MVME5500 Board Support Package.
More...
| file   | bsp.h |
|   | Global BSP definitions.
#define  | _256M   0x10000000 |
#define  | _512M   0x20000000 |
#define  | GT64x60_REG_BASE   0xf1000000  /* Base of GT64260 Reg Space */ |
#define  | GT64x60_REG_SPACE_SIZE   0x10000     /* 64Kb Internal Reg Space */ |
| #define  | GT64x60_DEV1_BASE |
#define  | GT64260_DEV1_SIZE   0x00100000 /* Device bank size */ |
#define  | _IO_BASE   GT64x60_REG_BASE |
#define  | BSP_NVRAM_BASE_ADDR   0xf1110000 |
#define  | BSP_RTC_INTA_REG   0x7ff0 |
#define  | BSP_RTC_SECOND   0x7ff2 |
#define  | BSP_RTC_MINUTE   0x7ff3 |
#define  | BSP_RTC_HOUR   0x7ff4 |
#define  | BSP_RTC_DATE   0x7ff5 |
#define  | BSP_RTC_INTERRUPTS   0x7ff6 |
#define  | BSP_RTC_WATCHDOG   0x7ff7 |
#define  | PCI0_IO_BASE   0xf0000000 |
#define  | PCI1_IO_BASE   0xf0800000 |
#define  | PCI0_MEM_BASE   0x80000000 |
#define  | PCI_MEM_BASE   0  /* glue for vmeUniverse */ |
#define  | PCI_MEM_BASE_ADJUSTMENT   0 |
#define  | PCI_DRAM_OFFSET   0 |
#define  | PCI1_MEM_BASE   0xe0000000 |
#define  | PCI1_MEM_SIZE   0x10000000 |
#define  | BSP_MAX_PCI_BUS_ON_PCI0   8 |
#define  | BSP_MAX_PCI_BUS_ON_PCI1   2 |
#define  | BSP_MAX_PCI_BUS   (BSP_MAX_PCI_BUS_ON_PCI0+BSP_MAX_PCI_BUS_ON_PCI1) |
#define  | BSP_PCI_IRQ0   BSP_GPP_IRQ_LOWEST_OFFSET |
#define  | BSP_INTERRUPT_STACK_SIZE   (16 * 1024) /* <skf> 2/09 wants it to be adjustable by BSP */ |
#define  | BSP_UART_IOBASE_COM1   GT64x60_DEV1_BASE + 0x20000 |
#define  | BSP_UART_IOBASE_COM2   GT64x60_DEV1_BASE + 0x21000 |
#define  | BSP_CONSOLE_PORT   BSP_UART_COM1  /* console */ |
#define  | BSP_UART_BAUD_BASE   115200 |
#define  | BSP_Convert_decrementer(_value)   ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) * 1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long long) (_value))) |
#define  | RTEMS_BSP_NETWORK_DRIVER_NAME   "wmG1" |
#define  | RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_i82544EI_driver_attach |
#define  | gccMemBar()   RTEMS_COMPILER_MEMORY_BARRIER() |
| enum   | BSP_BoardTypes { undefined = 0,
MVME5500,
MVME6100
| enum   | BSP_VMEchipTypes { Undefined,
UNIVERSE2,
TSI148
| enum   | DiscoveryChipVersion { notdefined,
GT64260A,
GT64260B,
MV64360
BSP_BoardTypes  | BSP_getBoardType (void) |
BSP_VMEchipTypes  | BSP_getVMEchipType (void) |
DiscoveryChipVersion  | BSP_getDiscoveryChipVersion (void) |
void  | bsp_reset (void) |
int  | BSP_disconnect_clock_handler (void) |
int  | BSP_connect_clock_handler (void) |
unsigned long  | _BSP_clear_hostbridge_errors (int enableMCP, int quiet) |
char *  | save_boot_params (void *r3, void *r4, void *r5, char *cmdline_start, char *cmdline_end) |
void  | zero_bss (void) |
uint32_t  | probeMemoryEnd (void) |
void  | pci_interface (void) |
void  | BSP_printPicIsrTbl (void) |
int  | I2Cread_eeprom (unsigned char I2cBusAddr, uint32_t devA2A1A0, uint32_t AddrBytes, unsigned char *pBuff, uint32_t numBytes) |
int  | RTEMS_BSP_NETWORK_DRIVER_ATTACH (struct rtems_bsdnet_ifconfig *, int) |
unsigned int  | BSP_mem_size |
unsigned int  | BSP_bus_frequency |
unsigned int  | BSP_processor_frequency |
unsigned int  | BSP_time_base_divisor |
◆ GT64x60_DEV1_BASE
          | #define GT64x60_DEV1_BASE |
