RTEMS  5.1
bsp.h
1
9 /*
10  *
11  * Copyright (c) 2015 University of York.
12  * Hesham Almatary <hesham@alumni.york.ac.uk>
13  *
14  * COPYRIGHT (c) 1989-1999.
15  * On-Line Applications Research Corporation (OAR).
16  *
17  * Redistribution and use in source and binary forms, with or without
18  * modification, are permitted provided that the following conditions
19  * are met:
20  * 1. Redistributions of source code must retain the above copyright
21  * notice, this list of conditions and the following disclaimer.
22  * 2. Redistributions in binary form must reproduce the above copyright
23  * notice, this list of conditions and the following disclaimer in the
24  * documentation and/or other materials provided with the distribution.
25  *
26  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
27  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29  * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
30  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
31  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
32  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
33  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
34  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
35  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
36  * SUCH DAMAGE.
37  */
38
39 #ifndef LIBBSP_RISCV_GRISCV_H
40 #define LIBBSP_RISCV_GRISCV_H
41
53 #include <rtems.h>
54 #include <rtems/clockdrv.h>
55 #include <rtems/console.h>
56 #include <rtems/irq-extension.h>
57
58 #include <bspopts.h>
60
61 #include <rtems/devnull.h>
62
63 #ifdef __cplusplus
64 extern "C" {
65 #endif
66
67 #define BSP_FEATURE_IRQ_EXTENSION
68
69 /* Maximum supported APBUARTs by BSP */
70 #define BSP_NUMBER_OF_TERMIOS_PORTS 8
71
72 /* GRLIB driver functions */
73
74 extern void BSP_shared_interrupt_mask(int irq);
75 extern void BSP_shared_interrupt_clear(int irq);
76 extern void BSP_shared_interrupt_unmask(int irq);
77
78 #ifdef __cplusplus
79 }
80 #endif
81
84 #endif /* LIBBSP_RISCV_GRISCV_H */
DEFAULT_INITIAL_EXTENSION Support.
Header file for the Interrupt Manager Extension.
Console Driver for all Boards.
Clock Driver API.
RTEMS /dev/null Device Driver.
