#define  | BSP_INTERRUPT_STACK_SIZE   (16 * 1024) |
#define  | BSP_MV64x60_BASE   (0xf1000000) |
#define  | BSP_MV64x60_DEV1_BASE   (0xf1100000) |
#define  | BSP_UART_IOBASE_COM1   ((BSP_MV64x60_DEV1_BASE)+0x20000) |
#define  | BSP_UART_IOBASE_COM2   ((BSP_MV64x60_DEV1_BASE)+0x21000) |
#define  | BSP_UART_USE_SHARED_IRQS |
#define  | BSP_NVRAM_BASE_ADDR   (0xf1110000) |
#define  | BSP_NVRAM_END_ADDR   (0xf1117fff) |
#define  | BSP_NVRAM_RTC_START   (0xf1117ff8) |
#define  | BSP_NVRAM_BOOTPARMS_START   (0xf1111000) |
#define  | BSP_NVRAM_BOOTPARMS_END   (0xf1111fff) |
#define  | PCI_CONFIG_ADDR   (BSP_MV64x60_BASE + 0xcf8) |
#define  | PCI_CONFIG_DATA   (BSP_MV64x60_BASE + 0xcfc) |
#define  | _IO_BASE   0x00000000 |
#define  | PCI_MEM_BASE   0 |
#define  | PCI_MEM_BASE_ADJUSTMENT   0 |
#define  | PCI_DRAM_OFFSET   0 |
#define  | BSP_PCI2LOCAL_ADDR(a)   ((uint32_t)(a)) |
#define  | BSP_LOCAL2PCI_ADDR(a)   ((uint32_t)(a)) |
#define  | BSP_CONFIG_NUM_PCI_CACHE_SLOTS   32 |
#define  | BSP_CONSOLE_PORT   BSP_UART_COM1 |
#define  | BSP_UART_BAUD_BASE   115200 |
#define  | BSP_VPD_I2C_ADDR   (0xA8>>1)    /* the VPD EEPROM  */ |
#define  | BSP_USR_I2C_ADDR   (0xAA>>1)    /* the user EEPROM */ |
#define  | BSP_THM_I2C_ADDR   (0x90>>1)    /* the DS1621 temperature sensor & thermostat */ |
#define  | BSP_I2C_BUS_DESCRIPTOR   gt64260_i2c_bus_descriptor |
#define  | BSP_I2C_BUS0_NAME   "/dev/i2c0" |
#define  | BSP_I2C_VPD_EEPROM_NAME   "vpd-eeprom" |
#define  | BSP_I2C_USR_EEPROM_NAME   "usr-eeprom" |
#define  | BSP_I2C_DS1621_NAME   "ds1621" |
#define  | BSP_I2C_THM_NAME   BSP_I2C_DS1621_NAME |
#define  | BSP_I2C_DS1621_RAW_NAME   "ds1621-raw" |
#define  | BSP_I2C_VPD_EEPROM_DEV_NAME   (BSP_I2C_BUS0_NAME ", " BSP_I2C_VPD_EEPROM_NAME) |
#define  | BSP_I2C_USR_EEPROM_DEV_NAME   (BSP_I2C_BUS0_NAME ", " BSP_I2C_USR_EEPROM_NAME) |
#define  | BSP_I2C_DS1621_DEV_NAME   (BSP_I2C_BUS0_NAME ", " BSP_I2C_DS1621_NAME) |
#define  | BSP_I2C_THM_DEV_NAME   BSP_I2C_DS1621_DEV_NAME |
#define  | BSP_I2C_DS1621_RAW_DEV_NAME   (BSP_I2C_BUS0_NAME ", " BSP_I2C_DS1621_RAW_NAME) |
#define  | BSP_PCI_HOSE0_MEM_BASE   0x80000000  /* must be aligned to size */ |
#define  | BSP_PCI_HOSE0_MEM_SIZE   0x20000000 |
#define  | BSP_PCI_HOSE1_MEM_BASE   0xe0000000 |
#define  | BSP_DEV_AND_PCI_IO_BASE   0xf0000000 |
#define  | BSP_DEV_AND_PCI_IO_SIZE   0x10000000 |
#define  | BSP_RW_PAGE_ATTRIBUTES   TRIV121_ATTR_M |
#define  | BSP_EXCEPTION_NOTEPAD   14 |
#define  | outport_byte(port,  value)   outb(value,port) |
#define  | outport_word(port,  value)   outw(value,port) |
#define  | outport_long(port,  value)   outl(value,port) |
#define  | inport_byte(port,  value)   (value = inb(port)) |
#define  | inport_word(port,  value)   (value = inw(port)) |
#define  | inport_long(port,  value)   (value = inl(port)) |
#define  | BSP_Convert_decrementer(_value)   ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) * 1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long long) (_value))) |
BSP_BoardType  | BSP_getBoardType (void) |
DiscoveryVersion  | BSP_getDiscoveryVersion (int assertion) |
void  | BSP_motload_pci_fixup (void) |
int  | BSP_i2c_initialize (void) |
void  | BSP_pci_initialize (void) |
void  | bsp_reset (void) |
int  | BSP_disconnect_clock_handler (void) |
int  | BSP_connect_clock_handler (void) |
unsigned long  | _BSP_clear_hostbridge_errors (int enableMCP, int quiet) |
void  | discovery_pic_set_debug_irq (int on) |
void  | discovery_pic_install_debug_irq (void) |
char *  | save_boot_params (void *r3, void *r4, void *r5, char *cmdline_start, char *cmdline_end) |
void  | zero_bss (void) |
uint32_t  | probeMemoryEnd (void) |
Beatnik (MVME5500 and MVME6100) Board Support Package.
