BF537-STAMP Board Support Package.
More...
| file   | bsp.h |
|   | Global BSP definitions.
#define  | BSP_DATA_CACHE_CONFIG   (3 << DMEM_CONTROL_DMC_SHIFT) |
#define  | PLL_CSEL   0x0000      /* CCLK = VCO      */ |
#define  | PLL_SSEL   0x0003      /* SCLK = CCLK/3   */ |
#define  | PLL_MSEL   0x3A00      /* VCO = 29xCLKIN  */ |
#define  | PLL_DF   0x0001      /* CLKIN = XTL/2   */ |
#define  | CCLK   500000000   /* CORE CLOCK     */ |
#define  | SCLK   100000000   /* SYSTEM CLOCK   */ |
#define  | CONSOLE_FORCE_BAUD   57600 |
#define  | L1_DATA_SRAM_A   0xff800000L |
#define  | FIFOLENGTH   0x100 |
| #define  | rtems_bsp_delay(microseconds) |
#define  | RAM_START   0 |
#define  | RAM_END   0x4000000 |
#define  | RTEMS_BSP_NETWORK_DRIVER_NAME   "eth1" |
#define  | RTEMS_BSP_NETWORK_DRIVER_ATTACH   bf537Stamp_network_driver_attach |
void  | setLED (uint8_t value) |
uint8_t  | getLEDs (void) |
void  | setLEDs (uint8_t value) |
uint8_t  | getButtons (void) |
rtems_isr_entry  | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
void  | Init_RTC (void) |
int  | bf537Stamp_network_driver_attach (struct rtems_bsdnet_ifconfig *, int) |
◆ rtems_bsp_delay
          | #define rtems_bsp_delay |
          microseconds | ) |
