Hurricane Board Support Package.
More...
| file   | bsp.h |
|   | Global BSP definitions.
#define  | BSP_FEATURE_IRQ_EXTENSION |
#define  | BSP_SHARED_HANDLER_SUPPORT   1 |
#define  | CPU_CLOCK_RATE_MHZ   (200) |
#define  | CLOCKS_PER_MICROSECOND   ( CPU_CLOCK_RATE_MHZ ) /* equivalent to CPU clock speed in MHz */ |
| #define  | rtems_bsp_delay(microseconds) |
#define  | RAM_START   0 |
#define  | RAM_END   0x100000 |
void  | WriteDisplay (char *string) |
uint32_t  | mips_get_timer (void) |
void  | init_tlb (void) |
void  | resettlb (int i) |
◆ rtems_bsp_delay
          | #define rtems_bsp_delay |
          microseconds | ) |
Value:{ \
     uint32_t _end_clock = \
          mips_get_timer() + microseconds * CLOCKS_PER_MICROSECOND; \
     _end_clock %= 0x100000000;   \
     while ( _end_clock < mips_get_timer() );  \
     while ( _end_clock > mips_get_timer() ); \
