RTEMS  5.1
mpci.h
1 /* SPDX-License-Identifier: BSD-2-Clause */
2
11 /*
12  * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
13  *
14  * Redistribution and use in source and binary forms, with or without
15  * modification, are permitted provided that the following conditions
16  * are met:
17  * 1. Redistributions of source code must retain the above copyright
18  * notice, this list of conditions and the following disclaimer.
19  * 2. Redistributions in binary form must reproduce the above copyright
20  * notice, this list of conditions and the following disclaimer in the
21  * documentation and/or other materials provided with the distribution.
22  *
23  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33  * POSSIBILITY OF SUCH DAMAGE.
34  */
35
36 #ifndef _RTEMS_CONFDEFS_MPCI_H
37 #define _RTEMS_CONFDEFS_MPCI_H
38
39 #ifndef __CONFIGURATION_TEMPLATE_h
40 #error "Do not include this file directly, use <rtems/confdefs.h> instead"
41 #endif
42
43 #ifdef CONFIGURE_INIT
44
45 #ifdef RTEMS_MULTIPROCESSING
46
47 #ifdef CONFIGURE_MP_APPLICATION
48
49 #include <rtems/confdefs/threads.h>
50
51 #ifndef CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
52  #define CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK 0
53 #endif
54
55 #ifndef CONFIGURE_MP_NODE_NUMBER
56  #define CONFIGURE_MP_NODE_NUMBER NODE_NUMBER
57 #endif
58
59 #ifndef CONFIGURE_MP_MAXIMUM_NODES
60  #define CONFIGURE_MP_MAXIMUM_NODES 2
61 #endif
62
63 #ifndef CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
64  #define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS 32
65 #endif
66
67 #ifndef CONFIGURE_MP_MAXIMUM_PROXIES
68  #define CONFIGURE_MP_MAXIMUM_PROXIES 32
69 #endif
70
71 #ifndef CONFIGURE_MP_MPCI_TABLE_POINTER
72  #include <mpci.h>
73
74  #define CONFIGURE_MP_MPCI_TABLE_POINTER &MPCI_table
75 #endif
76
77 #if CONFIGURE_MP_NODE_NUMBER < 1
78  #error "CONFIGURE_MP_NODE_NUMBER must be greater than or equal to one"
79 #endif
80
81 #if CONFIGURE_MP_NODE_NUMBER > CONFIGURE_MP_MAXIMUM_NODES
82  #error "CONFIGURE_MP_NODE_NUMBER must be less than or equal to CONFIGURE_MP_MAXIMUM_NODES"
83 #endif
84
85 #ifdef __cplusplus
86 extern "C" {
87 #endif
88
89 Objects_MP_Control _Objects_MP_Controls[
90  CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
91 ];
92
93 struct Thread_Configured_proxy_control {
94  Thread_Proxy_control Control;
96 };
97
98 static Thread_Configured_proxy_control _Thread_MP_Configured_proxies[
99  CONFIGURE_MP_MAXIMUM_PROXIES
100 ];
101
102 Thread_Configured_proxy_control * const _Thread_MP_Proxies =
103  &_Thread_MP_Configured_proxies[ 0 ];
104
106  CONFIGURE_MP_NODE_NUMBER,
107  CONFIGURE_MP_MAXIMUM_NODES,
108  CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS,
109  CONFIGURE_MP_MAXIMUM_PROXIES,
110  CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK,
111  CONFIGURE_MP_MPCI_TABLE_POINTER
112 };
113
115  CONFIGURE_MINIMUM_TASK_STACK_SIZE
116  + CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
117  + CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK
118  + CPU_ALL_TASKS_ARE_FP * CONTEXT_FP_SIZE
120 RTEMS_SECTION( ".rtemsstack.mpci" );
121
122 #ifdef __cplusplus
123 }
124 #endif
125
126 #endif /* CONFIGURE_MP_APPLICATION */
127
128 #else /* RTEMS_MULTIPROCESSING */
129
130 #ifdef CONFIGURE_MP_APPLICATION
131  #error "CONFIGURE_MP_APPLICATION must not be defined if multiprocessing is disabled"
132 #endif
133
134 #endif /* RTEMS_MULTIPROCESSING */
135
136 #endif /* CONFIGURE_INIT */
137
138 #endif /* _RTEMS_CONFDEFS_MPCI_H */
#define CONTEXT_FP_SIZE
Size of floating point context area.
Definition: context.h:52
#define RTEMS_ALIGNED(_alignment)
Instructs the compiler to enforce the specified alignment.
Definition: basedefs.h:216
#define CPU_INTERRUPT_STACK_ALIGNMENT
Definition: cpu.h:605
Evaluate Thread Configuration Options.
Thread queue heads.
Definition: threadq.h:360
char _MPCI_Receive_server_stack[]
The MPCI receive server stack.
const MPCI_Configuration _MPCI_Configuration
The MPCI configuration.
Definition: mpcidefault.c:32
#define RTEMS_SECTION(_section)
Instructs the compiler to place a specific variable or function in the specified section.
Definition: basedefs.h:154
Definition: thread.h:519
Definition: mpci.h:137
