RTEMS  5.1
irq.h
1
10 /* irq.h
11  *
12  * This include file describe the data structure and the functions implemented
13  * by RTEMS to write interrupt handlers.
14  *
15  * Copyright (C) 1999 valette@crf.canon.fr
16  *
17  * This code is heavilly inspired by the public specification of STREAM V2
18  * that can be found at :
19  *
20  * <http://www.chorus.com/Documentation/index.html> by following
21  * the STREAM API Specification Document link.
22  *
23  * The license and distribution terms for this file may be
24  * found in the file LICENSE in this distribution or at
25  * http://www.rtems.org/license/LICENSE.
26  *
27  * Adapted for the mvme3100 BSP by T. Straumann, 2007.
28  */
29
30 #ifndef BSP_POWERPC_IRQ_H
31 #define BSP_POWERPC_IRQ_H
32
33 #define BSP_SHARED_HANDLER_SUPPORT 1
34 #include <rtems/irq.h>
35
36 #ifndef ASM
37
38 #include <bsp/irq-default.h>
39
40 #ifdef __cplusplus
41 extern "C" {
42 #endif
43
52 /* Must pad number of external sources to 16 because
53  * of the layout of vector/priority registers in the
54  * 8540's openpic where there is a gap between
55  * registers corresponding to external and core sources.
56  */
57 #define BSP_EXT_IRQ_NUMBER (16)
58 #define BSP_CORE_IRQ_NUMBER (32)
59
60 /* openpic glue code from shared/irq assigns priorities and configures
61  * initial ISRs for BSP_PCI_IRQ_NUMBER entries (plus ISA stuff on legacy
62  * boards). Hence PCI_IRQ_NUMBER must also cover the internal sources
63  * even though they have nothing to do with PCI.
64  */
65 #define BSP_PCI_IRQ_NUMBER (BSP_EXT_IRQ_NUMBER + BSP_CORE_IRQ_NUMBER)
66 #define BSP_PCI_IRQ_LOWEST_OFFSET (0)
67 #define BSP_PCI_IRQ_MAX_OFFSET (BSP_PCI_IRQ_LOWEST_OFFSET + BSP_PCI_IRQ_NUMBER - 1)
68
69 #define BSP_CORE_IRQ_LOWEST_OFFSET (BSP_PCI_IRQ_LOWEST_OFFSET + BSP_EXT_IRQ_NUMBER)
70 #define BSP_CORE_IRQ_MAX_OFFSET (BSP_CORE_IRQ_LOWEST_OFFSET + BSP_CORE_IRQ_NUMBER - 1)
71
72 /*
73  * PowerPC exceptions handled as interrupt where an RTEMS managed interrupt
74  * handler might be connected
75  */
76 #define BSP_PROCESSOR_IRQ_NUMBER (1)
77 #define BSP_PROCESSOR_IRQ_LOWEST_OFFSET (BSP_CORE_IRQ_MAX_OFFSET + 1)
78 #define BSP_PROCESSOR_IRQ_MAX_OFFSET (BSP_PROCESSOR_IRQ_LOWEST_OFFSET + BSP_PROCESSOR_IRQ_NUMBER - 1)
79 /* Misc vectors for OPENPIC irqs (IPI, timers)
80  */
81 #define BSP_MISC_IRQ_NUMBER (8)
82 #define BSP_MISC_IRQ_LOWEST_OFFSET (BSP_PROCESSOR_IRQ_MAX_OFFSET + 1)
83 #define BSP_MISC_IRQ_MAX_OFFSET (BSP_MISC_IRQ_LOWEST_OFFSET + BSP_MISC_IRQ_NUMBER - 1)
84 /*
85  * Summary
86  */
87 #define BSP_IRQ_NUMBER (BSP_MISC_IRQ_MAX_OFFSET + 1)
88 #define BSP_LOWEST_OFFSET (BSP_PCI_IRQ_LOWEST_OFFSET)
89 #define BSP_MAX_OFFSET (BSP_MISC_IRQ_MAX_OFFSET)
90
91 /*
92  * Some PCI IRQ symbolic name definition
93  */
94 #define BSP_PCI_IRQ0 (BSP_PCI_IRQ_LOWEST_OFFSET)
95
96 #define BSP_VME0_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 0)
97 #define BSP_VME1_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 1)
98 #define BSP_VME2_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 2)
99 #define BSP_VME3_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 3)
100
101 #define BSP_ABORT_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 8)
102 #define BSP_TEMP_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 9)
103 #define BSP_PHY_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 10)
104 #define BSP_RTC_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 11)
105
106 /* Weird - they provide 3 different IRQ lines per ethernet controller
107  * but only one shared line for 2 UARTs ???
108  */
109 #define BSP_UART_COM1_IRQ (BSP_CORE_IRQ_LOWEST_OFFSET + 26)
110 #define BSP_UART_COM2_IRQ (BSP_CORE_IRQ_LOWEST_OFFSET + 26)
111 #define BSP_I2C_IRQ (BSP_CORE_IRQ_LOWEST_OFFSET + 27)
112
113 /*
114  * Some internal (CORE) name definitions
115  */
116 /* Ethernet (FEC) */
117 #define BSP_CORE_IRQ_FEC (BSP_CORE_IRQ_LOWEST_OFFSET + 25)
118 /* i2c controller */
119 #define BSP_CORE_IRQ_I2C (BSP_CORE_IRQ_LOWEST_OFFSET + 27)
120
121 /*
122  * Some Processor execption handled as RTEMS IRQ symbolic name definition
123  */
124 #define BSP_DECREMENTER (BSP_PROCESSOR_IRQ_LOWEST_OFFSET)
125
126 /*-------------------------------------------------------------------------+
127 | Function Prototypes.
128 +--------------------------------------------------------------------------*/
129
130 extern void BSP_rtems_irq_mng_init(unsigned cpuId);
131
132 #include <bsp/irq_supp.h>
133
134 #ifdef __cplusplus
135 };
136 #endif
137
138 #endif
139 #endif
