    RTEMS
    5.1
Go to the documentation of this file.   17 #ifndef LIBBSP_GENERIC_OR1K_H    18 #define LIBBSP_GENERIC_OR1K_H    38  #define OR1K_REG(x)           (*((volatile unsigned char *) (x)))    39  #define OR1K_BIT(n)           (1 << (n))    48 #define OR1K_BSP_CLOCK_FREQ       50000000UL    49 #define OR1K_BSP_UART_BASE        0x90000000    51 #define OR1K_BSP_UART_REG_TX              (OR1K_BSP_UART_BASE+0)    52 #define OR1K_BSP_UART_REG_RX              (OR1K_BSP_UART_BASE+0)    53 #define OR1K_BSP_UART_REG_DEV_LATCH_LOW   (OR1K_BSP_UART_BASE+0)    54 #define OR1K_BSP_UART_REG_DEV_LATCH_HIGH  (OR1K_BSP_UART_BASE+1)    55 #define OR1K_BSP_UART_REG_INT_ENABLE      (OR1K_BSP_UART_BASE+1)    56 #define OR1K_BSP_UART_REG_INT_ID          (OR1K_BSP_UART_BASE+2)    57 #define OR1K_BSP_UART_REG_FIFO_CTRL       (OR1K_BSP_UART_BASE+2)    58 #define OR1K_BSP_UART_REG_LINE_CTRL       (OR1K_BSP_UART_BASE+3)    59 #define OR1K_BSP_UART_REG_MODEM_CTRL      (OR1K_BSP_UART_BASE+4)    60 #define OR1K_BSP_UART_REG_LINE_STATUS     (OR1K_BSP_UART_BASE+5)    61 #define OR1K_BSP_UART_REG_MODEM_STATUS    (OR1K_BSP_UART_BASE+6)    62 #define OR1K_BSP_UART_REG_SCRATCH         (OR1K_BSP_UART_BASE+7)    65 #define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_1    (0x00)    66 #define OR1K_BSP_UART_REG_FIFO_CTRL_ENABLE_FIFO  (0x01)    67 #define OR1K_BSP_UART_REG_FIFO_CTRL_CLEAR_RCVR   (0x02)    68 #define OR1K_BSP_UART_REG_FIFO_CTRL_CLEAR_XMIT   (0x03)    69 #define OR1K_BSP_UART_REG_FIFO_CTRL_DMA_SELECT   (0x08)    70 #define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_4    (0x40)    71 #define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_8    (0x80)    72 #define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_14   (0xC0)    73 #define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_MASK (0xC0)    76 #define OR1K_BSP_UART_REG_LINE_CTRL_WLEN5  (0x00)    77 #define OR1K_BSP_UART_REG_LINE_CTRL_WLEN6  (0x01)    78 #define OR1K_BSP_UART_REG_LINE_CTRL_WLEN7  (0x02)    79 #define OR1K_BSP_UART_REG_LINE_CTRL_WLEN8  (0x03)    80 #define OR1K_BSP_UART_REG_LINE_CTRL_STOP   (0x04)    81 #define OR1K_BSP_UART_REG_LINE_CTRL_PARITY (0x08)    82 #define OR1K_BSP_UART_REG_LINE_CTRL_EPAR   (0x10)    83 #define OR1K_BSP_UART_REG_LINE_CTRL_SPAR   (0x20)    84 #define OR1K_BSP_UART_REG_LINE_CTRL_SBC    (0x40)    85 #define OR1K_BSP_UART_REG_LINE_CTRL_DLAB   (0x80)    88 #define OR1K_BSP_UART_REG_LINE_STATUS_DR   (0x01)    89 #define OR1K_BSP_UART_REG_LINE_STATUS_OE   (0x02)    90 #define OR1K_BSP_UART_REG_LINE_STATUS_PE   (0x04)    91 #define OR1K_BSP_UART_REG_LINE_STATUS_FE   (0x08)    92 #define OR1K_BSP_UART_REG_LINE_STATUS_BI   (0x10)    93 #define OR1K_BSP_UART_REG_LINE_STATUS_THRE (0x20)    94 #define OR1K_BSP_UART_REG_LINE_STATUS_TEMT (0x40)    97 #define OR1K_BSP_UART_REG_MODEM_CTRL_DTR  (0x01)    98 #define OR1K_BSP_UART_REG_MODEM_CTRL_RTS  (0x02)    99 #define OR1K_BSP_UART_REG_MODEM_CTRL_OUT1 (0x04)   100 #define OR1K_BSP_UART_REG_MODEM_CTRL_OUT2 (0x08)   101 #define OR1K_BSP_UART_REG_MODEM_CTRL_LOOP (0x10)   104 #define OR1K_BSP_UART_REG_MODEM_STATUS_DCTS (0x01)   105 #define OR1K_BSP_UART_REG_MODEM_STATUS_DDSR (0x02)   106 #define OR1K_BSP_UART_REG_MODEM_STATUS_TERI (0x04)   107 #define OR1K_BSP_UART_REG_MODEM_STATUS_DDCD (0x08)   108 #define OR1K_BSP_UART_REG_MODEM_STATUS_CTS  (0x10)   109 #define OR1K_BSP_UART_REG_MODEM_STATUS_DSR  (0x20)   110 #define OR1K_BSP_UART_REG_MODEM_STATUS_RI   (0x40)   111 #define OR1K_BSP_UART_REG_MODEM_STATUS_DCD  (0x80)   112 #define OR1K_BSP_UART_REG_MODEM_STATUS_ANY_DELTA (0x0F)
