Milkymist USB input devices driver.
More...
#define  | COMLOCV(x)   (*(volatile unsigned char *)(x)) |
#define  | COMLOC_DEBUG_PRODUCE   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1000) |
#define  | COMLOC_DEBUG(offset)   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1001+offset) |
#define  | COMLOC_MEVT_PRODUCE   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1101) |
#define  | COMLOC_MEVT(offset)   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1102+offset) |
#define  | COMLOC_KEVT_PRODUCE   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1142) |
#define  | COMLOC_KEVT(offset)   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1143+offset) |
#define  | COMLOC_MIDI_PRODUCE   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1183) |
#define  | COMLOC_MIDI(offset)   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1184+offset) |
