23 #ifndef LIBBSP_POWERPC_QORIQ_BSP_H    24 #define LIBBSP_POWERPC_QORIQ_BSP_H    38 #ifdef QORIQ_IS_HYPERVISOR_GUEST    39 #define QORIQ_THREAD_COUNT 1    41 #define QORIQ_THREAD_COUNT QORIQ_PHYSICAL_THREAD_COUNT    54 #define BSP_FEATURE_IRQ_EXTENSION    56 #define BSP_FDT_IS_SUPPORTED    58 #define QORIQ_CHIP(alpha, num) ((alpha) * 10000 + (num))    60 #define QORIQ_CHIP_P1020 QORIQ_CHIP('P', 1020)    62 #define QORIQ_CHIP_T2080 QORIQ_CHIP('T', 2080)    64 #define QORIQ_CHIP_T4240 QORIQ_CHIP('T', 4240)    66 #define QORIQ_CHIP_VARIANT QORIQ_CHIP(QORIQ_CHIP_SERIES, QORIQ_CHIP_NUMBER)    68 #define QORIQ_CHIP_IS_T_VARIANT(variant) ((variant) / 10000 == 'T')    70 extern unsigned BSP_bus_frequency;
    72 struct rtems_bsdnet_ifconfig;
    75   struct rtems_bsdnet_ifconfig *
config,
    79 int qoriq_if_intercom_attach_detach(
    80   struct rtems_bsdnet_ifconfig *
config,
    84 #if defined(HAS_UBOOT)    86   const char *bsp_uboot_getenv(
    94 #define BSP_IDLE_TASK_BODY bsp_idle_thread    96 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH BSP_tsec_attach    97 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH4 qoriq_if_intercom_attach_detach    99 #define RTEMS_BSP_NETWORK_DRIVER_NAME "tsec1"   100 #define RTEMS_BSP_NETWORK_DRIVER_NAME2 "tsec2"   101 #define RTEMS_BSP_NETWORK_DRIVER_NAME3 "tsec3"   102 #define RTEMS_BSP_NETWORK_DRIVER_NAME4 "intercom1"   112   uint32_t reserved_1[8];
   116 qoriq_start_spin_table_addr[QORIQ_CPU_COUNT / QORIQ_THREAD_COUNT];
   122 void qoriq_restart_secondary_processor(
   126 void qoriq_initialize_exceptions(
void *interrupt_stack_begin);
   128 void qoriq_decrementer_dispatch(
void);
   130 extern uint32_t bsp_time_base_frequency;
   132 extern uint32_t qoriq_clock_frequency;
 Definition: deflate.c:115
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
DEFAULT_INITIAL_EXTENSION Support.
Per CPU Core Structure.
Definition: percpu.h:347
void * bsp_idle_thread(uintptr_t ignored)
Optimized idle task.
Definition: bspidle.c:26
void bsp_restart(const void *addr)
Restarts the bsp with "addr" address.
Definition: restart.c:25
