RTEMS  5.1
asm.h
1
11 /*
12  * NOTE: The spacing in the use of these macros
13  * is critical to them working as advertised.
14  *
15  * This file is based on similar code found in newlib available
16  * from ftp.cygnus.com. The file which was used had no copyright
17  * notice. This file is freely distributable as long as the source
18  * of the file is noted. This file is:
19  *
20  * Copyright (c) 2015 University of York.
21  * Hesham Almatary <hesham@alumni.york.ac.uk>
22  *
23  *
24  * COPYRIGHT (c) 1994-1997.
25  * On-Line Applications Research Corporation (OAR).
26  *
27  * Redistribution and use in source and binary forms, with or without
28  * modification, are permitted provided that the following conditions
29  * are met:
30  * 1. Redistributions of source code must retain the above copyright
31  * notice, this list of conditions and the following disclaimer.
32  * 2. Redistributions in binary form must reproduce the above copyright
33  * notice, this list of conditions and the following disclaimer in the
34  * documentation and/or other materials provided with the distribution.
35  *
36  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
37  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
38  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
39  * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
40  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
41  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
42  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
43  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
44  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
45  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
46  * SUCH DAMAGE.
47  */
48
49 #ifndef __RISCV_ASM_H
50 #define __RISCV_ASM_H
51
52 /*
53  * Indicate we are in an assembly file and get the basic CPU definitions.
54  */
55
56 #ifndef ASM
57 #define ASM
58 #endif
59 #include <rtems/score/cpuopts.h>
60 #include <rtems/score/riscv.h>
61
72 /*
73  * Recent versions of GNU cpp define variables which indicate the
74  * need for underscores and percents. If not using GNU cpp or
75  * the version does not support this, then you will obviously
76  * have to define these as appropriate.
77  */
78
79 #ifndef __USER_LABEL_PREFIX__
80 #define __USER_LABEL_PREFIX__ _
81 #endif
82
83 #ifndef __REGISTER_PREFIX__
84 #define __REGISTER_PREFIX__
85 #endif
86
87 /* ANSI concatenation macros. */
88
89 #define CONCAT1(a, b) CONCAT2(a, b)
90 #define CONCAT2(a, b) a ## b
91
92 /* Use the right prefix for global labels. */
93
94 #define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
95
96 /* Use the right prefix for registers. */
97
98 #define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
99
100 /*
101  * define macros for all of the registers on this CPU
102  *
103  * EXAMPLE: #define d0 REG (d0)
104  */
105
106 /*
107  * Define macros to handle section beginning and ends.
108  */
109 #define BEGIN_CODE_DCL .text
110 #define END_CODE_DCL
111 #define BEGIN_DATA_DCL .data
112 #define END_DATA_DCL
113 #define BEGIN_CODE .text
114 #define END_CODE
115 #define BEGIN_DATA
116 #define END_DATA
117 #define BEGIN_BSS
118 #define END_BSS
119 #define END
120
121 /*
122  * Following must be tailor for a particular flavor of the C compiler.
123  * They may need to put underscores in front of the symbols.
124  */
125
126 #define PUBLIC(sym) .global SYM (sym)
127 #define EXTERN(sym) .extern SYM (sym)
128 #define TYPE_FUNC(sym) .type SYM (sym), %function
129
130 #if __riscv_xlen == 32
131
132 #define LREG lw
133
134 #define SREG sw
135
136 #elif __riscv_xlen == 64
137
138 #define LREG ld
139
140 #define SREG sd
141
142 #endif /* __riscv_xlen */
143
144 #ifdef __riscv_cmodel_medany
145
146 #define LADDR lla
147
148 #else /* !__riscv_cmodel_medany */
149
150 #define LADDR la
151
152 #endif /* __riscv_cmodel_medany */
153
154 #if __riscv_flen == 32
155
156 #define FLREG flw
157
158 #define FSREG fsw
159
160 #define FMVYX fmv.s.x
161
162 #define FMVXY fmv.x.s
163
164 #elif __riscv_flen == 64
165
166 #define FLREG fld
167
168 #define FSREG fsd
169
170 #if __riscv_xlen == 32
171
172 #define FMVYX fmv.s.x
173
174 #define FMVXY fmv.x.s
175
176 #elif __riscv_xlen == 64
177
178 #define FMVYX fmv.d.x
179
180 #define FMVXY fmv.x.d
181
182 #endif /* __riscv_xlen */
183
184 #endif /* __riscv_flen */
185
186 .macro GET_SELF_CPU_CONTROL REG
187 #ifdef RTEMS_SMP
188  csrr \REG, mscratch
189 #else
190  LADDR \REG, _Per_CPU_Information
191 #endif
192 .endm
193
194 .macro CLEAR_RESERVATIONS REG
195 #ifdef __riscv_atomic
196  /*
197  * Clear reservations, see also RISC-V User-Level ISA V2.3, comment in
198  * section 8.2 "Load-Reserved/Store-Conditional Instructions".
199  */
200  sc.w zero, zero, (\REG)
201 #endif
202 .endm
203
204 #endif
205
#define REG(x)
Definition: asm.h:72
