RTEMS  5.1
irq.h
1 /* irq.h
2  *
3  * This include file describe the data structure and the functions implemented
4  * by rtems to write interrupt handlers.
5  *
6  * CopyRight (C) 1999 valette@crf.canon.fr
7  *
8  * This code is heavilly inspired by the public specification of STREAM V2
9  * that can be found at :
10  *
11  * <http://www.chorus.com/Documentation/index.html> by following
12  * the STREAM API Specification Document link.
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  */
18
19 #ifndef LIBBSP_POWERPC_IRQ_H
20 #define LIBBSP_POWERPC_IRQ_H
21
22 #define BSP_SHARED_HANDLER_SUPPORT 1
23
24 #ifndef ASM
25
26 #include <rtems/irq.h>
27
28
29 /*
30  * Symblolic IRQ names and related definitions.
31  */
32
33 /*
34  * PCI IRQ handlers related definitions
35  * CAUTION : BSP_PCI_IRQ_LOWEST_OFFSET should be equal to OPENPIC_VEC_SOURCE
36  */
37 #define BSP_PCI_IRQ_NUMBER (16)
38 #define BSP_PCI_IRQ_LOWEST_OFFSET (0)
39 #define BSP_PCI_IRQ_MAX_OFFSET (BSP_PCI_IRQ_LOWEST_OFFSET + BSP_PCI_IRQ_NUMBER - 1)
40
41 #define BSP_PROCESSOR_IRQ_NUMBER (1)
42 #define BSP_PROCESSOR_IRQ_LOWEST_OFFSET (BSP_PCI_IRQ_MAX_OFFSET)
43 #define BSP_PROCESSOR_IRQ_MAX_OFFSET (BSP_PROCESSOR_IRQ_LOWEST_OFFSET+BSP_PROCESSOR_IRQ_NUMBER-1)
44
45
46  /*
47  * Summary
48  */
49 #define BSP_IRQ_NUMBER (BSP_PROCESSOR_IRQ_MAX_OFFSET + 1)
50 #define BSP_LOWEST_OFFSET (BSP_PCI_IRQ_LOWEST_OFFSET)
51 #define BSP_MAX_OFFSET (BSP_IRQ_NUMBER - 1)
52
53  /*
54  * Some Processor execption handled as rtems IRQ symbolic name definition
55  */
56 #define BSP_DECREMENTER (BSP_PROCESSOR_IRQ_LOWEST_OFFSET)
57
58 #include <bsp/irq_supp.h>
59
60 #define BSP_INTERRUPT_VECTOR_MIN BSP_LOWEST_OFFSET
61 #define BSP_INTERRUPT_VECTOR_MAX BSP_MAX_OFFSET
62
63 #ifdef __cplusplus
64 extern "C" {
65 #endif
66
67 void BSP_rtems_irq_mng_init(unsigned cpuId);
68
69 #ifdef __cplusplus
70 }
71 #endif
72
73 #endif
74 #endif
