_F198   K(KT_FN,207) |
#define  | K_F199   K(KT_FN,208) |
#define  | K_F200   K(KT_FN,209) |
#define  | K_F201   K(KT_FN,210) |
#define  | K_F202   K(KT_FN,211) |
#define  | K_F203   K(KT_FN,212) |
#define  | K_F204   K(KT_FN,213) |
#define  | K_F205   K(KT_FN,214) |
#define  | K_F206   K(KT_FN,215) |
#define  | K_F207   K(KT_FN,216) |
#define  | K_F208   K(KT_FN,217) |
#define  | K_F209   K(KT_FN,218) |
#define  | K_F210   K(KT_FN,219) |
#define  | K_F211   K(KT_FN,220) |
#define  | K_F212   K(KT_FN,221) |
#define  | K_F213   K(KT_FN,222) |
#define  | K_F214   K(KT_FN,223) |
#define  | K_F215   K(KT_FN,224) |
#define  | K_F216   K(KT_FN,225) |
#define  | K_F217   K(KT_FN,226) |
#define  | K_F218   K(KT_FN,227) |
#define  | K_F219   K(KT_FN,228) |
#define  | K_F220   K(KT_FN,229) |
#define  | K_F221   K(KT_FN,230) |
#define  | K_F222   K(KT_FN,231) |
#define  | K_F223   K(KT_FN,232) |
#define  | K_F224   K(KT_FN,233) |
#define  | K_F225   K(KT_FN,234) |
#define  | K_F226   K(KT_FN,235) |
#define  | K_F227   K(KT_FN,236) |
#define  | K_F228   K(KT_FN,237) |
#define  | K_F229   K(KT_FN,238) |
#define  | K_F230   K(KT_FN,239) |
#define  | K_F231   K(KT_FN,240) |
#define  | K_F232   K(KT_FN,241) |
#define  | K_F233   K(KT_FN,242) |
#define  | K_F234   K(KT_FN,243) |
#define  | K_F235   K(KT_FN,244) |
#define  | K_F236   K(KT_FN,245) |
#define  | K_F237   K(KT_FN,246) |
#define  | K_F238   K(KT_FN,247) |
#define  | K_F239   K(KT_FN,248) |
#define  | K_F240   K(KT_FN,249) |
#define  | K_F241   K(KT_FN,250) |
#define  | K_F242   K(KT_FN,251) |
#define  | K_F243   K(KT_FN,252) |
#define  | K_F244   K(KT_FN,253) |
#define  | K_F245   K(KT_FN,254) |
#define  | K_UNDO   K(KT_FN,255) |
#define  | K_HOLE   K(KT_SPEC,0) |
#define  | K_ENTER   K(KT_SPEC,1) |
#define  | K_SH_REGS   K(KT_SPEC,2) |
#define  | K_SH_MEM   K(KT_SPEC,3) |
#define  | K_SH_STAT   K(KT_SPEC,4) |
#define  | K_BREAK   K(KT_SPEC,5) |
#define  | K_CONS   K(KT_SPEC,6) |
#define  | K_CAPS   K(KT_SPEC,7) |
#define  | K_NUM   K(KT_SPEC,8) |
#define  | K_HOLD   K(KT_SPEC,9) |
#define  | K_SCROLLFORW   K(KT_SPEC,10) |
#define  | K_SCROLLBACK   K(KT_SPEC,11) |
#define  | K_BOOT   K(KT_SPEC,12) |
#define  | K_CAPSON   K(KT_SPEC,13) |
#define  | K_COMPOSE   K(KT_SPEC,14) |
#define  | K_SAK   K(KT_SPEC,15) |
#define  | K_DECRCONSOLE   K(KT_SPEC,16) |
#define  | K_INCRCONSOLE   K(KT_SPEC,17) |
#define  | K_SPAWNCONSOLE   K(KT_SPEC,18) |
#define  | K_BARENUMLOCK   K(KT_SPEC,19) |
#define  | K_ALLOCATED   K(KT_SPEC,126) /* dynamically allocated keymap */ |
#define  | K_NOSUCHMAP   K(KT_SPEC,127) /* returned by KDGKBENT */ |
#define  | K_P0   K(KT_PAD,0) |
#define  | K_P1   K(KT_PAD,1) |
#define  | K_P2   K(KT_PAD,2) |
#define  | K_P3   K(KT_PAD,3) |
#define  | K_P4   K(KT_PAD,4) |
#define  | K_P5   K(KT_PAD,5) |
#define  | K_P6   K(KT_PAD,6) |
#define  | K_P7   K(KT_PAD,7) |
#define  | K_P8   K(KT_PAD,8) |
#define  | K_P9   K(KT_PAD,9) |
#define  | K_PPLUS   K(KT_PAD,10)	/* key-pad plus */ |
#define  | K_PMINUS   K(KT_PAD,11)	/* key-pad minus */ |
#define  | K_PSTAR   K(KT_PAD,12)	/* key-pad asterisk (star) */ |
#define  | K_PSLASH   K(KT_PAD,13)	/* key-pad slash */ |
#define  | K_PENTER   K(KT_PAD,14)	/* key-pad enter */ |
#define  | K_PCOMMA   K(KT_PAD,15)	/* key-pad comma: kludge... */ |
#define  | K_PDOT   K(KT_PAD,16)	/* key-pad dot (period): kludge... */ |
#define  | K_PPLUSMINUS   K(KT_PAD,17)	/* key-pad plus/minus */ |
#define  | K_PPARENL   K(KT_PAD,18)	/* key-pad left parenthesis */ |
#define  | K_PPARENR   K(KT_PAD,19)	/* key-pad right parenthesis */ |
#define  | NR_PAD   20 |
#define  | K_DGRAVE   K(KT_DEAD,0) |
#define  | K_DACUTE   K(KT_DEAD,1) |
#define  | K_DCIRCM   K(KT_DEAD,2) |
#define  | K_DTILDE   K(KT_DEAD,3) |
#define  | K_DDIERE   K(KT_DEAD,4) |
#define  | K_DCEDIL   K(KT_DEAD,5) |
#define  | NR_DEAD   6 |
#define  | K_DOWN   K(KT_CUR,0) |
#define  | K_LEFT   K(KT_CUR,1) |
#define  | K_RIGHT   K(KT_CUR,2) |
#define  | K_UP   K(KT_CUR,3) |
#define  | K_SHIFT   K(KT_SHIFT,KG_SHIFT) |
#define  | K_CTRL   K(KT_SHIFT,KG_CTRL) |
#define  | K_ALT   K(KT_SHIFT,KG_ALT) |
#define  | K_ALTGR   K(KT_SHIFT,KG_ALTGR) |
#define  | K_SHIFTL   K(KT_SHIFT,KG_SHIFTL) |
#define  | K_SHIFTR   K(KT_SHIFT,KG_SHIFTR) |
#define  | K_CTRLL   K(KT_SHIFT,KG_CTRLL) |
#define  | K_CTRLR   K(KT_SHIFT,KG_CTRLR) |
#define  | K_CAPSSHIFT   K(KT_SHIFT,KG_CAPSSHIFT) |
#define  | K_ASC0   K(KT_ASCII,0) |
#define  | K_ASC1   K(KT_ASCII,1) |
#define  | K_ASC2   K(KT_ASCII,2) |
#define  | K_ASC3   K(KT_ASCII,3) |
#define  | K_ASC4   K(KT_ASCII,4) |
#define  | K_ASC5   K(KT_ASCII,5) |
#define  | K_ASC6   K(KT_ASCII,6) |
#define  | K_ASC7   K(KT_ASCII,7) |
#define  | K_ASC8   K(KT_ASCII,8) |
#define  | K_ASC9   K(KT_ASCII,9) |
#define  | K_HEX0   K(KT_ASCII,10) |
#define  | K_HEX1   K(KT_ASCII,11) |
#define  | K_HEX2   K(KT_ASCII,12) |
#define  | K_HEX3   K(KT_ASCII,13) |
#define  | K_HEX4   K(KT_ASCII,14) |
#define  | K_HEX5   K(KT_ASCII,15) |
#define  | K_HEX6   K(KT_ASCII,16) |
#define  | K_HEX7   K(KT_ASCII,17) |
#define  | K_HEX8   K(KT_ASCII,18) |
#define  | K_HEX9   K(KT_ASCII,19) |
#define  | K_HEXa   K(KT_ASCII,20) |
#define  | K_HEXb   K(KT_ASCII,21) |
#define  | K_HEXc   K(KT_ASCII,22) |
#define  | K_HEXd   K(KT_ASCII,23) |
#define  | K_HEXe   K(KT_ASCII,24) |
#define  | K_HEXf   K(KT_ASCII,25) |
#define  | NR_ASCII   26 |
#define  | K_SHIFTLOCK   K(KT_LOCK,KG_SHIFT) |
#define  | K_CTRLLOCK   K(KT_LOCK,KG_CTRL) |
#define  | K_ALTLOCK   K(KT_LOCK,KG_ALT) |
#define  | K_ALTGRLOCK   K(KT_LOCK,KG_ALTGR) |
#define  | K_SHIFTLLOCK   K(KT_LOCK,KG_SHIFTL) |
#define  | K_SHIFTRLOCK   K(KT_LOCK,KG_SHIFTR) |
#define  | K_CTRLLLOCK   K(KT_LOCK,KG_CTRLL) |
#define  | K_CTRLRLOCK   K(KT_LOCK,KG_CTRLR) |
#define  | K_SHIFT_SLOCK   K(KT_SLOCK,KG_SHIFT) |
#define  | K_CTRL_SLOCK   K(KT_SLOCK,KG_CTRL) |
#define  | K_ALT_SLOCK   K(KT_SLOCK,KG_ALT) |
#define  | K_ALTGR_SLOCK   K(KT_SLOCK,KG_ALTGR) |
#define  | K_SHIFTL_SLOCK   K(KT_SLOCK,KG_SHIFTL) |
#define  | K_SHIFTR_SLOCK   K(KT_SLOCK,KG_SHIFTR) |
#define  | K_CTRLL_SLOCK   K(KT_SLOCK,KG_CTRLL) |
#define  | K_CTRLR_SLOCK   K(KT_SLOCK,KG_CTRLR) |
#define  | NR_LOCK   8 |
#define  | MAX_DIACR   256 |
#define  | VC_SHIFTLOCK   KG_SHIFT	/* shift lock mode */ |
#define  | VC_ALTGRLOCK   KG_ALTGR	/* altgr lock mode */ |
#define  | VC_CTRLLOCK   KG_CTRL 	/* control lock mode */ |
#define  | VC_ALTLOCK   KG_ALT  	/* alt lock mode */ |
#define  | VC_SHIFTLLOCK   KG_SHIFTL	/* shiftl lock mode */ |
#define  | VC_SHIFTRLOCK   KG_SHIFTR	/* shiftr lock mode */ |
#define  | VC_CTRLLLOCK   KG_CTRLL 	/* ctrll lock mode */ |
#define  | VC_CTRLRLOCK   KG_CTRLR 	/* ctrlr lock mode */ |
#define  | LED_SHOW_FLAGS   0        /* traditional state */ |
#define  | LED_SHOW_IOCTL   1        /* only change leds upon ioctl */ |
#define  | LED_SHOW_MEM   2          /* `heartbeat': peek into memory */ |
#define  | VC_SCROLLOCK   0	/* scroll-lock mode */ |
#define  | VC_NUMLOCK   1	/* numeric lock mode */ |
#define  | VC_CAPSLOCK   2	/* capslock mode */ |
#define  | VC_XLATE   0	/* translate keycodes using keymap */ |
#define  | VC_MEDIUMRAW   1	/* medium raw (keycode) mode */ |
#define  | VC_RAW   2	/* raw (scancode) mode */ |
#define  | VC_UNICODE   3	/* Unicode mode */ |
#define  | VC_APPLIC   0	/* application key mode */ |
#define  | VC_CKMODE   1	/* cursor key mode */ |
#define  | VC_REPEAT   2	/* keyboard repeat */ |
#define  | VC_CRLF   3	/* 0 - enter sends CR, 1 - enter sends CRLF */ |
#define  | VC_META   4	/* 0 - meta, 1 - meta=prefix with ESC */ |
#define  | U(x)   ((x) ^ 0xf000) |
