RTEMS  5.1
irq.h
1 /* irq.h
2  *
3  * This include file describe the data structure and the functions implemented
4  * by rtems to write interrupt handlers.
5  *
6  * CopyRight (C) 1999 valette@crf.canon.fr
7  *
8  * This code is heavilly inspired by the public specification of STREAM V2
9  * that can be found at :
10  *
11  * <http://www.chorus.com/Documentation/index.html> by following
12  * the STREAM API Specification Document link.
13  *
14  * Modified for mpc8260 by Andy Dachs <a.dachs@sstl.co.uk>
15  * Surrey Satellite Technology Limited
16  * The interrupt handling on the mpc8260 seems quite different from
17  * the 860 (I don't know the 860 well). Although some interrupts
18  * are routed via the CPM irq and some are direct to the SIU they all
19  * appear logically the same. Therefore I removed the distinction
20  * between SIU and CPM interrupts.
21  *
22  * The license and distribution terms for this file may be
23  * found in the file LICENSE in this distribution or at
24  * http://www.rtems.org/license/LICENSE.
25  */
26
27 #ifndef LIBBSP_POWERPC_IRQ_H
28 #define LIBBSP_POWERPC_IRQ_H
29 #include <rtems/irq.h>
30
31 #ifndef ASM
32
33 #ifdef __cplusplus
34 extern "C" {
35 #endif
36
37 /*
38 extern volatile unsigned int ppc_cached_irq_mask;
39 */
40
41 /*
42  * Symblolic IRQ names and related definitions.
43  */
44
45  /*
46  * CPM IRQ handlers related definitions
47  * CAUTION : BSP_CPM_IRQ_LOWEST_OFFSET should be equal to OPENPIC_VEC_SOURCE
48  */
49 #define BSP_CPM_IRQ_NUMBER (64)
50 #define BSP_CPM_IRQ_LOWEST_OFFSET (0)
51 #define BSP_CPM_IRQ_MAX_OFFSET (BSP_CPM_IRQ_LOWEST_OFFSET + BSP_CPM_IRQ_NUMBER - 1)
52  /*
53  * PowerPc exceptions handled as interrupt where a rtems managed interrupt
54  * handler might be connected
55  */
56 #define BSP_PROCESSOR_IRQ_NUMBER (1)
57 #define BSP_PROCESSOR_IRQ_LOWEST_OFFSET (BSP_CPM_IRQ_MAX_OFFSET + 1)
58 #define BSP_PROCESSOR_IRQ_MAX_OFFSET (BSP_PROCESSOR_IRQ_LOWEST_OFFSET + BSP_PROCESSOR_IRQ_NUMBER - 1)
59  /*
60  * Summary
61  */
62 #define BSP_IRQ_NUMBER (BSP_PROCESSOR_IRQ_MAX_OFFSET + 1)
63 #define BSP_LOWEST_OFFSET (BSP_CPM_IRQ_LOWEST_OFFSET)
64 #define BSP_MAX_OFFSET (BSP_PROCESSOR_IRQ_MAX_OFFSET)
65
66  /*
67  * Some SIU IRQ symbolic name definition. Please note that
68  * INT IRQ are defined but a single one will be used to
69  * redirect all CPM interrupt.
70  *
71  * On the mpc8260 all this seems to be transparent. Although the
72  * CPM, PIT and TMCNT interrupt may well be the only interrupts routed
73  * to the SIU at the hardware level all of them appear as CPM interupts
74  * to software apart from the registers for setting priority.
75  *
76  * The MPC8260 User Manual seems shot through with inconsistencies
77  * about this whole area.
78  */
79
80  /*
81  * Some CPM IRQ symbolic name definition
82  */
83 #define BSP_CPM_IRQ_ERROR (BSP_CPM_IRQ_LOWEST_OFFSET + 0)
84 #define BSP_CPM_IRQ_I2C (BSP_CPM_IRQ_LOWEST_OFFSET + 1)
85 #define BSP_CPM_IRQ_SPI (BSP_CPM_IRQ_LOWEST_OFFSET + 2)
86 #define BSP_CPM_IRQ_RISC_TIMERS (BSP_CPM_IRQ_LOWEST_OFFSET + 3)
87 #define BSP_CPM_IRQ_SMC1 (BSP_CPM_IRQ_LOWEST_OFFSET + 4)
88 #define BSP_CPM_IRQ_SMC2 (BSP_CPM_IRQ_LOWEST_OFFSET + 5)
89 #define BSP_CPM_IRQ_IDMA1 (BSP_CPM_IRQ_LOWEST_OFFSET + 6)
90 #define BSP_CPM_IRQ_IDMA2 (BSP_CPM_IRQ_LOWEST_OFFSET + 7)
91 #define BSP_CPM_IRQ_IDMA3 (BSP_CPM_IRQ_LOWEST_OFFSET + 8)
92 #define BSP_CPM_IRQ_IDMA4 (BSP_CPM_IRQ_LOWEST_OFFSET + 9)
93 #define BSP_CPM_IRQ_SDMA (BSP_CPM_IRQ_LOWEST_OFFSET + 10)
94
95 #define BSP_CPM_IRQ_TIMER_1 (BSP_CPM_IRQ_LOWEST_OFFSET + 12)
96 #define BSP_CPM_IRQ_TIMER_2 (BSP_CPM_IRQ_LOWEST_OFFSET + 13)
97 #define BSP_CPM_IRQ_TIMER_3 (BSP_CPM_IRQ_LOWEST_OFFSET + 14)
98 #define BSP_CPM_IRQ_TIMER_4 (BSP_CPM_IRQ_LOWEST_OFFSET + 15)
99 #define BSP_CPM_IRQ_TMCNT (BSP_CPM_IRQ_LOWEST_OFFSET + 16)
100 #define BSP_CPM_IRQ_PIT (BSP_CPM_IRQ_LOWEST_OFFSET + 17)
101
102 #define BSP_CPM_IRQ_IRQ1 (BSP_CPM_IRQ_LOWEST_OFFSET + 19)
103 #define BSP_CPM_IRQ_IRQ2 (BSP_CPM_IRQ_LOWEST_OFFSET + 20)
104 #define BSP_CPM_IRQ_IRQ3 (BSP_CPM_IRQ_LOWEST_OFFSET + 21)
105 #define BSP_CPM_IRQ_IRQ4 (BSP_CPM_IRQ_LOWEST_OFFSET + 22)
106 #define BSP_CPM_IRQ_IRQ5 (BSP_CPM_IRQ_LOWEST_OFFSET + 23)
107 #define BSP_CPM_IRQ_IRQ6 (BSP_CPM_IRQ_LOWEST_OFFSET + 24)
108 #define BSP_CPM_IRQ_IRQ7 (BSP_CPM_IRQ_LOWEST_OFFSET + 25)
109
110 #define BSP_CPM_IRQ_FCC1 (BSP_CPM_IRQ_LOWEST_OFFSET + 32)
111 #define BSP_CPM_IRQ_FCC2 (BSP_CPM_IRQ_LOWEST_OFFSET + 33)
112 #define BSP_CPM_IRQ_FCC3 (BSP_CPM_IRQ_LOWEST_OFFSET + 34)
113 #define BSP_CPM_IRQ_MCC1 (BSP_CPM_IRQ_LOWEST_OFFSET + 36)
114 #define BSP_CPM_IRQ_MCC2 (BSP_CPM_IRQ_LOWEST_OFFSET + 37)
115
116 #define BSP_CPM_IRQ_SCC1 (BSP_CPM_IRQ_LOWEST_OFFSET + 40)
117 #define BSP_CPM_IRQ_SCC2 (BSP_CPM_IRQ_LOWEST_OFFSET + 41)
118 #define BSP_CPM_IRQ_SCC3 (BSP_CPM_IRQ_LOWEST_OFFSET + 42)
119 #define BSP_CPM_IRQ_SCC4 (BSP_CPM_IRQ_LOWEST_OFFSET + 43)
120
121 #define BSP_CPM_IRQ_PC15 (BSP_CPM_IRQ_LOWEST_OFFSET + 48)
122 #define BSP_CPM_IRQ_PC14 (BSP_CPM_IRQ_LOWEST_OFFSET + 49)
123 #define BSP_CPM_IRQ_PC13 (BSP_CPM_IRQ_LOWEST_OFFSET + 50)
124 #define BSP_CPM_IRQ_PC12 (BSP_CPM_IRQ_LOWEST_OFFSET + 51)
125 #define BSP_CPM_IRQ_PC11 (BSP_CPM_IRQ_LOWEST_OFFSET + 52)
126 #define BSP_CPM_IRQ_PC10 (BSP_CPM_IRQ_LOWEST_OFFSET + 53)
127 #define BSP_CPM_IRQ_PC9 (BSP_CPM_IRQ_LOWEST_OFFSET + 54)
128 #define BSP_CPM_IRQ_PC8 (BSP_CPM_IRQ_LOWEST_OFFSET + 55)
129 #define BSP_CPM_IRQ_PC7 (BSP_CPM_IRQ_LOWEST_OFFSET + 56)
130 #define BSP_CPM_IRQ_PC6 (BSP_CPM_IRQ_LOWEST_OFFSET + 57)
131 #define BSP_CPM_IRQ_PC5 (BSP_CPM_IRQ_LOWEST_OFFSET + 58)
132 #define BSP_CPM_IRQ_PC4 (BSP_CPM_IRQ_LOWEST_OFFSET + 59)
133 #define BSP_CPM_IRQ_PC3 (BSP_CPM_IRQ_LOWEST_OFFSET + 60)
134 #define BSP_CPM_IRQ_PC2 (BSP_CPM_IRQ_LOWEST_OFFSET + 61)
135 #define BSP_CPM_IRQ_PC1 (BSP_CPM_IRQ_LOWEST_OFFSET + 62)
136 #define BSP_CPM_IRQ_PC0 (BSP_CPM_IRQ_LOWEST_OFFSET + 63)
137
138  /*
139  * Some Processor exception handled as rtems IRQ symbolic name definition
140  */
141 #define BSP_DECREMENTER (BSP_PROCESSOR_IRQ_LOWEST_OFFSET)
142 #define BSP_PERIODIC_TIMER (BSP_DECREMENTER)
143
144 #define BSP_INTERRUPT_VECTOR_MIN BSP_LOWEST_OFFSET
145
146 #define BSP_INTERRUPT_VECTOR_MAX BSP_MAX_OFFSET
147
148 #define CPM_INTERRUPT
149
150 /*-------------------------------------------------------------------------+
151 | Function Prototypes.
152 +--------------------------------------------------------------------------*/
153 /*
154  * ------------------------ PPC CPM Mngt Routines -------
155  */
156
157 /*
158  * function to disable a particular irq. After calling
159  * this function, even if the device asserts the interrupt line it will
160  * not be propagated further to the processor
161  */
162 int BSP_irq_disable_at_cpm (const rtems_irq_number irqLine);
163 /*
164  * function to enable a particular irq. After calling
165  * this function, if the device asserts the interrupt line it will
166  * be propagated further to the processor
167  */
168 int BSP_irq_enable_at_cpm (const rtems_irq_number irqLine);
169 /*
170  * function to acknoledge a particular irq. After calling
171  * this function, if a device asserts an enabled interrupt line it will
172  * be propagated further to the processor. Mainly usefull for people
173  * writting raw handlers as this is automagically done for rtems managed
174  * handlers.
175  */
176 int BSP_irq_ack_at_cpm (const rtems_irq_number irqLine);
177 /*
178  * function to check if a particular irq is enabled. After calling
179  */
180 int BSP_irq_enabled_at_cpm (const rtems_irq_number irqLine);
181
182 extern void BSP_rtems_irq_mng_init(unsigned cpuId);
183
184 #ifdef __cplusplus
185 }
186 #endif
187
188 /* Now that we have defined some basics, include the generic support */
189 #include <bsp/irq-generic.h>
190
191 #endif
192
193 #endif
Generic BSP interrupt support API.
