28 #define LENGTH_CODES 29    34 #define L_CODES (LITERALS+1+LENGTH_CODES)    43 #define HEAP_SIZE (2*L_CODES+1)    50 #define EXTRA_STATE   69    52 #define COMMENT_STATE 91    53 #define HCRC_STATE   103    54 #define BUSY_STATE   113    55 #define FINISH_STATE 666    86 typedef unsigned IPos;
   163     uInt max_chain_length;
   174 #   define max_insert_length  max_lazy_match   198     ush bl_count[MAX_BITS+1];
   201     int heap[2*L_CODES+1];
   208     uch depth[2*L_CODES+1];
   273 #define put_byte(s, c) {s->pending_buf[s->pending++] = (c);}   276 #define MIN_LOOKAHEAD (MAX_MATCH+MIN_MATCH+1)   281 #define MAX_DIST(s)  ((s)->w_size-MIN_LOOKAHEAD)   286 #define WIN_INIT MAX_MATCH   292 int ZLIB_INTERNAL _tr_tally OF((
deflate_state *s,
unsigned dist,
unsigned lc));
   293 void ZLIB_INTERNAL _tr_flush_block OF((
deflate_state *s, charf *buf,
   294                         ulg stored_len,
int last));
   296 void ZLIB_INTERNAL _tr_stored_block OF((
   297                         ulg stored_len,
int last));
   299 #define d_code(dist) \   300    ((dist) < 256 ? _dist_code[dist] : _dist_code[256+((dist)>>7)])   309 #if defined(GEN_TREES_H) || !defined(STDC)   310   extern uch ZLIB_INTERNAL _length_code[];
   311   extern uch ZLIB_INTERNAL _dist_code[];
   313   extern const uch ZLIB_INTERNAL _length_code[];
   314   extern const uch ZLIB_INTERNAL _dist_code[];
   317 # define _tr_tally_lit(s, c, flush) \   319     s->d_buf[s->last_lit] = 0; \   320     s->l_buf[s->last_lit++] = cc; \   321     s->dyn_ltree[cc].Freq++; \   322     flush = (s->last_lit == s->lit_bufsize-1); \   324 # define _tr_tally_dist(s, distance, length, flush) \   325   { uch len = (length); \   326     ush dist = (distance); \   327     s->d_buf[s->last_lit] = dist; \   328     s->l_buf[s->last_lit++] = len; \   330     s->dyn_ltree[_length_code[len]+LITERALS+1].Freq++; \   331     s->dyn_dtree[d_code(dist)].Freq++; \   332     flush = (s->last_lit == s->lit_bufsize-1); \   335 # define _tr_tally_lit(s, c, flush) flush = _tr_tally(s, 0, c)   336 # define _tr_tally_dist(s, distance, length, flush) \   337               flush = _tr_tally(s, distance, length) Definition: deflate.c:153
Definition: inftrees.h:24
Definition: clnt_tcp.c:94
