#define  | BSP_INTERRUPT_STACK_SIZE   (16 * 1024) |
#define  | _IO_BASE   0xe0000000 /* Motload's PCI IO base */ |
#define  | _ISA_MEM_BASE   CHRP_ISA_MEM_BASE |
#define  | PCI_DRAM_OFFSET   CHRP_PCI_DRAM_OFFSET |
#define  | PCI_MEM_BASE   0 |
#define  | PCI_MEM_WIN0   0x80000000 |
#define  | BSP_OPEN_PIC_BASE_OFFSET   0x40000 |
#define  | BSP_OPEN_PIC_BIG_ENDIAN |
#define  | BSP_8540_CCSR_BASE   (0xe1000000) |
#define  | BSP_UART_IOBASE_COM1   (BSP_8540_CCSR_BASE+0x4500) |
#define  | BSP_UART_IOBASE_COM2   (BSP_8540_CCSR_BASE+0x4600) |
#define  | PCI_CONFIG_ADDR   (BSP_8540_CCSR_BASE+0x8000) |
#define  | PCI_CONFIG_DATA   (BSP_8540_CCSR_BASE+0x8004) |
#define  | PCI_CONFIG_WR_ADDR(addr,  val)   out_be32((uint32_t*)(addr), (val)) |
#define  | BSP_CONSOLE_PORT   BSP_UART_COM1 |
#define  | BSP_UART_BAUD_BASE   (-9600) /* use existing divisor to determine clock rate */ |
#define  | BSP_UART_USE_SHARED_IRQS |
#define  | BSP_MVME3100_IRQ_DETECT_REG   ((volatile uint8_t *)0xe2000007) |
#define  | BSP_VPD_I2C_ADDR   (0xA8>>1)		/* the VPD EEPROM  */ |
#define  | BSP_USR0_I2C_ADDR   (0xA4>>1)		/* the 1st user EEPROM */ |
#define  | BSP_USR1_I2C_ADDR   (0xA6>>1)		/* the 2nd user EEPROM */ |
#define  | BSP_THM_I2C_ADDR   (0x90>>1)		/* the DS1621 temperature sensor & thermostat */ |
#define  | BSP_RTC_I2C_ADDR   (0xD0>>1)		/* the DS1375 wall-clock */ |
#define  | BSP_I2C_BUS_DESCRIPTOR   mpc8540_i2c_bus_descriptor |
#define  | BSP_I2C_BUS0_NAME   "/dev/i2c0" |
#define  | BSP_I2C_VPD_EEPROM_NAME   "vpd-eeprom" |
#define  | BSP_I2C_USR_EEPROM_NAME   "usr-eeprom" |
#define  | BSP_I2C_USR1_EEPROM_NAME   "usr1-eeprom" |
#define  | BSP_I2C_DS1621_NAME   "ds1621" |
#define  | BSP_I2C_THM_NAME   BSP_I2C_DS1621_NAME |
#define  | BSP_I2C_DS1621_RAW_NAME   "ds1621-raw" |
#define  | BSP_I2C_DS1375_RAW_NAME   "ds1375-raw" |
#define  | BSP_I2C_RTC_RAW_NAME   BSP_I2C_DS1375_RAW_NAME |
#define  | BSP_I2C_VPD_EEPROM_DEV_NAME   (BSP_I2C_BUS0_NAME "." BSP_I2C_VPD_EEPROM_NAME) |
#define  | BSP_I2C_USR_EEPROM_DEV_NAME   (BSP_I2C_BUS0_NAME "." BSP_I2C_USR_EEPROM_NAME) |
#define  | BSP_I2C_USR1_EEPROM_DEV_NAME   (BSP_I2C_BUS0_NAME "." BSP_I2C_USR1_EEPROM_NAME) |
#define  | BSP_I2C_DS1621_DEV_NAME   (BSP_I2C_BUS0_NAME "." BSP_I2C_DS1621_NAME) |
#define  | BSP_I2C_THM_DEV_NAME   BSP_I2C_DS1621_DEV_NAME |
#define  | BSP_I2C_DS1621_RAW_DEV_NAME   (BSP_I2C_BUS0_NAME "." BSP_I2C_DS1621_RAW_NAME) |
#define  | BSP_I2C_DS1375_RAW_DEV_NAME   (BSP_I2C_BUS0_NAME "." BSP_I2C_DS1375_RAW_NAME) |
#define  | BSP_EEPROM_BOOTPARMS_NAME   BSP_I2C_USR1_EEPROM_DEV_NAME |
#define  | BSP_EEPROM_BOOTPARMS_SIZE   1024 |
#define  | BSP_EEPROM_BOOTPARMS_OFFSET   0 |
#define  | BSP_BOOTPARMS_WRITE_ENABLE()   do { BSP_eeprom_write_enable(); } while (0) |
#define  | BSP_BOOTPARMS_WRITE_DISABLE()   do { BSP_eeprom_write_protect();} while (0) |
#define  | BSP_MVME3100_SYS_CR   ((volatile uint8_t *)0xe2000001) |
#define  | BSP_MVME3100_SYS_CR_RESET_MSK   (7<<5) |
#define  | BSP_MVME3100_SYS_CR_RESET   (5<<5) |
#define  | BSP_MVME3100_SYS_CR_EEPROM_WP   (1<<1) |
#define  | BSP_MVME3100_SYS_CR_TSTAT_MSK   (1<<0) |
#define  | BSP_MVME3100_SYS_IND_REG   ((volatile uint8_t *)0xe2000002) |
#define  | BSP_LED_BRD_FAIL   (1<<0) |
#define  | BSP_LED_USR1   (1<<1) |
#define  | BSP_LED_USR2   (1<<2) |
#define  | BSP_LED_USR3   (1<<3) |
#define  | BSP_MVME3100_FLASH_CSR   ((volatile uint8_t *)0xe2000003) |
#define  | BSP_MVME3100_FLASH_CSR_FLASH_RDY   (1<<0) |
#define  | BSP_MVME3100_FLASH_CSR_FBT_BLK_SEL   (1<<1) |
#define  | BSP_MVME3100_FLASH_CSR_F_WP_HW   (1<<2) |
#define  | BSP_MVME3100_FLASH_CSR_F_WP_SW   (1<<3) |
#define  | BSP_MVME3100_FLASH_CSR_MAP_SEL   (1<<4) |
#define  | BSP_Convert_decrementer(_value)   ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) * 1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long long) (_value))) |
#define  | RTEMS_BSP_NETWORK_DRIVER_NAME   "tse1" |
#define  | RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_tsec_attach |
int  | BSP_i2c_initialize (void) |
uint8_t  | BSP_setSysReg (volatile uint8_t *r, uint8_t mask) |
uint8_t  | BSP_clrSysReg (volatile uint8_t *r, uint8_t mask) |
uint8_t  | BSP_eeprom_write_protect (void) |
uint8_t  | BSP_eeprom_write_enable (void) |
uint8_t  | BSP_setLEDs (uint8_t mask) |
uint8_t  | BSP_clrLEDs (uint8_t mask) |
int  | BSP_disconnect_clock_handler (void) |
int  | BSP_connect_clock_handler (void) |
unsigned long  | _BSP_clear_hostbridge_errors (int enableMCP, int quiet) |
void  | BSP_motload_pci_fixup (void) |
int  | rtems_tsec_attach (struct rtems_bsdnet_ifconfig *ifcfg, int attaching) |
char *  | save_boot_params (void *r3, void *r4, void *r5, char *cmdline_start, char *cmdline_end) |
void  | zero_bss (void) |
void  | BSP_vme_config (void) |
void  | BSP_pciConfigDump_early (void) |
MVME3100 Board Support Package.
