#define  | LM32_TSMAC_RX_LEN_FIFO   (0x000) |
#define  | LM32_TSMAC_RX_DATA_FIFO   (0x004) |
#define  | LM32_TSMAC_TX_LEN_FIFO   (0x008) |
#define  | LM32_TSMAC_TX_DATA_FIFO   (0x00C) |
#define  | LM32_TSMAC_VERID   (0x100) |
#define  | LM32_TSMAC_INTR_SRC   (0x104) |
#define  | INTR_RX_SMRY   (0x00020000) |
#define  | INTR_TX_SMRY   (0x00010000) |
#define  | INTR_RX_FIFO_FULL   (0x00001000) |
#define  | INTR_RX_ERROR   (0x00000800) |
#define  | INTR_RX_FIFO_ERROR   (0x00000400) |
#define  | INTR_RX_FIFO_ALMOST_FULL   (0x00000200) |
#define  | INTR_RX_PKT_RDY   (0x00000100) |
#define  | INTR_TX_FIFO_FULL   (0x00000010) |
#define  | INTR_TX_DISCFRM   (0x00000008) |
#define  | INTR_TX_FIFO_ALMOST_EMPTY   (0x00000004) |
#define  | INTR_TX_FIFO_ALMOST_FULL   (0x00000002) |
#define  | INTR_TX_PKT_SENT   (0x00000001) |
#define  | LM32_TSMAC_INTR_ENB   (0x108) |
#define  | INTR_ENB   (0x00040000) |
#define  | LM32_TSMAC_RX_STATUS   (0x10C) |
#define  | STAT_RX_FIFO_FULL   (0x00000010) |
#define  | STAT_RX_ERROR   (0x00000008) |
#define  | STAT_RX_FIFO_ERROR   (0x00000004) |
#define  | STAT_RX_FIFO_ALMOST_FULL   (0x00000002) |
#define  | STAT_RX_PKT_RDY   (0x00000001) |
#define  | LM32_TSMAC_TX_STATUS   (0x110) |
#define  | STAT_TX_FIFO_FULL   (0x00000010) |
#define  | STAT_TX_DISCFRM   (0x00000008) |
#define  | STAT_TX_FIFO_ALMOST_EMPTY   (0x00000004) |
#define  | STAT_TX_FIFO_ALMOST_FULL   (0x00000002) |
#define  | STAT_TX_PKT_SENT   (0x00000001) |
#define  | LM32_TSMAC_RX_FRAMES_CNT   (0x114) |
#define  | LM32_TSMAC_TX_FRAMES_CNT   (0x118) |
#define  | LM32_TSMAC_RX_FIFO_TH   (0x11C) |
#define  | LM32_TSMAC_TX_FIFO_TH   (0x120) |
#define  | LM32_TSMAC_SYS_CTL   (0x124) |
#define  | SYS_CTL_TX_FIFO_FLUSH   (0x00000010) |
#define  | SYS_CTL_RX_FIFO_FLUSH   (0x00000008) |
#define  | SYS_CTL_TX_SNDPAUSREQ   (0x00000004) |
#define  | SYS_CTL_TX_FIFOCTRL   (0x00000002) |
#define  | SYS_CTL_IGNORE_NEXT_PKT   (0x00000001) |
#define  | LM32_TSMAC_PAUSE_TMR   (0x128) |
#define  | LM32_TSMAC_MAC_REGS_DATA   (0x200) |
#define  | LM32_TSMAC_MAC_REGS_ADDR_RW   (0x204) |
#define  | REGS_ADDR_WRITE   (0x80000000) |
#define  | LM32_TSMAC_MODE_BYTE0   (0x000) |
#define  | MODE_TX_EN   (1<<3) |
#define  | MODE_RX_EN   (1<<2) |
#define  | MODE_FC_EN   (1<<1) |
#define  | MODE_GBIT_EN   (1<<0) |
#define  | LM32_TSMAC_TX_RX_CTL_BYTE0   (0x002) |
#define  | TX_RX_CTL_RECEIVE_SHORT   (1<<8) |
#define  | TX_RX_CTL_RECEIVE_BRDCST   (1<<7) |
#define  | TX_RX_CTL_DIS_RTRY   (1<<6) |
#define  | TX_RX_CTL_HDEN   (1<<5) |
#define  | TX_RX_CTL_RECEIVE_MLTCST   (1<<4) |
#define  | TX_RX_CTL_RECEIVE_PAUSE   (1<<3) |
#define  | TX_RX_CTL_TX_DIS_FCS   (1<<2) |
#define  | TX_RX_CTL_DISCARD_FCS   (1<<1) |
#define  | TX_RX_CTL_PRMS   (1<<0) |
#define  | LM32_TSMAC_MAX_PKT_SIZE_BYTE0   (0x004) |
#define  | LM32_TSMAC_IPG_VAL_BYTE0   (0x008) |
#define  | LM32_TSMAC_MAC_ADDR_0_BYTE0   (0x00A) |
#define  | LM32_TSMAC_MAC_ADDR_1_BYTE0   (0x00C) |
#define  | LM32_TSMAC_MAC_ADDR_2_BYTE0   (0x00E) |
#define  | LM32_TSMAC_TX_RX_STS_BYTE0   (0x012) |
#define  | TX_RX_STS_RX_IDLE   (1<<10) |
#define  | TX_RX_STS_TAGGED_FRAME   (1<<9) |
#define  | TX_RX_STS_BRDCST_FRAME   (1<<8) |
#define  | TX_RX_STS_MULTCST_FRAME   (1<<7) |
#define  | TX_RX_STS_IPG_SHRINK   (1<<6) |
#define  | TX_RX_STS_SHORT_FRAME   (1<<5) |
#define  | TX_RX_STS_LONG_FRAME   (1<<4) |
#define  | TX_RX_STS_ERROR_FRAME   (1<<3) |
#define  | TX_RX_STS_CRC   (1<<2) |
#define  | TX_RX_STS_PAUSE_FRAME   (1<<1) |
#define  | TX_RX_STS_TX_IDLE   (1<<0) |
#define  | LM32_TSMAC_GMII_MNG_CTL_BYTE0   (0x014) |
#define  | GMII_MNG_CTL_CMD_FIN   (1<<14) |
#define  | GMII_MNG_CTL_READ_PHYREG   (0) |
#define  | GMII_MNG_CTL_WRITE_PHYREG   (1<<13) |
#define  | GMII_MNG_CTL_PHY_ADD_MASK   (0x001f) |
#define  | GMII_MNG_CTL_PHY_ADD_SHIFT   (8) |
#define  | GMII_MNG_CTL_REG_ADD_MASK   (0x001f) |
#define  | GMII_MNG_CTL_REG_ADD_SHIFT   (0) |
#define  | LM32_TSMAC_GMII_MNG_DAT_BYTE0   (0x016) |
#define  | LM32_TSMAC_MLT_TAB_0_BYTE0   (0x022) |
#define  | LM32_TSMAC_MLT_TAB_1_BYTE0   (0x024) |
#define  | LM32_TSMAC_MLT_TAB_2_BYTE0   (0x026) |
#define  | LM32_TSMAC_MLT_TAB_3_BYTE0   (0x028) |
#define  | LM32_TSMAC_MLT_TAB_4_BYTE0   (0x02A) |
#define  | LM32_TSMAC_MLT_TAB_5_BYTE0   (0x02C) |
#define  | LM32_TSMAC_MLT_TAB_6_BYTE0   (0x02E) |
#define  | LM32_TSMAC_MLT_TAB_7_BYTE0   (0x030) |
#define  | LM32_TSMAC_VLAN_TAG_BYTE0   (0x032) |
#define  | LM32_TSMAC_PAUS_OP_BYTE0   (0x034) |
#define  | LM32_TSMAC_RX_PKT_IGNR_CNT   (0x300) |
#define  | LM32_TSMAC_RX_LEN_CHK_ERR_CNT   (0x304) |
#define  | LM32_TSMAC_RX_LNG_FRM_CNT   (0x308) |
#define  | LM32_TSMAC_RX_SHRT_FRM_CNT   (0x30C) |
#define  | LM32_TSMAC_RX_IPG_VIOL_CNT   (0x310) |
#define  | LM32_TSMAC_RX_CRC_ERR_CNT   (0x314) |
#define  | LM32_TSMAC_RX_OK_PKT_CNT   (0x318) |
#define  | LM32_TSMAC_RX_CTL_FRM_CNT   (0x31C) |
#define  | LM32_TSMAC_RX_PAUSE_FRM_CNT   (0x320) |
#define  | LM32_TSMAC_RX_MULTICAST_CNT   (0x324) |
#define  | LM32_TSMAC_RX_BRDCAST_CNT   (0x328) |
#define  | LM32_TSMAC_RX_VLAN_TAG_CNT   (0x32C) |
#define  | LM32_TSMAC_RX_PRE_SHRINK_CNT   (0x330) |
#define  | LM32_TSMAC_RX_DRIB_NIB_CNT   (0x334) |
#define  | LM32_TSMAC_RX_UNSUP_OPCD_CNT   (0x338) |
#define  | LM32_TSMAC_RX_BYTE_CNT   (0x33C) |
#define  | LM32_TSMAC_TX_UNICAST_CNT   (0x400) |
#define  | LM32_TSMAC_TX_PAUSE_FRM_CNT   (0x404) |
#define  | LM32_TSMAC_TX_MULTICAST_CNT   (0x408) |
#define  | LM32_TSMAC_TX_BRDCAST_CNT   (0x40C) |
#define  | LM32_TSMAC_TX_VLAN_TAG_CNT   (0x410) |
#define  | LM32_TSMAC_TX_BAD_FCS_CNT   (0x414) |
#define  | LM32_TSMAC_TX_JUMBO_CNT   (0x418) |
#define  | LM32_TSMAC_TX_BYTE_CNT   (0x41C) |
LatticeMico32 TSMAC (Tri-Speed MAC) definitions.
