B1553BRM device driver.
More...
#define  | BC_TR   0x0001 |
#define  | BC_RTRT   0x0002 |
#define  | BC_BUSA   0x0004 |
#define  | BC_EOL   0x0020 |
#define  | BC_SKIP   0x0040 |
#define  | BC_BAME   0x8000 |
#define  | BRM_MBC_IRQ   1                    /* Monitor Block Counter irq */ |
#define  | BRM_CBA_IRQ   2                    /* Command Block Accessed irq */ |
#define  | BRM_RTF_IRQ   4                    /* Retry Fail irq */ |
#define  | BRM_ILLOP_IRQ   8                    /* Illogical Opcode irq */ |
#define  | BRM_BC_ILLCMD_IRQ   16                   /* BC Illocigal Command irq */ |
#define  | BRM_EOL_IRQ   32                   /* End Of List irq */ |
#define  | BRM_RT_ILLCMD_IRQ   128                  /* RT Illegal Command irq */ |
#define  | BRM_IXEQ0_IRQ   256                  /* Index Equal Zero irq */ |
#define  | BRM_BDRCV_IRQ   512                  /* Broadcast Command Received irq */ |
#define  | BRM_SUBAD_IRQ   1024                 /* Subaddress Accessed irq */ |
#define  | BRM_MERR_IRQ   2048                 /* Message Error irq */ |
#define  | BRM_TAPF_IRQ   8192                 /* Terminal Address Parity Fail irq */ |
#define  | BRM_WRAPF_IRQ   16384                /* Wrap Fail irq */ |
#define  | BRM_DMAF_IRQ   32768                /* DMA Fail irq */ |
#define  | BRM_SET_MODE   0 |
#define  | BRM_SET_BUS   1 |
#define  | BRM_SET_MSGTO   2 |
#define  | BRM_SET_RT_ADDR   3 |
#define  | BRM_SET_STD   4 |
#define  | BRM_SET_BCE   5 |
#define  | BRM_TX_BLOCK   7 |
#define  | BRM_RX_BLOCK   8 |
#define  | BRM_DO_LIST   10 |
#define  | BRM_LIST_DONE   11 |
#define  | BRM_CLR_STATUS   12 |
#define  | BRM_GET_STATUS   13 |
#define  | BRM_SET_EVENTID   14 |
#define  | GET_ERROR_DESCRIPTOR(event_in)   (event_in>>16) |
#define  | BRM_MODE_BC   0x0 |
#define  | BRM_MODE_RT   0x1 |
#define  | BRM_MODE_BM   0x2 |
#define  | BRM_MODE_BM_RT   0x3 /* both RT and BM */ |
#define  | BRM_FREQ_12MHZ   0 |
#define  | BRM_FREQ_16MHZ   1 |
#define  | BRM_FREQ_20MHZ   2 |
#define  | BRM_FREQ_24MHZ   3 |
#define  | BRM_FREQ_MASK   0x3 |
#define  | CLKDIV_MASK   0xf |
#define  | CLKSEL_MASK   0x7 |
void  | b1553brm_register_drv (void) |
void  | b1553brm_print (int options) |
void  | b1553brm_print_dev (struct drvmgr_dev *dev, int options) |
unsigned short  | b1553brm_rt_cmd_legalize [16] |
