RTEMS  5.1
irq.h
1 /* irq.h
2  *
3  * This include file describe the data structure and the functions implemented
4  * by rtems to write interrupt handlers.
5  *
6  *
7  * SS555 port sponsored by Defence Research and Development Canada - Suffield
8  * Copyright (C) 2004, Real-Time Systems Inc. (querbach@realtime.bc.ca)
9  *
10  * Derived from libbsp/powerpc/mbx8xx/irq/irq.h:
11  *
12  * CopyRight (C) 1999 valette@crf.canon.fr
13  *
14  * This code is heavilly inspired by the public specification of STREAM V2
15  * that can be found at :
16  *
17  * <http://www.chorus.com/Documentation/index.html> by following
18  * the STREAM API Specification Document link.
19  *
20  * The license and distribution terms for this file may be
21  * found in the file LICENSE in this distribution or at
22  * http://www.rtems.org/license/LICENSE.
23  */
24
25 #ifndef LIBBSP_POWERPC_SS555_IRQ_IRQ_H
26 #define LIBBSP_POWERPC_SS555_IRQ_IRQ_H
27
28 #include <libcpu/irq.h>
29
30 #ifndef ASM
31
32 #include <bsp/irq-default.h>
33
34 #ifdef __cplusplus
35 extern "C" {
36 #endif
37
38 /*
39  * These are no longer prototyped anywhere else. This appears to be
40  * remnants of the IRQ code upgrade.
41  *
42  * --joel 28 April 2010
43  */
44 int CPU_install_rtems_irq_handler(const rtems_irq_connect_data* irq);
45 int CPU_get_current_rtems_irq_handler(rtems_irq_connect_data* irq);
46 int CPU_remove_rtems_irq_handler(const rtems_irq_connect_data* irq);
47 int CPU_rtems_irq_mngt_set(rtems_irq_global_settings* config);
48 int CPU_rtems_irq_mngt_get(rtems_irq_global_settings** config);
49 void C_default_exception_handler(CPU_Exception_frame* excPtr);
50
51 /*
52  * The SS555 has no external interrupt controller chip, so use the standard
53  * routines from the CPU-dependent code.
54  */
55 #define BSP_install_rtems_irq_handler(ptr) CPU_install_rtems_irq_handler(ptr)
56 #define BSP_get_current_rtems_irq_handler(ptr) CPU_get_current_rtems_irq_handler(ptr)
57 #define BSP_remove_rtems_irq_handler(ptr) CPU_remove_rtems_irq_handler(ptr)
58 #define BSP_rtems_irq_mngt_set(config) CPU_rtems_irq_mngt_set(config)
59 #define BSP_rtems_irq_mngt_get(config) CPU_rtems_irq_mngt_get(config)
60 #define BSP_rtems_irq_mng_init(cpuId) CPU_rtems_irq_mng_init(cpuId)
61
62 #ifdef __cplusplus
63 }
64 #endif
65
66 #endif /* ASM */
67
68 #endif /* LIBBSP_POWERPC_SS555_IRQ_IRQ_H */
Definition: deflate.c:115
Definition: irq.h:92
Definition: irq.h:45
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
