RTEMS  5.1
asm.h
1
17 /*
18  * COPYRIGHT:
19  *
20  * This file is based on similar code found in newlib available
21  * from ftp.cygnus.com. The file which was used had no copyright
22  * notice. This file is freely distributable as long as the source
23  * of the file is noted. This file is:
24  *
25  * COPYRIGHT (c) 1994-1997.
26  * On-Line Applications Research Corporation (OAR).
27  */
28
29 #ifndef _RTEMS_ASM_H
30 #define _RTEMS_ASM_H
31
32 /*
33  * Indicate we are in an assembly file and get the basic CPU definitions.
34  */
35
36 #ifndef ASM
37 #define ASM
38 #endif
39 #include <rtems/score/cpuopts.h>
40 #include <rtems/score/i386.h>
41 #include <rtems/score/percpu.h>
42
52 /*
53  * Recent versions of GNU cpp define variables which indicate the
54  * need for underscores and percents. If not using GNU cpp or
55  * the version does not support this, then you will obviously
56  * have to define these as appropriate.
57  */
58
59 #ifndef __USER_LABEL_PREFIX__
60 #define __USER_LABEL_PREFIX__
61 #endif
62
63 /*
64  * Looks like there is a bug in gcc 2.6.2 where this is not
65  * defined correctly when configured as i386-coff and
66  * i386-aout.
67  */
68
69 #undef __REGISTER_PREFIX__
70 #define __REGISTER_PREFIX__ %
71
72 /*
73 #ifndef __REGISTER_PREFIX__
74 #define __REGISTER_PREFIX__
75 #endif
76 */
77
78 #include <rtems/concat.h>
79
80 /* Use the right prefix for global labels. */
81
82 #define SYM(x) CONCAT0 (__USER_LABEL_PREFIX__, x)
83
84 /* Use the right prefix for registers. */
85
86 #define REG(x) CONCAT0 (__REGISTER_PREFIX__, x)
87
88 #define eax REG (eax)
89 #define ebx REG (ebx)
90 #define ecx REG (ecx)
91 #define edx REG (edx)
92 #define esi REG (esi)
93 #define edi REG (edi)
94 #define esp REG (esp)
95 #define ebp REG (ebp)
96 #define cr0 REG (cr0)
97 #define cr4 REG (cr4)
98
99 #define ax REG (ax)
100 #define bx REG (bx)
101 #define cx REG (cx)
102 #define dx REG (dx)
103 #define si REG (si)
104 #define di REG (di)
105 #define sp REG (sp)
106 #define bp REG (bp)
107
108 #define ah REG (ah)
109 #define bh REG (bh)
110 #define ch REG (ch)
111 #define dh REG (dh)
112
113 #define al REG (al)
114 #define bl REG (bl)
115 #define cl REG (cl)
116 #define dl REG (dl)
117
118 #define cs REG (cs)
119 #define ds REG (ds)
120 #define es REG (es)
121 #define fs REG (fs)
122 #define gs REG (gs)
123 #define ss REG (ss)
124
125 /*
126  * Define macros to handle section beginning and ends.
127  */
128
129
130 #define BEGIN_CODE_DCL .text
131 #define END_CODE_DCL
132 #define BEGIN_DATA_DCL .data
133 #define END_DATA_DCL
134 #define BEGIN_CODE .text
135 #define END_CODE
136 #define BEGIN_DATA .data
137 #define END_DATA
138 #define BEGIN_BSS .bss
139 #define END_BSS
140 #define END
141
142 /*
143  * Following must be tailor for a particular flavor of the C compiler.
144  * They may need to put underscores in front of the symbols.
145  */
146
147 #define PUBLIC(sym) .globl SYM (sym)
148 #define EXTERN(sym) .globl SYM (sym)
149
150 #ifdef RTEMS_SMP
151 .macro GET_CPU_ID REG
152  .set LAPIC_ID, 0x20
153  .set LAPIC_ID_SHIFT, 0x18L
154  movl imps_lapic_addr,\REG
155  movl LAPIC_ID(\REG),\REG
156  shrl $LAPIC_ID_SHIFT,\REG /* LAPIC_ID in REG */
157  movb imps_apic_cpu_map(\REG),\REG /* CPU ID in REG */
158 .endm
159
160 .macro GET_SELF_CPU_CONTROL REG
162  shll $PER_CPU_CONTROL_SIZE_LOG2,\REG /* Calculate offset for CPU structure */
163  leal _Per_CPU_Information(\REG),\REG /* Address of info for current CPU in REG */
164 .endm
165 #else
166 .macro GET_CPU_ID REG
167  movl $0,\REG
168 .endm
169
170 .macro GET_SELF_CPU_CONTROL REG
171  leal _Per_CPU_Information, \REG
172 .endm
173 #endif
174
177 #endif
Intel I386 CPU Dependent Source.
#define REG(x)
Definition: asm.h:72
unsigned imps_lapic_addr
base address of the local apic. Usually 0xFEE00000
Definition: smp-imps.c:202
