RTEMS  5.1
asm.h
1
11 /*
12  * NOTE: The spacing in the use of these macros
13  * is critical to them working as advertised.
14  *
15  * COPYRIGHT:
16  *
17  * This file is based on similar code found in newlib available
18  * from ftp.cygnus.com. The file which was used had no copyright
19  * notice. This file is freely distributable as long as the source
20  * of the file is noted. This file is:
21  *
22  * COPYRIGHT (c) 2011
23  * Anthony Green
24  *
25  * COPYRIGHT (c) 1989-1999, 2010.
26  * On-Line Applications Research Corporation (OAR).
27  *
28  * The license and distribution terms for this file may be
29  * found in the file LICENSE in this distribution or at
30  * http://www.rtems.org/license/LICENSE.
31  *
32  * $Id: asm.h,v 1.9 2010/06/29 00:31:09 joel Exp $
33  */
34
35 #ifndef _RTEMS_ASM_H
36 #define _RTEMS_ASM_H
37
38 /*
39  * Indicate we are in an assembly file and get the basic CPU definitions.
40  */
41
42 #include <rtems/score/moxie.h>
43
54 /*
55  * Recent versions of GNU cpp define variables which indicate the
56  * need for underscores and percents. If not using GNU cpp or
57  * the version does not support this, then you will obviously
58  * have to define these as appropriate.
59  */
60
61 #ifndef __USER_LABEL_PREFIX__
62 #define __USER_LABEL_PREFIX__
63 #endif
64
65 #ifndef __REGISTER_PREFIX__
66 #define __REGISTER_PREFIX__ "$"
67 #endif
68
69 #include <rtems/concat.h>
70
71 /* Use the right prefix for global labels. */
72
73 #define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
74
75 /* Use the right prefix for registers. */
76
77 #define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
78
79 /*
80  * define macros for all of the registers on this CPU
81  *
82  * EXAMPLE: #define d0 REG (d0)
83  */
84 #define fp REG(fp)
85 #define sp REG(sp)
86 #define r0 REG(r0)
87 #define r1 REG(r1)
88 #define r2 REG(r2)
89 #define r3 REG(r3)
90 #define r4 REG(r4)
91 #define r5 REG(r5)
92 #define r6 REG(r6)
93 #define r7 REG(r7)
94 #define r8 REG(r8)
95 #define r9 REG(r9)
96 #define r10 REG(r10)
97 #define r11 REG(r11)
98 #define r12 REG(r12)
99 #define r13 REG(r13)
100
101 /*
102  * Define macros to handle section beginning and ends.
103  */
104
105
106 #define BEGIN_CODE_DCL .text
107 #define END_CODE_DCL
108 #define BEGIN_DATA_DCL .data
109 #define END_DATA_DCL
110 #define BEGIN_CODE asm ( ".text
111 #define END_CODE ");
112 #define BEGIN_DATA
113 #define END_DATA
114 #define BEGIN_BSS
115 #define END_BSS
116 #define END
117
118 /*
119  * Following must be tailor for a particular flavor of the C compiler.
120  * They may need to put underscores in front of the symbols.
121  */
122
123 #define PUBLIC(sym) .globl SYM (sym)
124 #define EXTERN(sym) .globl SYM (sym)
125
128 #endif
