RTEMS
5.1
bsps
x86_64
amd64
include
bsp.h
1
9
/* bsp.h
10
11
* This include file contains all board IO definitions.
12
13
14
15
* Copyright (c) 2018.
16
* Amaan Cheval <amaan.cheval@gmail.com>
17
18
* Copyright (c) 1989-1999.
19
* On-Line Applications Research Corporation (OAR).
20
21
22
* modification, are permitted provided that the following conditions
23
* are met:
24
* 1. Redistributions of source code must retain the above copyright
25
* notice, this list of conditions and the following disclaimer.
26
* 2. Redistributions in binary form must reproduce the above copyright
27
* notice, this list of conditions and the following disclaimer in the
28
* documentation and/or other materials provided with the distribution.
29
30
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
31
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
32
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
33
* ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
34
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
35
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
36
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
37
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
38
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
39
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
40
* SUCH DAMAGE.
41
42
43
#ifndef LIBBSP_X86_64_AMD64_BSP_H
44
#define LIBBSP_X86_64_AMD64_BSP_H
45
52
#include <bspopts.h>
53
bsp/default-initial-extension.h
54
55
rtems.h
56
57
#ifdef __cplusplus
58
extern
"C"
59
#endif
60
61
#ifdef __cplusplus
62
63
#endif
64
67
#endif
DEFAULT_INITIAL_EXTENSION Support.
rtems.h
