RTEMS  5.1
gr_rasta_spw_router.h
1 /* GR-RASTA-SPW-ROUTER PCI Peripheral driver
2  *
3  * COPYRIGHT (c) 2015.
4  * Cobham Gaisler.
5  *
6  * The license and distribution terms for this file may be
7  * found in found in the file LICENSE in this distribution or at
8  * http://www.rtems.org/license/LICENSE.
9  *
10  */
11
12 #ifndef __GR_RASTA_SPW_ROUTER_H__
13 #define __GR_RASTA_SPW_ROUTER_H__
14
15 #include <drvmgr/drvmgr.h>
16
17 #ifdef __cplusplus
18 extern "C" {
19 #endif
20
21 /* An array of pointers to GR-RASTA-SPW-ROUTER resources. The resources will be
22  * used by the drivers controlling the cores on the GR-RASTA-SPW-ROUTER target
23  * AMBA bus.
24  *
25  * The gr_rasta_spw_router_resources is declared weak so that the user can
26  * override the default configuration. The array must be terminated with a
27  * NULL resource.
28  */
29 extern struct drvmgr_bus_res *gr_rasta_spw_router_resources[];
30
31 /* Options to gr_rasta_spw_router_print function */
32 #define RASTA_SPW_ROUTER_OPTIONS_AMBA 0x01 /* Print AMBA bus devices */
33 #define RASTA_SPW_ROUTER_OPTIONS_IRQ 0x02 /* Print current IRQ setup */
34
35 /* Print information about all GR-CPCI-LEON4-N2X PCI boards */
36 void gr_rasta_spw_router_print(int options);
37
38 /* Print information about one GR-CPCI-LEON4-N2X PCI board */
39 void gr_rasta_spw_router_print_dev(struct drvmgr_dev *dev, int options);
40
41 /* Register GR-RASTA-SPW-ROUTER driver to Driver Manager */
42 void gr_rasta_spw_router_register_drv(void);
43
44 #ifdef __cplusplus
45 }
46 #endif
47
48 #endif
Definition: drvmgr.h:214
Definition: drvmgr.h:275
