RTEMS  5.1
irq.h
1 /* irq.h
2  *
3  * This include file describe the data structure and the functions implemented
4  * by rtems to write interrupt handlers.
5  *
6  * CopyRight (C) 1999 valette@crf.canon.fr
7  *
8  * This code is heavilly inspired by the public specification of STREAM V2
9  * that can be found at :
10  *
11  * <http://www.chorus.com/Documentation/index.html> by following
12  * the STREAM API Specification Document link.
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  *
18  * Copyright 2004, 2005 Brookhaven National Laboratory and
19  * Shuchen Kate Feng <feng1@bnl.gov>
20  *
21  * - modified shared/irq/irq.h for Mvme5500 (no ISA devices/PIC)
22  * - Discovery GT64260 interrupt controller instead of 8259.
23  * - Added support for software IRQ priority levels.
24  * - modified to optimize the IRQ latency and handling
25  */
26
27 #ifndef LIBBSP_POWERPC_MVME5500_IRQ_IRQ_H
28 #define LIBBSP_POWERPC_MVME5500_IRQ_IRQ_H
29
30 #define BSP_SHARED_HANDLER_SUPPORT 1
31 #include <rtems/irq.h>
32
33 #ifndef ASM
34
35 #include <bsp/irq-default.h>
36
37 #define OneTierIrqPrioTbl 1
38
39 /*
40  * Symbolic IRQ names and related definitions.
41  */
42
43 /* leave the ISA symbols in there, so we can reuse shared/irq.c
44  * Also, we start numbering PCI irqs at 16 because the OPENPIC
45  * driver relies on this when mapping irq number <-> vectors
46  * (OPENPIC_VEC_SOURCE in openpic.h)
47  */
48
49  /* See section 25.2 , Table 734 of GT64260 controller
50  * Main Interrupt Cause Low register
51  */
52 #define BSP_MICL_IRQ_NUMBER (32)
53 #define BSP_MICL_IRQ_LOWEST_OFFSET (0)
54 #define BSP_MICL_IRQ_MAX_OFFSET (BSP_MICL_IRQ_LOWEST_OFFSET + BSP_MICL_IRQ_NUMBER -1)
55  /*
56  * Main Interrupt Cause High register
57  */
58 #define BSP_MICH_IRQ_NUMBER (32)
59 #define BSP_MICH_IRQ_LOWEST_OFFSET (BSP_MICL_IRQ_MAX_OFFSET+1)
60 #define BSP_MICH_IRQ_MAX_OFFSET (BSP_MICH_IRQ_LOWEST_OFFSET + BSP_MICH_IRQ_NUMBER -1)
61  /* External GPP Interrupt assignements
62  */
63 #define BSP_GPP_IRQ_NUMBER (32)
64 #define BSP_GPP_IRQ_LOWEST_OFFSET (BSP_MICH_IRQ_MAX_OFFSET+1)
65 #define BSP_GPP_IRQ_MAX_OFFSET (BSP_GPP_IRQ_LOWEST_OFFSET + BSP_GPP_IRQ_NUMBER - 1)
66
67  /*
68  * PowerPc exceptions handled as interrupt where a rtems managed interrupt
69  * handler might be connected
70  */
71 #define BSP_PROCESSOR_IRQ_NUMBER (1)
72 #define BSP_PROCESSOR_IRQ_LOWEST_OFFSET (BSP_GPP_IRQ_MAX_OFFSET + 1)
73 #define BSP_PROCESSOR_IRQ_MAX_OFFSET (BSP_PROCESSOR_IRQ_LOWEST_OFFSET + BSP_PROCESSOR_IRQ_NUMBER - 1)
74
75  /* allow a couple of vectors for VME and counter/timer irq sources etc.
76  * This is probably not needed any more.
77  */
78 #define BSP_MISC_IRQ_NUMBER (30)
79 #define BSP_MISC_IRQ_LOWEST_OFFSET (BSP_PROCESSOR_IRQ_MAX_OFFSET + 1)
80 #define BSP_MISC_IRQ_MAX_OFFSET (BSP_MISC_IRQ_LOWEST_OFFSET + BSP_MISC_IRQ_NUMBER - 1)
81
82  /*
83  * Summary
84  */
85 #define BSP_IRQ_NUMBER (BSP_MISC_IRQ_MAX_OFFSET + 1)
86 #define BSP_MAIN_IRQ_NUMBER (64)
87 #define BSP_PIC_IRQ_NUMBER (96)
88 #define BSP_LOWEST_OFFSET (BSP_MICL_IRQ_LOWEST_OFFSET)
89 #define BSP_MAX_OFFSET (BSP_MISC_IRQ_MAX_OFFSET)
90
91  /* Main CPU interrupt cause (Low) */
92 #define BSP_MAIN_TIMER0_1_IRQ (BSP_MICL_IRQ_LOWEST_OFFSET+8)
93 #define BSP_MAIN_PCI0_7_0 (BSP_MICL_IRQ_LOWEST_OFFSET+12)
94 #define BSP_MAIN_PCI0_15_8 (BSP_MICL_IRQ_LOWEST_OFFSET+13)
95 #define BSP_MAIN_PCI0_23_16 (BSP_MICL_IRQ_LOWEST_OFFSET+14)
96 #define BSP_MAIN_PCI0_31_24 (BSP_MICL_IRQ_LOWEST_OFFSET+15)
97 #define BSP_MAIN_PCI1_7_0 (BSP_MICL_IRQ_LOWEST_OFFSET+16)
98 #define BSP_MAIN_PCI1_15_8 (BSP_MICL_IRQ_LOWEST_OFFSET+18)
99 #define BSP_MAIN_PCI1_23_16 (BSP_MICL_IRQ_LOWEST_OFFSET+19)
100 #define BSP_MAIN_PCI1_31_24 (BSP_MICL_IRQ_LOWEST_OFFSET+20)
101
102
103  /* Main CPU interrupt cause (High) */
104 #define BSP_MAIN_ETH0_IRQ (BSP_MICH_IRQ_LOWEST_OFFSET)
105 #define BSP_MAIN_ETH1_IRQ (BSP_MICH_IRQ_LOWEST_OFFSET+1)
106 #define BSP_MAIN_ETH2_IRQ (BSP_MICH_IRQ_LOWEST_OFFSET+2)
107 #define BSP_MAIN_GPP7_0_IRQ (BSP_MICH_IRQ_LOWEST_OFFSET+24)
108 #define BSP_MAIN_GPP15_8_IRQ (BSP_MICH_IRQ_LOWEST_OFFSET+25)
109 #define BSP_MAIN_GPP23_16_IRQ (BSP_MICH_IRQ_LOWEST_OFFSET+26)
110 #define BSP_MAIN_GPP31_24_IRQ (BSP_MICH_IRQ_LOWEST_OFFSET+27)
111
112  /* on the MVME5500, these are the GT64260B external GPP0 interrupt */
113 #define BSP_PCI_IRQ_LOWEST_OFFSET (BSP_GPP_IRQ_LOWEST_OFFSET)
114 #define BSP_UART_COM2_IRQ (BSP_GPP_IRQ_LOWEST_OFFSET)
115 #define BSP_UART_COM1_IRQ (BSP_GPP_IRQ_LOWEST_OFFSET)
116 #define BSP_GPP8_IRQ_OFFSET (BSP_GPP_IRQ_LOWEST_OFFSET+8)
117 #define BSP_GPP_PMC1_INTA (BSP_GPP8_IRQ_OFFSET)
118 #define BSP_GPP16_IRQ_OFFSET (BSP_GPP_IRQ_LOWEST_OFFSET+16)
119 #define BSP_GPP24_IRQ_OFFSET (BSP_GPP_IRQ_LOWEST_OFFSET+24)
120 #define BSP_GPP_VME_VLINT0 (BSP_GPP_IRQ_LOWEST_OFFSET+12)
121 #define BSP_GPP_VME_VLINT1 (BSP_GPP_IRQ_LOWEST_OFFSET+13)
122 #define BSP_GPP_VME_VLINT2 (BSP_GPP_IRQ_LOWEST_OFFSET+14)
123 #define BSP_GPP_VME_VLINT3 (BSP_GPP_IRQ_LOWEST_OFFSET+15)
124 #define BSP_GPP_PMC2_INTA (BSP_GPP_IRQ_LOWEST_OFFSET+16)
125 #define BSP_GPP_82544_IRQ (BSP_GPP_IRQ_LOWEST_OFFSET+20)
126 #define BSP_GPP_WDT_NMI_IRQ (BSP_GPP_IRQ_LOWEST_OFFSET+24)
127 #define BSP_GPP_WDT_EXP_IRQ (BSP_GPP_IRQ_LOWEST_OFFSET+25)
128
129  /*
130  * Some Processor execption handled as rtems IRQ symbolic name definition
131  */
132 #define BSP_DECREMENTER (BSP_PROCESSOR_IRQ_LOWEST_OFFSET)
133
134 extern void BSP_rtems_irq_mng_init(unsigned cpuId);
135
136 #include <bsp/irq_supp.h>
137
138 #endif
139 #endif
