RTEMS  5.1
Data Structures | Macros | Typedefs | Enumerations | Functions
capture.h File Reference
Capture Engine Component of the RTEMS Measurement and Monitoring System. More...
struct  rtems_capture_from
 Task id and mask for the from trigger. More...
struct  rtems_capture_control
 Capture control structure for a group of tasks. More...
struct  rtems_capture_record
struct  rtems_capture_task_record
struct  rtems_capture_record_lock_context
 Capture record lock context. More...
#define RTEMS_CAPTURE_INIT   (1u << 0)
#define RTEMS_CAPTURE_ON   (1U << 1)
#define RTEMS_CAPTURE_NO_MEMORY   (1U << 2)
#define RTEMS_CAPTURE_TRIGGERED   (1U << 3)
#define RTEMS_CAPTURE_GLOBAL_WATCH   (1U << 4)
#define RTEMS_CAPTURE_ONLY_MONITOR   (1U << 5)
#define RTEMS_CAPTURE_OVERFLOW   (1U << 0)
#define RTEMS_CAPTURE_READER_ACTIVE   (1U << 1)
#define RTEMS_CAPTURE_READER_WAITING   (1U << 2)
#define RTEMS_CAPTURE_TRIGGER_TASKS   (32)
#define RTEMS_CAPTURE_CONTROL_FROM_MASK(_s)   (UINT32_C(1) << (RTEMS_CAPTURE_TRIGGER_TASKS - ((_s) + 1)))
#define RTEMS_CAPTURE_WATCH   (1U << 0)
#define RTEMS_CAPTURE_SWITCH   (1 << 0)
#define RTEMS_CAPTURE_CREATE   (1 << 1)
#define RTEMS_CAPTURE_START   (1 << 2)
#define RTEMS_CAPTURE_RESTART   (1 << 3)
#define RTEMS_CAPTURE_DELETE   (1 << 4)
#define RTEMS_CAPTURE_BEGIN   (1 << 5)
#define RTEMS_CAPTURE_EXITTED   (1 << 6)
#define RTEMS_CAPTURE_TERMINATED   (1 << 7)
#define RTEMS_CAPTURE_FROM_TRIGS
#define RTEMS_CAPTURE_TO_TRIGS
#define RTEMS_CAPTURE_TRACED   (1U << 0)
#define RTEMS_CAPTURE_INIT_TASK   (1U << 1)
#define RTEMS_CAPTURE_RECORD_TASK   (1U << 2)
#define RTEMS_CAPTURE_REAL_PRI_EVENT_MASK   UINT32_C (0x000000ff)
#define RTEMS_CAPTURE_CURR_PRI_EVENT_MASK   UINT32_C (0x0000ff00)
#define RTEMS_CAPTURE_REAL_PRIORITY_EVENT   (0)
#define RTEMS_CAPTURE_CURR_PRIORITY_EVENT   (8)
#define RTEMS_CAPTURE_EVENT_START   (16)
#define RTEMS_CAPTURE_CREATED_BY_EVENT   UINT32_C (0x00010000)
#define RTEMS_CAPTURE_CREATED_EVENT   UINT32_C (0x00020000)
#define RTEMS_CAPTURE_STARTED_BY_EVENT   UINT32_C (0x00040000)
#define RTEMS_CAPTURE_STARTED_EVENT   UINT32_C (0x00080000)
#define RTEMS_CAPTURE_RESTARTED_BY_EVENT   UINT32_C (0x00100000)
#define RTEMS_CAPTURE_RESTARTED_EVENT   UINT32_C (0x00200000)
#define RTEMS_CAPTURE_DELETED_BY_EVENT   UINT32_C (0x00400000)
#define RTEMS_CAPTURE_DELETED_EVENT   UINT32_C (0x00800000)
#define RTEMS_CAPTURE_TERMINATED_EVENT   UINT32_C (0x01000000)
#define RTEMS_CAPTURE_BEGIN_EVENT   UINT32_C (0x02000000)
#define RTEMS_CAPTURE_EXITTED_EVENT   UINT32_C (0x04000000)
#define RTEMS_CAPTURE_SWITCHED_OUT_EVENT   UINT32_C (0x08000000)
#define RTEMS_CAPTURE_SWITCHED_IN_EVENT   UINT32_C (0x10000000)
#define RTEMS_CAPTURE_TIMESTAMP   UINT32_C (0x20000000)
#define RTEMS_CAPTURE_EVENT_END   (29)
typedef uint64_t rtems_capture_time
 A capture timestamp. More...
typedef struct rtems_capture_from rtems_capture_from
typedef struct rtems_capture_control rtems_capture_control
typedef struct rtems_capture_record rtems_capture_record
typedef struct rtems_capture_task_record rtems_capture_task_record
typedef enum rtems_capture_trigger_mode rtems_capture_trigger_mode
 Capture trigger modes. More...
typedef enum rtems_capture_trigger rtems_capture_trigger
 Capture trigger. More...
typedef void(* rtems_capture_timestamp) (rtems_capture_time *time)
 Capture timestamp callout handler. More...
enum  rtems_capture_trigger_mode { rtems_capture_to_any, rtems_capture_from_any, rtems_capture_from_to }
enum  rtems_capture_trigger {
  rtems_capture_switch, rtems_capture_create, rtems_capture_start, rtems_capture_restart,
  rtems_capture_delete, rtems_capture_begin, rtems_capture_exitted, rtems_capture_terminated
rtems_status_code rtems_capture_open (uint32_t size, rtems_capture_timestamp timestamp)
 Capture open. More...
rtems_status_code rtems_capture_close (void)
 Capture close. More...
rtems_status_code rtems_capture_set_control (bool enable)
 Capture control trace enable/disable. More...
rtems_status_code rtems_capture_set_monitor (bool enable)
 Capture monitor enable/disable. More...
rtems_status_code rtems_capture_flush (bool prime)
rtems_status_code rtems_capture_watch_add (rtems_name name, rtems_id id)
 Capture add watch. More...
rtems_status_code rtems_capture_watch_del (rtems_name name, rtems_id id)
 Capture delete watch. More...
rtems_status_code rtems_capture_watch_ctrl (rtems_name name, rtems_id id, bool enable)
 Capture enable/disable watch. More...
rtems_status_code rtems_capture_watch_global (bool enable)
 Capture enable/disable global watch. More...
bool rtems_capture_watch_global_on (void)
 Get global watch state. More...
rtems_status_code rtems_capture_watch_ceiling (rtems_task_priority ceiling)
 Set watch ceiling. More...
rtems_task_priority rtems_capture_watch_get_ceiling (void)
 Get watch ceiling. More...
rtems_status_code rtems_capture_watch_floor (rtems_task_priority floor)
 Capture set watch floor. More...
rtems_task_priority rtems_capture_watch_get_floor (void)
rtems_status_code rtems_capture_set_trigger (rtems_name from_name, rtems_id from_id, rtems_name to_name, rtems_id to_id, rtems_capture_trigger_mode mode, rtems_capture_trigger trigger)
 Capture set trigger. More...
rtems_status_code rtems_capture_clear_trigger (rtems_name from_name, rtems_id from_id, rtems_name to_name, rtems_id to_id, rtems_capture_trigger_mode mode, rtems_capture_trigger trigger)
 Capture clear trigger. More...
rtems_status_code rtems_capture_read (uint32_t cpu, size_t *read, const void **recs)
 Capture read records from capture buffer. More...
rtems_status_code rtems_capture_release (uint32_t cpu, uint32_t count)
 Capture release records. More...
bool rtems_capture_filter (rtems_tcb *task, uint32_t events)
 Capture filter. More...
void rtems_capture_get_time (rtems_capture_time *time)
 Capture returns the current time. More...
const char * rtems_capture_event_text (int event)
 Capture get event text. More...
void rtems_capture_initialize_task (rtems_tcb *tcb)
 Capture initialize task. More...
void rtems_capture_record_task (rtems_tcb *tcb)
 Capture record task. More...
void rtems_capture_record_lock (rtems_capture_record_lock_context *context)
 Capture record lock. More...
void rtems_capture_record_unlock (rtems_capture_record_lock_context *context)
 Capture record unlock. More...
void * rtems_capture_record_open (rtems_tcb *task, uint32_t events, size_t size, rtems_capture_record_lock_context *context)
 Capture record open. More...
void rtems_capture_record_close (rtems_capture_record_lock_context *context)
 Capture record close. More...
rtems_capture_control * rtems_capture_get_control_list (void)
 Capture get control list. More...
This is the Capture Engine component of the RTEMS Measurement and Monitoring system.
