23 #ifndef LIBBSP_POWERPC_MPC55XXEVB_BSP_H    24 #define LIBBSP_POWERPC_MPC55XXEVB_BSP_H    38 #define BSP_FEATURE_IRQ_EXTENSION    40 #define MPC55XX_PERIPHERAL_CLOCK \    41   (MPC55XX_SYSTEM_CLOCK / MPC55XX_SYSTEM_CLOCK_DIVIDER)    50 #include <bsp/linker-symbols.h>    64 #define BSP_Convert_decrementer( _value ) \    65   (((unsigned long long) (_value)) / ((unsigned long long)bsp_clicks_per_usec))    71 struct rtems_bsdnet_ifconfig;
    73 int smsc9218i_attach_detach(
    74   struct rtems_bsdnet_ifconfig *
config,
    78 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH smsc9218i_attach_detach    80 #define RTEMS_BSP_NETWORK_DRIVER_NAME "eth0"    88 #define BSP_IDLE_TASK_BODY bsp_idle_thread    90 LINKER_SYMBOL(bsp_section_dsram_begin)
    91 LINKER_SYMBOL(bsp_section_dsram_end)
    92 LINKER_SYMBOL(bsp_section_dsram_size)
    93 LINKER_SYMBOL(bsp_section_dsram_load_begin)
    94 LINKER_SYMBOL(bsp_section_dsram_load_end)
    96 #define BSP_DSRAM_SECTION __attribute__((section(".bsp_dsram")))    98 LINKER_SYMBOL(bsp_section_sysram_begin)
    99 LINKER_SYMBOL(bsp_section_sysram_end)
   100 LINKER_SYMBOL(bsp_section_sysram_size)
   101 LINKER_SYMBOL(bsp_section_sysram_load_begin)
   102 LINKER_SYMBOL(bsp_section_sysram_load_end)
   104 #define BSP_SYSRAM_SECTION __attribute__((section(".bsp_sysram"))) Definition: deflate.c:115
int mount(const char *source, const char *target, const char *filesystemtype, rtems_filesystem_options_t options, const void *data)
Mounts a file system instance at the specified target path.
Definition: mount.c:178
uint32_t bsp_clicks_per_usec
Time base clicks per micro second.
Definition: bspstart.c:99
Header file for tic-tac code.
unsigned int bsp_clock_speed
System clock frequency.
Definition: bspstart.c:48
DEFAULT_INITIAL_EXTENSION Support.
General purpose assembler macros, linker command file support and some inline functions for direct re...
rtems_status_code
Classic API Status.
Definition: status.h:43
void * bsp_idle_thread(uintptr_t ignored)
Optimized idle task.
Definition: bspidle.c:26
void bsp_restart(const void *addr)
Restarts the bsp with "addr" address.
Definition: restart.c:25
