42 #ifndef _INCLUDE_ERC32_h    43 #define _INCLUDE_ERC32_h    59 #define ERC32_INTERRUPT_MASKED_ERRORS             1    60 #define ERC32_INTERRUPT_EXTERNAL_1                2    61 #define ERC32_INTERRUPT_EXTERNAL_2                3    62 #define ERC32_INTERRUPT_UART_A_RX_TX              4    63 #define ERC32_INTERRUPT_UART_B_RX_TX              5    64 #define ERC32_INTERRUPT_CORRECTABLE_MEMORY_ERROR  6    65 #define ERC32_INTERRUPT_UART_ERROR                7    66 #define ERC32_INTERRUPT_DMA_ACCESS_ERROR          8    67 #define ERC32_INTERRUPT_DMA_TIMEOUT               9    68 #define ERC32_INTERRUPT_EXTERNAL_3               10    69 #define ERC32_INTERRUPT_EXTERNAL_4               11    70 #define ERC32_INTERRUPT_GENERAL_PURPOSE_TIMER    12    71 #define ERC32_INTERRUPT_REAL_TIME_CLOCK          13    72 #define ERC32_INTERRUPT_EXTERNAL_5               14    73 #define ERC32_INTERRUPT_WATCHDOG_TIMEOUT         15    86 #define ERC32_TRAP_TYPE( _source ) SPARC_ASYNCHRONOUS_TRAP((_source) + 0x10)    88 #define ERC32_TRAP_SOURCE( _trap ) ((_trap) - 0x10)    90 #define ERC32_Is_MEC_Trap( _trap ) \    91   ( (_trap) >= ERC32_TRAP_TYPE( ERC32_INTERRUPT_MASKED_ERRORS ) && \    92     (_trap) <= ERC32_TRAP_TYPE( ERC32_INTERRUPT_WATCHDOG_TIMEOUT ) )   105   volatile uint32_t    Control;
   106   volatile uint32_t    Software_Reset;
   107   volatile uint32_t    Power_Down;
   108   volatile uint32_t    Unimplemented_0;
   109   volatile uint32_t    Memory_Configuration;
   110   volatile uint32_t    IO_Configuration;
   111   volatile uint32_t    Wait_State_Configuration;
   112   volatile uint32_t    Unimplemented_1;
   113   volatile uint32_t    Memory_Access_0;
   114   volatile uint32_t    Memory_Access_1;
   115   volatile uint32_t    Unimplemented_2[ 7 ];
   116   volatile uint32_t    Interrupt_Shape;
   117   volatile uint32_t    Interrupt_Pending;
   118   volatile uint32_t    Interrupt_Mask;
   119   volatile uint32_t    Interrupt_Clear;
   120   volatile uint32_t    Interrupt_Force;
   121   volatile uint32_t    Unimplemented_3[ 2 ];
   123   volatile uint32_t    Watchdog_Program_and_Timeout_Acknowledge;
   124   volatile uint32_t    Watchdog_Trap_Door_Set;
   125   volatile uint32_t    Unimplemented_4[ 6 ];
   126   volatile uint32_t    Real_Time_Clock_Counter;
   127   volatile uint32_t    Real_Time_Clock_Scalar;
   128   volatile uint32_t    General_Purpose_Timer_Counter;
   129   volatile uint32_t    General_Purpose_Timer_Scalar;
   130   volatile uint32_t    Unimplemented_5[ 2 ];
   132   volatile uint32_t    Unimplemented_6;
   133   volatile uint32_t    System_Fault_Status;
   134   volatile uint32_t    First_Failing_Address;
   135   volatile uint32_t    First_Failing_Data;
   136   volatile uint32_t    First_Failing_Syndrome_and_Check_Bits;
   137   volatile uint32_t    Error_and_Reset_Status;
   138   volatile uint32_t    Error_Mask;
   139   volatile uint32_t    Unimplemented_7[ 2 ];
   140   volatile uint32_t    Debug_Control;
   141   volatile uint32_t    Breakpoint;
   142   volatile uint32_t    Watchpoint;
   143   volatile uint32_t    Unimplemented_8;
   144   volatile uint32_t    Test_Control;
   145   volatile uint32_t    Test_Data;
   146   volatile uint32_t    Unimplemented_9[ 2 ];
   147   volatile uint32_t    UART_Channel_A;
   148   volatile uint32_t    UART_Channel_B;
   149   volatile uint32_t    UART_Status;
   165 #define  ERC32_MEC_CONTROL_OFFSET                                  0x00   166 #define  ERC32_MEC_SOFTWARE_RESET_OFFSET                           0x04   167 #define  ERC32_MEC_POWER_DOWN_OFFSET                               0x08   168 #define  ERC32_MEC_UNIMPLEMENTED_0_OFFSET                          0x0C   169 #define  ERC32_MEC_MEMORY_CONFIGURATION_OFFSET                     0x10   170 #define  ERC32_MEC_IO_CONFIGURATION_OFFSET                         0x14   171 #define  ERC32_MEC_WAIT_STATE_CONFIGURATION_OFFSET                 0x18   172 #define  ERC32_MEC_UNIMPLEMENTED_1_OFFSET                          0x1C   173 #define  ERC32_MEC_MEMORY_ACCESS_0_OFFSET                          0x20   174 #define  ERC32_MEC_MEMORY_ACCESS_1_OFFSET                          0x24   175 #define  ERC32_MEC_UNIMPLEMENTED_2_OFFSET                          0x28   176 #define  ERC32_MEC_INTERRUPT_SHAPE_OFFSET                          0x44   177 #define  ERC32_MEC_INTERRUPT_PENDING_OFFSET                        0x48   178 #define  ERC32_MEC_INTERRUPT_MASK_OFFSET                           0x4C   179 #define  ERC32_MEC_INTERRUPT_CLEAR_OFFSET                          0x50   180 #define  ERC32_MEC_INTERRUPT_FORCE_OFFSET                          0x54   181 #define  ERC32_MEC_UNIMPLEMENTED_3_OFFSET                          0x58   182 #define  ERC32_MEC_WATCHDOG_PROGRAM_AND_TIMEOUT_ACKNOWLEDGE_OFFSET 0x60   183 #define  ERC32_MEC_WATCHDOG_TRAP_DOOR_SET_OFFSET                   0x64   184 #define  ERC32_MEC_UNIMPLEMENTED_4_OFFSET                          0x6C   185 #define  ERC32_MEC_REAL_TIME_CLOCK_COUNTER_OFFSET                  0x80   186 #define  ERC32_MEC_REAL_TIME_CLOCK_SCALAR_OFFSET                   0x84   187 #define  ERC32_MEC_GENERAL_PURPOSE_TIMER_COUNTER_OFFSET            0x88   188 #define  ERC32_MEC_GENERAL_PURPOSE_TIMER_SCALAR_OFFSET             0x8C   189 #define  ERC32_MEC_UNIMPLEMENTED_5_OFFSET                          0x90   190 #define  ERC32_MEC_TIMER_CONTROL_OFFSET                            0x98   191 #define  ERC32_MEC_UNIMPLEMENTED_6_OFFSET                          0x9C   192 #define  ERC32_MEC_SYSTEM_FAULT_STATUS_OFFSET                      0xA0   193 #define  ERC32_MEC_FIRST_FAILING_ADDRESS_OFFSET                    0xA4   194 #define  ERC32_MEC_FIRST_FAILING_DATA_OFFSET                       0xA8   195 #define  ERC32_MEC_FIRST_FAILING_SYNDROME_AND_CHECK_BITS_OFFSET    0xAC   196 #define  ERC32_MEC_ERROR_AND_RESET_STATUS_OFFSET                   0xB0   197 #define  ERC32_MEC_ERROR_MASK_OFFSET                               0xB4   198 #define  ERC32_MEC_UNIMPLEMENTED_7_OFFSET                          0xB8   199 #define  ERC32_MEC_DEBUG_CONTROL_OFFSET                            0xC0   200 #define  ERC32_MEC_BREAKPOINT_OFFSET                               0xC4   201 #define  ERC32_MEC_WATCHPOINT_OFFSET                               0xC8   202 #define  ERC32_MEC_UNIMPLEMENTED_8_OFFSET                          0xCC   203 #define  ERC32_MEC_TEST_CONTROL_OFFSET                             0xD0   204 #define  ERC32_MEC_TEST_DATA_OFFSET                                0xD4   205 #define  ERC32_MEC_UNIMPLEMENTED_9_OFFSET                          0xD8   206 #define  ERC32_MEC_UART_CHANNEL_A_OFFSET                           0xE0   207 #define  ERC32_MEC_UART_CHANNEL_B_OFFSET                           0xE4   208 #define  ERC32_MEC_UART_STATUS_OFFSET                              0xE8   216 #define ERC32_CONFIGURATION_POWER_DOWN_MASK               0x00000001   217 #define ERC32_CONFIGURATION_POWER_DOWN_ALLOWED            0x00000001   218 #define ERC32_CONFIGURATION_POWER_DOWN_DISABLED           0x00000000   220 #define ERC32_CONFIGURATION_SOFTWARE_RESET_MASK           0x00000002   221 #define ERC32_CONFIGURATION_SOFTWARE_RESET_ALLOWED        0x00000002   222 #define ERC32_CONFIGURATION_SOFTWARE_RESET_DISABLED       0x00000000   224 #define ERC32_CONFIGURATION_BUS_TIMEOUT_MASK              0x00000004   225 #define ERC32_CONFIGURATION_BUS_TIMEOUT_ENABLED           0x00000004   226 #define ERC32_CONFIGURATION_BUS_TIMEOUT_DISABLED          0x00000000   228 #define ERC32_CONFIGURATION_ACCESS_PROTECTION_MASK        0x00000008   229 #define ERC32_CONFIGURATION_ACCESS_PROTECTION_ENABLED     0x00000008   230 #define ERC32_CONFIGURATION_ACCESS_PROTECTION_DISABLED    0x00000000   236 #define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_MASK  0x00001C00   237 #define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_256K  ( 0 << 10 )   238 #define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_512K  ( 1 << 10 )   239 #define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_1MB   ( 2 << 10 )   240 #define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_2MB   ( 3 << 10 )   241 #define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_4MB   ( 4 << 10 )   242 #define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_8MB   ( 5 << 10 )   243 #define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_16MB  ( 6 << 10 )   244 #define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_32MB  ( 7 << 10 )   246 #define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_MASK  0x001C0000   247 #define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_128K    ( 0 << 18 )   248 #define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_256K    ( 1 << 18 )   249 #define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_512K   ( 2 << 18 )   250 #define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_1M   ( 3 << 18 )   251 #define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_2M   ( 4 << 18 )   252 #define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_4M  ( 5 << 18 )   253 #define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_8M  ( 6 << 18 )   254 #define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_16M  ( 7 << 18 )   260 #define ERC32_MEC_TIMER_CONTROL_GCR   0x00000001    262 #define ERC32_MEC_TIMER_CONTROL_GCL   0x00000002    264 #define ERC32_MEC_TIMER_CONTROL_GSE   0x00000004    266 #define ERC32_MEC_TIMER_CONTROL_GSL   0x00000008    269 #define ERC32_MEC_TIMER_CONTROL_RTCCR 0x00000100    271 #define ERC32_MEC_TIMER_CONTROL_RTCCL 0x00000200    273 #define ERC32_MEC_TIMER_CONTROL_RTCSE 0x00000400    275 #define ERC32_MEC_TIMER_CONTROL_RTCSL 0x00000800    283 #define ERC32_MEC_UART_CONTROL_RTD  0x000000FF    289 #define ERC32_MEC_UART_STATUS_DR   0x00000001    290 #define ERC32_MEC_UART_STATUS_TSE  0x00000002    291 #define ERC32_MEC_UART_STATUS_THE  0x00000004    292 #define ERC32_MEC_UART_STATUS_FE   0x00000010    293 #define ERC32_MEC_UART_STATUS_PE   0x00000020    294 #define ERC32_MEC_UART_STATUS_OE   0x00000040    295 #define ERC32_MEC_UART_STATUS_CU   0x00000080    296 #define ERC32_MEC_UART_STATUS_TXE  0x00000006    297 #define ERC32_MEC_UART_STATUS_CLRA 0x00000080    298 #define ERC32_MEC_UART_STATUS_CLRB 0x00800000    299 #define ERC32_MEC_UART_STATUS_ERRA 0x00000070    300 #define ERC32_MEC_UART_STATUS_ERRB 0x00700000    302 #define ERC32_MEC_UART_STATUS_DRA   (ERC32_MEC_UART_STATUS_DR  << 0)   303 #define ERC32_MEC_UART_STATUS_TSEA  (ERC32_MEC_UART_STATUS_TSE << 0)   304 #define ERC32_MEC_UART_STATUS_THEA  (ERC32_MEC_UART_STATUS_THE << 0)   305 #define ERC32_MEC_UART_STATUS_FEA   (ERC32_MEC_UART_STATUS_FE  << 0)   306 #define ERC32_MEC_UART_STATUS_PEA   (ERC32_MEC_UART_STATUS_PE  << 0)   307 #define ERC32_MEC_UART_STATUS_OEA   (ERC32_MEC_UART_STATUS_OE  << 0)   308 #define ERC32_MEC_UART_STATUS_CUA   (ERC32_MEC_UART_STATUS_CU  << 0)   309 #define ERC32_MEC_UART_STATUS_TXEA  (ERC32_MEC_UART_STATUS_TXE << 0)   311 #define ERC32_MEC_UART_STATUS_DRB   (ERC32_MEC_UART_STATUS_DR  << 16)   312 #define ERC32_MEC_UART_STATUS_TSEB  (ERC32_MEC_UART_STATUS_TSE << 16)   313 #define ERC32_MEC_UART_STATUS_THEB  (ERC32_MEC_UART_STATUS_THE << 16)   314 #define ERC32_MEC_UART_STATUS_FEB   (ERC32_MEC_UART_STATUS_FE  << 16)   315 #define ERC32_MEC_UART_STATUS_PEB   (ERC32_MEC_UART_STATUS_PE  << 16)   316 #define ERC32_MEC_UART_STATUS_OEB   (ERC32_MEC_UART_STATUS_OE  << 16)   317 #define ERC32_MEC_UART_STATUS_CUB   (ERC32_MEC_UART_STATUS_CU  << 16)   318 #define ERC32_MEC_UART_STATUS_TXEB  (ERC32_MEC_UART_STATUS_TXE << 16)   331 static __inline__
int bsp_irq_fixup(
int irq)
   346 #define ERC32_Clear_interrupt( _source ) \   348     ERC32_MEC.Interrupt_Clear = (1 << (_source)); \   351 #define ERC32_Force_interrupt( _source ) \   355     _level = sparc_disable_interrupts(); \   356     ERC32_MEC.Test_Control = ERC32_MEC.Test_Control | 0x80000; \   357     ERC32_MEC.Interrupt_Force = (1 << (_source)); \   358     sparc_enable_interrupts( _level ); \   361 #define ERC32_Is_interrupt_pending( _source ) \   362   (ERC32_MEC.Interrupt_Pending & (1 << (_source)))   364 #define ERC32_Is_interrupt_masked( _source ) \   365   (ERC32_MEC.Interrupt_Mask & (1 << (_source)))   367 #define ERC32_Mask_interrupt( _source ) \   371     _level = sparc_disable_interrupts(); \   372       ERC32_MEC.Interrupt_Mask |= (1 << (_source)); \   373     sparc_enable_interrupts( _level ); \   376 #define ERC32_Unmask_interrupt( _source ) \   380     _level = sparc_disable_interrupts(); \   381       ERC32_MEC.Interrupt_Mask &= ~(1 << (_source)); \   382     sparc_enable_interrupts( _level ); \   385 #define ERC32_Disable_interrupt( _source, _previous ) \   388     uint32_t   _mask = 1 << (_source); \   390     _level = sparc_disable_interrupts(); \   391       (_previous) = ERC32_MEC.Interrupt_Mask; \   392       ERC32_MEC.Interrupt_Mask = _previous | _mask; \   393     sparc_enable_interrupts( _level ); \   394     (_previous) &= _mask; \   397 #define ERC32_Restore_interrupt( _source, _previous ) \   400     uint32_t   _mask = 1 << (_source); \   402     _level = sparc_disable_interrupts(); \   403       ERC32_MEC.Interrupt_Mask = \   404         (ERC32_MEC.Interrupt_Mask & ~_mask) | (_previous); \   405     sparc_enable_interrupts( _level ); \   409 #define BSP_Clear_interrupt(_source) ERC32_Clear_interrupt(_source)   410 #define BSP_Force_interrupt(_source) ERC32_Force_interrupt(_source)   411 #define BSP_Is_interrupt_pending(_source) ERC32_Is_interrupt_pending(_source)   412 #define BSP_Is_interrupt_masked(_source) ERC32_Is_interrupt_masked(_source)   413 #define BSP_Unmask_interrupt(_source) ERC32_Unmask_interrupt(_source)   414 #define BSP_Mask_interrupt(_source) ERC32_Mask_interrupt(_source)   415 #define BSP_Disable_interrupt(_source, _previous) \   416         ERC32_Disable_interrupt(_source, _prev)   417 #define BSP_Restore_interrupt(_source, _previous) \   418         ERC32_Restore_interrupt(_source, _previous)   421 #define BSP_Cpu_Is_interrupt_masked(_source, _cpu) \   422         BSP_Is_interrupt_masked(_source)   423 #define BSP_Cpu_Unmask_interrupt(_source, _cpu) \   424         BSP_Unmask_interrupt(_source)   425 #define BSP_Cpu_Mask_interrupt(_source, _cpu) \   426         BSP_Mask_interrupt(_source)   427 #define BSP_Cpu_Disable_interrupt(_source, _previous, _cpu) \   428         BSP_Disable_interrupt(_source, _prev)   429 #define BSP_Cpu_Restore_interrupt(_source, _previous, _cpu) \   430         BSP_Cpu_Restore_interrupt(_source, _previous)   467 #define ERC32_MEC_TIMER_COUNTER_RELOAD_AT_ZERO     0x00000001   468 #define ERC32_MEC_TIMER_COUNTER_STOP_AT_ZERO       0x00000000   470 #define ERC32_MEC_TIMER_COUNTER_LOAD_COUNTER       0x00000002   472 #define ERC32_MEC_TIMER_COUNTER_ENABLE_COUNTING    0x00000004   473 #define ERC32_MEC_TIMER_COUNTER_DISABLE_COUNTING   0x00000000   475 #define ERC32_MEC_TIMER_COUNTER_LOAD_SCALER        0x00000008   477 #define ERC32_MEC_TIMER_COUNTER_RELOAD_MASK        0x00000001   478 #define ERC32_MEC_TIMER_COUNTER_ENABLE_MASK        0x00000004   480 #define ERC32_MEC_TIMER_COUNTER_DEFINED_MASK       0x0000000F   481 #define ERC32_MEC_TIMER_COUNTER_CURRENT_MODE_MASK  0x00000005   483 extern uint32_t   _ERC32_MEC_Timer_Control_Mirror;
   491 #define ERC32_MEC_Set_General_Purpose_Timer_Control( _value ) \   497     __value = ((_value) & 0x0f); \   498     _level = sparc_disable_interrupts(); \   499       _control = _ERC32_MEC_Timer_Control_Mirror; \   500       _control &= ERC32_MEC_TIMER_COUNTER_DEFINED_MASK << 8; \   501       _ERC32_MEC_Timer_Control_Mirror = _control | _value; \   502       _control &= (ERC32_MEC_TIMER_COUNTER_CURRENT_MODE_MASK << 8); \   503       _control |= __value; \   505       ERC32_MEC.Timer_Control = _control; \   506     sparc_enable_interrupts( _level ); \   509 #define ERC32_MEC_Get_General_Purpose_Timer_Control( _value ) \   511     (_value) = _ERC32_MEC_Timer_Control_Mirror & 0xf; \   520 #define ERC32_MEC_Set_Real_Time_Clock_Timer_Control( _value ) \   526     __value = ((_value) & 0x0f) << 8; \   527     _level = sparc_disable_interrupts(); \   528       _control = _ERC32_MEC_Timer_Control_Mirror; \   529       _control &= ERC32_MEC_TIMER_COUNTER_DEFINED_MASK; \   530       _ERC32_MEC_Timer_Control_Mirror = _control | __value; \   531       _control &= ERC32_MEC_TIMER_COUNTER_CURRENT_MODE_MASK; \   532       _control |= __value; \   534       ERC32_MEC.Timer_Control = _control; \   535     sparc_enable_interrupts( _level ); \   538 #define ERC32_MEC_Get_Real_Time_Clock_Timer_Control( _value ) \   540     (_value) = (_ERC32_MEC_Timer_Control_Mirror >> 8) & 0xf; \ Information Required to Build RTEMS for a Particular Member of the SPARC Family.
Definition: timerdata.h:41
