33     volatile unsigned int conf;
    34     volatile unsigned int stat;
    35     volatile unsigned int ctrl;
    36     volatile unsigned int dummy0[3];
    37     volatile unsigned int smask;
    38     volatile unsigned int scode;
    40     volatile unsigned int dummy1[56];
    42     volatile unsigned int pimsr;
    43     volatile unsigned int pimr;
    44     volatile unsigned int pisr;
    45     volatile unsigned int pir;
    46     volatile unsigned int imr;
    47     volatile unsigned int picr;
    49     volatile unsigned int dummy2[58];
    51     volatile unsigned int tx0ctrl;
    52     volatile unsigned int tx0addr;
    53     volatile unsigned int tx0size;
    54     volatile unsigned int tx0wr;
    55     volatile unsigned int tx0rd;
    56     volatile unsigned int tx0irq;
    58     volatile unsigned int dummy3[58];
    60     volatile unsigned int rx0ctrl;
    61     volatile unsigned int rx0addr;
    62     volatile unsigned int rx0size;
    63     volatile unsigned int rx0wr;
    64     volatile unsigned int rx0rd;
    65     volatile unsigned int rx0irq;
    66     volatile unsigned int rx0mask;
    67     volatile unsigned int rx0code;
    71     unsigned int passive_cnt;
    72     unsigned int overrun_cnt;
    73     unsigned int rxsync_cnt;
    74     unsigned int txsync_cnt;
    75     unsigned int txloss_cnt;
    76     unsigned int ahberr_cnt;
    78     unsigned int busoff_cnt;
    96     unsigned long long mask;
    97     unsigned long long code;
   106     unsigned char data[8];
   112     GRCAN_RET_INVARG        = -1,
   113     GRCAN_RET_NOTSTARTED    = -2,
   114     GRCAN_RET_TIMEOUT       = -3,
   116     GRCAN_RET_BUSOFF        = -4,
   118     GRCAN_RET_AHBERR        = -5,
   143 #define GRCAN_CFG_ABORT      0x00000001   144 #define GRCAN_CFG_ENABLE0    0x00000002   145 #define GRCAN_CFG_ENABLE1    0x00000004   146 #define GRCAN_CFG_SELECTION  0x00000008   147 #define GRCAN_CFG_SILENT     0x00000010   148 #define GRCAN_CFG_BPR        0x00000300   149 #define GRCAN_CFG_RSJ        0x00007000   150 #define GRCAN_CFG_PS1        0x00f00000   151 #define GRCAN_CFG_PS2        0x000f0000   152 #define GRCAN_CFG_SCALER     0xff000000   154 #define GRCAN_CFG_BPR_BIT    8   155 #define GRCAN_CFG_RSJ_BIT    12   156 #define GRCAN_CFG_PS1_BIT    20   157 #define GRCAN_CFG_PS2_BIT    16   158 #define GRCAN_CFG_SCALER_BIT 24   160 #define GRCAN_CTRL_RESET  0x2   161 #define GRCAN_CTRL_ENABLE 0x1   163 #define GRCAN_TXCTRL_ENABLE 1   164 #define GRCAN_TXCTRL_ONGOING 1   166 #define GRCAN_RXCTRL_ENABLE 1   167 #define GRCAN_RXCTRL_ONGOING 1   170 #define GRCAN_IRQ_IRQ 0   171 #define GRCAN_IRQ_TXSYNC 1   172 #define GRCAN_IRQ_RXSYNC 2   174 #define GRCAN_ERR_IRQ        0x1   175 #define GRCAN_OFF_IRQ        0x2   176 #define GRCAN_OR_IRQ         0x4   177 #define GRCAN_RXAHBERR_IRQ   0x8   178 #define GRCAN_TXAHBERR_IRQ   0x10   179 #define GRCAN_RXIRQ_IRQ      0x20   180 #define GRCAN_TXIRQ_IRQ      0x40   181 #define GRCAN_RXFULL_IRQ     0x80   182 #define GRCAN_TXEMPTY_IRQ    0x100   183 #define GRCAN_RX_IRQ         0x200   184 #define GRCAN_TX_IRQ         0x400   185 #define GRCAN_RXSYNC_IRQ     0x800   186 #define GRCAN_TXSYNC_IRQ     0x1000   187 #define GRCAN_RXERR_IRQ      0x2000   188 #define GRCAN_TXERR_IRQ      0x4000   189 #define GRCAN_RXMISS_IRQ     0x8000   190 #define GRCAN_TXLOSS_IRQ     0x10000   192 #define GRCAN_STAT_PASS      0x1   193 #define GRCAN_STAT_OFF       0x2   194 #define GRCAN_STAT_OR        0x4   195 #define GRCAN_STAT_AHBERR    0x8   196 #define GRCAN_STAT_ACTIVE    0x10   197 #define GRCAN_STAT_RXERRCNT  0xff00   198 #define GRCAN_STAT_TXERRCNT  0xff0000   203 extern int grcan_dev_count(
void);
   212 extern void *grcan_open(
int dev_no);
   223 extern void *grcan_open_by_name(
char *name,
int *dev_no);
   230 extern int grcan_close(
void *d);
   251 extern int grcan_read(
   276 extern int grcan_write(
   295 extern int grcan_get_state(
void *d);
   303 extern int grcan_start(
void *d);
   305 extern int grcan_stop(
void *d);
   307 extern int grcan_flush(
void *d);
   313 extern int grcan_set_silent(
void *d,
int silent);
   315 extern int grcan_set_abort(
void *d,
int abort);
   317 extern int grcan_set_selection(
void *d,
const struct grcan_selection *selection);
   319 extern int grcan_set_speed(
void *d,
unsigned int hz);
   321 extern int grcan_set_btrs(
void *d,
const struct grcan_timing *timing);
   325 int grcan_set_rxblock(
void* d,
int block);
   327 int grcan_set_txblock(
void* d,
int block);
   329 int grcan_set_txcomplete(
void* d,
int complete);
   331 int grcan_set_rxcomplete(
void* d,
int complete);
   333 extern int grcan_get_stats(
void *d,
struct grcan_stats *stats);
   335 extern int grcan_clr_stats(
void *d);
   337 extern int grcan_set_afilter(
void *d,
const struct grcan_filter *filter);
   339 extern int grcan_set_sfilter(
void *d,
   341 extern int grcan_get_status(
void *d,
unsigned int *status);
   343 void grcan_register_drv(
void);
Definition: inftrees.h:24
Definition: b1553brm.c:75
