28 void BSP_uart_init(
int uart,
unsigned long baud,
unsigned long databits,
unsigned long parity,
unsigned long stopbits,
int hwFlow);
    29 void BSP_uart_set_attributes(
int uart,
unsigned long baud,
unsigned long stopbits);
    30 void BSP_uart_set_baud(
int uart,
unsigned long baud);
    31 void BSP_uart_intr_ctrl(
int uart,
int cmd);
    32 void BSP_uart_throttle(
int uart);
    33 void BSP_uart_unthrottle(
int uart);
    34 int  BSP_uart_polled_status(
int uart);
    35 void BSP_uart_polled_write(
int uart,
int val);
    36 int  BSP_uart_polled_read(
int uart);
    37 void BSP_uart_termios_set(
int uart,
void *ttyp);
    38 int  BSP_uart_termios_read_com1(
int uart);
    39 int  BSP_uart_termios_read_com2(
int uart);
    40 ssize_t BSP_uart_termios_write_com1(
int minor,
const char *buf,
size_t len);
    41 ssize_t BSP_uart_termios_write_com2(
int minor,
const char *buf,
size_t len);
    42 void BSP_uart_termios_isr_com1(
void *);
    43 void BSP_uart_termios_isr_com2(
void *);
    44 void BSP_uart_dbgisr_com1(
void);
    45 void BSP_uart_dbgisr_com2(
void);
    46 extern int BSP_poll_char_via_serial(
void);
    47 extern void BSP_output_char_via_serial(
char val);
    48 extern int BSPConsolePort;
    49 extern int BSPBaseBaud;
    56 #define BSP_UART_INTR_CTRL_DISABLE  (0)    57 #define BSP_UART_INTR_CTRL_GDB      (0xaa)     58 #define BSP_UART_INTR_CTRL_ENABLE   (0xbb)     59 #define BSP_UART_INTR_CTRL_TERMIOS  (0xcc)     62 #define BSP_UART_STATUS_ERROR    (-1)     63 #define BSP_UART_STATUS_NOCHAR   (0)      64 #define BSP_UART_STATUS_CHAR     (1)      65 #define BSP_UART_STATUS_BREAK    (2)      68 #define BSP_UART_COM1            (0)    69 #define BSP_UART_COM2            (1)    75 #define COM1_BASE_IO    0x3F8    76 #define COM2_BASE_IO    0x2F8   104 #define MODEM_STATUS                0   105 #define NO_MORE_INTR                1   106 #define TRANSMITTER_HODING_REGISTER_EMPTY   2   107 #define RECEIVER_DATA_AVAIL         4   108 #define RECEIVER_ERROR              6   109 #define CHARACTER_TIMEOUT_INDICATION        12   114 #define RECEIVE_ENABLE      0x1   115 #define TRANSMIT_ENABLE     0x2   116 #define RECEIVER_LINE_ST_ENABLE 0x4   117 #define MODEM_ENABLE        0x8   118 #define INTERRUPT_DISABLE   0x0   173 #define FIFO_CTRL   0x01       175 #define XMIT_RESET  0x02       176 #define RCV_RESET   0x04       179 #define RECEIVE_FIFO_TRIGGER1   0x0     180 #define RECEIVE_FIFO_TRIGGER4   0x40    181 #define RECEIVE_FIFO_TRIGGER8   0x80    182 #define RECEIVE_FIFO_TRIGGER12  0xc0    183 #define TRIG_LEVEL          0xc0
