43 #ifndef _RTEMS_POWERPC_POWERPC_H    44 #define _RTEMS_POWERPC_POWERPC_H    95 #define PPC_LOW_POWER_MODE_NONE      0    96 #define PPC_LOW_POWER_MODE_STANDARD  1   101 #define PPC_NO_CACHE_ALIGNMENT 4   107 #define PPC_NO_CACHE_ALIGNMENT_POWER 2   122 #define PPC_CACHE_ALIGNMENT 32   124 #define PPC_HAS_RFCI        1   125 #define PPC_USE_MULTIPLE    1   126 #define PPC_I_CACHE     16384   127 #define PPC_D_CACHE     16384          128 #define PPC_HAS_EXCEPTION_PREFIX 0   129 #define PPC_HAS_EVPR             1   131 #elif defined(ppc403)   140 #define PPC_CACHE_ALIGNMENT 16   142 #define PPC_HAS_RFCI        1   143 #define PPC_USE_MULTIPLE    1   144 #define PPC_I_CACHE     2048   145 #define PPC_D_CACHE     1024   147 #define PPC_HAS_EXCEPTION_PREFIX 0   148 #define PPC_HAS_EVPR             1   150 #elif defined (ppc440)   152 #define PPC_CACHE_ALIGNMENT         32   154 #define PPC_HAS_RFCI                 1   155 #define PPC_USE_MULTIPLE             1   156 #define PPC_I_CACHE              32768   157 #define PPC_D_CACHE              32768   158 #define PPC_HAS_EXCEPTION_PREFIX     0   159 #define PPC_HAS_EVPR                 1   161 #elif defined(mpc555)   164 #define PPC_CACHE_ALIGNMENT PPC_NO_CACHE_ALIGNMENT   167 #define PPC_LOW_POWER_MODE  PPC_LOW_POWER_MODE_STANDARD   170 #define PPC_I_CACHE         0   171 #define PPC_D_CACHE         0   173 #elif defined(mpc505) || defined(mpc509)   180 #define CPU_MODEL_NAME  "PowerPC 505/509"   182 #define PPC_CACHE_ALIGNMENT     PPC_NO_CACHE_ALIGNMENT   183 #define PPC_I_CACHE             4096   184 #define PPC_D_CACHE             0   187 #elif defined(ppc601)   193 #define PPC_USE_MULTIPLE    1   194 #define PPC_I_CACHE     0   195 #define PPC_D_CACHE     32768   197 #elif defined(ppc603)   202 #define PPC_I_CACHE     8192   203 #define PPC_D_CACHE     8192   205 #elif defined(ppc603e)   213 #define PPC_I_CACHE     16384   214 #define PPC_D_CACHE     16384   216 #define PPC_LOW_POWER_MODE PPC_LOW_POWER_MODE_STANDARD   218 #elif defined(mpc604)   223 #define PPC_I_CACHE     16384   224 #define PPC_D_CACHE     16384   226 #elif defined(mpc860)   231 #define PPC_I_CACHE             4096   232 #define PPC_D_CACHE             4096   233 #define PPC_CACHE_ALIGNMENT 16   234 #define PPC_INTERRUPT_MAX       71   235 #define PPC_USE_MULTIPLE    1   237 #define PPC_MSR_0       0x00009000   238 #define PPC_MSR_1       0x00001000   239 #define PPC_MSR_2       0x00001000   240 #define PPC_MSR_3       0x00000000   242 #elif defined(mpc821)   246 #define PPC_I_CACHE             4096   247 #define PPC_D_CACHE             4096   248 #define PPC_CACHE_ALIGNMENT 16   249 #define PPC_INTERRUPT_MAX       71   251 #define PPC_MSR_0       0x00009000   252 #define PPC_MSR_1       0x00001000   253 #define PPC_MSR_2       0x00001000   254 #define PPC_MSR_3       0x00000000   256 #elif defined(mpc750)   258 #define PPC_I_CACHE     16384   259 #define PPC_D_CACHE     16384   261 #elif defined(mpc7400)   263 #define PPC_I_CACHE     32768   264 #define PPC_D_CACHE     32768   266 #elif defined(mpc7455)   271 #define PPC_CACHE_ALIGNMENT     32   272 #define PPC_I_CACHE     32768   273 #define PPC_D_CACHE     32768   275 #elif defined(mpc8260)   279 #define PPC_I_CACHE             16384   280 #define PPC_D_CACHE             16384   281 #define PPC_CACHE_ALIGNMENT 32   282 #define PPC_INTERRUPT_MAX       125   283 #define PPC_USE_MULTIPLE    1   285 #elif defined(__ppc_generic)   289 #error "Unsupported CPU Model"   298 #ifndef PPC_INTERRUPT_MAX   299 #define PPC_INTERRUPT_MAX   16   302 #ifndef PPC_CACHE_ALIGNMENT   303 #define PPC_CACHE_ALIGNMENT PPC_DEFAULT_CACHE_LINE_SIZE   306 #if (PPC_CACHE_ALIGNMENT == 16)   307 #define PPC_CACHE_ALIGN_POWER 4   308 #elif (PPC_CACHE_ALIGNMENT == 32)   309 #define PPC_CACHE_ALIGN_POWER 5   310 #elif (PPC_CACHE_ALIGNMENT == 64)   311 #define PPC_CACHE_ALIGN_POWER 6   312 #elif (PPC_CACHE_ALIGNMENT == PPC_NO_CACHE_ALIGNMENT)   313 #define PPC_CACHE_ALIGN_POWER PPC_NO_CACHE_ALIGNMENT_POWER   315 #error "Undefined power of 2 for PPC_CACHE_ALIGNMENT"   323 #ifndef PPC_HAS_EXCEPTION_PREFIX   324 #define PPC_HAS_EXCEPTION_PREFIX 1   341 #define PPC_HAS_EVPR 0   348 #ifndef PPC_LOW_POWER_MODE   349 #define PPC_LOW_POWER_MODE PPC_LOW_POWER_MODE_NONE   358 #define PPC_HAS_RFCI 0   366 #ifndef PPC_USE_MULTIPLE   367 #define PPC_USE_MULTIPLE 0   381 #define PPC_IRQ_SYSTEM_RESET     0    382 #define PPC_IRQ_MCHECK       1    383 #define PPC_IRQ_PROTECT      2    384 #define PPC_IRQ_ISI              3    385 #define PPC_IRQ_EXTERNAL     4    386 #define PPC_IRQ_ALIGNMENT        5    387 #define PPC_IRQ_PROGRAM      6    388 #define PPC_IRQ_NOFP         7    389 #define PPC_IRQ_DECREMENTER  8    390 #define PPC_IRQ_RESERVED_A       9    391 #define PPC_IRQ_RESERVED_B      10    392 #define PPC_IRQ_SCALL       11    393 #define PPC_IRQ_TRACE           12    394 #define PPC_IRQ_FP_ASST         13    395 #define PPC_STD_IRQ_LAST        PPC_IRQ_FP_ASST   397 #define PPC_IRQ_FIRST           PPC_IRQ_SYSTEM_RESET   399 #if defined(ppc403) || defined(ppc405) || defined(ppc440)   401 #define PPC_IRQ_CRIT     PPC_IRQ_SYSTEM_RESET    402 #define PPC_IRQ_PIT      (PPC_STD_IRQ_LAST+1)    403 #define PPC_IRQ_FIT  (PPC_STD_IRQ_LAST+2)    404 #define PPC_IRQ_WATCHDOG (PPC_STD_IRQ_LAST+3)    405 #define PPC_IRQ_DEBUG    (PPC_STD_IRQ_LAST+4)    406 #define PPC_IRQ_LAST     PPC_IRQ_DEBUG   408 #elif defined(mpc505) || defined(mpc509)   409 #define PPC_IRQ_SOFTEMU   (PPC_STD_IRQ_LAST+1)       410 #define PPC_IRQ_DATA_BP   (PPC_STD_IRQ_LAST+ 2)   411 #define PPC_IRQ_INST_BP   (PPC_STD_IRQ_LAST+ 3)   412 #define PPC_IRQ_MEXT_BP   (PPC_STD_IRQ_LAST+ 4)   413 #define PPC_IRQ_NMEXT_BP  (PPC_STD_IRQ_LAST+ 5)   415 #elif defined(mpc555)   416 #define PPC_IRQ_SOFTEMU   (PPC_STD_IRQ_LAST+1)     417 #define PPC_IRQ_INST_PE   (PPC_STD_IRQ_LAST+2)     418 #define PPC_IRQ_DATA_PE   (PPC_STD_IRQ_LAST+3)     419 #define PPC_IRQ_DATA_BP   (PPC_STD_IRQ_LAST+4)     420 #define PPC_IRQ_INST_BP   (PPC_STD_IRQ_LAST+5)     421 #define PPC_IRQ_MEXT_BP   (PPC_STD_IRQ_LAST+6)     422 #define PPC_IRQ_NMEXT_BP  (PPC_STD_IRQ_LAST+7)     423 #define PPC_IRQ_LAST      PPC_IRQ_NMEXT_BP   425 #elif defined(ppc601)   427 #define PPC_IRQ_TRACE    (PPC_STD_IRQ_LAST+1)    428 #define PPC_IRQ_LAST     PPC_IRQ_TRACE   430 #elif defined(ppc602)   431 #define PPC_IRQ_LAST     (PPC_STD_IRQ_LAST)   433 #elif defined(ppc603) || defined(ppc603e)   434 #define PPC_IRQ_TRANS_MISS (PPC_STD_IRQ_LAST+1)    435 #define PPC_IRQ_DATA_LOAD  (PPC_STD_IRQ_LAST+2)    436 #define PPC_IRQ_DATA_STORE (PPC_STD_IRQ_LAST+3)    437 #define PPC_IRQ_ADDR_BRK   (PPC_STD_IRQ_LAST+4)    438 #define PPC_IRQ_SYS_MGT    (PPC_STD_IRQ_LAST+5)    439 #define PPC_IRQ_LAST       PPC_IRQ_SYS_MGT   441 #elif defined(mpc604)   442 #define PPC_IRQ_ADDR_BRK (PPC_STD_IRQ_LAST+1)    443 #define PPC_IRQ_SYS_MGT  (PPC_STD_IRQ_LAST+2)    444 #define PPC_IRQ_LAST     PPC_IRQ_SYS_MGT   446 #elif defined(mpc860) || defined(mpc821)   447 #define PPC_IRQ_EMULATE         (PPC_STD_IRQ_LAST+1)    448 #define PPC_IRQ_INST_MISS       (PPC_STD_IRQ_LAST+2)    449 #define PPC_IRQ_DATA_MISS       (PPC_STD_IRQ_LAST+3)    450 #define PPC_IRQ_INST_ERR        (PPC_STD_IRQ_LAST+4)    451 #define PPC_IRQ_DATA_ERR        (PPC_STD_IRQ_LAST+5)    452 #define PPC_IRQ_DATA_BPNT       (PPC_STD_IRQ_LAST+6)    453 #define PPC_IRQ_INST_BPNT       (PPC_STD_IRQ_LAST+7)    454 #define PPC_IRQ_IO_BPNT         (PPC_STD_IRQ_LAST+8)    455 #define PPC_IRQ_DEV_PORT        (PPC_STD_IRQ_LAST+9)    456 #define PPC_IRQ_IRQ0            (PPC_STD_IRQ_LAST + 10)   457 #define PPC_IRQ_LVL0            (PPC_STD_IRQ_LAST + 11)   458 #define PPC_IRQ_IRQ1            (PPC_STD_IRQ_LAST + 12)   459 #define PPC_IRQ_LVL1            (PPC_STD_IRQ_LAST + 13)   460 #define PPC_IRQ_IRQ2        (PPC_STD_IRQ_LAST + 14)   461 #define PPC_IRQ_LVL2        (PPC_STD_IRQ_LAST + 15)   462 #define PPC_IRQ_IRQ3        (PPC_STD_IRQ_LAST + 16)   463 #define PPC_IRQ_LVL3        (PPC_STD_IRQ_LAST + 17)   464 #define PPC_IRQ_IRQ4        (PPC_STD_IRQ_LAST + 18)   465 #define PPC_IRQ_LVL4        (PPC_STD_IRQ_LAST + 19)   466 #define PPC_IRQ_IRQ5        (PPC_STD_IRQ_LAST + 20)   467 #define PPC_IRQ_LVL5        (PPC_STD_IRQ_LAST + 21)   468 #define PPC_IRQ_IRQ6        (PPC_STD_IRQ_LAST + 22)   469 #define PPC_IRQ_LVL6        (PPC_STD_IRQ_LAST + 23)   470 #define PPC_IRQ_IRQ7        (PPC_STD_IRQ_LAST + 24)   471 #define PPC_IRQ_LVL7        (PPC_STD_IRQ_LAST + 25)   472 #define PPC_IRQ_CPM_ERROR   (PPC_STD_IRQ_LAST + 26)   473 #define PPC_IRQ_CPM_PC4     (PPC_STD_IRQ_LAST + 27)   474 #define PPC_IRQ_CPM_PC5     (PPC_STD_IRQ_LAST + 28)   475 #define PPC_IRQ_CPM_SMC2    (PPC_STD_IRQ_LAST + 29)   476 #define PPC_IRQ_CPM_SMC1    (PPC_STD_IRQ_LAST + 30)   477 #define PPC_IRQ_CPM_SPI     (PPC_STD_IRQ_LAST + 31)   478 #define PPC_IRQ_CPM_PC6     (PPC_STD_IRQ_LAST + 32)   479 #define PPC_IRQ_CPM_TIMER4  (PPC_STD_IRQ_LAST + 33)   480 #define PPC_IRQ_CPM_RESERVED_8  (PPC_STD_IRQ_LAST + 34)   481 #define PPC_IRQ_CPM_PC7     (PPC_STD_IRQ_LAST + 35)   482 #define PPC_IRQ_CPM_PC8     (PPC_STD_IRQ_LAST + 36)   483 #define PPC_IRQ_CPM_PC9     (PPC_STD_IRQ_LAST + 37)   484 #define PPC_IRQ_CPM_TIMER3  (PPC_STD_IRQ_LAST + 38)   485 #define PPC_IRQ_CPM_RESERVED_D  (PPC_STD_IRQ_LAST + 39)   486 #define PPC_IRQ_CPM_PC10    (PPC_STD_IRQ_LAST + 40)   487 #define PPC_IRQ_CPM_PC11    (PPC_STD_IRQ_LAST + 41)   488 #define PPC_IRQ_CPM_I2C     (PPC_STD_IRQ_LAST + 42)   489 #define PPC_IRQ_CPM_RISC_TIMER  (PPC_STD_IRQ_LAST + 43)   490 #define PPC_IRQ_CPM_TIMER2  (PPC_STD_IRQ_LAST + 44)   491 #define PPC_IRQ_CPM_RESERVED_13 (PPC_STD_IRQ_LAST + 45)   492 #define PPC_IRQ_CPM_IDMA2   (PPC_STD_IRQ_LAST + 46)   493 #define PPC_IRQ_CPM_IDMA1   (PPC_STD_IRQ_LAST + 47)   494 #define PPC_IRQ_CPM_SDMA_ERROR  (PPC_STD_IRQ_LAST + 48)   495 #define PPC_IRQ_CPM_PC12    (PPC_STD_IRQ_LAST + 49)   496 #define PPC_IRQ_CPM_PC13    (PPC_STD_IRQ_LAST + 50)   497 #define PPC_IRQ_CPM_TIMER1  (PPC_STD_IRQ_LAST + 51)   498 #define PPC_IRQ_CPM_PC14    (PPC_STD_IRQ_LAST + 52)   499 #define PPC_IRQ_CPM_SCC4    (PPC_STD_IRQ_LAST + 53)   500 #define PPC_IRQ_CPM_SCC3    (PPC_STD_IRQ_LAST + 54)   501 #define PPC_IRQ_CPM_SCC2    (PPC_STD_IRQ_LAST + 55)   502 #define PPC_IRQ_CPM_SCC1    (PPC_STD_IRQ_LAST + 56)   503 #define PPC_IRQ_CPM_PC15    (PPC_STD_IRQ_LAST + 57)   505 #define PPC_IRQ_LAST             PPC_IRQ_CPM_PC15   507 #elif defined(mpc8260)   509 #define PPC_IRQ_INST_MISS       (PPC_STD_IRQ_LAST+1)    510 #define PPC_IRQ_DATA_MISS       (PPC_STD_IRQ_LAST+2)    511 #define PPC_IRQ_DATA_L_MISS     (PPC_STD_IRQ_LAST+3)    512 #define PPC_IRQ_DATA_S_MISS     (PPC_STD_IRQ_LAST+4)    513 #define PPC_IRQ_INST_BPNT       (PPC_STD_IRQ_LAST+5)    514 #define PPC_IRQ_SYS_MGT         (PPC_STD_IRQ_LAST+6)    516 #define PPC_IRQ_CPM_NONE    (PPC_STD_IRQ_LAST + 50)   517 #define PPC_IRQ_CPM_I2C     (PPC_STD_IRQ_LAST + 51)   518 #define PPC_IRQ_CPM_SPI     (PPC_STD_IRQ_LAST + 52)   519 #define PPC_IRQ_CPM_RISC_TIMER  (PPC_STD_IRQ_LAST + 53)   520 #define PPC_IRQ_CPM_SMC1    (PPC_STD_IRQ_LAST + 54)   521 #define PPC_IRQ_CPM_SMC2    (PPC_STD_IRQ_LAST + 55)   522 #define PPC_IRQ_CPM_IDMA1   (PPC_STD_IRQ_LAST + 56)   523 #define PPC_IRQ_CPM_IDMA2   (PPC_STD_IRQ_LAST + 57)   524 #define PPC_IRQ_CPM_IDMA3   (PPC_STD_IRQ_LAST + 58)   525 #define PPC_IRQ_CPM_IDMA4   (PPC_STD_IRQ_LAST + 59)   526 #define PPC_IRQ_CPM_SDMA    (PPC_STD_IRQ_LAST + 60)   527 #define PPC_IRQ_CPM_RES_A   (PPC_STD_IRQ_LAST + 61)   528 #define PPC_IRQ_CPM_TIMER1  (PPC_STD_IRQ_LAST + 62)   529 #define PPC_IRQ_CPM_TIMER2  (PPC_STD_IRQ_LAST + 63)   530 #define PPC_IRQ_CPM_TIMER3  (PPC_STD_IRQ_LAST + 64)   531 #define PPC_IRQ_CPM_TIMER4  (PPC_STD_IRQ_LAST + 65)   532 #define PPC_IRQ_CPM_TMCNT   (PPC_STD_IRQ_LAST + 66)   533 #define PPC_IRQ_CPM_PIT     (PPC_STD_IRQ_LAST + 67)   534 #define PPC_IRQ_CPM_RES_B   (PPC_STD_IRQ_LAST + 68)   535 #define PPC_IRQ_CPM_IRQ1    (PPC_STD_IRQ_LAST + 69)   536 #define PPC_IRQ_CPM_IRQ2    (PPC_STD_IRQ_LAST + 70)   537 #define PPC_IRQ_CPM_IRQ3    (PPC_STD_IRQ_LAST + 71)   538 #define PPC_IRQ_CPM_IRQ4    (PPC_STD_IRQ_LAST + 72)   539 #define PPC_IRQ_CPM_IRQ5    (PPC_STD_IRQ_LAST + 73)   540 #define PPC_IRQ_CPM_IRQ6    (PPC_STD_IRQ_LAST + 74)   541 #define PPC_IRQ_CPM_IRQ7    (PPC_STD_IRQ_LAST + 75)   542 #define PPC_IRQ_CPM_RES_C   (PPC_STD_IRQ_LAST + 76)   543 #define PPC_IRQ_CPM_RES_D   (PPC_STD_IRQ_LAST + 77)   544 #define PPC_IRQ_CPM_RES_E   (PPC_STD_IRQ_LAST + 78)   545 #define PPC_IRQ_CPM_RES_F   (PPC_STD_IRQ_LAST + 79)   546 #define PPC_IRQ_CPM_RES_G   (PPC_STD_IRQ_LAST + 80)   547 #define PPC_IRQ_CPM_RES_H   (PPC_STD_IRQ_LAST + 81)   548 #define PPC_IRQ_CPM_FCC1    (PPC_STD_IRQ_LAST + 82)   549 #define PPC_IRQ_CPM_FCC2    (PPC_STD_IRQ_LAST + 83)   550 #define PPC_IRQ_CPM_FCC3    (PPC_STD_IRQ_LAST + 84)   551 #define PPC_IRQ_CPM_RES_I   (PPC_STD_IRQ_LAST + 85)   552 #define PPC_IRQ_CPM_MCC1    (PPC_STD_IRQ_LAST + 86)   553 #define PPC_IRQ_CPM_MCC2    (PPC_STD_IRQ_LAST + 87)   554 #define PPC_IRQ_CPM_RES_J   (PPC_STD_IRQ_LAST + 88)   555 #define PPC_IRQ_CPM_RES_K   (PPC_STD_IRQ_LAST + 89)   556 #define PPC_IRQ_CPM_SCC1    (PPC_STD_IRQ_LAST + 90)   557 #define PPC_IRQ_CPM_SCC2    (PPC_STD_IRQ_LAST + 91)   558 #define PPC_IRQ_CPM_SCC3    (PPC_STD_IRQ_LAST + 92)   559 #define PPC_IRQ_CPM_SCC4    (PPC_STD_IRQ_LAST + 93)   560 #define PPC_IRQ_CPM_RES_L   (PPC_STD_IRQ_LAST + 94)   561 #define PPC_IRQ_CPM_RES_M   (PPC_STD_IRQ_LAST + 95)   562 #define PPC_IRQ_CPM_RES_N   (PPC_STD_IRQ_LAST + 96)   563 #define PPC_IRQ_CPM_RES_O   (PPC_STD_IRQ_LAST + 97)   564 #define PPC_IRQ_CPM_PC15    (PPC_STD_IRQ_LAST + 98)   565 #define PPC_IRQ_CPM_PC14    (PPC_STD_IRQ_LAST + 99)   566 #define PPC_IRQ_CPM_PC13    (PPC_STD_IRQ_LAST + 100)   567 #define PPC_IRQ_CPM_PC12    (PPC_STD_IRQ_LAST + 101)   568 #define PPC_IRQ_CPM_PC11    (PPC_STD_IRQ_LAST + 102)   569 #define PPC_IRQ_CPM_PC10    (PPC_STD_IRQ_LAST + 103)   570 #define PPC_IRQ_CPM_PC9     (PPC_STD_IRQ_LAST + 104)   571 #define PPC_IRQ_CPM_PC8     (PPC_STD_IRQ_LAST + 105)   572 #define PPC_IRQ_CPM_PC7     (PPC_STD_IRQ_LAST + 106)   573 #define PPC_IRQ_CPM_PC6     (PPC_STD_IRQ_LAST + 107)   574 #define PPC_IRQ_CPM_PC5     (PPC_STD_IRQ_LAST + 108)   575 #define PPC_IRQ_CPM_PC4     (PPC_STD_IRQ_LAST + 109)   576 #define PPC_IRQ_CPM_PC3     (PPC_STD_IRQ_LAST + 110)   577 #define PPC_IRQ_CPM_PC2     (PPC_STD_IRQ_LAST + 111)   578 #define PPC_IRQ_CPM_PC1     (PPC_STD_IRQ_LAST + 112)   579 #define PPC_IRQ_CPM_PC0     (PPC_STD_IRQ_LAST + 113)   581 #define PPC_IRQ_LAST             PPC_IRQ_CPM_PC0   591 #if PPC_INTERRUPT_MAX <= PPC_IRQ_LAST   592 #undef PPC_INTERRUPT_MAX   593 #define PPC_INTERRUPT_MAX ((PPC_IRQ_LAST) + 1)   601 #define PPC_MSR_RI       0x000000002    604 #define PPC_MSR_DR       0x000000010    605 #define PPC_MSR_IR       0x000000020    611 #if (PPC_HAS_EXCEPTION_PREFIX)   612 #define PPC_MSR_EP       0x000000040    614 #define PPC_MSR_EP       0x000000000    618 #define PPC_MSR_FP       0x000002000    620 #define PPC_MSR_FP       0x000000000    623 #if (PPC_LOW_POWER_MODE == PPC_LOW_POWER_MODE_NONE)   624 #define PPC_MSR_POW      0x000000000    626 #define PPC_MSR_POW      0x000040000    629 #define PPC_MSR_ME       0x000001000    630 #define PPC_MSR_EE       0x000008000    633 #define PPC_MSR_CE       0x000020000    635 #define PPC_MSR_CE       0x000000000    638 #define PPC_MSR_DISABLE_MASK (PPC_MSR_ME|PPC_MSR_EE|PPC_MSR_CE)   640 #if defined(__powerpc64__)   641 #define PPC_MINIMUM_STACK_FRAME_SIZE 32   643 #define PPC_MINIMUM_STACK_FRAME_SIZE PPC_STACK_ALIGNMENT IBM/Motorola PowerPC Definitions.
