    RTEMS
    5.1
Go to the documentation of this file.   19 #ifndef _RTEMS_SCORE_REGISTERS_H    20 #define _RTEMS_SCORE_REGISTERS_H    25 #define EFLAGS_CARRY            0x1    26 #define EFLAGS_PARITY           0x4    28 #define EFLAGS_AUX_CARRY        0x10    29 #define EFLAGS_ZERO         0x40    30 #define EFLAGS_SIGN         0x80    32 #define EFLAGS_TRAP         0x100    33 #define EFLAGS_INTR_ENABLE      0x200    34 #define EFLAGS_DIRECTION        0x400    35 #define EFLAGS_OVERFLOW         0x800    37 #define EFLAGS_IOPL_MASK        0x3000    38 #define EFLAGS_NESTED_TASK      0x8000    40 #define EFLAGS_RESUME           0x10000    41 #define EFLAGS_VIRTUAL_MODE     0x20000    42 #define EFLAGS_ALIGN_CHECK      0x40000    43 #define EFLAGS_VIRTUAL_INTR     0x80000    45 #define EFLAGS_VIRTUAL_INTR_PEND    0x100000    46 #define EFLAGS_ID           0x200000    51 #define CR0_PROTECTION_ENABLE       0x1    52 #define CR0_MONITOR_COPROC      0x2    53 #define CR0_COPROC_SOFT_EMUL        0x4    54 #define CR0_FLOATING_INSTR_EXCEPTION    0x8    56 #define CR0_EXTENSION_TYPE      0x10    57 #define CR0_NUMERIC_ERROR       0x20    59 #define CR0_WRITE_PROTECT       0x10000    60 #define CR0_ALIGMENT_MASK       0x40000    62 #define CR0_NO_WRITE_THROUGH        0x20000000    63 #define CR0_PAGE_LEVEL_CACHE_DISABLE    0x40000000    64 #define CR0_PAGING          0x80000000    70 #define CR3_PAGE_CACHE_DISABLE      0x10    71 #define CR3_PAGE_WRITE_THROUGH      0x8    72 #define CR3_PAGE_DIRECTORY_MASK     0xFFFFF000
