RTEMS  5.1
irq.h
1
9 /*
10  * Copyright (c) 2012.
11  * Aeroflex Gaisler AB.
12  *
13  * The license and distribution terms for this file may be
14  * found in the file LICENSE in this distribution or at
15  * http://www.rtems.org/license/LICENSE.
16  */
17
18 #ifndef LIBBSP_LEON3_IRQ_CONFIG_H
19 #define LIBBSP_LEON3_IRQ_CONFIG_H
20
21 #include <leon.h>
23
24 #define BSP_INTERRUPT_VECTOR_MAX_STD 15 /* Standard IRQ controller */
25 #define BSP_INTERRUPT_VECTOR_MAX_EXT 31 /* Extended IRQ controller */
26
27 #define BSP_INTERRUPT_VECTOR_MIN 0
28 #define BSP_INTERRUPT_VECTOR_MAX BSP_INTERRUPT_VECTOR_MAX_EXT
29
30 /* The check is different depending on IRQ controller, runtime detected */
31 #define BSP_INTERRUPT_CUSTOM_VALID_VECTOR
32
36 static inline bool bsp_interrupt_is_valid_vector(rtems_vector_number vector)
37 {
39  && ((vector <= (rtems_vector_number) BSP_INTERRUPT_VECTOR_MAX_STD &&
40  LEON3_IrqCtrl_EIrq == 0) ||
41  (vector <= (rtems_vector_number) BSP_INTERRUPT_VECTOR_MAX_EXT &&
42  LEON3_IrqCtrl_EIrq != 0));
43 }
44
45 void bsp_interrupt_set_affinity(
46  rtems_vector_number vector,
47  const Processor_mask *affinity
48 );
49
50 void bsp_interrupt_get_affinity(
51  rtems_vector_number vector,
52  Processor_mask *affinity
53 );
54
55 #endif /* LIBBSP_LEON3_IRQ_CONFIG_H */
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Processor Mask API.
Minimum vector number.
Definition: irq.h:38
