10 #ifndef _DRIVER_MANAGER_H_    11 #define _DRIVER_MANAGER_H_    14 #include <drvmgr/drvmgr_list.h>    26 #define DRVMGR_LEVEL_MAX 4    31 #ifndef DRVMGR_USE_LOCKS    32 #define DRVMGR_USE_LOCKS 1    40 #define BUS_LIST_HEAD(list) LIST_HEAD(list, struct drvmgr_bus)    41 #define BUS_LIST_TAIL(list) LIST_TAIL(list, struct drvmgr_bus)    42 #define DEV_LIST_HEAD(list) LIST_HEAD(list, struct drvmgr_dev)    43 #define DEV_LIST_TAIL(list) LIST_TAIL(list, struct drvmgr_dev)    44 #define DRV_LIST_HEAD(list) LIST_HEAD(list, struct drvmgr_drv)    45 #define DRV_LIST_TAIL(list) LIST_TAIL(list, struct drvmgr_drv)    48 #define DRVMGR_BUS_TYPE_NONE 0          49 #define DRVMGR_BUS_TYPE_ROOT 1          50 #define DRVMGR_BUS_TYPE_PCI 2           51 #define DRVMGR_BUS_TYPE_AMBAPP 3        52 #define DRVMGR_BUS_TYPE_LEON2_AMBA 4        53 #define DRVMGR_BUS_TYPE_AMBAPP_DIST 5       54 #define DRVMGR_BUS_TYPE_SPW_RMAP 6      55 #define DRVMGR_BUS_TYPE_AMBAPP_RMAP 7       80 #define DRIVER_ID_BUS_MASK 0x00000000000000FFULL    83 #define DRIVER_ID_RSV_MASK 0xFF00000000000000ULL    86 #define DRIVER_ID_DEV_MASK 0x00FFFFFFFFFFFF00ULL    89 #define DRIVER_ID(busid, devid) ((unsigned long long) \    90     ((((unsigned long long)(devid) << 8) & DRIVER_ID_DEV_MASK) | \    91      ((unsigned long long)(busid) & DRIVER_ID_BUS_MASK)))    94 #define DRIVER_BUSID_GET(id)    ((unsigned long long)(id) & DRIVER_ID_BUS_MASK)    95 #define DRIVER_DEVID_GET(id)    (((unsigned long long)(id) & DRIVER_ID_DEV_MASK) >> 8)    97 #define DRIVER_ROOTBUS_ID(bus_type) DRIVER_ID(bus_type, 0)   102 #define DRIVER_ROOT_ID      DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_ROOT)   105 #define DRIVER_PCIBUS_ID    DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_PCI)   108 #define DRIVER_GRLIB_AMBAPP_ID  DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_AMBAPP)   111 #define DRIVER_LEON2_AMBA_ID    DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_LEON2_AMBA)   114 #define DRIVER_AMBAPP_DIST_ID   DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_AMBAPP_DIST)   126 typedef void (*drvmgr_isr)(
void *arg);
   131     int (*init[DRVMGR_LEVEL_MAX])(
struct drvmgr_bus *);
   136     int (*int_register)(
struct drvmgr_dev *,
int index,
const char *info, drvmgr_isr isr,
void *arg);
   137     int (*int_unregister)(
int index, drvmgr_isr isr,
void *arg);
   138     int (*int_clear)(
int index);
   139     int (*int_mask)(
int index);
   140     int (*int_unmask)(
int index);
   142     int (*int_set_affinity)(
int index,
   143                     const Processor_mask *cpus);
   149     int (*get_freq)(
struct drvmgr_dev*, int,
unsigned int*);
   154                 void (*print)(
void *
p,
char *str),
void *
p);
   156 #define BUS_OPS_NUM (sizeof(struct drvmgr_bus_ops)/sizeof(void (*)(void)))   162 #define DRVMGR_FUNC(_ID_, _FUNC_) {(int)(_ID_), (void *)(_FUNC_)}   163 #define DRVMGR_FUNC_END {0, NULL}   182     DRVMGR_KT_STRING = 2,
   183     DRVMGR_KT_POINTER = 3,
   186 #define DRVMGR_KEY_EMPTY    {NULL, DRVMGR_KT_NONE, {0}}   187 #define DRVMGR_RES_EMPTY    {0, 0, NULL}   188 #define MMAP_EMPTY  {0, 0, 0}   200     enum drvmgr_kt      key_type;
   233 #define DRVMGR_TRANSLATE_ONE2ONE    NULL   234 #define DRVMGR_TRANSLATE_NO_BRIDGE  ((void *)1)     259 #define BUS_STATE_INIT_FAILED   0x00000001     260 #define BUS_STATE_LIST_INACTIVE 0x00001000     261 #define BUS_STATE_DEPEND_FAILED 0x00000004     264 #define DEV_STATE_INIT_FAILED   0x00000001     265 #define DEV_STATE_INIT_DONE 0x00000002     266 #define DEV_STATE_DEPEND_FAILED 0x00000004     267 #define DEV_STATE_UNITED    0x00000100     268 #define DEV_STATE_REMOVED   0x00000200     269 #define DEV_STATE_IGNORED   0x00000400     272 #define DEV_STATE_LIST_INACTIVE 0x00001000     298     int (*init[DRVMGR_LEVEL_MAX])(
struct drvmgr_dev *);
   300     int (*
info)(
struct drvmgr_dev *, void (*print)(
void *
p,
char *str),
void *
p,
int,
char *argv[]);
   302 #define DRVMGR_OPS_NUM(x) (sizeof(x)/sizeof(void (*)(void)))   323 typedef void (*drvmgr_drv_reg_func)(void);
   344 extern void _DRV_Manager_initialization(
void);
   351 extern void _DRV_Manager_init_level(
int level);
   358 extern int drvmgr_init(
void);
   364 extern void drvmgr_init_update(
void);
   367 extern int drvmgr_root_drv_register(
struct drvmgr_drv *drv);
   370 extern int drvmgr_drv_register(
   373 extern int drvmgr_dev_register(
struct drvmgr_dev *dev);
   385 extern int drvmgr_dev_unregister(
   388 extern int drvmgr_bus_register(
struct drvmgr_bus *bus);
   391 extern int drvmgr_bus_unregister(
   398 extern int drvmgr_children_unregister(
   401 extern int drvmgr_dev_drv_separate(
   409 extern int drvmgr_alloc_dev(
struct drvmgr_dev **pdev,
int extra);
   417 extern int drvmgr_alloc_bus(
struct drvmgr_bus **pbus,
int extra);
   427 extern void drvmgr_bus_res_add(
struct drvmgr_bus *bus,
   461     enum drvmgr_kt key_type);
   478     enum drvmgr_kt key_type);
   513 #define DRVMGR_FED_BF 1        514 #define DRVMGR_FED_DF 0        515 extern intptr_t drvmgr_for_each_dev(
   528 extern int drvmgr_get_dev(
   539 extern int drvmgr_freq_get(
   542     unsigned int *freq_hz);
   553 extern int drvmgr_get_dev_prefix(
struct drvmgr_dev *
dev,
char *dev_prefix);
   568 extern int drvmgr_interrupt_register(
   585 extern int drvmgr_interrupt_unregister(
   600 extern int drvmgr_interrupt_clear(
   614 extern int drvmgr_interrupt_unmask(
   626 extern int drvmgr_interrupt_mask(
   639 extern int drvmgr_interrupt_set_affinity(
   642     const Processor_mask *cpus);
   646 enum drvmgr_tr_opts {
   665     CPUMEM_FROM_DMA = 0x1,
   681     DMAMEM_FROM_CPU = 0x3,
   683 #define DRVMGR_TR_REVERSE 0x1      684 #define DRVMGR_TR_PATH 0x2     722 extern unsigned int drvmgr_translate(
   724     unsigned int options,
   747 extern unsigned int drvmgr_translate_bus(
   762 extern int drvmgr_translate_check(
   764     unsigned int options,
   773 extern int drvmgr_func_get(
void *obj,
int funcid,
void **func);
   776 extern int drvmgr_func_call(
void *obj,
int funcid,
void *a,
void *b,
void *c,
void *d);
   782 #define DRVMGR_FUNCID(major, minor) ((((major) & 0xfff) << 20) | ((minor) & 0xfffff))   783 #define DRVMGR_FUNCID_NONE 0   784 #define DRVMGR_FUNCID_END DRVMGR_FUNCID(DRVMGR_FUNCID_NONE, 0)   793 #define RW_SIZE_1   0x00001       794 #define RW_SIZE_2   0x00002   795 #define RW_SIZE_4   0x00004   796 #define RW_SIZE_8   0x00008   797 #define RW_SIZE_ANY 0x00000   798 #define RW_SIZE(id) ((unsigned int)(id) & 0xf)   800 #define RW_DIR_ANY  0x00000      801 #define RW_READ     0x00000      802 #define RW_WRITE    0x00010      803 #define RW_SET      0x00020      804 #define RW_DIR(id)  (((unsigned int)(id) >> 4) & 0x3)   806 #define RW_RAW      0x00000     807 #define RW_LITTLE   0x00040     808 #define RW_BIG      0x00080     809 #define RW_ENDIAN(id) (((unsigned int)(id) >> 6) & 0x3)   811 #define RW_TYPE_ANY 0x00000     812 #define RW_REG      0x00100   813 #define RW_MEM      0x00200   814 #define RW_MEMREG   0x00300   815 #define RW_CFG      0x00400   816 #define RW_TYPE(id) (((unsigned int)(id) >> 8) & 0xf)   818 #define RW_ARG      0x01000    819 #define RW_ERR      0x02000    822 #define DRVMGR_RWFUNC(minor) DRVMGR_FUNCID(FUNCID_RW, minor)   833 typedef uint8_t (*drvmgr_r8)(uint8_t *srcadr);
   834 typedef uint16_t (*drvmgr_r16)(uint16_t *srcadr);
   835 typedef uint32_t (*drvmgr_r32)(uint32_t *srcadr);
   836 typedef uint64_t (*drvmgr_r64)(uint64_t *srcadr);
   837 typedef void (*drvmgr_w8)(uint8_t *dstadr, uint8_t data);
   838 typedef void (*drvmgr_w16)(uint16_t *dstadr, uint16_t data);
   839 typedef void (*drvmgr_w32)(uint32_t *dstadr, uint32_t data);
   840 typedef void (*drvmgr_w64)(uint64_t *dstadr, uint64_t data);
   844 typedef int (*drvmgr_rmem)(
void *dest,
const void *src,
int n);
   848 typedef int (*drvmgr_wmem)(
void *dest,
const void *src,
int n);
   852 typedef int (*drvmgr_memset)(
void *dstadr,
int c,
size_t n);
   855 typedef uint8_t (*drvmgr_r8_arg)(uint8_t *srcadr,
void *a);
   856 typedef uint16_t (*drvmgr_r16_arg)(uint16_t *srcadr,
void *a);
   857 typedef uint32_t (*drvmgr_r32_arg)(uint32_t *srcadr,
void *a);
   858 typedef uint64_t (*drvmgr_r64_arg)(uint64_t *srcadr,
void *a);
   859 typedef void (*drvmgr_w8_arg)(uint8_t *dstadr, uint8_t data,
void *a);
   860 typedef void (*drvmgr_w16_arg)(uint16_t *dstadr, uint16_t data,
void *a);
   861 typedef void (*drvmgr_w32_arg)(uint32_t *dstadr, uint32_t data,
void *a);
   862 typedef void (*drvmgr_w64_arg)(uint64_t *dstadr, uint64_t data,
void *a);
   863 typedef int (*drvmgr_rmem_arg)(
void *dest,
const void *src,
int n,
void *a);
   864 typedef int (*drvmgr_wmem_arg)(
void *dest,
const void *src,
int n,
void *a);
   865 typedef int (*drvmgr_memset_arg)(
void *dstadr,
int c,
size_t n,
void *a);
   869                 int funcid,
void *adr);
   872 extern void drvmgr_rw_memset(
   906 extern int drvmgr_for_each_listdev(
   908     unsigned int state_set_mask,
   909     unsigned int state_clr_mask,
   914 #define PRINT_DEVS_FAILED   0x01       915 #define PRINT_DEVS_ASSIGNED 0x02       916 #define PRINT_DEVS_UNASSIGNED   0x04       917 #define PRINT_DEVS_IGNORED  0x08       918 #define PRINT_DEVS_ALL      (PRINT_DEVS_FAILED | \   919                 PRINT_DEVS_ASSIGNED | \   920                 PRINT_DEVS_UNASSIGNED |\   924 extern void drvmgr_summary(
void);
   927 extern void drvmgr_print_devs(
unsigned int options);
   930 extern void drvmgr_print_topo(
void);
   935 extern void drvmgr_print_mem(
void);
   937 #define OPTION_DEV_GENINFO   0x00000001   938 #define OPTION_DEV_BUSINFO   0x00000002   939 #define OPTION_DEV_DRVINFO   0x00000004   940 #define OPTION_DRV_DEVS      0x00000100   941 #define OPTION_BUS_DEVS      0x00010000   942 #define OPTION_RECURSIVE     0x01000000   943 #define OPTION_INFO_ALL      0xffffffff   946 extern void drvmgr_info(
void *
id,
   949 extern void drvmgr_info_dev(
struct drvmgr_dev *
dev,
   952 extern void drvmgr_info_bus(
   955 extern void drvmgr_info_drv(
struct drvmgr_drv *drv,
   958 extern void drvmgr_info_devs_on_bus(
   961 extern void drvmgr_info_devs(
   964 extern void drvmgr_info_drvs(
   967 extern void drvmgr_info_buses(
   970 extern struct drvmgr_drv *drvmgr_drv_by_id(uint64_t
id);
   973 extern struct drvmgr_drv *drvmgr_drv_by_name(
const char *name);
   976 extern struct drvmgr_dev *drvmgr_dev_by_name(
const char *name);
 struct drvmgr_drv_ops * ops
Definition: drvmgr.h:313
unsigned int size
Definition: drvmgr.h:227
struct drvmgr_bus * parent
Definition: drvmgr.h:282
uint64_t drv_id
Definition: drvmgr.h:310
struct drvmgr_bus_res * reslist
Definition: drvmgr.h:248
int(* unite)(struct drvmgr_drv *, struct drvmgr_dev *)
Definition: drvmgr.h:133
struct drvmgr_drv * next
Definition: drvmgr.h:307
struct drvmgr_dev * children
Definition: drvmgr.h:244
int minor_bus
Definition: drvmgr.h:209
struct drvmgr_drv_res resource[]
Definition: drvmgr.h:216
int state
Definition: drvmgr.h:254
unsigned char bus_type
Definition: drvmgr.h:239
struct drvmgr_bus_ops * ops
Definition: drvmgr.h:245
struct drvmgr_bus * bus
Definition: drvmgr.h:288
struct drvmgr_map_entry * maps_up
Definition: drvmgr.h:249
void * priv
Definition: drvmgr.h:243
unsigned p
Definition: tte.h:90
char * str
Definition: drvmgr.h:193
int bus_type
Definition: drvmgr.h:312
struct drvmgr_func * funcs
Definition: drvmgr.h:314
void(* get_info_dev)(struct drvmgr_dev *, void(*print)(void *p, char *str), void *p)
Definition: drvmgr.h:153
char * from_adr
Definition: drvmgr.h:228
int(* info)(struct drvmgr_dev *, void(*print)(void *p, char *str), void *p, int, char *argv[])
Definition: drvmgr.h:300
struct drvmgr_dev * next_in_bus
Definition: drvmgr.h:278
unsigned int state
Definition: drvmgr.h:291
struct drvmgr_dev * dev
Definition: drvmgr.h:242
void * ptr
Definition: drvmgr.h:194
Definition: drvmgr.h:277
int obj_type
Definition: drvmgr.h:276
struct drvmgr_map_entry * maps_down
Definition: drvmgr.h:250
Definition: drvmgr.h:246
int dev_cnt
Definition: drvmgr.h:247
char * name
Definition: drvmgr.h:226
char * name
Definition: drvmgr.h:311
struct drvmgr_key * keys
Definition: drvmgr.h:210
struct drvmgr_dev * next_in_drv
Definition: drvmgr.h:279
char * dev_prefix
Definition: drvmgr.h:122
int error
Definition: drvmgr.h:293
int(* remove)(struct drvmgr_dev *)
Definition: drvmgr.h:299
unsigned int dev_cnt
Definition: drvmgr.h:315
void * businfo
Definition: drvmgr.h:287
int obj_type
Definition: drvmgr.h:306
Definition: drvmgr.h:308
int level
Definition: drvmgr.h:292
unsigned int i
Definition: drvmgr.h:192
short minor_bus
Definition: drvmgr.h:284
void * priv
Definition: drvmgr.h:286
int level
Definition: drvmgr.h:253
short minor_drv
Definition: drvmgr.h:283
unsigned size
Definition: tte.h:74
unsigned char depth
Definition: drvmgr.h:240
unsigned int dev_priv_size
Definition: drvmgr.h:316
struct drvmgr_drv * drv
Definition: drvmgr.h:281
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
char * name
Definition: drvmgr.h:285
struct drvmgr_bus * next
Definition: drvmgr.h:241
struct drvmgr_bus_res * next
Definition: drvmgr.h:215
Definition: drvmgr_list.h:24
SuperCore SMP Implementation.
int obj_type
Definition: drvmgr.h:238
char * to_adr
Definition: drvmgr.h:230
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
uint64_t drv_id
Definition: drvmgr.h:208
int error
Definition: drvmgr.h:255
