RTEMS
5.1
bsps
include
grlib
greth.h
1
2
* Cobham Gaisler ethernet MAC driver
3
* adapted from Opencores driver by Marko Isomaki
4
5
* The license and distribution terms for this file may be
6
* found in found in the file LICENSE in this distribution or at
7
* http://www.rtems.org/license/LICENSE.
8
9
10
#ifndef __GRETH_H__
11
#define __GRETH_H__
12
13
#ifdef __cplusplus
14
extern
"C"
15
#endif
16
17
/* Ethernet configuration registers */
18
19
typedef
struct
_greth_regs
20
volatile
uint32_t ctrl;
/* Ctrl Register */
21
volatile
uint32_t status;
/* Status Register */
22
volatile
uint32_t mac_addr_msb;
/* Bit 47-32 of MAC address */
23
volatile
uint32_t mac_addr_lsb;
/* Bit 31-0 of MAC address */
24
volatile
uint32_t mdio_ctrl;
/* MDIO control and status */
25
volatile
uint32_t txdesc;
/* Transmit descriptor pointer */
26
volatile
uint32_t rxdesc;
/* Receive descriptor pointer */
27
volatile
uint32_t edcl;
/* EDCL IP register */
28
volatile
uint32_t ht_msb;
/* Multicast MSB hash */
29
volatile
uint32_t ht_lsb;
/* Multicast LSB hash */
30
greth_regs
31
32
#define GRETH_TOTAL_BD 128
33
#define GRETH_MAXBUF_LEN 1520
34
35
/* Tx BD */
36
#define GRETH_TXD_ENABLE 0x0800
/* Tx BD Enable */
37
#define GRETH_TXD_WRAP 0x1000
/* Tx BD Wrap (last BD) */
38
#define GRETH_TXD_IRQ 0x2000
/* Tx BD IRQ Enable */
39
#define GRETH_TXD_MORE 0x20000
/* Tx BD More (more descs for packet) */
40
#define GRETH_TXD_IPCS 0x40000
/* Tx BD insert ip chksum */
41
#define GRETH_TXD_TCPCS 0x80000
/* Tx BD insert tcp chksum */
42
#define GRETH_TXD_UDPCS 0x100000
/* Tx BD insert udp chksum */
43
44
#define GRETH_TXD_UNDERRUN 0x4000
/* Tx BD Underrun Status */
45
#define GRETH_TXD_RETLIM 0x8000
/* Tx BD Retransmission Limit Status */
46
#define GRETH_TXD_LATECOL 0x10000
/* Tx BD Late Collision */
47
48
#define GRETH_TXD_STATS (GRETH_TXD_UNDERRUN | \
49
GRETH_TXD_RETLIM | \
50
GRETH_TXD_LATECOL)
51
52
#define GRETH_TXD_CS (GRETH_TXD_IPCS | \
53
GRETH_TXD_TCPCS | \
54
GRETH_TXD_UDPCS)
55
56
/* Rx BD */
57
#define GRETH_RXD_ENABLE 0x0800
/* Rx BD Enable */
58
#define GRETH_RXD_WRAP 0x1000
/* Rx BD Wrap (last BD) */
59
#define GRETH_RXD_IRQ 0x2000
/* Rx BD IRQ Enable */
60
61
#define GRETH_RXD_DRIBBLE 0x4000
/* Rx BD Dribble Nibble Status */
62
#define GRETH_RXD_TOOLONG 0x8000
/* Rx BD Too Long Status */
63
#define GRETH_RXD_CRCERR 0x10000
/* Rx BD CRC Error Status */
64
#define GRETH_RXD_OVERRUN 0x20000
/* Rx BD Overrun Status */
65
#define GRETH_RXD_LENERR 0x40000
/* Rx BD Length Error */
66
#define GRETH_RXD_ID 0x40000
/* Rx BD IP Detected */
67
#define GRETH_RXD_IR 0x40000
/* Rx BD IP Chksum Error */
68
#define GRETH_RXD_UD 0x40000
/* Rx BD UDP Detected*/
69
#define GRETH_RXD_UR 0x40000
/* Rx BD UDP Chksum Error */
70
#define GRETH_RXD_TD 0x40000
/* Rx BD TCP Detected */
71
#define GRETH_RXD_TR 0x40000
/* Rx BD TCP Chksum Error */
72
73
74
#define GRETH_RXD_STATS (GRETH_RXD_OVERRUN | \
75
GRETH_RXD_DRIBBLE | \
76
GRETH_RXD_TOOLONG | \
77
GRETH_RXD_CRCERR)
78
79
/* CTRL Register */
80
#define GRETH_CTRL_TXEN 0x00000001
/* Transmit Enable */
81
#define GRETH_CTRL_RXEN 0x00000002
/* Receive Enable */
82
#define GRETH_CTRL_TXIRQ 0x00000004
83
#define GRETH_CTRL_RXIRQ 0x00000008
84
#define GRETH_CTRL_FULLD 0x00000010
/* Full Duplex */
85
#define GRETH_CTRL_PRO 0x00000020
/* Promiscuous (receive all) */
86
#define GRETH_CTRL_RST 0x00000040
/* Reset MAC */
87
#define GRETH_CTRL_SP 0x00000080
/* 100MBit speed mode */
88
#define GRETH_CTRL_GB 0x00000100
/* 1GBit speed mode */
89
#define GRETH_CTRL_MCE 0x00000800
/* Multicast Enable */
90
#define GRETH_CTRL_DD 0x00001000
/* Disable EDCL Duplex Detection */
91
#define GRETH_CTRL_ED 0x00004000
/* EDCL Disable */
92
#define GRETH_CTRL_MC 0x02000000
/* Multicast available */
93
#define GRETH_CTRL_ME 0x04000000
/* MDIO interrupts enabled */
94
#define GRETH_CTRL_GA 0x08000000
/* Gigabit MAC available */
95
96
97
#define GRETH_STATUS_RXERR 0x00000001
/* Receive Error */
98
#define GRETH_STATUS_TXERR 0x00000002
/* Transmit Error IRQ */
99
#define GRETH_STATUS_RXIRQ 0x00000004
/* Receive Frame IRQ */
100
#define GRETH_STATUS_TXIRQ 0x00000008
101
#define GRETH_STATUS_RXAHBERR 0x00000010
/* Receiver AHB Error */
102
#define GRETH_STATUS_TXAHBERR 0x00000020
/* Transmitter AHB Error */
103
104
/* MDIO Control */
105
#define GRETH_MDIO_WRITE 0x00000001
/* MDIO Write */
106
#define GRETH_MDIO_READ 0x00000002
/* MDIO Read */
107
#define GRETH_MDIO_LINKFAIL 0x00000004
/* MDIO Link failed */
108
#define GRETH_MDIO_BUSY 0x00000008
/* MDIO Link Busy */
109
#define GRETH_MDIO_REGADR 0x000007C0
/* Register Address */
110
#define GRETH_MDIO_PHYADR 0x0000F800
/* PHY address */
111
#define GRETH_MDIO_DATA 0xFFFF0000
/* MDIO DATA */
112
113
114
/* MII registers */
115
#define GRETH_MII_EXTADV_1000FD 0x00000200
116
#define GRETH_MII_EXTADV_1000HD 0x00000100
117
#define GRETH_MII_EXTPRT_1000FD 0x00000800
118
#define GRETH_MII_EXTPRT_1000HD 0x00000400
119
120
#define GRETH_MII_100T4 0x00000200
121
#define GRETH_MII_100TXFD 0x00000100
122
#define GRETH_MII_100TXHD 0x00000080
123
#define GRETH_MII_10FD 0x00000040
124
#define GRETH_MII_10HD 0x00000020
125
126
127
/* Attach routine */
128
129
void
greth_register_drv(
void
130
131
/* PHY data */
132
struct
phy_device_info
133
134
int
vendor;
135
int
device
136
int
rev;
137
138
int
adv;
139
int
part;
140
141
int
extadv;
142
int
extpart;
143
144
145
/* Limit speed modes advertised during auto-negotiation */
146
#define GRETH_ADV_10_HD 0x0001
147
#define GRETH_ADV_10_FD 0x0002
148
#define GRETH_ADV_100_HD 0x0004
149
#define GRETH_ADV_100_FD 0x0008
150
#define GRETH_ADV_1000_HD 0x0010
151
#define GRETH_ADV_1000_FD 0x0020
152
#define GRETH_ADV_ALL 0x003f
153
154
#ifdef CPU_U32_FIX
155
void ipalign(struct mbuf *m);
156
#endif
157
158
159
#ifdef __cplusplus
160
161
#endif
162
163
#endif
164
phy_device_info
Definition:
greth.h:132
device
Definition:
rtemscompat1.h:15
_greth_regs
Definition:
greth.h:19
