RTEMS  5.1
sh7_sci.h
1 /*
2  * Bit values for the serial control registers of the Hitachi SH704X
3  *
4  * From Hitachi tutorials
5  *
6  * Authors: Ralf Corsepius (corsepiu@faw.uni-ulm.de) and
7  * Bernd Becker (becker@faw.uni-ulm.de)
8  *
9  * COPYRIGHT (c) 1997-1998, FAW Ulm, Germany
10  *
11  * This program is distributed in the hope that it will be useful,
12  * but WITHOUT ANY WARRANTY; without even the implied warranty of
13  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
14  *
15  *
16  * COPYRIGHT (c) 1998.
17  * On-Line Applications Research Corporation (OAR).
18  *
19  * The license and distribution terms for this file may be
20  * found in the file LICENSE in this distribution or at
21  * http://www.rtems.org/license/LICENSE.
22  */
23
24 #ifndef _sh7_sci_h
25 #define _sh7_sci_h
26
27 #include <rtems/score/iosh7045.h>
28
29 /*
30  * Serial mode register bits
31  */
32
33 #define SCI_SYNC_MODE 0x80
34 #define SCI_SEVEN_BIT_DATA 0x40
35 #define SCI_PARITY_ON 0x20
36 #define SCI_ODD_PARITY 0x10
37 #define SCI_STOP_BITS_2 0x08
38 #define SCI_ENABLE_MULTIP 0x04
39 #define SCI_PHI_64 0x03
40 #define SCI_PHI_16 0x02
41 #define SCI_PHI_4 0x01
42 #define SCI_PHI_0 0x00
43
44 /*
45  * Serial register offsets, relative to SCI0_SMR or SCI1_SMR
46  */
47
48 #define SCI_SMR 0x00
49 #define SCI_BRR 0x01
50 #define SCI_SCR 0x02
51 #define SCI_TDR 0x03
52 #define SCI_SSR 0x04
53 #define SCI_RDR 0x05
54
55 /*
56  * Serial control register bits
57  */
58 #define SCI_TIE 0x80 /* Transmit interrupt enable */
59 #define SCI_RIE 0x40 /* Receive interrupt enable */
60 #define SCI_TE 0x20 /* Transmit enable */
61 #define SCI_RE 0x10 /* Receive enable */
62 #define SCI_MPIE 0x08 /* Multiprocessor interrupt enable */
63 #define SCI_TEIE 0x04 /* Transmit end interrupt enable */
64 #define SCI_CKE1 0x02 /* Clock enable 1 */
65 #define SCI_CKE0 0x01 /* Clock enable 0 */
66
67 /*
68  * Serial status register bits
69  */
70 #define SCI_TDRE 0x80 /* Transmit data register empty */
71 #define SCI_RDRF 0x40 /* Receive data register full */
72 #define SCI_ORER 0x20 /* Overrun error */
73 #define SCI_FER 0x10 /* Framing error */
74 #define SCI_PER 0x08 /* Parity error */
75 #define SCI_TEND 0x04 /* Transmit end */
76 #define SCI_MPB 0x02 /* Multiprocessor bit */
77 #define SCI_MPBT 0x01 /* Multiprocessor bit transfer */
78
79 /*
80  * INTC Priority Settings
81  */
82
83 #define SCI0_IPMSK 0x00F0
84 #define SCI0_LOWIP 0x0010
85 #define SCI1_IPMSK 0x000F
86 #define SCI1_LOWIP 0x0001
87
88 #endif /* _sh7_sci_h */
