RTEMS  5.1
cyg_type.h
1 #ifndef CYGONCE_INFRA_CYG_TYPE_H
2 #define CYGONCE_INFRA_CYG_TYPE_H
3
4 //==========================================================================
5 //
6 // cyg_type.h
7 //
8 // Standard types, and some useful coding macros.
9 //
10 //==========================================================================
11 // ####ECOSGPLCOPYRIGHTBEGIN####
12 // -------------------------------------------
13 // This file is part of eCos, the Embedded Configurable Operating System.
14 // Copyright (C) 1998, 1999, 2000, 2001, 2002, 2009 Free Software Foundation, Inc.
15 //
16 // eCos is free software; you can redistribute it and/or modify it under
17 // the terms of the GNU General Public License as published by the Free
18 // Software Foundation; either version 2 or (at your option) any later
19 // version.
20 //
21 // eCos is distributed in the hope that it will be useful, but WITHOUT
22 // ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
23 // FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
24 // for more details.
25 //
26 // You should have received a copy of the GNU General Public License
27 // along with eCos; if not, write to the Free Software Foundation, Inc.,
28 // 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
29 //
30 // As a special exception, if other files instantiate templates or use
31 // macros or inline functions from this file, or you compile this file
32 // and link it with other works to produce a work based on this file,
33 // this file does not by itself cause the resulting work to be covered by
34 // the GNU General Public License. However the source code for this file
35 // must still be made available in accordance with section (3) of the GNU
36 // General Public License v2.
37 //
38 // This exception does not invalidate any other reasons why a work based
39 // on this file might be covered by the GNU General Public License.
40 // -------------------------------------------
41 // ####ECOSGPLCOPYRIGHTEND####
42 //==========================================================================
43 //#####DESCRIPTIONBEGIN####
44 //
45 // Author(s): nickg from an original by hmt
46 // Contributors: nickg
47 // Date: 1997-09-08
48 // Purpose: share unambiguously sized types.
49 // Description: we typedef [cyg_][u]int8,16,32 &c for general use.
50 // Usage: #include "cyg/infra/cyg_type.h"
51 // ...
52 // cyg_int32 my_32bit_integer;
53 //
54 //####DESCRIPTIONEND####
55 //
56
57 #include <stddef.h> // Definition of NULL from the compiler
58 #include <stdint.h>
59
60 typedef uint16_t cyg_uint16;
61
62 typedef uint32_t cyg_uint32;
63
64 // -------------------------------------------------------------------------
65 // Allow creation of procedure-like macros that are a single statement,
66 // and must be followed by a semi-colon
67
68 #define CYG_MACRO_START do {
69 #define CYG_MACRO_END } while (0)
70
71 #define CYG_EMPTY_STATEMENT CYG_MACRO_START CYG_MACRO_END
72
73 #define CYG_UNUSED_PARAM( _type_, _name_ ) CYG_MACRO_START \
74  _type_ __tmp1 = (_name_); \
75  _type_ __tmp2 = __tmp1; \
76  __tmp1 = __tmp2; \
77 CYG_MACRO_END
78
79 // -------------------------------------------------------------------------
80 #endif // CYGONCE_INFRA_CYG_TYPE_H multiple inclusion protection
81 // EOF cyg_type.h
