RTEMS  5.1
bsp.h
1
9 /* bsp.h
10  *
11  * This include file contains all GEN405 board IO definitions.
12  *
13  * derived from helas403/include/bsp.h:
14  * Id: bsp.h,v 1.4 2001/06/18 17:01:48 joel Exp
15  * Author: Thomas Doerfler <td@imd.m.isar.de>
16  * IMD Ingenieurbuero fuer Microcomputertechnik
17  *
18  * COPYRIGHT (c) 1998 by IMD
19  *
20  * Changes from IMD are covered by the original distributions terms.
21  * This file has been derived from the papyrus BSP.
22  *
23  * Author: Andrew Bray <andy@i-cubed.co.uk>
24  *
25  * COPYRIGHT (c) 1995 by i-cubed ltd.
26  *
27  * To anyone who acknowledges that this file is provided "AS IS"
28  * without any express or implied warranty:
29  * permission to use, copy, modify, and distribute this file
30  * for any purpose is hereby granted without fee, provided that
31  * the above copyright notice and this notice appears in all
32  * copies, and that the name of i-cubed limited not be used in
33  * advertising or publicity pertaining to distribution of the
34  * software without specific, written prior permission.
35  * i-cubed limited makes no representations about the suitability
36  * of this software for any purpose.
37  *
38  * Derived from c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h
39  *
40  * COPYRIGHT (c) 1989-1999.
41  * On-Line Applications Research Corporation (OAR).
42  *
43  * The license and distribution terms for this file may be
44  * found in the file LICENSE in this distribution or at
45  * http://www.rtems.org/license/LICENSE.
46  *
47  */
48
49 #ifndef LIBBSP_POWERPC_VIRTEX_BSP_H
50 #define LIBBSP_POWERPC_VIRTEX_BSP_H
51
62 #include <bspopts.h>
63
64 #ifdef ASM
65 /* Definition of where to store registers in alignment handler */
66 #define ALIGN_REGS 0x0140
67
68 #else
69 #include <rtems.h>
70 #include <bsp/irq.h>
71 #include <bsp/vectors.h>
73
74 #ifdef __cplusplus
75 extern "C" {
76 #endif
77
78 #define BSP_FEATURE_IRQ_EXTENSION
79
80 /* Network Defines */
81 #if 1 /* EB/doe changes */
82 #define RTEMS_BSP_NETWORK_DRIVER_NAME "eth0"
83 #else
84 #include "xiltemac.h"
85 #define RTEMS_BSP_NETWORK_DRIVER_NAME XILTEMAC_DRIVER_PREFIX
86 #endif
87 struct rtems_bsdnet_ifconfig;
88 extern int xilTemac_driver_attach(struct rtems_bsdnet_ifconfig*, int );
89 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH xilTemac_driver_attach
90
91 #ifdef __cplusplus
92 }
93 #endif
94
95 #endif /* ASM */
96
99 #endif
DEFAULT_INITIAL_EXTENSION Support.
PowerPC Exceptions API.
