2 #define __DMA_IMAGE_H 1    29 #include "include/ppctypes.h"    31 void init_dma_image_TASK_PCI_TX(uint8 *vMem_taskBar, sint64 vMemOffset);
    32 void init_dma_image_TASK_PCI_RX(uint8 *vMem_taskBar, sint64 vMemOffset);
    33 void init_dma_image_TASK_FEC_TX(uint8 *vMem_taskBar, sint64 vMemOffset);
    34 void init_dma_image_TASK_FEC_RX(uint8 *vMem_taskBar, sint64 vMemOffset);
    35 void init_dma_image_TASK_LPC(uint8 *vMem_taskBar, sint64 vMemOffset);
    36 void init_dma_image_TASK_ATA(uint8 *vMem_taskBar, sint64 vMemOffset);
    37 void init_dma_image_TASK_CRC16_DP_0(uint8 *vMem_taskBar, sint64 vMemOffset);
    38 void init_dma_image_TASK_CRC16_DP_1(uint8 *vMem_taskBar, sint64 vMemOffset);
    39 void init_dma_image_TASK_GEN_DP_0(uint8 *vMem_taskBar, sint64 vMemOffset);
    40 void init_dma_image_TASK_GEN_DP_1(uint8 *vMem_taskBar, sint64 vMemOffset);
    41 void init_dma_image_TASK_GEN_DP_2(uint8 *vMem_taskBar, sint64 vMemOffset);
    42 void init_dma_image_TASK_GEN_DP_3(uint8 *vMem_taskBar, sint64 vMemOffset);
    43 void init_dma_image_TASK_GEN_TX_BD(uint8 *vMem_taskBar, sint64 vMemOffset);
    44 void init_dma_image_TASK_GEN_RX_BD(uint8 *vMem_taskBar, sint64 vMemOffset);
    45 void init_dma_image_TASK_GEN_DP_BD_0(uint8 *vMem_taskBar, sint64 vMemOffset);
    46 void init_dma_image_TASK_GEN_DP_BD_1(uint8 *vMem_taskBar, sint64 vMemOffset);
    49 #ifndef MBAR_TASK_TABLE    50 #define MBAR_TASK_TABLE                     0xf0008000UL    54 #define MBAR_DMA_FREE                       MBAR_TASK_TABLE + 0x00001500UL    57 #define TASK_BAR                            MBAR_TASK_TABLE + 0x00000000UL    58 #define TASK_BAR_OFFSET                     0x00000000UL    61     volatile uint32  TaskNum;
    62     volatile uint32 *PtrStartTDT;
    63     volatile uint32 *PtrEndTDT;
    64     volatile uint32 *PtrVarTab;
    65     volatile uint32 *PtrFDT;
    66     volatile uint32 *PtrCSave;
    67     volatile uint32  NumDRD;
    68     volatile uint32 *DRD[7];
    69     volatile uint32  NumVar;
    71     volatile uint32  NumInc;
    73     volatile uint8  *TaskPragma;
    74     volatile uint32 *AddrDstFIFO;
    75     volatile sint16 *IncrBytes;
    76     volatile uint32 *AddrPktSizeReg;
    77     volatile sint16 *IncrSrc;
    78     volatile uint32 *AddrSCStatusReg;
    79     volatile uint32 *Bytes;
    80     volatile uint32 *IterExtra;
    81     volatile uint32 *StartAddrSrc;
    86     volatile uint32  TaskNum;
    87     volatile uint32 *PtrStartTDT;
    88     volatile uint32 *PtrEndTDT;
    89     volatile uint32 *PtrVarTab;
    90     volatile uint32 *PtrFDT;
    91     volatile uint32 *PtrCSave;
    92     volatile uint32  NumDRD;
    93     volatile uint32 *DRD[5];
    94     volatile uint32  NumVar;
    96     volatile uint32  NumInc;
    98     volatile uint8  *TaskPragma;
    99     volatile uint32 *AddrPktSizeReg;
   100     volatile sint16 *IncrBytes;
   101     volatile uint32 *AddrSrcFIFO;
   102     volatile sint16 *IncrDst;
   103     volatile uint32 *Bytes;
   104     volatile uint32 *IterExtra;
   105     volatile uint32 *StartAddrDst;
   110     volatile uint32  TaskNum;
   111     volatile uint32 *PtrStartTDT;
   112     volatile uint32 *PtrEndTDT;
   113     volatile uint32 *PtrVarTab;
   114     volatile uint32 *PtrFDT;
   115     volatile uint32 *PtrCSave;
   116     volatile uint32  NumDRD;
   117     volatile uint32 *DRD[22];
   118     volatile uint32  NumVar;
   119     volatile uint32 *var;
   120     volatile uint32  NumInc;
   121     volatile uint32 *inc;
   122     volatile uint8  *TaskPragma;
   123     volatile uint32 *AddrDRD;
   124     volatile uint32  AddrDRDIdx;
   125     volatile sint16 *IncrBytes;
   126     volatile uint32 *AddrDstFIFO;
   127     volatile sint16 *IncrSrc;
   128     volatile uint32 *AddrEnable;
   129     volatile sint16 *IncrSrcMA;
   130     volatile uint32 *BDTableBase;
   131     volatile uint32 *BDTableLast;
   132     volatile uint32 *BDTableStart;
   133     volatile uint32 *Bytes;
   138     volatile uint32  TaskNum;
   139     volatile uint32 *PtrStartTDT;
   140     volatile uint32 *PtrEndTDT;
   141     volatile uint32 *PtrVarTab;
   142     volatile uint32 *PtrFDT;
   143     volatile uint32 *PtrCSave;
   144     volatile uint32  NumDRD;
   145     volatile uint32 *DRD[13];
   146     volatile uint32  NumVar;
   147     volatile uint32 *var;
   148     volatile uint32  NumInc;
   149     volatile uint32 *inc;
   150     volatile uint8  *TaskPragma;
   151     volatile uint32 *AddrEnable;
   152     volatile sint16 *IncrBytes;
   153     volatile uint32 *AddrSrcFIFO;
   154     volatile sint16 *IncrDst;
   155     volatile uint32 *BDTableBase;
   156     volatile sint16 *IncrDstMA;
   157     volatile uint32 *BDTableLast;
   158     volatile uint32 *BDTableStart;
   159     volatile uint32 *Bytes;
   164     volatile uint32  TaskNum;
   165     volatile uint32 *PtrStartTDT;
   166     volatile uint32 *PtrEndTDT;
   167     volatile uint32 *PtrVarTab;
   168     volatile uint32 *PtrFDT;
   169     volatile uint32 *PtrCSave;
   170     volatile uint32  NumDRD;
   171     volatile uint32 *DRD[4];
   172     volatile uint32  NumVar;
   173     volatile uint32 *var;
   174     volatile uint32  NumInc;
   175     volatile uint32 *inc;
   176     volatile uint8  *TaskPragma;
   177     volatile uint32 *Bytes;
   178     volatile sint16 *IncrBytes;
   179     volatile uint32 *IterExtra;
   180     volatile sint16 *IncrDst;
   181     volatile sint16 *IncrDstMA;
   182     volatile sint16 *IncrSrc;
   183     volatile uint32 *StartAddrDst;
   184     volatile sint16 *IncrSrcMA;
   185     volatile uint32 *StartAddrSrc;
   190     volatile uint32  TaskNum;
   191     volatile uint32 *PtrStartTDT;
   192     volatile uint32 *PtrEndTDT;
   193     volatile uint32 *PtrVarTab;
   194     volatile uint32 *PtrFDT;
   195     volatile uint32 *PtrCSave;
   196     volatile uint32  NumDRD;
   197     volatile uint32 *DRD[7];
   198     volatile uint32  NumVar;
   199     volatile uint32 *var;
   200     volatile uint32  NumInc;
   201     volatile uint32 *inc;
   202     volatile uint8  *TaskPragma;
   203     volatile uint32 *AddrEnable;
   204     volatile sint16 *IncrBytes;
   205     volatile uint32 *BDTableBase;
   206     volatile sint16 *IncrDst;
   207     volatile uint32 *BDTableLast;
   208     volatile sint16 *IncrSrc;
   209     volatile uint32 *BDTableStart;
   210     volatile uint32 *Bytes;
   215     volatile uint32  TaskNum;
   216     volatile uint32 *PtrStartTDT;
   217     volatile uint32 *PtrEndTDT;
   218     volatile uint32 *PtrVarTab;
   219     volatile uint32 *PtrFDT;
   220     volatile uint32 *PtrCSave;
   221     volatile uint32  NumDRD;
   222     volatile uint32 *DRD[9];
   223     volatile uint32  NumVar;
   224     volatile uint32 *var;
   225     volatile uint32  NumInc;
   226     volatile uint32 *inc;
   227     volatile uint8  *TaskPragma;
   228     volatile uint32 *Bytes;
   229     volatile sint16 *IncrBytes;
   230     volatile uint32 *IterExtra;
   231     volatile sint16 *IncrDst;
   232     volatile sint16 *IncrDstMA;
   233     volatile sint16 *IncrSrc;
   234     volatile uint32 *StartAddrDst;
   235     volatile sint16 *IncrSrcMA;
   236     volatile uint32 *StartAddrSrc;
   241     volatile uint32  TaskNum;
   242     volatile uint32 *PtrStartTDT;
   243     volatile uint32 *PtrEndTDT;
   244     volatile uint32 *PtrVarTab;
   245     volatile uint32 *PtrFDT;
   246     volatile uint32 *PtrCSave;
   247     volatile uint32  NumDRD;
   248     volatile uint32 *DRD[9];
   249     volatile uint32  NumVar;
   250     volatile uint32 *var;
   251     volatile uint32  NumInc;
   252     volatile uint32 *inc;
   253     volatile uint8  *TaskPragma;
   254     volatile uint32 *Bytes;
   255     volatile sint16 *IncrBytes;
   256     volatile uint32 *IterExtra;
   257     volatile sint16 *IncrDst;
   258     volatile sint16 *IncrDstMA;
   259     volatile sint16 *IncrSrc;
   260     volatile uint32 *StartAddrDst;
   261     volatile sint16 *IncrSrcMA;
   262     volatile uint32 *StartAddrSrc;
   267     volatile uint32  TaskNum;
   268     volatile uint32 *PtrStartTDT;
   269     volatile uint32 *PtrEndTDT;
   270     volatile uint32 *PtrVarTab;
   271     volatile uint32 *PtrFDT;
   272     volatile uint32 *PtrCSave;
   273     volatile uint32  NumDRD;
   274     volatile uint32 *DRD[4];
   275     volatile uint32  NumVar;
   276     volatile uint32 *var;
   277     volatile uint32  NumInc;
   278     volatile uint32 *inc;
   279     volatile uint8  *TaskPragma;
   280     volatile uint32 *Bytes;
   281     volatile sint16 *IncrBytes;
   282     volatile uint32 *IterExtra;
   283     volatile sint16 *IncrDst;
   284     volatile sint16 *IncrDstMA;
   285     volatile sint16 *IncrSrc;
   286     volatile uint32 *StartAddrDst;
   287     volatile sint16 *IncrSrcMA;
   288     volatile uint32 *StartAddrSrc;
   293     volatile uint32  TaskNum;
   294     volatile uint32 *PtrStartTDT;
   295     volatile uint32 *PtrEndTDT;
   296     volatile uint32 *PtrVarTab;
   297     volatile uint32 *PtrFDT;
   298     volatile uint32 *PtrCSave;
   299     volatile uint32  NumDRD;
   300     volatile uint32 *DRD[4];
   301     volatile uint32  NumVar;
   302     volatile uint32 *var;
   303     volatile uint32  NumInc;
   304     volatile uint32 *inc;
   305     volatile uint8  *TaskPragma;
   306     volatile uint32 *Bytes;
   307     volatile sint16 *IncrBytes;
   308     volatile uint32 *IterExtra;
   309     volatile sint16 *IncrDst;
   310     volatile sint16 *IncrDstMA;
   311     volatile sint16 *IncrSrc;
   312     volatile uint32 *StartAddrDst;
   313     volatile sint16 *IncrSrcMA;
   314     volatile uint32 *StartAddrSrc;
   319     volatile uint32  TaskNum;
   320     volatile uint32 *PtrStartTDT;
   321     volatile uint32 *PtrEndTDT;
   322     volatile uint32 *PtrVarTab;
   323     volatile uint32 *PtrFDT;
   324     volatile uint32 *PtrCSave;
   325     volatile uint32  NumDRD;
   326     volatile uint32 *DRD[4];
   327     volatile uint32  NumVar;
   328     volatile uint32 *var;
   329     volatile uint32  NumInc;
   330     volatile uint32 *inc;
   331     volatile uint8  *TaskPragma;
   332     volatile uint32 *Bytes;
   333     volatile sint16 *IncrBytes;
   334     volatile uint32 *IterExtra;
   335     volatile sint16 *IncrDst;
   336     volatile sint16 *IncrDstMA;
   337     volatile sint16 *IncrSrc;
   338     volatile uint32 *StartAddrDst;
   339     volatile sint16 *IncrSrcMA;
   340     volatile uint32 *StartAddrSrc;
   345     volatile uint32  TaskNum;
   346     volatile uint32 *PtrStartTDT;
   347     volatile uint32 *PtrEndTDT;
   348     volatile uint32 *PtrVarTab;
   349     volatile uint32 *PtrFDT;
   350     volatile uint32 *PtrCSave;
   351     volatile uint32  NumDRD;
   352     volatile uint32 *DRD[4];
   353     volatile uint32  NumVar;
   354     volatile uint32 *var;
   355     volatile uint32  NumInc;
   356     volatile uint32 *inc;
   357     volatile uint8  *TaskPragma;
   358     volatile uint32 *Bytes;
   359     volatile sint16 *IncrBytes;
   360     volatile uint32 *IterExtra;
   361     volatile sint16 *IncrDst;
   362     volatile sint16 *IncrDstMA;
   363     volatile sint16 *IncrSrc;
   364     volatile uint32 *StartAddrDst;
   365     volatile sint16 *IncrSrcMA;
   366     volatile uint32 *StartAddrSrc;
   371     volatile uint32  TaskNum;
   372     volatile uint32 *PtrStartTDT;
   373     volatile uint32 *PtrEndTDT;
   374     volatile uint32 *PtrVarTab;
   375     volatile uint32 *PtrFDT;
   376     volatile uint32 *PtrCSave;
   377     volatile uint32  NumDRD;
   378     volatile uint32 *DRD[8];
   379     volatile uint32  NumVar;
   380     volatile uint32 *var;
   381     volatile uint32  NumInc;
   382     volatile uint32 *inc;
   383     volatile uint8  *TaskPragma;
   384     volatile uint32 *AddrDstFIFO;
   385     volatile sint16 *IncrBytes;
   386     volatile uint32 *AddrEnable;
   387     volatile sint16 *IncrSrc;
   388     volatile uint32 *BDTableBase;
   389     volatile sint16 *IncrSrcMA;
   390     volatile uint32 *BDTableLast;
   391     volatile uint32 *BDTableStart;
   392     volatile uint32 *Bytes;
   397     volatile uint32  TaskNum;
   398     volatile uint32 *PtrStartTDT;
   399     volatile uint32 *PtrEndTDT;
   400     volatile uint32 *PtrVarTab;
   401     volatile uint32 *PtrFDT;
   402     volatile uint32 *PtrCSave;
   403     volatile uint32  NumDRD;
   404     volatile uint32 *DRD[7];
   405     volatile uint32  NumVar;
   406     volatile uint32 *var;
   407     volatile uint32  NumInc;
   408     volatile uint32 *inc;
   409     volatile uint8  *TaskPragma;
   410     volatile uint32 *AddrEnable;
   411     volatile sint16 *IncrBytes;
   412     volatile uint32 *AddrSrcFIFO;
   413     volatile sint16 *IncrDst;
   414     volatile uint32 *BDTableBase;
   415     volatile uint32 *BDTableLast;
   416     volatile uint32 *BDTableStart;
   417     volatile uint32 *Bytes;
   422     volatile uint32  TaskNum;
   423     volatile uint32 *PtrStartTDT;
   424     volatile uint32 *PtrEndTDT;
   425     volatile uint32 *PtrVarTab;
   426     volatile uint32 *PtrFDT;
   427     volatile uint32 *PtrCSave;
   428     volatile uint32  NumDRD;
   429     volatile uint32 *DRD[7];
   430     volatile uint32  NumVar;
   431     volatile uint32 *var;
   432     volatile uint32  NumInc;
   433     volatile uint32 *inc;
   434     volatile uint8  *TaskPragma;
   435     volatile uint32 *AddrEnable;
   436     volatile sint16 *IncrBytes;
   437     volatile uint32 *BDTableBase;
   438     volatile sint16 *IncrDst;
   439     volatile uint32 *BDTableLast;
   440     volatile sint16 *IncrSrc;
   441     volatile uint32 *BDTableStart;
   442     volatile uint32 *Bytes;
   447     volatile uint32  TaskNum;
   448     volatile uint32 *PtrStartTDT;
   449     volatile uint32 *PtrEndTDT;
   450     volatile uint32 *PtrVarTab;
   451     volatile uint32 *PtrFDT;
   452     volatile uint32 *PtrCSave;
   453     volatile uint32  NumDRD;
   454     volatile uint32 *DRD[7];
   455     volatile uint32  NumVar;
   456     volatile uint32 *var;
   457     volatile uint32  NumInc;
   458     volatile uint32 *inc;
   459     volatile uint8  *TaskPragma;
   460     volatile uint32 *AddrEnable;
   461     volatile sint16 *IncrBytes;
   462     volatile uint32 *BDTableBase;
   463     volatile sint16 *IncrDst;
   464     volatile uint32 *BDTableLast;
   465     volatile sint16 *IncrSrc;
   466     volatile uint32 *BDTableStart;
   467     volatile uint32 *Bytes;
 Definition: dma_image.h:60
Definition: dma_image.h:189
Definition: dma_image.h:370
Definition: dma_image.h:85
Definition: dma_image.h:421
Definition: dma_image.h:214
Definition: dma_image.h:344
Definition: dma_image.h:109
Definition: dma_image.h:396
Definition: dma_image.h:240
Definition: dma_image.h:137
Definition: dma_image.h:318
Definition: dma_image.h:266
Definition: dma_image.h:163
Definition: dma_image.h:446
Definition: dma_image.h:292
