RTEMS  5.1
asm.h
1
17 /*
18  * COPYRIGHT:
19  *
20  * This file is based on similar code found in newlib available
21  * from ftp.cygnus.com. The file which was used had no copyright
22  * notice. This file is freely distributable as long as the source
23  * of the file is noted. This file is:
24  *
25  * COPYRIGHT (c) 1994-1997.
26  * On-Line Applications Research Corporation (OAR).
27  */
28
29 #ifndef _RTEMS_ASM_H
30 #define _RTEMS_ASM_H
31
32 /*
33  * Indicate we are in an assembly file and get the basic CPU definitions.
34  */
35
36 #ifndef ASM
37 #define ASM
38 #endif
39 #include <rtems/score/cpuopts.h>
40 #include <rtems/score/nios2.h>
41
52 /*
53  * Recent versions of GNU cpp define variables which indicate the
54  * need for underscores and percents. If not using GNU cpp or
55  * the version does not support this, then you will obviously
56  * have to define these as appropriate.
57  */
58
59 #ifndef __USER_LABEL_PREFIX__
60 #define __USER_LABEL_PREFIX__ _
61 #endif
62
63 #ifndef __REGISTER_PREFIX__
64 #define __REGISTER_PREFIX__
65 #endif
66
67 #include <rtems/concat.h>
68
69 /* Use the right prefix for global labels. */
70
71 #define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
72
73 /* Use the right prefix for registers. */
74
75 #define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
76
77 /*
78  * define macros for all of the registers on this CPU
79  *
80  * EXAMPLE: #define d0 REG (d0)
81  */
82
83 /*
84  * Define macros to handle section beginning and ends.
85  */
86
87
88 #define BEGIN_CODE_DCL .text
89 #define END_CODE_DCL
90 #define BEGIN_DATA_DCL .data
91 #define END_DATA_DCL
92 #define BEGIN_CODE .text
93 #define END_CODE
94 #define BEGIN_DATA
95 #define END_DATA
96 #define BEGIN_BSS
97 #define END_BSS
98 #define END
99
100 /*
101  * Following must be tailor for a particular flavor of the C compiler.
102  * They may need to put underscores in front of the symbols.
103  */
104
105 #define PUBLIC(sym) .globl SYM (sym)
106 #define EXTERN(sym) .globl SYM (sym)
107
110 #endif
NIOS II Set up Basic CPU Dependency Settings Based on Compiler Settings.
