Motorola Board Support Package.
More...
| file   | bsp.h |
|   | Global BSP definitions.
#define  | _IO_BASE   PREP_ISA_IO_BASE |
#define  | _ISA_MEM_BASE   PREP_ISA_MEM_BASE |
#define  | PCI_DRAM_OFFSET   PREP_PCI_DRAM_OFFSET |
#define  | PCI_MEM_BASE   PREP_ISA_MEM_BASE |
#define  | PCI_MEM_WIN0   0 |
#define  | BSP_UART_IOBASE_COM1   ((_IO_BASE)+0x3f8) |
#define  | BSP_UART_IOBASE_COM2   ((_IO_BASE)+0x2f8) |
#define  | BSP_KBD_IOBASE   ((_IO_BASE)+0x60) |
#define  | BSP_VGA_IOBASE   ((_IO_BASE)+0x3c0) |
#define  | BSP_CONSOLE_PORT   BSP_UART_COM1 |
#define  | BSP_UART_BAUD_BASE   115200 |
#define  | BSP_PIC_DO_EOI   openpic_eoi(0) |
#define  | outport_byte(port,  value)   outb(value,port) |
#define  | outport_word(port,  value)   outw(value,port) |
#define  | outport_long(port,  value)   outl(value,port) |
#define  | inport_byte(port,  value)   (value = inb(port)) |
#define  | inport_word(port,  value)   (value = inw(port)) |
#define  | inport_long(port,  value)   (value = inl(port)) |
#define  | BSP_Convert_decrementer(_value)   ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) * 1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long long) (_value))) |
int  | BSP_disconnect_clock_handler (void) |
int  | BSP_connect_clock_handler (void) |
unsigned long  | _BSP_clear_hostbridge_errors (int enableMCP, int quiet) |
char *  | save_boot_params (void *r3, void *r4, void *r5, char *cmdline_start, char *cmdline_end) |
void  | zero_bss (void) |
void  | VIA_isa_bridge_interrupts_setup (void) |
unsigned int  | BSP_mem_size |
unsigned int  | BSP_heap_start |
unsigned int  | BSP_bus_frequency |
unsigned int  | BSP_processor_frequency |
unsigned int  | BSP_time_base_divisor |
char *  | BSP_commandline_string |
