  | PPC_ASSERT_OFFSET (gpr1, GPR1) |
  | PPC_ASSERT_OFFSET (msr, MSR) |
  | PPC_ASSERT_OFFSET (lr, LR) |
  | PPC_ASSERT_OFFSET (cr, CR) |
  | PPC_ASSERT_OFFSET (gpr14, GPR14) |
  | PPC_ASSERT_OFFSET (gpr15, GPR15) |
  | PPC_ASSERT_OFFSET (gpr16, GPR16) |
  | PPC_ASSERT_OFFSET (gpr17, GPR17) |
  | PPC_ASSERT_OFFSET (gpr18, GPR18) |
  | PPC_ASSERT_OFFSET (gpr19, GPR19) |
  | PPC_ASSERT_OFFSET (gpr20, GPR20) |
  | PPC_ASSERT_OFFSET (gpr21, GPR21) |
  | PPC_ASSERT_OFFSET (gpr22, GPR22) |
  | PPC_ASSERT_OFFSET (gpr23, GPR23) |
  | PPC_ASSERT_OFFSET (gpr24, GPR24) |
  | PPC_ASSERT_OFFSET (gpr25, GPR25) |
  | PPC_ASSERT_OFFSET (gpr26, GPR26) |
  | PPC_ASSERT_OFFSET (gpr27, GPR27) |
  | PPC_ASSERT_OFFSET (gpr28, GPR28) |
  | PPC_ASSERT_OFFSET (gpr29, GPR29) |
  | PPC_ASSERT_OFFSET (gpr30, GPR30) |
  | PPC_ASSERT_OFFSET (gpr31, GPR31) |
  | PPC_ASSERT_OFFSET (tp, TP) |
  | PPC_ASSERT_OFFSET (isr_dispatch_disable, ISR_DISPATCH_DISABLE) |
  | RTEMS_STATIC_ASSERT (sizeof(Context_Control) % PPC_DEFAULT_CACHE_LINE_SIZE==0, ppc_context_size) |
  | PPC_EXC_ASSERT_OFFSET (EXC_SRR0, SRR0_FRAME_OFFSET) |
  | PPC_EXC_ASSERT_OFFSET (EXC_SRR1, SRR1_FRAME_OFFSET) |
  | PPC_EXC_ASSERT_OFFSET (_EXC_number, EXCEPTION_NUMBER_OFFSET) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (EXC_CR) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (EXC_CTR) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (EXC_XER) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (EXC_LR) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR0) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR1) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR2) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR3) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR4) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR5) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR6) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR7) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR8) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR9) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR10) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR11) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR12) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR13) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR14) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR15) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR16) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR17) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR18) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR19) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR20) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR21) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR22) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR23) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR24) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR25) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR26) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR27) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR28) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR29) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR30) |
  | PPC_EXC_ASSERT_CANONIC_OFFSET (GPR31) |
  | PPC_EXC_MIN_ASSERT_OFFSET (EXC_SRR0, SRR0_FRAME_OFFSET) |
  | PPC_EXC_MIN_ASSERT_OFFSET (EXC_SRR1, SRR1_FRAME_OFFSET) |
  | PPC_EXC_MIN_ASSERT_OFFSET (EXC_INTERRUPT_ENTRY_INSTANT, PPC_EXC_INTERRUPT_ENTRY_INSTANT_OFFSET) |
  | PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (EXC_CR) |
  | PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (EXC_CTR) |
  | PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (EXC_XER) |
  | PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (EXC_LR) |
  | PPC_EXC_MIN_ASSERT_OFFSET (EXC_INTERRUPT_FRAME, PPC_EXC_INTERRUPT_FRAME_OFFSET) |
  | PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR0) |
  | PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR1) |
  | PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR2) |
  | PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR3) |
  | PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR4) |
  | PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR5) |
  | PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR6) |
  | PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR7) |
  | PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR8) |
  | PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR9) |
  | PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR10) |
  | PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR11) |
  | PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR12) |
  | RTEMS_STATIC_ASSERT (CPU_INTERRUPT_FRAME_SIZE % CPU_STACK_ALIGNMENT==0, CPU_INTERRUPT_FRAME_SIZE) |
  | RTEMS_STATIC_ASSERT (PPC_EXC_FRAME_SIZE % CPU_STACK_ALIGNMENT==0, PPC_EXC_FRAME_SIZE) |
  | RTEMS_STATIC_ASSERT (sizeof(CPU_Exception_frame)+FRAME_LINK_SPACE<=PPC_EXC_FRAME_SIZE, CPU_Exception_frame) |
PowerPC Dependent Source.
