Macros used for grcan controller.
More...
| file   | grcan.h |
| file   | occan.h |
|   | Gaisler wrapper to OpenCores CAN - driver interface.
#define  | GRCAN_CFG_ABORT   0x00000001 |
#define  | GRCAN_CFG_ENABLE0   0x00000002 |
#define  | GRCAN_CFG_ENABLE1   0x00000004 |
#define  | GRCAN_CFG_SELECTION   0x00000008 |
#define  | GRCAN_CFG_SILENT   0x00000010 |
#define  | GRCAN_CFG_BPR   0x00000300 |
#define  | GRCAN_CFG_RSJ   0x00007000 |
#define  | GRCAN_CFG_PS1   0x00f00000 |
#define  | GRCAN_CFG_PS2   0x000f0000 |
#define  | GRCAN_CFG_SCALER   0xff000000 |
#define  | GRCAN_CFG_BPR_BIT   8 |
#define  | GRCAN_CFG_RSJ_BIT   12 |
#define  | GRCAN_CFG_PS1_BIT   20 |
#define  | GRCAN_CFG_PS2_BIT   16 |
#define  | GRCAN_CFG_SCALER_BIT   24 |
#define  | GRCAN_CTRL_RESET   0x2 |
#define  | GRCAN_CTRL_ENABLE   0x1 |
#define  | GRCAN_TXCTRL_ENABLE   1 |
#define  | GRCAN_TXCTRL_ONGOING   1 |
#define  | GRCAN_RXCTRL_ENABLE   1 |
#define  | GRCAN_RXCTRL_ONGOING   1 |
#define  | GRCAN_IRQ_IRQ   0 |
#define  | GRCAN_IRQ_TXSYNC   1 |
#define  | GRCAN_IRQ_RXSYNC   2 |
#define  | GRCAN_ERR_IRQ   0x1 |
#define  | GRCAN_OFF_IRQ   0x2 |
#define  | GRCAN_OR_IRQ   0x4 |
#define  | GRCAN_RXAHBERR_IRQ   0x8 |
#define  | GRCAN_TXAHBERR_IRQ   0x10 |
#define  | GRCAN_RXIRQ_IRQ   0x20 |
#define  | GRCAN_TXIRQ_IRQ   0x40 |
#define  | GRCAN_RXFULL_IRQ   0x80 |
#define  | GRCAN_TXEMPTY_IRQ   0x100 |
#define  | GRCAN_RX_IRQ   0x200 |
#define  | GRCAN_TX_IRQ   0x400 |
#define  | GRCAN_RXSYNC_IRQ   0x800 |
#define  | GRCAN_TXSYNC_IRQ   0x1000 |
#define  | GRCAN_RXERR_IRQ   0x2000 |
#define  | GRCAN_TXERR_IRQ   0x4000 |
#define  | GRCAN_RXMISS_IRQ   0x8000 |
#define  | GRCAN_TXLOSS_IRQ   0x10000 |
#define  | GRCAN_STAT_PASS   0x1 |
#define  | GRCAN_STAT_OFF   0x2 |
#define  | GRCAN_STAT_OR   0x4 |
#define  | GRCAN_STAT_AHBERR   0x8 |
#define  | GRCAN_STAT_ACTIVE   0x10 |
#define  | GRCAN_STAT_RXERRCNT   0xff00 |
#define  | GRCAN_STAT_TXERRCNT   0xff0000 |
| enum   | {
  GRCAN_RET_OK = 0,
GRCAN_RET_INVARG = -1,
GRCAN_RET_NOTSTARTED = -2,
GRCAN_RET_TIMEOUT = -3,
  GRCAN_RET_BUSOFF = -4,
GRCAN_RET_AHBERR = -5
| enum   | grcan_state { STATE_STOPPED = 0,
STATE_STARTED = 1,
STATE_BUSOFF = 2,
STATE_AHBERR = 3
int  | grcan_dev_count (void) |
void *  | grcan_open (int dev_no) |
void *  | grcan_open_by_name (char *name, int *dev_no) |
int  | grcan_close (void *d) |
int  | grcan_read (void *d, CANMsg *msg, size_t count) |
int  | grcan_write (void *d, CANMsg *msg, size_t count) |
int  | grcan_get_state (void *d) |
int  | grcan_start (void *d) |
int  | grcan_stop (void *d) |
int  | grcan_flush (void *d) |
int  | grcan_set_silent (void *d, int silent) |
int  | grcan_set_abort (void *d, int abort) |
int  | grcan_set_selection (void *d, const struct grcan_selection *selection) |
int  | grcan_set_speed (void *d, unsigned int hz) |
int  | grcan_set_btrs (void *d, const struct grcan_timing *timing) |
int  | grcan_set_rxblock (void *d, int block) |
int  | grcan_set_txblock (void *d, int block) |
int  | grcan_set_txcomplete (void *d, int complete) |
int  | grcan_set_rxcomplete (void *d, int complete) |
int  | grcan_get_stats (void *d, struct grcan_stats *stats) |
int  | grcan_clr_stats (void *d) |
int  | grcan_set_afilter (void *d, const struct grcan_filter *filter) |
int  | grcan_set_sfilter (void *d, const struct grcan_filter *filter) |
int  | grcan_get_status (void *d, unsigned int *status) |
void  | grcan_register_drv (void) |
