RTEMS  5.1
core_cmSimd.h
1 /**************************************************************************/
7 /* Copyright (c) 2009 - 2015 ARM LIMITED
8
9  All rights reserved.
10  Redistribution and use in source and binary forms, with or without
11  modification, are permitted provided that the following conditions are met:
12  - Redistributions of source code must retain the above copyright
13  notice, this list of conditions and the following disclaimer.
14  - Redistributions in binary form must reproduce the above copyright
15  notice, this list of conditions and the following disclaimer in the
16  documentation and/or other materials provided with the distribution.
17  - Neither the name of ARM nor the names of its contributors may be used
18  to endorse or promote products derived from this software without
19  specific prior written permission.
20  *
21  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22  AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23  IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24  ARE DISCLAIMED. IN NO EVENT SHALL COPYRIGHT HOLDERS AND CONTRIBUTORS BE
25  LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26  CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27  SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28  INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29  CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30  ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31  POSSIBILITY OF SUCH DAMAGE.
32  ---------------------------------------------------------------------------*/
33
34
35 #if defined ( __ICCARM__ )
36  #pragma system_include /* treat file as system include file for MISRA check */
37 #elif defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050)
38  #pragma clang system_header /* treat file as system include file */
39 #endif
40
41 #ifndef __CORE_CMSIMD_H
42 #define __CORE_CMSIMD_H
43
44 #ifdef __cplusplus
45  extern "C" {
46 #endif
47
48
49 /* ################### Compiler specific Intrinsics ########################### */
56 /*------------------ RealView Compiler -----------------*/
57 #if defined ( __CC_ARM )
58  #include "cmsis_armcc.h"
59
60 /*------------------ ARM Compiler V6 -------------------*/
61 #elif defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050)
62  #include "cmsis_armcc_V6.h"
63
64 /*------------------ GNU Compiler ----------------------*/
65 #elif defined ( __GNUC__ )
66  #include "cmsis_gcc.h"
67
68 /*------------------ ICC Compiler ----------------------*/
69 #elif defined ( __ICCARM__ )
70  #include <cmsis_iar.h>
71
72 /*------------------ TI CCS Compiler -------------------*/
73 #elif defined ( __TMS470__ )
74  #include <cmsis_ccs.h>
75
76 /*------------------ TASKING Compiler ------------------*/
77 #elif defined ( __TASKING__ )
78  /*
79  * The CMSIS functions have been implemented as intrinsics in the compiler.
80  * Please use "carm -?i" to get an up to date list of all intrinsics,
81  * Including the CMSIS ones.
82  */
83
84 /*------------------ COSMIC Compiler -------------------*/
85 #elif defined ( __CSMC__ )
86  #include <cmsis_csm.h>
87
88 #endif
89
93 #ifdef __cplusplus
94 }
95 #endif
96
97 #endif /* __CORE_CMSIMD_H */
CMSIS Cortex-M Core Function/Instruction Header File.
