RTEMS  5.1
console.h
1 /* SPDX-License-Identifier: BSD-2-Clause */
2
11 /*
12  * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
13  *
14  * Redistribution and use in source and binary forms, with or without
15  * modification, are permitted provided that the following conditions
16  * are met:
17  * 1. Redistributions of source code must retain the above copyright
18  * notice, this list of conditions and the following disclaimer.
19  * 2. Redistributions in binary form must reproduce the above copyright
20  * notice, this list of conditions and the following disclaimer in the
21  * documentation and/or other materials provided with the distribution.
22  *
23  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33  * POSSIBILITY OF SUCH DAMAGE.
34  */
35
36 #ifndef _RTEMS_CONFDEFS_SIMPLECONSOLE_H
37 #define _RTEMS_CONFDEFS_SIMPLECONSOLE_H
38
39 #ifndef __CONFIGURATION_TEMPLATE_h
40 #error "Do not include this file directly, use <rtems/confdefs.h> instead"
41 #endif
42
43 #ifdef CONFIGURE_INIT
44
45 #if defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER) \
46  && defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER)
47  #error "CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER and CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER are mutually exclusive"
48 #endif
49
50 #if defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER) \
51  || defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER)
52
53 #include <rtems/console.h>
54 #include <rtems/sysinit.h>
55
56 #ifdef __cplusplus
57 extern "C" {
58 #endif
59
60 #ifdef CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
61  RTEMS_SYSINIT_ITEM(
63  RTEMS_SYSINIT_DEVICE_DRIVERS,
64  RTEMS_SYSINIT_ORDER_SECOND
65  );
66 #endif
67
68 #ifdef CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
69  RTEMS_SYSINIT_ITEM(
71  RTEMS_SYSINIT_DEVICE_DRIVERS,
72  RTEMS_SYSINIT_ORDER_SECOND
73  );
74 #endif
75
76 #ifdef __cplusplus
77 }
78 #endif
79
80 #endif /* CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
81  || CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER */
82
83 #endif /* CONFIGURE_INIT */
84
85 #endif /* _RTEMS_CONFDEFS_SIMPLECONSOLE_H */
void _Console_simple_Initialize(void)
Initializes a simple console device.
Definition: consolesimple.c:91
void _Console_simple_task_Initialize(void)
Initializes a simple task console device.
Definition: consolesimpletask.c:217
Console Driver for all Boards.
